    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
    • EdsonE
      Edson
      thom,
      I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
      http://www.mahfuz.arq.br
        hmm... no tooltips...? how odd...
        and you get it on other plugins`?
        I don't see why there should be a difference for OSX on this... πŸ˜•
        • EdsonE
          Edson
          I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
          • wind-borneW
            wind-borne
            @edson said:
            thom,
            I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical.
            "To read between the lines was easier than to follow the text."OSX 10.11.6
            %(#BF80BF)[SU 8 pro
            • EdsonE
              Edson
              not so in mine. no feedback either way.
              • jeff hammondJ
                position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work.
                  eh? Is this a know OSX issue?
                  what an bizzare one... πŸ˜• πŸ˜’
                  • EdsonE
                    Edson
                    bizarre indeed! the tooltips are working now! and what a useful plugin this is! πŸ‘ thanks for it, thom.
                    • jeff hammondJ
                      it's hard to say since sketchup is the only app i use that allows you to drag a toolbar to the top of the screen and it will switch to horizontal orientation.
                      it's very weird toolbar behavior in OSX world so i doubt it's a known issue since no apps do it.
                      i just stumbled upon it one day when i tried 1001bit toolbar across the top of my screen.
                      (bonzai has a few horizontal toolbars but their tooltips (vert&horizontal) aren't standard so they've done something to modify the icons/tooltips)
                      • N
                        nicasiojoel
                        Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
                          2.0.4 - 11.07.2011
                          • Close All Edge Gaps: Heals closed edges.
                          • Close All Edge Gaps: Undoable.
                          • Close All Edge Gaps: Inputbox store values correctly.
                            πŸ‘
                            • EarthMoverE
                              EarthMover
                              Nice update. Thanks Thomthom!! πŸ‘
                              Content Creator at Skapeup
                              • mitcorbM
                                mitcorb
                                Hi, ThomThom:
                                Thank you again for this excellent tool. And thank you for the 2.0.4 update. Will you be inserting info on the update in the first post?
                                  hm.. was just a minor update, really needed?
                                    MartinK
                                    Thanks for the plugin. I'm getting ready to try the simplify curves routine on a large number of contours. As always, these plugins you and others generously make available are great time savers, and I appreciate your efforts. Thanks again. πŸ‘
                                    • xiombargX
                                      xiombarg
                                      Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
                                        rock1
                                        on dividing a face with lines is there a way that the divisions go at a fixed distance. for. e.g. we copy one line at 1m and repeat copy it, we press 6x to make 6 copies for it. the same thing i want to do with this plugin, hw is this possible ❓
                                        Signature removed by SCF Admin
                                          By using the VCB - similar to how you use the native Move tool.
                                          • C
                                            chango70
                                            Very useful, thank you!
                                            • 11
                                            • 6 / 11
