    [Plugin] Edge Tools
    211 Posts 74 Posters 323.4k Views 74 Watching
      rock1
      wow!!! ๐Ÿ˜ฎ ๐Ÿ˜ฒ Truly out of the world. The most useful one I found was that this plugin automatically detects edges and heals them ๐Ÿ˜ . Thanks a lot thomthom!!
      Signature removed by SCF Admin
        Thom,
        when using 'split faces into multiple' then inputting an array only # works (not #). Not a major thing but thought you'd like to know.
        It's the same for #/
          Thom,
          hmm... never knew that was a input format. That shouldn't be too hard to add.
            Strange thing is I never knew the other method of input until I used this tool.
            Anyway it's no biggie as I'm sure you're up to your eyes as it is.
              I've had an update lingering for this anyway (small compatibility fix). So I need to get it out anyway.
              • K
                kizner
                THANK A LOT - I WAS LOOKING FOR YOUR PLUGINS- THIS IS MUST HAVE IN ALL SKP.
                EVERY BODY SHOULD TRY
                  # 2.0.3 - 10.05.2011
                  #		 * VCB input now accepts all array format variants.
                  #		 * Fixed namespace compatibility with TT_Lib 2.5.4
                  Requires TT_Lib 2.5.4
                    ๐Ÿ‘
                    Thanks Thom
                      That one was for you Rich! ๐Ÿ˜‰
                        You've moved up in my favourite person list. Your now 82nd ๐Ÿ‘
                        • EdsonE
                          Edson
                          thom,
                          I have run into a small problem: when I hover over the icons on the toolbar I get no feedback as to what each icon refers to. to be more precise, the name of the tools do not appear. I am on mac. do you have a fix for that? or, is there any place where I could find what each icon in the toolbar means?
                          edson mahfuz, architect| porto alegre โ€ข brasil
                          http://www.mahfuz.arq.br
                            hmm... no tooltips...? how odd...
                            and you get it on other plugins`?
                            I don't see why there should be a difference for OSX on this... ๐Ÿ˜•
                            • EdsonE
                              Edson
                              I do not get it with any other plugin, including your own. all the others work fine. edge tools is the only one in which the problem appears.
                              • wind-borneW
                                wind-borne
                                @edson said:
                                thom,
                                I noticed on my Mac if Edge tools toolbar is horizontal there was no feedback yet works fine vertical.
                                "To read between the lines was easier than to follow the text."OSX 10.11.6
                                %(#BF80BF)[SU 8 pro
                                • EdsonE
                                  Edson
                                  not so in mine. no feedback either way.
                                  • jeff hammondJ
                                    position the toolbar vertically then quit sketchup.. relaunch and the tooltips should work.
                                      eh? Is this a know OSX issue?
                                      what an bizzare one... ๐Ÿ˜• ๐Ÿ˜’
                                      • EdsonE
                                        Edson
                                        bizarre indeed! the tooltips are working now! and what a useful plugin this is! ๐Ÿ‘ thanks for it, thom.
                                        • jeff hammondJ
                                          it's hard to say since sketchup is the only app i use that allows you to drag a toolbar to the top of the screen and it will switch to horizontal orientation.
                                          it's very weird toolbar behavior in OSX world so i doubt it's a known issue since no apps do it.
                                          i just stumbled upon it one day when i tried 1001bit toolbar across the top of my screen.
                                          (bonzai has a few horizontal toolbars but their tooltips (vert&horizontal) aren't standard so they've done something to modify the icons/tooltips)
                                          • N
                                            nicasiojoel
                                            Thom, Thanks a lot. This should be a must on all sketchup user. A very useful plug. It makes work easier and faster.
                                            • 11
                                            • 6 / 11
