    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
      I'm getting crashes when I try to import an .obj file I got. (120MB)
      I've tried different options - triangulate on/off, material on/off - but it bugsplats every time. Memory usage of Sketchup.exe doesn't exceed 300MB.
      Any ideas?
      • jason_marantoJ Offline
        jason_maranto
        Wow, that is extremely fast! Thank-you 😍
        Best,
        Jason.
        • F Offline
          fluid
          Thomthom, I've never tried a file that big. How many polygons is it?
          • TIGT Online
            Fluid
            Did you also see this? http://forums.sketchucation.com/viewtopic.php?p=320223#p320223
            The materials using textures [after #1] aren't being made from the MTL or then applied to the right faces πŸ˜•
            • F Offline
              fluid
              TIG, yes, I did. Please be patient, it'll be fixed soon. I'm just working on this on my spare time πŸ˜„
              • TIGT Online
                No problem πŸ˜„
                Just checking... πŸ˜‰
                  I do not know - it's a file we got from different office.
                  Do you got dropbox? I could drop you the file if you want to have a look..?
                    pibuz
                    Thank you fluid for the effort you're putting into this!
                    We're all grateful to you, you're providing an excellent tool.
                    ..so are you all, from Thom, to TIG, to everyone who contribute to make SketchUp a more powerful software!
                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    • F Offline
                      fluid
                      Thomthom,, I just installed Dropbox, how am I gonna share a folder with you?
                      • F Offline
                        fluid
                        Just released 1.0.4, it should fix the face/material issue.
                        • TIGT Online
                          Thanks again!
                          This update does indeed seem to address the textured materials import issue πŸ˜„
                            pibuz
                            Works like a charm!
                            Thanks TIG for the support and a GIANT thank you to fluid for this excellent tool!
                              @fluid
                              Changed the original post title to reflect the current version number
                              Great update πŸ‘
                              • F Offline
                                fluid
                                Released 1.0.5, fixing a bug causing a bunch of crashes. Thanks to Thomthom for the help.
                                  dedmin
                                    pibuz
                                    Back to report a bugsplat.
                                    I made a quite heavy tree with TreeD, which got correctly exported in OBJ format, resulting in a 42MB file. When I tried to import (several times) the obj, after a rather short time the tree was imported into sketchy (no bugsplats), but it had no textures applied. The materials were correctly created (their names themselves were correct too, corresponding to the ones figuring in the mlt file), but they had no textures embedded, but when I tried to add the textures the mapping was wrong.
                                    I tried to separately export the trunk/branches (26MB) and the leaves (16MB) from TreeD. The trunk/branches gave no errors in the import process, but when I tried to import the leaves' mesh I got the bugsplat, two times.
                                    Then, the final solution I tried (which finally worked) was to import in a new file only the leaves using TIG's old importer (this worked, in the known biblical time πŸ˜† ) and then I manually merged the two sketchup files (the origin was common).
                                    Is this something fixable? I guess the issue concerns huge obj files. What I don't understand is that I recently imported xfrog obj files which were even 80MB each, and I got no problems. What is going on?
                                    • F Offline
                                      fluid
                                      Hi pibuz,
                                      If you have Dropbox I can take a look at the file that is giving you problems.
                                      • TIGT Online
                                        It's not a Plugin, it's a compiled 'Importer'.
                                        It adds an additional Importer type 'Wavefront/OBJ' under the File > Import file-browser...
                                        The same as other compiled importers/exporters - it's the Ruby based tools that are in other menus like Plugins...
                                          bizmen
                                          Which folder do I have to extract the fluidimporter file? I cannot see it under the plugins menu after extracting on its default folder.
                                          Btw. I'm using Google sketch up v8 (free version) ,and should I install the fluid ray demo version before fluidimporter for sketchup appears?
                                          If yes, which installer should I download? I'm using windows vista ultimate 64 bit, 4gb ram
                                          FluidRay for SketchUp Win32 Demo (Version 1.1.2)
                                          FluidRay for SketchUp Win32 SSE2 Demo (Version 1.1.2)
                                          FluidRay for SketchUp Win64 SSE2 Demo (Version 1.1.2)
                                          FluidRay for SketchUp Win64 SSE41 Demo (Version 1.1.2)
                                            bizmen
                                            Thanks TIG, you're the MAN!
                                            • 2 / 9
