    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
    • F Offline
      fluid
      Released 1.0.5, fixing a bug causing a bunch of crashes. Thanks to Thomthom for the help.
        dedmin
          pibuz
          Back to report a bugsplat.
          I made a quite heavy tree with TreeD, which got correctly exported in OBJ format, resulting in a 42MB file. When I tried to import (several times) the obj, after a rather short time the tree was imported into sketchy (no bugsplats), but it had no textures applied. The materials were correctly created (their names themselves were correct too, corresponding to the ones figuring in the mlt file), but they had no textures embedded, but when I tried to add the textures the mapping was wrong.
          I tried to separately export the trunk/branches (26MB) and the leaves (16MB) from TreeD. The trunk/branches gave no errors in the import process, but when I tried to import the leaves' mesh I got the bugsplat, two times.
          Then, the final solution I tried (which finally worked) was to import in a new file only the leaves using TIG's old importer (this worked, in the known biblical time πŸ˜† ) and then I manually merged the two sketchup files (the origin was common).
          Is this something fixable? I guess the issue concerns huge obj files. What I don't understand is that I recently imported xfrog obj files which were even 80MB each, and I got no problems. What is going on?
          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          • F Offline
            fluid
            Hi pibuz,
            If you have Dropbox I can take a look at the file that is giving you problems.
            • TIGT Online
              It's not a Plugin, it's a compiled 'Importer'.
              It adds an additional Importer type 'Wavefront/OBJ' under the File > Import file-browser...
              The same as other compiled importers/exporters - it's the Ruby based tools that are in other menus like Plugins...
                bizmen
                Which folder do I have to extract the fluidimporter file? I cannot see it under the plugins menu after extracting on its default folder.
                Btw. I'm using Google sketch up v8 (free version) ,and should I install the fluid ray demo version before fluidimporter for sketchup appears?
                If yes, which installer should I download? I'm using windows vista ultimate 64 bit, 4gb ram
                FluidRay for SketchUp Win32 Demo (Version 1.1.2)
                FluidRay for SketchUp Win32 SSE2 Demo (Version 1.1.2)
                FluidRay for SketchUp Win64 SSE2 Demo (Version 1.1.2)
                FluidRay for SketchUp Win64 SSE41 Demo (Version 1.1.2)
                  bizmen
                  Thanks TIG, you're the MAN!
                  • W Offline
                    whoa
                    Hello
                    I just installed your importer and I have no issue importing the .obj file, however I am not getting any textures?
                    Everything is just gray. I received the files from a furniture company, 4 seperate folders with several .obj files + .mtl and some jpgs that I guess are the textures. How do I add these into sketchup onto the objects?
                    Thank you
                    • TIGT Online
                      @whoa said:
                      Hello
                      Thank you
                      You can read OBJ and MTL files in Notepad or equivalent.
                      The OBJ file defines the MTL file by name mtllib xxx.mtl.
                      The OBJ file usually expects the MTL file to be in the same folder as itself.
                      The MTL file defines materials.
                      They can be simple plain color like this (Kd values as %s =~[170,170,170]=~'mid-gray')
                      newmtl Color_003
                      Ka 0.000000 0.000000 0.000000
                      Kd 0.666667 0.666667 0.666667
                      Ks 0.000000 0.000000 0.000000
                      d 1.000000
                      or with a texture specified by an image-file it is like this
                      newmtl Wood_Floor
                      Kd 0.607843 0.411765 0.239216
                      d 1.000000
                      map_Kd MyModel/Wood_Floor.jpg
                      In this example the MTL file is expecting to find that material's texture's image-file called Wood_Floor.jpg in a subfolder that's in the MTL file's folder, that's named MyModel.
                      Note that many OBJ exporters use an image subfolder, but some do not - in that case the line might read
                      and then the textures' image files should be in the same folder as the MTL file itself...
                      If an OBJ importer can't find the image file it usually skips using it, and just uses the color specified for the material - in the case of 'Wood_Floor' this would be an RGB color based on the Kd values, as percentages of 255 =~[155,105,61]=~'mid-brown'...
                      Note that the 'd' value is the opacity: where 1.000000 is solid and 0.500000 is 50% transparent etc... So you can adjust these prior to import if desired...
                      • E Offline
                        emanshiu
                        Thank you for writing this tool. But everyttime i try to load in an OBJ, the sketchup just crashes. It crashes on a very simple text file. I'm a bit confused at what I can do. Am I doing something wrong? These files are all exported from Maya. Thanks!
                        • TIGT Online
                          What are the error messages in the Ruby Console etc ?
                          Have you tried it with my [TIG] older/slower OBJimporter.rb ?
                          Any error messages there ?
                          CAN you zip the OBJ & MTL files... and image files [in a folder if specified in the MTL etc] and post them so we can test it...
                          • E Offline
                            emanshiu
                            There are no error messages as it just crashes.
                            I'm sorry i was not aware theres an older one. I just tried to find it but can't where is it?
                            Also is there any way to import an obj and have it place at 0,0,0?
                            thanks so much for the help!
                            • TIGT Online
                              Search the Plugins-Index [here] for my OBJimporter.rb ...
                              That does place the geometry directly at it's original location.
                              The alternative, newer compiled version allows you to manually locate the geometry BUT it's easy enough to make that [0,0,0] ...
                              • E Offline
                                emanshiu
                                any idea on the crashing? it's really just a cube from maya.....
                                • TIGT Online
                                  Unless you zip up the OBJ/MTL/Image-files and post them how can I know?
                                  Have you tried the older importer.rb file ?
                                  I haven't been directly involved in making the newer one BUT there might be clues in the way each one works...
                                  Please post the files if we are to progress this issue anywhere...
                                  • F Offline
                                    fluid
                                    Yep, if you post the file that is causing the crash, I'll be happy to test it on FluidImporter as well.
                                    • E Offline
                                      Efrado
                                      HI ,TIG &NICOLA
                                      WHAT ATEAM YOU ARE DOING πŸ‘ πŸ‘
                                      JUST A HUMBLE MAC USER WAITING TO TRY YOUR EFFORT IN THIS PLATFORM,PLEASE 😒
                                      • N Offline
                                        niks
                                        hi Fluid and Tig... thank you very much for this importer. tried it for a test and achieve great result πŸ˜„
                                          blockade08
                                          @tig said:
                                          @whoa said:
                                          Hello
                                          Thank you
                                          newmtl Color_003
                                          d 1.000000
                                          newmtl Wood_Floor
                                          d 1.000000
                                          Thank you so much TIG you just saved me from hours of trying to fix up the textures as normally happens when i try a new importer/exporter πŸ˜„ Thanks a bunch πŸ˜„
                                          BTW for anyone who also has this problem, my .OBJ said mtllib C:\......\*wheremyModelIs*\test.mtl
                                          I changed it to mtllib test.mtl - took off the directory data and it worked like a charm πŸ˜„
                                            chocochoc
                                            Hi there,
                                            I tried to download the fluidimporter, but the website gives back a 500 error.
                                            I couldn't find a mirror to download it. Is there someone who would send it to me or give me an available link ?
                                            • 3 / 9
