    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
    • TIGT Online
      Fluid
      Did you also see this? http://forums.sketchucation.com/viewtopic.php?p=320223#p320223
      The materials using textures [after #1] aren't being made from the MTL or then applied to the right faces πŸ˜•
      • F Offline
        fluid
        TIG, yes, I did. Please be patient, it'll be fixed soon. I'm just working on this on my spare time πŸ˜„
        • TIGT Online
          No problem πŸ˜„
          Just checking... πŸ˜‰
            @fluid said:
            Thomthom, I've never tried a file that big. How many polygons is it?
            I do not know - it's a file we got from different office.
            Do you got dropbox? I could drop you the file if you want to have a look..?
              pibuz
              Thank you fluid for the effort you're putting into this!
              We're all grateful to you, you're providing an excellent tool.
              ..so are you all, from Thom, to TIG, to everyone who contribute to make SketchUp a more powerful software!
              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
              • F Offline
                fluid
                Thomthom,, I just installed Dropbox, how am I gonna share a folder with you?
                • F Offline
                  fluid
                  Just released 1.0.4, it should fix the face/material issue.
                  • TIGT Online
                    Thanks again!
                    This update does indeed seem to address the textured materials import issue πŸ˜„
                      pibuz
                      Works like a charm!
                      Thanks TIG for the support and a GIANT thank you to fluid for this excellent tool!
                        @fluid
                        Changed the original post title to reflect the current version number
                        Great update πŸ‘
                        • F Offline
                          fluid
                          Released 1.0.5, fixing a bug causing a bunch of crashes. Thanks to Thomthom for the help.
                            dedmin
                              pibuz
                              Back to report a bugsplat.
                              I made a quite heavy tree with TreeD, which got correctly exported in OBJ format, resulting in a 42MB file. When I tried to import (several times) the obj, after a rather short time the tree was imported into sketchy (no bugsplats), but it had no textures applied. The materials were correctly created (their names themselves were correct too, corresponding to the ones figuring in the mlt file), but they had no textures embedded, but when I tried to add the textures the mapping was wrong.
                              I tried to separately export the trunk/branches (26MB) and the leaves (16MB) from TreeD. The trunk/branches gave no errors in the import process, but when I tried to import the leaves' mesh I got the bugsplat, two times.
                              Then, the final solution I tried (which finally worked) was to import in a new file only the leaves using TIG's old importer (this worked, in the known biblical time πŸ˜† ) and then I manually merged the two sketchup files (the origin was common).
                              Is this something fixable? I guess the issue concerns huge obj files. What I don't understand is that I recently imported xfrog obj files which were even 80MB each, and I got no problems. What is going on?
                              • F Offline
                                fluid
                                Hi pibuz,
                                If you have Dropbox I can take a look at the file that is giving you problems.
                                • TIGT Online
                                  It's not a Plugin, it's a compiled 'Importer'.
                                  It adds an additional Importer type 'Wavefront/OBJ' under the File > Import file-browser...
                                  The same as other compiled importers/exporters - it's the Ruby based tools that are in other menus like Plugins...
                                    bizmen
                                    Which folder do I have to extract the fluidimporter file? I cannot see it under the plugins menu after extracting on its default folder.
                                    Btw. I'm using Google sketch up v8 (free version) ,and should I install the fluid ray demo version before fluidimporter for sketchup appears?
                                    If yes, which installer should I download? I'm using windows vista ultimate 64 bit, 4gb ram
                                    FluidRay for SketchUp Win32 Demo (Version 1.1.2)
                                    FluidRay for SketchUp Win32 SSE2 Demo (Version 1.1.2)
                                    FluidRay for SketchUp Win64 SSE2 Demo (Version 1.1.2)
                                    FluidRay for SketchUp Win64 SSE41 Demo (Version 1.1.2)
                                      bizmen
                                      Thanks TIG, you're the MAN!
                                      • W Offline
                                        whoa
                                        Hello
                                        I just installed your importer and I have no issue importing the .obj file, however I am not getting any textures?
                                        Everything is just gray. I received the files from a furniture company, 4 seperate folders with several .obj files + .mtl and some jpgs that I guess are the textures. How do I add these into sketchup onto the objects?
                                        Thank you
                                        • TIGT Online
                                          @whoa said:
                                          Hello
                                          Thank you
                                          You can read OBJ and MTL files in Notepad or equivalent.
                                          The OBJ file defines the MTL file by name mtllib xxx.mtl.
                                          The OBJ file usually expects the MTL file to be in the same folder as itself.
                                          The MTL file defines materials.
                                          They can be simple plain color like this (Kd values as %s =~[170,170,170]=~'mid-gray')
                                          newmtl Color_003
                                          Ka 0.000000 0.000000 0.000000
                                          Kd 0.666667 0.666667 0.666667
                                          Ks 0.000000 0.000000 0.000000
                                          d 1.000000
                                          or with a texture specified by an image-file it is like this
                                          newmtl Wood_Floor
                                          Kd 0.607843 0.411765 0.239216
                                          d 1.000000
                                          map_Kd MyModel/Wood_Floor.jpg
                                          In this example the MTL file is expecting to find that material's texture's image-file called Wood_Floor.jpg in a subfolder that's in the MTL file's folder, that's named MyModel.
                                          Note that many OBJ exporters use an image subfolder, but some do not - in that case the line might read
                                          and then the textures' image files should be in the same folder as the MTL file itself...
                                          If an OBJ importer can't find the image file it usually skips using it, and just uses the color specified for the material - in the case of 'Wood_Floor' this would be an RGB color based on the Kd values, as percentages of 255 =~[155,105,61]=~'mid-brown'...
                                          Note that the 'd' value is the opacity: where 1.000000 is solid and 0.500000 is 50% transparent etc... So you can adjust these prior to import if desired...
                                          • E Offline
                                            emanshiu
                                            Thank you for writing this tool. But everyttime i try to load in an OBJ, the sketchup just crashes. It crashes on a very simple text file. I'm a bit confused at what I can do. Am I doing something wrong? These files are all exported from Maya. Thanks!
                                            • 2 / 9
