    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 213.3k Views 75 Watching
      Oops. No, the toolbar for Artisan doesn't show up now nor does it appear in the menu.
      The unscrambled version does work and Artisan seems to work with it, too.
        SketchUpNoobie
        Yep, the latest version works for me too and doesn't mess up Artisan. Thanks.
        SketchUpNoobie: the complete noob in all things SketchUp.
          Here's a slightly improved version http://forums.sketchucation.com/viewtopic.php?p=17156#p17156
          It avoids the clash with Artisan [which is quite frankly completely inexplicable!] and fixes one or two other internal glitches...
          I have removed the test version from the recent post - please replace it with this linked one asap.....
          ALL users should download it asap........
            Why inexplicable?
              Thanks TIG. I'll do that when I get home and check it. I expect it'll be just fine though.
                Why inexplicable?
                Because I can't explain [explicate] it ! πŸ˜’
                My original code was encrypted [a simple encryption, as used by Didier Bur too].
                If that loads after Artisan then it has no menu BUT works from the Ruby Console [files load in alphanumeric order].
                If you renamed it so it loaded before Artisan then it was fine... BUT then Artisan didn't load at all πŸ˜’
                I used a decrypted version that worked fine with Artisan, so I was unaware of the problem...
                My own version had some minor coding tweaks BUT nothing I can see that should make it behave any differently to the encrypted one... There are almost 4,000 lines of code so I don't want to trawl all of them to find the possible culprit... there are no error messages to help and 'Roof' and 'Artisan' now work fine together with this version anyway...
                This new 'unencrypted' & tweaked version works fine now - I recommend everyone to change to it... πŸ˜’
                  Nice explication πŸ‘
                  My comedic timing must be a little off today... πŸ˜’
                  • Gus RG
                    Gus R
                    Thanks very much for the update TIG.
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                      SketchUpNoobie
                      Yep. The update seems to be working fine. Thanks.
                      • W
                        Whaat
                        Thanks for updating the plugin, Tig. If you can figure out the problem, let me know. Maybe there is something I can change to fix this. I also have no idea what would cause this.
                        • CAntonisC
                          CAntonis
                          Thank U TIG!
                          This plugin will be appreciated as every thing else you created!
                          BRAVO!!!!
                          • tbdT
                            tbd
                            after some debugging at 2am I found the problem - scrambled scripts and pack eval encrypted scripts both return (eval) for FILE , so when tested with file_loaded? the one that gets loaded second it will not execute the block after (usually menu creation code)
                            workaround: use file_loaded("your_filename") or file_loaded("reverse URI")
                            eg file_loaded("roof.rb") or file_loaded("ro.plugins.drop")
                            http://plugins.ro
                            • utilerU
                              utiler
                              Thanks TIG, much appreciated!! πŸ‘
                              Just Curious...
                                Thanks for the info...OR we could just separate the menu code from the scrambled part so that it's not eval'd...
                                • CAntonisC
                                  CAntonis
                                  Thank U very much TIG. You made a great plugin even greater!
                                  Antonis
                                  • jim smithJ
                                    jim smith
                                    Thanks for the update TIG
                                    "Out of clutter find simplicity,
                                    from discord find harmony,
                                    In the middle of difficulty lies opportunity"
                                    Albert Einstein
                                    • Gus RG
                                      Gus R
                                      ➑ Not to be a pest but something isn't right. The "eaves soffit size" is resulting in erroneous dimensions on opposing sides. For instance I input and eaves soffit size of 24" all around but I wind up with 1'-9 3/16" on one side and 2'-2 1/2" on another. Another conflict perhaps or am I imagining things. Did this with a "new" skp as well. Any ideas? Thanks.
                                        @gus r said:
                                        :arrow: Not to be a pest but something isn't right. The "eaves soffit size" is resulting in erroneous dimensions on opposing sides. For instance I input and eaves soffit size of 24" all around but I wind up with 1'-9 3/16" on one side and 2'-2 1/2" on another. Another conflict perhaps or am I imagining things. Did this with a "new" skp as well. Any ideas? Thanks.
                                        I assume this is with 'gable-roof' ?
                                        The other tools all offset equally anyway ?
                                        I can't reproduce any error...
                                        On a hipped-roof the overhang is always equal too ?
                                        Can you post a SKP that will give you the error [or PM it]...
                                        I can't break it πŸ˜•
                                        • Gus RG
                                          Gus R
                                          TIG OK, here's a skp file that I just created. Looks like the gable roof comes out good but the hip and mansard result in the same overhang dimensions. This is all using default setting on the ruby.rb.
                                          roof ruby test.skp
                                            I can reproduce the problem using your example SKP.
                                            Currently I am a complete loss to say why this might be happening...
                                            I'll sleep on it and come back to you... πŸ˜•
                                            • 3 / 9
