    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 198.6k Views 75 Watching
    • Gus RG Offline
      Gus R
      TIG,
      Great plugin which I put through much use.
      Recently however I went to use the roof plugin and noticed that it was missing from the plugins menu. Checked my plugin directory and it was in the correct location. Downloaded it again, just in case, and again placed it in the plugins directory but it still didn't show up in the plugins menu.
      It finally showed up after I moved roof.rb into the tools menu which is something I've done in the past.
      Only thing I've installed since I last used roof.rb has been "SDS2 Artisan". Probably conflict? Otherwise it works in the tools directory.
      Thanks.
      ➑ Update
      I renamed artisan_loader.rb to artisan_loader.rbx and put roof.rb back in the plugins directory and it once again shows up.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        I dropped this in my plugin folder but its not showing up under "Plugins". Am I doing something wrong TIG?
        Did you see the post by Gus R? I did the same thing that he did with the Artisan loader file extension and it shows up. It does appear to be a conflict between the two plugins. I guess moving it to Tools isn't a big deal though.
        • TIGT Online
          I assume you mean you put the Roof.rb file into the Plugins folder ?
          There are also 'help' files available...
          Where there any error messages at startup...
          There should be no conflicts with the other scripts...
          I have artisan AND Roof running together without issues πŸ˜•
          It would be better if Roof.rb remained in the Plugins folder...
          It will work inside the Tools folder but that is really for Google's own scripts...
          You could try it in the Plugins but add a # to the start of its name [#Roof.rb] so that it loads before Artisan - then see if Artisan works too...
          You can also test if it's loading [even if the menu item isn't there] by typing this into the Ruby Console...
          Roof::hip
          Working ? Messages ?
          Please report back...
            TIG, it does load as the entry into the Console works. I changed the name to #Roof.rb and that works, too. The menu entry shows near the top of the Plugins menu instead of alphabetically.
            • TIGT Online
              BUT does Artisan then work ?
              It already works for me either way, so I can't see what Artisan might be doing to screw up 'Roof' loading properly and making its menu?
              Here's my [unscrambled] 'current' version - please see if this version of 'Roof.rb' works ?? NOTE: this pre-v.4 one is for 'testing only'...*** EDIT: I have removed the temporary version - please get this one [i.e. the 4 of you who tried it and any v3 users!] http://forums.sketchucation.com/viewtopic.php?p=17156#p17156
                Oops. No, the toolbar for Artisan doesn't show up now nor does it appear in the menu.
                The unscrambled version does work and Artisan seems to work with it, too.
                  SketchUpNoobie
                  Yep, the latest version works for me too and doesn't mess up Artisan. Thanks.
                  SketchUpNoobie: the complete noob in all things SketchUp.
                  • TIGT Online
                    Here's a slightly improved version http://forums.sketchucation.com/viewtopic.php?p=17156#p17156
                    It avoids the clash with Artisan [which is quite frankly completely inexplicable!] and fixes one or two other internal glitches...
                    I have removed the test version from the recent post - please replace it with this linked one asap.....
                    ALL users should download it asap........
                      Why inexplicable?
                        Thanks TIG. I'll do that when I get home and check it. I expect it'll be just fine though.
                        • TIGT Online
                          Why inexplicable?
                          Because I can't explain [explicate] it ! πŸ˜’
                          My original code was encrypted [a simple encryption, as used by Didier Bur too].
                          If that loads after Artisan then it has no menu BUT works from the Ruby Console [files load in alphanumeric order].
                          If you renamed it so it loaded before Artisan then it was fine... BUT then Artisan didn't load at all πŸ˜’
                          I used a decrypted version that worked fine with Artisan, so I was unaware of the problem...
                          My own version had some minor coding tweaks BUT nothing I can see that should make it behave any differently to the encrypted one... There are almost 4,000 lines of code so I don't want to trawl all of them to find the possible culprit... there are no error messages to help and 'Roof' and 'Artisan' now work fine together with this version anyway...
                          This new 'unencrypted' & tweaked version works fine now - I recommend everyone to change to it... πŸ˜’
                            Nice explication πŸ‘
                            My comedic timing must be a little off today... πŸ˜’
                            • Gus RG Offline
                              Gus R
                              Thanks very much for the update TIG.
                                SketchUpNoobie
                                Yep. The update seems to be working fine. Thanks.
                                • W Offline
                                  Whaat
                                  Thanks for updating the plugin, Tig. If you can figure out the problem, let me know. Maybe there is something I can change to fix this. I also have no idea what would cause this.
                                  • CAntonisC Offline
                                    CAntonis
                                    Thank U TIG!
                                    This plugin will be appreciated as every thing else you created!
                                    BRAVO!!!!
                                    • tbdT Offline
                                      tbd
                                      after some debugging at 2am I found the problem - scrambled scripts and pack eval encrypted scripts both return (eval) for FILE , so when tested with file_loaded? the one that gets loaded second it will not execute the block after (usually menu creation code)
                                      workaround: use file_loaded("your_filename") or file_loaded("reverse URI")
                                      eg file_loaded("roof.rb") or file_loaded("ro.plugins.drop")
                                      http://plugins.ro
                                      • utilerU Offline
                                        utiler
                                        Thanks TIG, much appreciated!! πŸ‘
                                        Just Curious...
                                        • TIGT Online
                                          Thanks for the info...OR we could just separate the menu code from the scrambled part so that it's not eval'd...
                                          • CAntonisC Offline
                                            CAntonis
                                            Thank U very much TIG. You made a great plugin even greater!
                                            Antonis
                                            • 3 / 9
