    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • jason_marantoJ Offline
      jason_maranto
      Hey Fredo,
      I am currently trying my best to learn how to use curviloft and I working on a project that I think fits alot of what the tool does -- since everyone else is sharing I thought I would too. This is a the arm for a robot from a show I watched as a child called Robotech (also known as Macross overseas).
      http://www.spotoarts.com/jason/armandgun_posed_dc.skp (5mb download)
      I am using curviloft, roundcorner, and JJP for alot of this -- you may also notice that this is a dynamic component and if you click on it I have rigged it to animate between 2 positions... although the poly-count is really stretching the limits of what can be animated.
      Thank-you for your plugins!
      ๐Ÿ’ญ I also forgot to mention I'm using your BZ toolbar set as well ๐Ÿ˜
      Best,
      Jason.
      • fredo6F Offline
        NEW RELEASE: Curviloft 1.1a - 12 Jan 11
        Sorry for long absence. This new release hopefully includes a functional version of Loft Along Path, along with other fixes. It also support a two-phase loading.
        Note that you will need to upgrade to LibFredo6 3.6.
        There is still no documentation. So the best is have a look at the video:
        [flash=640,480:3menursp]http://www.youtube.com/v/AZnVY3unWPU&hl[/flash:3menursp]
        See main post for download
          Thanks again Fredo6, this is an amazing tool ๐Ÿ‘
          • utilerU Offline
            utiler
            Fredo, I don't know how many time I can say thank you with out it becoming monotonous but, thank you!
            Just Curious...
              ๐Ÿ˜ฎ Wow!
              Thank you, thank you, thank you.
                Daniel S
                Thank you Fredo!!!
                I like the respect tangency method ๐ŸŽ‰
                But looks like the skinning option has a regression ๐Ÿ˜ž
                Daniel S
                skin.skp
                • fredo6F Offline
                  @daniel s said:
                  [b]But looks like the skinning option has a regression ๐Ÿ˜ž
                  Daniel S
                  Daniel,
                  You always find the right bugs. Thanks for that! This seems to be with 3 sides shapes.
                  I have a look.
                    Happy new year Fredo! ๐Ÿ˜Ž et ๐Ÿ‘
                    • fredo6F Offline
                      Small bug signaled by Daniel S in Skinning (on 3-side shapes) is fixed.
                      You just need to upgrade to LibFredo6 3.6b
                        Daniel S
                        That was fast.. thank you again Fredo!!!
                        Awesome plugin
                        Daniel S
                          Speedy SAV (in English after sales service ) ๐Ÿ’š
                          ๐Ÿ˜Ž
                            jason_maranto
                            Hi Fredo,
                            Thank-you again for this -- I do have a slight request... I have some re-occurring twisting and if I take the time to align the verts manually the result comes out exactly the way I want, but manually setting the verts seems a bit temperamental at this point and I was wondering if it could be possible to set the "twist" parameters to decimal increments as it would solve my problem (1 is too large a change). See attached file for example.
                            If there is a better solution then I am very interested... I have split the profiles down the middle and successfully finished it that way.
                            Best,
                            Jason.
                            twisty verts.skp
                            • massimoM Offline
                              massimo Moderator
                              Amazing as usual... ๐Ÿ˜ฎ
                              Thank you.
                              • fredo6F Offline
                                @jason_maranto said:
                                Hi Fredo,
                                Best,
                                Jason.
                                Jason,
                                In your case, the alignment issue can be solved by using naturalvertex matching, as opposed to best-fit of shapes(which is the default).
                                Here is an illustration on your model. In your case, the natural 'straight' matching is more appropriate than the shape best-fit method.
                                PS: by the way, your model is a good illustration for using the transversal Spline methods (like F-Spline, second icon from the right, in red). See in attached file
                                twisty verts - Fredo.skp
                                • fredo6F Offline
                                  Thanks to your thanks. I hope you are safe with all the water flooding in Queensland.
                                    jason_maranto
                                    Thank-you again Fredo -- I tried all the other icons there but failed to try that last one (toggle natural) ๐Ÿ˜ณ This is such an amazing tool for Sketchup ๐Ÿ˜
                                    Best,
                                    Jason.
                                      Ben Ritter
                                      Fredo, thank you very very much, again.
                                      • erikBE Offline
                                        erikB
                                        Very usefull pluging !!!
                                        Thank you very much Fredo.
                                        I had some bugsplats due to the fact that I was still using an old version of JPP. (It was the libtraductor.rb file who caused it)
                                        But after upgrading both rudys work like charme.
                                        greetings, erikB
                                        • mitcorbM Offline
                                          mitcorb
                                          Well, good to know the updates appear to be backward compatible to earlier Sketchup versions. We would expect nothing less from the very capable Fredo6.
                                          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                                          And, I add my Thank You, Fredo
                                          • fredo6F Offline
                                            ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                                            Yes. Normally the scripts should still work in SU6.
                                            The issue with SU* is that, due to a change of the Ruby interpreter, there were some small bugs generated and also some unuseful warnings.
                                            Also, for me, it is better is users can move to latest versions because it is easier to support.
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 62 / 66
