    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • fredo6F
      Jason,
      I had a look and yes the design is quite impressive. I see of course where you used the plugins.
      You really should put a picture in your post.
      • jason_marantoJ
        jason_maranto
        Hey Fredo,
        I am currently trying my best to learn how to use curviloft and I working on a project that I think fits alot of what the tool does -- since everyone else is sharing I thought I would too. This is a the arm for a robot from a show I watched as a child called Robotech (also known as Macross overseas).
        http://www.spotoarts.com/jason/armandgun_posed_dc.skp (5mb download)
        I am using curviloft, roundcorner, and JJP for alot of this -- you may also notice that this is a dynamic component and if you click on it I have rigged it to animate between 2 positions... although the poly-count is really stretching the limits of what can be animated.
        Thank-you for your plugins!
        ๐Ÿ’ญ I also forgot to mention I'm using your BZ toolbar set as well ๐Ÿ˜
        Best,
        Jason.
        • fredo6F
          NEW RELEASE: Curviloft 1.1a - 12 Jan 11
          Sorry for long absence. This new release hopefully includes a functional version of Loft Along Path, along with other fixes. It also support a two-phase loading.
          Note that you will need to upgrade to LibFredo6 3.6.
          There is still no documentation. So the best is have a look at the video:
          [flash=640,480:3menursp]http://www.youtube.com/v/AZnVY3unWPU&hl[/flash:3menursp]
          See main post for download
            Thanks again Fredo6, this is an amazing tool ๐Ÿ‘
            • utilerU
              utiler
              Fredo, I don't know how many time I can say thank you with out it becoming monotonous but, thank you!
              Just Curious...
                ๐Ÿ˜ฎ Wow!
                Thank you, thank you, thank you.
                  Daniel S
                  Thank you Fredo!!!
                  I like the respect tangency method ๐ŸŽ‰
                  But looks like the skinning option has a regression ๐Ÿ˜ž
                  Daniel S
                  skin.skp
                  • fredo6F
                    @daniel s said:
                    [b]But looks like the skinning option has a regression ๐Ÿ˜ž
                    Daniel S
                    Daniel,
                    You always find the right bugs. Thanks for that! This seems to be with 3 sides shapes.
                    I have a look.
                      Happy new year Fredo! ๐Ÿ˜Ž et ๐Ÿ‘
                      • fredo6F
                        Small bug signaled by Daniel S in Skinning (on 3-side shapes) is fixed.
                        You just need to upgrade to LibFredo6 3.6b
                          Daniel S
                          That was fast.. thank you again Fredo!!!
                          Awesome plugin
                          Daniel S
                            Speedy SAV (in English after sales service ) ๐Ÿ’š
                            ๐Ÿ˜Ž
                            • jason_marantoJ
                              jason_maranto
                              Hi Fredo,
                              Thank-you again for this -- I do have a slight request... I have some re-occurring twisting and if I take the time to align the verts manually the result comes out exactly the way I want, but manually setting the verts seems a bit temperamental at this point and I was wondering if it could be possible to set the "twist" parameters to decimal increments as it would solve my problem (1 is too large a change). See attached file for example.
                              If there is a better solution then I am very interested... I have split the profiles down the middle and successfully finished it that way.
                              Best,
                              Jason.
                              twisty verts.skp
                              • massimoM
                                massimo Moderator
                                Amazing as usual... ๐Ÿ˜ฎ
                                Thank you.
                                • fredo6F
                                  @jason_maranto said:
                                  Hi Fredo,
                                  Best,
                                  Jason.
                                  Jason,
                                  In your case, the alignment issue can be solved by using naturalvertex matching, as opposed to best-fit of shapes(which is the default).
                                  Here is an illustration on your model. In your case, the natural 'straight' matching is more appropriate than the shape best-fit method.
                                  PS: by the way, your model is a good illustration for using the transversal Spline methods (like F-Spline, second icon from the right, in red). See in attached file
                                  twisty verts - Fredo.skp
                                  • fredo6F
                                    Thanks to your thanks. I hope you are safe with all the water flooding in Queensland.
                                    • jason_marantoJ
                                      jason_maranto
                                      Thank-you again Fredo -- I tried all the other icons there but failed to try that last one (toggle natural) ๐Ÿ˜ณ This is such an amazing tool for Sketchup ๐Ÿ˜
                                      Best,
                                      Jason.
                                      • B
                                        Ben Ritter
                                        Fredo, thank you very very much, again.
                                        • erikBE
                                          erikB
                                          Very usefull pluging !!!
                                          Thank you very much Fredo.
                                          I had some bugsplats due to the fact that I was still using an old version of JPP. (It was the libtraductor.rb file who caused it)
                                          But after upgrading both rudys work like charme.
                                          greetings, erikB
                                          • mitcorbM
                                            mitcorb
                                            Well, good to know the updates appear to be backward compatible to earlier Sketchup versions. We would expect nothing less from the very capable Fredo6.
                                            ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
                                            And, I add my Thank You, Fredo
