    1.3k Posts 299 Posters 3.0m Views 297 Watching
      Speedy SAV (in English after sales service ) 💚
      • jason_marantoJ Offline
        jason_maranto
        Hi Fredo,
        Thank-you again for this -- I do have a slight request... I have some re-occurring twisting and if I take the time to align the verts manually the result comes out exactly the way I want, but manually setting the verts seems a bit temperamental at this point and I was wondering if it could be possible to set the "twist" parameters to decimal increments as it would solve my problem (1 is too large a change). See attached file for example.
        If there is a better solution then I am very interested... I have split the profiles down the middle and successfully finished it that way.
        Best,
        Jason.
        twisty verts.skp
        • massimoM Offline
          massimo Moderator
          Amazing as usual... 😮
          Thank you.
          • fredo6F Offline
            @jason_maranto said:
            Hi Fredo,
            Best,
            Jason.
            Jason,
            In your case, the alignment issue can be solved by using naturalvertex matching, as opposed to best-fit of shapes(which is the default).
            Here is an illustration on your model. In your case, the natural 'straight' matching is more appropriate than the shape best-fit method.
            PS: by the way, your model is a good illustration for using the transversal Spline methods (like F-Spline, second icon from the right, in red). See in attached file
            twisty verts - Fredo.skp
            • fredo6F Offline
              @utiler said:
              Fredo, I don't know how many time I can say thank you with out it becoming monotonous but, thank you!
              Thanks to your thanks. I hope you are safe with all the water flooding in Queensland.
                jason_maranto
                Thank-you again Fredo -- I tried all the other icons there but failed to try that last one (toggle natural) 😳 This is such an amazing tool for Sketchup 😍
                Best,
                Jason.
                  Ben Ritter
                  Fredo, thank you very very much, again.
                  • erikBE Offline
                    erikB
                    Very usefull pluging !!!
                    Thank you very much Fredo.
                    I had some bugsplats due to the fact that I was still using an old version of JPP. (It was the libtraductor.rb file who caused it)
                    But after upgrading both rudys work like charme.
                    greetings, erikB
                    • mitcorbM Offline
                      mitcorb
                      Well, good to know the updates appear to be backward compatible to earlier Sketchup versions. We would expect nothing less from the very capable Fredo6.
                      And, I add my Thank You, Fredo
                      • fredo6F Offline
                        Yes. Normally the scripts should still work in SU6.
                        The issue with SU* is that, due to a change of the Ruby interpreter, there were some small bugs generated and also some unuseful warnings.
                        Also, for me, it is better is users can move to latest versions because it is easier to support.
                        • N Offline
                          notareal
                          Thank you! ☀
                            chloesdad
                            Just wanted to add my thanks to you, Fredo for your generosity and talent.
                            • FletchF Offline
                              Fletch
                              Fredo, with you+SketchUp it eliminates need for almost any other modeling software. 😄
                              (except for Sculptris... but I believe Whaat will have that covered in a few days/weeks/months.)
                              Fletch
                                rattusNOR
                                Great work. Thank you Fredo !
                                  bowlr
                                  Thanks for the plugins, howver, after I copied the files to plugins folder, I get this error msg from SU
                                  "Error Loading File ZLoader__Curviloft.rb
                                  no such file to load -- LibFredo6.rb"
                                    bowlr, please go back and read the first post in the thread. Especially this:
                                    IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
                                    • mitcorbM Offline
                                      mitcorb
                                      Quote:"Also, for me, it is better if users can move to latest versions because it is easier to support."
                                      Fredo endquote
                                      I agree in principle on this statement. However, I must consider more than just upgrading to SU8. My hardware is going beyond outdated, and the logistics of migrating what I have accumulated is not trivial for me. 😄
                                        I think Fredo was referring to having users move to the latest versions of his tools.
                                        • mitcorbM Offline
                                          mitcorb
                                          Ok, I missed the subtle distinction there.
                                            Or I might have. that's just the way I read his comment, though.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 65
                                            • 66
                                            • 21 / 66
