    1.3k Posts 300 Posters 3.3m Views 298 Watching
      Ah oK ๐Ÿ˜„
      But that is not normal ๐Ÿ˜‰
      • fredo6F
        Ah oK ๐Ÿ˜„
        I cannot really say that this is normal ๐Ÿ˜†
        This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
          DIEGO-RODRIGUEZ
          Hi Fred.
          a question.
          is normal that generates the mesh outside the component or group that I'm working?
          • fredo6F
            @diego-rodriguez said:
            Hi Fred.
            a question.
            It's part of the bug fixed but not yet released.
            This was already signaled. see that post
            • charly2008C
              charly2008
              again a new Object
              Charly
              • mitcorbM
                mitcorb
                @Charly: Someone has probably already said this, but your Curviloft models remind me of high style jewelry in the tradition of Faberge, perhaps, or someone like him. I would have to guess you might actually work with jewelry or decorative art in some way. Again, I salute your creativity.
                The other possibility is that you are a very discerning and talented machinist.
                However, there are dentists who like to work with jewelry.
                Now don't let this all go to your head. We won't be able to do a thing with you ๐Ÿ’š
                • charly2008C
                  charly2008
                  Hi mitcorb,
                  at first many thanks for your nice comments. I'm just a retired mechanical engineer. I have nothing to do with jewelry. My thanks to Fredo and TIG for their wonderful plugins that allow me always to try new ideas. Curviloft inspired me again and again to construct new forms. It is not a great art, but only practice and a little visionary. In principle, everyone who deals with it can do it.
                  Charly
                    jbw007
                    Hi Fredo,
                    I've download your fantastic plugin, but I'm not able to use it. I get the toolbar and menu items, and I've created the curves that I want to work on. Nothing happens at all. I've check the video 10 times and can't see what's wrong. It's the only Plugin that I have installed, after a reinstall of SU. Nothing in the Ruby console, in fact the same problem that 'Rachmatrf' have in June. I've looked through the forum for the answer to him, but failed to find the solution. Can you help ?
                    Regards
                    Jens
                    Running XP SP3, and SU8
                    • fredo6F
                      Jason,
                      I had a look and yes the design is quite impressive. I see of course where you used the plugins.
                      You really should put a picture in your post.
                      • jason_marantoJ
                        jason_maranto
                        Hey Fredo,
                        I am currently trying my best to learn how to use curviloft and I working on a project that I think fits alot of what the tool does -- since everyone else is sharing I thought I would too. This is a the arm for a robot from a show I watched as a child called Robotech (also known as Macross overseas).
                        http://www.spotoarts.com/jason/armandgun_posed_dc.skp (5mb download)
                        I am using curviloft, roundcorner, and JJP for alot of this -- you may also notice that this is a dynamic component and if you click on it I have rigged it to animate between 2 positions... although the poly-count is really stretching the limits of what can be animated.
                        Thank-you for your plugins!
                        ๐Ÿ’ญ I also forgot to mention I'm using your BZ toolbar set as well ๐Ÿ˜
                        Best,
                        Jason.
                        • fredo6F
                          NEW RELEASE: Curviloft 1.1a - 12 Jan 11
                          Sorry for long absence. This new release hopefully includes a functional version of Loft Along Path, along with other fixes. It also support a two-phase loading.
                          Note that you will need to upgrade to LibFredo6 3.6.
                          There is still no documentation. So the best is have a look at the video:
                          [flash=640,480:3menursp]http://www.youtube.com/v/AZnVY3unWPU&hl[/flash:3menursp]
                          See main post for download
                            Thanks again Fredo6, this is an amazing tool ๐Ÿ‘
                            • utilerU
                              utiler
                              Fredo, I don't know how many time I can say thank you with out it becoming monotonous but, thank you!
                              Just Curious...
                                ๐Ÿ˜ฎ Wow!
                                Thank you, thank you, thank you.
                                  Daniel S
                                  Thank you Fredo!!!
                                  I like the respect tangency method ๐ŸŽ‰
                                  But looks like the skinning option has a regression ๐Ÿ˜ž
                                  Daniel S
                                  skin.skp
                                  • fredo6F
                                    @daniel s said:
                                    [b]But looks like the skinning option has a regression ๐Ÿ˜ž
                                    Daniel S
                                    Daniel,
                                    You always find the right bugs. Thanks for that! This seems to be with 3 sides shapes.
                                    I have a look.
                                      Happy new year Fredo! ๐Ÿ˜Ž et ๐Ÿ‘
                                      • fredo6F
                                        Small bug signaled by Daniel S in Skinning (on 3-side shapes) is fixed.
                                        You just need to upgrade to LibFredo6 3.6b
                                          Daniel S
                                          That was fast.. thank you again Fredo!!!
                                          Awesome plugin
                                          Daniel S
                                            Speedy SAV (in English after sales service ) ๐Ÿ’š
                                            ๐Ÿ˜Ž
