    3D Trees
    27 Posts 14 Posters 5.2k Views 14 Watching
    • shuraS
      shura
      Thank you Bohdan, now it works perfectly!!
        When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
        If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them... πŸ˜’
          markitekt
          RPS has a free tree maker that works pretty well too.
          http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
          Mark P.
            davesec
            hi!
            when i import a tree into sketchup each leaf seems to be bound in a box?
              Antonio83
              thank you all very much πŸ˜„
              • shuraS
                shura
                Hello Dave,
                you are right - and this is kind of a disadvantage...
                ...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.
                afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
                cheers
                alex
                  Starling75
                  @shura said:
                  Hello Dave,
                  cheers
                  alex
                  You can organize your tree and put leaf edges on separate hidden layer - see attached example.
                  Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..
                  This plugin should be helpfull:
                  http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109
                  Bo
                  tree_small.skp
                  http://www.starlingarch.cz
                    Running CleanUp on the trees will reduce the number of faces used.
                    • W
                      wyatt
                      In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
                      • soloS
                        Speed tree anyone?
                        http://www.speedtree.com/ (watch the video)
                        (except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
                        Here is a quick test.
                        • GaieusG
                          Did you buy it, Pete? 😲
                          (If that's the trial, is it fully functional and savable?)
                          The price is not only "hairy" but the whole licensing is so weird and stupid that I cannot even understand what they mean.
                            I didn't even see a price on their site - it all said "contact us".
                            What about the mesh complexity?
                            • GaieusG
                              On one of the pages there is a download link to a PDF file (what a stupid solution BTW). Different prices range between $6,000+ and $10,000+
                                bwhaaaaah!
                                • HieruH
                                  Hieru
                                  Apparently the educational licence is under $100.
                                  That just doesn't make sense to me.
                                  www.davidhier.co.uk
                                    When you consider ILM developers have given testimonials it must be a serious piece of kit. A game developers dream I suppose.
                                    • soloS
                                      Then there is always Vue trees, best used in Vue obviously.
                                      However for a low detailed SU version it's doable. (1.7MB)
