    3D Trees
    27 Posts 14 Posters 4.6k Views 14 Watching
      Antonio83
      Do you know where I can find 3D trees?
      • jason_marantoJ Offline
        jason_maranto
        This is free and pretty good:
        http://www.frecle.net/index.php?show=treed.about
        Best,
        Jason.
          Now that's a cool app, Jason, thanks for the link! πŸ‘
            Starling75
            http://forums.sketchucation.com/viewtopic.php?f=81&t=29722&hilit=tree+starling&start=15#p262163
            πŸ˜„
            http://www.starlingarch.cz
              smithryan07
              That program is Great! How do you export it out so that you can import it into SU? 😳
                Use the 3ds format.
                  @thomthom said:
                  Use the 3ds format.
                  Sorry, use the .obj format, and then use TIGs obj importer.
                    When I try to load any of the sample trees it comes with the textures are missing.
                    • shuraS Offline
                      shura
                      Thanks for bringing up Tree(d) again. I already abandoned it because the of the limited export formats - but I just realized that I didn't have the newest version.
                      So for anyone who is scratching his head like I did:
                      Download Tree(D) version 3.1 because in v3.0 there is no obj-export available.
                      Now it works with TIGs obj-importer, but for some reason the materials don't get imported.
                      Any idea what I am doing wrong here?
                        Starling75
                        Textures must be in the same folder together with exported *.obj and *.mtl files.
                        • shuraS Offline
                          shura
                          Thank you Bohdan, now it works perfectly!!
                            When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
                            If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them... πŸ˜’
                              markitekt
                              RPS has a free tree maker that works pretty well too.
                              http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
                              Mark P.
                                davesec
                                hi!
                                when i import a tree into sketchup each leaf seems to be bound in a box?
                                  Antonio83
                                  thank you all very much πŸ˜„
                                  • shuraS Offline
                                    shura
                                    Hello Dave,
                                    you are right - and this is kind of a disadvantage...
                                    ...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.
                                    afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
                                    cheers
                                    alex
                                      Starling75
                                      @shura said:
                                      Hello Dave,
                                      cheers
                                      alex
                                      You can organize your tree and put leaf edges on separate hidden layer - see attached example.
                                      Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..
                                      This plugin should be helpfull:
                                      http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109
                                      Bo
                                      tree_small.skp
                                        Running CleanUp on the trees will reduce the number of faces used.
                                        • W Offline
                                          wyatt
                                          In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
                                          • soloS Offline
                                            Speed tree anyone?
                                            http://www.speedtree.com/ (watch the video)
                                            (except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
                                            Here is a quick test.
