3D Trees
Do you know where I can find 3D trees?
Now that's a cool app, Jason, thanks for the link!
That program is Great! How do you export it out so that you can import it into SU?
Use the 3ds format.
@thomthom said:
Use the 3ds format.
Sorry, use the .obj format, and then use TIGs obj importer.
When I try to load any of the sample trees it comes with the textures are missing.
Thanks for bringing up Tree(d) again. I already abandoned it because the of the limited export formats - but I just realized that I didn't have the newest version.
So for anyone who is scratching his head like I did:
Download Tree(D) version 3.1 because in v3.0 there is no obj-export available.
Now it works with TIGs obj-importer, but for some reason the materials don't get imported.
Any idea what I am doing wrong here? -
Any idea what I am doing wrong here?Textures must be in the same folder together with exported *.obj and *.mtl files.
Thank you Bohdan, now it works perfectly!!
When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them...
RPS has a free tree maker that works pretty well too.
http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
Mark P. -
hi!
when i import a tree into sketchup each leaf seems to be bound in a box?
thank you all very much
Hello Dave,
you are right - and this is kind of a disadvantage...
...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
cheers
alex -
@shura said:
Hello Dave,
cheers
alexYou can organize your tree and put leaf edges on separate hidden layer - see attached example.
Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..This plugin should be helpfull:
http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109Bo
Running CleanUp on the trees will reduce the number of faces used.
In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
Speed tree anyone?
http://www.speedtree.com/ (watch the video)
(except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
Here is a quick test.
