    3D Trees
    27 Posts 14 Posters 5.4k Views 14 Watching
    • GaieusG
      Now that's a cool app, Jason, thanks for the link! πŸ‘
        Starling75
        http://forums.sketchucation.com/viewtopic.php?f=81&t=29722&hilit=tree+starling&start=15#p262163
        πŸ˜„
        http://www.starlingarch.cz
          smithryan07
          That program is Great! How do you export it out so that you can import it into SU? 😳
            Use the 3ds format.
              @thomthom said:
              Use the 3ds format.
              Sorry, use the .obj format, and then use TIGs obj importer.
                When I try to load any of the sample trees it comes with the textures are missing.
                • shuraS
                  shura
                  Thanks for bringing up Tree(d) again. I already abandoned it because the of the limited export formats - but I just realized that I didn't have the newest version.
                  So for anyone who is scratching his head like I did:
                  Download Tree(D) version 3.1 because in v3.0 there is no obj-export available.
                  Now it works with TIGs obj-importer, but for some reason the materials don't get imported.
                  Any idea what I am doing wrong here?
                    Starling75
                    Textures must be in the same folder together with exported *.obj and *.mtl files.
                    • shuraS
                      shura
                      Thank you Bohdan, now it works perfectly!!
                        When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
                        If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them... πŸ˜’
                          markitekt
                          RPS has a free tree maker that works pretty well too.
                          http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
                          Mark P.
                            davesec
                            hi!
                            when i import a tree into sketchup each leaf seems to be bound in a box?
                              Antonio83
                              thank you all very much πŸ˜„
                              • shuraS
                                shura
                                Hello Dave,
                                you are right - and this is kind of a disadvantage...
                                ...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.
                                afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
                                cheers
                                alex
                                  Starling75
                                  @shura said:
                                  Hello Dave,
                                  cheers
                                  alex
                                  You can organize your tree and put leaf edges on separate hidden layer - see attached example.
                                  Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..
                                  This plugin should be helpfull:
                                  http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109
                                  Bo
                                  tree_small.skp
                                    Running CleanUp on the trees will reduce the number of faces used.
                                    • W
                                      wyatt
                                      In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
                                      • soloS
                                        Speed tree anyone?
                                        http://www.speedtree.com/ (watch the video)
                                        (except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
                                        Here is a quick test.
                                        • GaieusG
                                          Did you buy it, Pete? 😲
                                          (If that's the trial, is it fully functional and savable?)
                                          The price is not only "hairy" but the whole licensing is so weird and stupid that I cannot even understand what they mean.
                                            I didn't even see a price on their site - it all said "contact us".
                                            What about the mesh complexity?
