    3D Trees
    27 Posts 14 Posters 5.2k Views 14 Watching
      When I try to load any of the sample trees it comes with the textures are missing.
      • shuraS
        shura
        Thanks for bringing up Tree(d) again. I already abandoned it because the of the limited export formats - but I just realized that I didn't have the newest version.
        So for anyone who is scratching his head like I did:
        Download Tree(D) version 3.1 because in v3.0 there is no obj-export available.
        Now it works with TIGs obj-importer, but for some reason the materials don't get imported.
        Any idea what I am doing wrong here?
          Starling75
          Textures must be in the same folder together with exported *.obj and *.mtl files.
          http://www.starlingarch.cz
          • shuraS
            shura
            Thank you Bohdan, now it works perfectly!!
              When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
              If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them... πŸ˜’
                markitekt
                RPS has a free tree maker that works pretty well too.
                http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
                Mark P.
                  davesec
                  hi!
                  when i import a tree into sketchup each leaf seems to be bound in a box?
                    Antonio83
                    thank you all very much πŸ˜„
                    • shuraS
                      shura
                      Hello Dave,
                      you are right - and this is kind of a disadvantage...
                      ...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.
                      afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
                      cheers
                      alex
                        Starling75
                        @shura said:
                        Hello Dave,
                        cheers
                        alex
                        You can organize your tree and put leaf edges on separate hidden layer - see attached example.
                        Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..
                        This plugin should be helpfull:
                        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109
                        Bo
                        tree_small.skp
                          Running CleanUp on the trees will reduce the number of faces used.
                          • W
                            wyatt
                            In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
                            • soloS
                              Speed tree anyone?
                              http://www.speedtree.com/ (watch the video)
                              (except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
                              Here is a quick test.
                              • GaieusG
                                Did you buy it, Pete? 😲
                                (If that's the trial, is it fully functional and savable?)
                                The price is not only "hairy" but the whole licensing is so weird and stupid that I cannot even understand what they mean.
                                  I didn't even see a price on their site - it all said "contact us".
                                  What about the mesh complexity?
                                  • GaieusG
                                    On one of the pages there is a download link to a PDF file (what a stupid solution BTW). Different prices range between $6,000+ and $10,000+
                                      bwhaaaaah!
                                      • HieruH
                                        Hieru
                                        Apparently the educational licence is under $100.
                                        That just doesn't make sense to me.
                                        www.davidhier.co.uk
                                          When you consider ILM developers have given testimonials it must be a serious piece of kit. A game developers dream I suppose.
                                          • soloS
                                            Then there is always Vue trees, best used in Vue obviously.
                                            However for a low detailed SU version it's doable. (1.7MB)
