    3D Trees
    27 Posts 14 Posters 5.2k Views 14 Watching
    • shuraS
      shura
      Thanks for bringing up Tree(d) again. I already abandoned it because the of the limited export formats - but I just realized that I didn't have the newest version.
      So for anyone who is scratching his head like I did:
      Download Tree(D) version 3.1 because in v3.0 there is no obj-export available.
      Now it works with TIGs obj-importer, but for some reason the materials don't get imported.
      Any idea what I am doing wrong here?
        Starling75
        Textures must be in the same folder together with exported *.obj and *.mtl files.
        http://www.starlingarch.cz
        • shuraS
          shura
          Thank you Bohdan, now it works perfectly!!
            When you have an OBJ file that uses an MTL file you need to read the image-file-path set in in the MTL file [it's a plain text file and it's readable using Notepad etc].
            If it's the same folder as the MTL file [i.e. there's no folder in the path] then it's in the same folder that the image files should be - BUT if the textures' paths include a sub-folder then ensure the image files are in that sub-folder so that the importer can find them... πŸ˜’
              markitekt
              RPS has a free tree maker that works pretty well too.
              http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
              Mark P.
                davesec
                hi!
                when i import a tree into sketchup each leaf seems to be bound in a box?
                  Antonio83
                  thank you all very much πŸ˜„
                  • shuraS
                    shura
                    Hello Dave,
                    you are right - and this is kind of a disadvantage...
                    ...although in rendering you will not see the edges, and of course you can switch off all edges and profiles in styles - but then the whole model would be without them.
                    afaik there is no easy way to hide all profiles and edges, but I might be just unknowing (hopefully, please someone point to the right method or plugin)
                    cheers
                    alex
                      Starling75
                      @shura said:
                      Hello Dave,
                      cheers
                      alex
                      You can organize your tree and put leaf edges on separate hidden layer - see attached example.
                      Select all leafs by material then deselect faces and put edges on separate layer ... or choose hide command ..
                      This plugin should be helpfull:
                      http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=109
                      Bo
                      tree_small.skp
                        Running CleanUp on the trees will reduce the number of faces used.
                        • W
                          wyatt
                          In case anyone is searching this thread later, I posted a tutorial here: Tree[d] to SketchUp Tutorial
                          • soloS
                            Speed tree anyone?
                            http://www.speedtree.com/ (watch the video)
                            (except the price is hairy, the export to FBX and conversion to SU is awesome as a great looking tree can end up as little as 3MB.)
                            Here is a quick test.
                            • GaieusG
                              Did you buy it, Pete? 😲
                              (If that's the trial, is it fully functional and savable?)
                              The price is not only "hairy" but the whole licensing is so weird and stupid that I cannot even understand what they mean.
                                I didn't even see a price on their site - it all said "contact us".
                                What about the mesh complexity?
                                • GaieusG
                                  On one of the pages there is a download link to a PDF file (what a stupid solution BTW). Different prices range between $6,000+ and $10,000+
                                    bwhaaaaah!
                                    • HieruH
                                      Hieru
                                      Apparently the educational licence is under $100.
                                      That just doesn't make sense to me.
                                      www.davidhier.co.uk
                                        When you consider ILM developers have given testimonials it must be a serious piece of kit. A game developers dream I suppose.
                                        • soloS
                                          Then there is always Vue trees, best used in Vue obviously.
                                          However for a low detailed SU version it's doable. (1.7MB)
