    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
      Mine of the day ๐Ÿ˜„
      When you create a component with glue property you must reload it from the menu Component ๐Ÿ˜ฎ
      The first one created on the screen don't want glue! ๐Ÿ˜ฎ
      (and I don't know why โ“ โ“ โ“
      • Wo3DanW Offline
        Wo3Dan
        .....The first one created on the screen don't want glue! ๐Ÿ˜ฎ
        But it does glue to, when created on a face!!!
        (If just on its own at time of creation, then the first one doesn't glue to. For there is nothing for it to glue to. Like copies of unglued instances, they don't glue to any face either.)
          Yes instance are gluing
          but create a component on a face is some annoying ๐Ÿ˜‰
          Component will have not face (background)! ๐Ÿ˜ฎ
            It glues to a face IF it's on a face when it's created.
            If it's made NOT on a face it's just the same as placing a cutting-component in empty space and then you wouldn't expect that to cut a face when you moved it onto it.
            A cutting-component sets its 'face' to what it's placed onto - if that's 'nil' then it's 'nil' !!!
            • plot-parisP Offline
              plot-paris
              a fairly new one:
              before thomthom's Solid Inspector came along, I never knew, whether an object was solid or not.
              I just discovered, that in the Entity Info window SketchUp puts a "solid" in front of the group's name to indicate, when an object is indeed solid... thats cool, isn't it?
              • jeff hammondJ Offline
                @plot-paris said:
                a fairly new one:
                fairly new indeed
                this wasn't possible prior to SU8..
                  About the perpendicular tool of Chris Fullmer (thx Jeff) โ˜€
                  Ahhhhhhhh! Never thought (or remembered)to click on the segment ๐Ÿ˜ฎ ๐Ÿ‘
                  That was not explicit due this alert message! ๐Ÿ’š
                  http://forums.sketchucation.com/download/file.php?id=55372
                  • brookefoxB Offline
                    brookefox
                    Label endpoints; by default you will be given the coordinates of same.
                    ~ Brooke
                    • TK0001T Offline
                      TK0001
                      The day I discovered SHIFT + pressing the scroll wheel = pan was a good day.
                        d12dozr
                        It might be a better day when you discover LMB + scroll wheel = Pan as well ๐Ÿ˜‰
                        http://goo.gl/f7ooYh
                        • TK0001T Offline
                          TK0001
                          I just tried it. Didn't work.
                          ETA: Whoops, yes it does.
                          This is the greatest day of my life.
                          • DavidBoulderD Offline
                            DavidBoulder
                            Just stumbled across this. Take a 10' cube, use the scale tool to vertically stretch the cube, and just type a distance. This become the new height for your selected object. You don't need to give it a positive or negative number to say home much smaller or bigger you want it. Just type the size you want it to be. If it happens to be smaller than the existing size, then it will get smaller. This seems more useful on a single axis stretch, but it also works when scaling x,y & z at the same time.
                            Don't know how many times I had to divide 10'6 3/4" by 9'3" to figure out the proper scale for something. Actually a long time ago I realized I can snap the stretch to a guide or other geometry so I typically drew a dummy line to snap to, but now I don't even need to do that.
                            (update), so I guess it was right there in the online help, but I haven't read that in 5 years
                            http://sketchup.google.com/support/bin/answer.py?hl=en&answer=94906
                            Other nice tidbits. you can type a negative distance to mirror the object, and if you do a non,uniform 2d or 3d scale, you can type multiple distances, to for example make whatever shape you have drawn, fit in a 20',30',50' bounding box.
                            David Goldwasser
                            OpenStudio Developer
                            National Renewable Energy Laboratory
                              @ DavidB
                              that works also for Move and Rotate ๐Ÿ˜‰
                                SketchUpNoobie
                                I used to think you had to click and drag whenever you push/pull, move, rectangle, circle, etc. I just found out a couple of months ago that you could just click, get it where you want it, and click again to finish. I was like, "Oh." ๐Ÿ˜ณ
                                SketchUpNoobie: the complete noob in all things SketchUp.
                                  And double-clicking will repeat last operation.
                                    SketchUpNoobie
                                    I know that. ๐Ÿ˜‰ Dunno' when I figured it out though. Probably while watching a tutorial or something. That's why I like watching tutorials even if they are on things I already know.
                                      Roger
                                      It seems that my Duh! moment was taking this long to find this discussion. I have always felt I was the lone idiot, but now I feel much better and much more informed.
                                      Thanks DUHsters.
                                      http://www.azcreative.com
                                      • Chris FullmerC Offline
                                        That is the point of the thread - we all feel like the lone idiot...until you post your stupidity publicly and find that many many other people had done, or are doing, the exact same thing. It's very cathartic ๐Ÿ˜„
                                        • david_hD Offline
                                          david_h
                                          Idiots are never alone.
                                          They travel in herds. . . .most frequently seen on the great American Freeway system.
                                            You should suffer fools gladly... one day you will be one of them!
                                            I once invented my great new tool for the context-menu that would select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
                                            • 34
                                            • 35
                                            • 8 / 35
