    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • jeff hammondJ
      @spookychick1013 said:
      I guess I'm a bit dense, but perpendicular in what way? No sarcasm, I just don't exactly understand what you mean.
      it's not that they need to be vertical per se but the profile splines should be parallel to get your desired results.. it's just something i noticed with curviloft and the orthogonal settings.. (fwiw, in rhino, the profiles can be tilted like you have them and the lofted surface remains straight on the bottom/top_
      the red lines are perpendicular.. so are the splines created with curviloft/orthogonal
      Whatever changes you made to the profile curves certainly worked out well, and I most certainlydont mind in the slightest. Although, so I can learn from this, what changes did you make and how did you do it?
      i redrew all the profiles using fredo's BezierSpline plugin.. it makes a smoother curve and evens out the segmentation..
      here's a video showing the whole process.. i did this on a laptop using the trackpad so i apologize about the jumpy navigation etc..
      [flash=660,405:3u6imqlr]http://www.youtube.com/v/Ai8ggH9NfIs?fs=1&hl=en_US&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:3u6imqlr]
      [also - i copy/pasted your lines into my own template.. i noticed with yours that they are drawn upside down.. the solid blue axis line should be pointing up instead of down.. if you turn on sky or ground, you'll see what i'm saying + the navigation is weird (for me) in your file]
      • O
        olbapxpablo
        curviloft is not working for me.
        other plug-ins works fine except this one
        is there anyone can help?
          Can you be more specific please?
          No menus/toolbars?
          Error messages?
          Unexpected results?
            SpookyChick1013
            Ooooohhh-k...Now I get it. Still having my morning coffee, so it took a moment to get it. Thanks, now I understand what you meant.
            Downloading that plugin today! Looks like more options and less of a PITA than the native bezier stuff.
            Excellent! Thank you for the tutorial and the time you spent on this.
            %(#0000BF)[OOOOOps! um, yeah...There was a reason I set it up like that. I was aware of that, but I just forgot to put it back the normal way way before copying the file. I guess I need to take better process notes as I'm working, and reread them occasionally. My apologies for that, Jeff; and also you Fredo, if you have taken a look at this model.
            Anyway, once again, thanks very much for your time and effort explaining things and helping me on this Jeff. It is greatly appreciated. 😄]
            https://kuromatsudriveyards.com
            Fo-su to tomo ni aran koto o...
            • O
              olbapxpablo
              No menus/toolbars?
              Error messages?
              Unexpected results?
              thanks sir
              theres menu and i can do the steps but theres no result or looks like nothing happen still on its original form
              and sometimes after i click on the shape 1,2 & 3 then click outside or anywhere to finalize the steps my SU8 turn to notresponding state
                @charly2008 said:
                Hi Thomas,
                i welded each line and below the result in Sketchup 8.
                Charly
                I just tried to weld - and I could not get it working.
                • charly2008C
                  charly2008
                  Hi Thomas,
                  I tried it again (Without welding). Select the lines, each with double click and activate Curviloft. If the lines have changed the color, select the lines again and re-enable Curviloft. Then it works. I don't know why. Maybe Fredo can answer the question.
                  Charly
                    aaaaah!
                    I so very nearly had it there. selecting the curves and extra time so it said 3 and 4 made it computer - but as it generated I got a BugSplat.
                    Would you mind upload the mesh you got from that loft? I really need that patch.
                    • charly2008C
                      charly2008
                      Here is the mesh
                      CurviError1skp.skp
                        cheers!
                        • B
                          blair
                          Is there a way to make a contribution to Fredo through PayPAL or something?
                            @blair said:
                            Is there a way to make a contribution to Fredo through PayPal or something?
                            Of course!
                            ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
                            • E
                              Efrado
                              Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
                              what am i doing wrong?
                              • Y
                                yokaxi
                                thanks
                                • charly2008C
                                  charly2008
                                  Hello community,
                                  please show your ideas, everything what you can do with Curviloft.
                                  Charly
                                    SUFractal
                                    WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                                      Window > Preferences > Extensions... activate it! 😉
                                        robert111
                                        charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                                        thanks charly
                                        • charly2008C
                                          charly2008
                                          Hi Robert,
                                          the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                                          Charly
                                          Curviloft99.skp
                                            robert111
                                            thanks charly , and for the seconde image ( black one) ??????
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 65
                                            • 66
                                            • 18 / 66
