    1.3k Posts 299 Posters 2.9m Views 297 Watching
      SpookyChick1013
      hey spooky,
      if your loft lines were vertical then ortho would do what you're asking it to..
      %(#0000BF)[Thanks, I actually was unaware that that can make a difference. I definitely will be keeping it in mind for the future, although my question to Fredo about this still stands, because either the program was operating wrong before, and started working the way it's supposed to, or it originally was working right and something went wrong. Either way, it seems odd that a plugin would change behavior midsession like that. Then again, I do have a talent for breaking things, so who knows..... 😕]
      as it is, the splines are perpendicular to your profiles..
      I guess I'm a bit dense, but perpendicular in what way? No sarcasm, I just don't exactly understand what you mean.
      curviloft lets you make global adjustments to the segments etc (in the main curviloft display) as well as individual sections (while in edit mode, click in one of the sections which will highlight yellow then adjust segmentation in there)..
      Right. That I was aware of. One of the many things I love about Curviloft.
      that aside, i think you'd be better off using a different approach as you'll see in pics 3&4 + in the attached skp
      [attachment=4:obxht400]<!-- ia4 -->1.jpg<!-- ia4 -->[/attachment:obxht400]
      [attachment=3:obxht400]<!-- ia3 -->2.jpg<!-- ia3 -->[/attachment:obxht400]
      [attachment=2:obxht400]<!-- ia2 -->3.jpg<!-- ia2 -->[/attachment:obxht400]
      [attachment=1:obxht400]<!-- ia1 -->4.jpg<!-- ia1 -->[/attachment:obxht400]
      [attachment=0:obxht400]<!-- ia0 -->handle.skp<!-- ia0 -->[/attachment:obxht400]
      i hope this makes enough sense.. i posted this with a 1am vino filter 😄
      No worries about the vino filter Jeff. You're speaking clearly enough, and 1 am is the perfect time for that... The model you sent back looks great. I had not even considered using the skinning function as you did. I definitely should have tried that. Whatever changes you made to the profile curves certainly worked out well, and I most certainlydont mind in the slightest. Although, so I can learn from this, what changes did you make and how did you do it?
      https://kuromatsudriveyards.com
      Fo-su to tomo ni aran koto o...
      • jeff hammondJ Offline
        it's not that they need to be vertical per se but the profile splines should be parallel to get your desired results.. it's just something i noticed with curviloft and the orthogonal settings.. (fwiw, in rhino, the profiles can be tilted like you have them and the lofted surface remains straight on the bottom/top_
        the red lines are perpendicular.. so are the splines created with curviloft/orthogonal
        i redrew all the profiles using fredo's BezierSpline plugin.. it makes a smoother curve and evens out the segmentation..
        here's a video showing the whole process.. i did this on a laptop using the trackpad so i apologize about the jumpy navigation etc..
        [flash=660,405:3u6imqlr]http://www.youtube.com/v/Ai8ggH9NfIs?fs=1&amp;hl=en_US&amp;color1=0x2b405b&amp;color2=0x6b8ab6&amp;border=1[/flash:3u6imqlr]
        [also - i copy/pasted your lines into my own template.. i noticed with yours that they are drawn upside down.. the solid blue axis line should be pointing up instead of down.. if you turn on sky or ground, you'll see what i'm saying + the navigation is weird (for me) in your file]
        • O Offline
          olbapxpablo
          curviloft is not working for me.
          other plug-ins works fine except this one
          is there anyone can help?
            Can you be more specific please?
            No menus/toolbars?
            Error messages?
            Unexpected results?
              SpookyChick1013
              Ooooohhh-k...Now I get it. Still having my morning coffee, so it took a moment to get it. Thanks, now I understand what you meant.
              Downloading that plugin today! Looks like more options and less of a PITA than the native bezier stuff.
              Excellent! Thank you for the tutorial and the time you spent on this.
              %(#0000BF)[OOOOOps! um, yeah...There was a reason I set it up like that. I was aware of that, but I just forgot to put it back the normal way way before copying the file. I guess I need to take better process notes as I'm working, and reread them occasionally. My apologies for that, Jeff; and also you Fredo, if you have taken a look at this model.
              Anyway, once again, thanks very much for your time and effort explaining things and helping me on this Jeff. It is greatly appreciated. 😄]
              • O Offline
                olbapxpablo
                No menus/toolbars?
                Error messages?
                Unexpected results?
                thanks sir
                theres menu and i can do the steps but theres no result or looks like nothing happen still on its original form
                and sometimes after i click on the shape 1,2 & 3 then click outside or anywhere to finalize the steps my SU8 turn to notresponding state
                  @charly2008 said:
                  Hi Thomas,
                  i welded each line and below the result in Sketchup 8.
                  Charly
                  I just tried to weld - and I could not get it working.
                  • charly2008C Offline
                    charly2008
                    Hi Thomas,
                    I tried it again (Without welding). Select the lines, each with double click and activate Curviloft. If the lines have changed the color, select the lines again and re-enable Curviloft. Then it works. I don't know why. Maybe Fredo can answer the question.
                    Charly
                      aaaaah!
                      I so very nearly had it there. selecting the curves and extra time so it said 3 and 4 made it computer - but as it generated I got a BugSplat.
                      Would you mind upload the mesh you got from that loft? I really need that patch.
                        charly2008
                        Here is the mesh
                        CurviError1skp.skp
                          cheers!
                            blair
                            Is there a way to make a contribution to Fredo through PayPAL or something?
                              @blair said:
                              Is there a way to make a contribution to Fredo through PayPal or something?
                              Of course!
                              ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
                              • E Offline
                                Efrado
                                Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
                                what am i doing wrong?
                                • Y Offline
                                  yokaxi
                                  thanks
                                    charly2008
                                    Hello community,
                                    please show your ideas, everything what you can do with Curviloft.
                                    Charly
                                      SUFractal
                                      WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                                        Window > Preferences > Extensions... activate it! 😉
                                          robert111
                                          charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                                          thanks charly
                                            charly2008
                                            Hi Robert,
                                            the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                                            Charly
                                            Curviloft99.skp
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 65
                                            • 66
                                            • 18 / 66
