    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • Chris FullmerC Offline
      Hey TIG, thanks for looking into it. I am without a computer at home for now, so I'm mostly useless. But what was the problem you found? I was able to load shape bender just fine without having any of my other plugins loaded. Did I mess something up in my overly complicated menu system?
        Wait till you get a proper link in to check what's up... I think it's the way that some of your scripts check if a Plugin is loaded already... I moved the confirmations in that file so each of them is immediately after its the first-run check and its seems to work OK then...
        You have over-complicated your menu checking somewhat.... but - hey 😎 -join-the-club πŸ˜„
        It seems to depend on which of your scripts a user has loading... and of course it shouldn't πŸ˜’
        It's probably an easy fix BUT it probably affects several of your scripts 😞
        • mariochaM Offline
          mariocha
          Huh ....
          The shape in the attached file makes Shape Bender crash SU.
          I tried it several times.
          (The line I want to use is hard to see, on the red axis)
          branch-o.skp
          %(#008000)[Mario C.
            Bug Splat for me, too. Even after I moved the straight line so it lies on the red axis. It works with a simple long, skinny box. Perhaps there's too much geometry in the branch?
            • jeff hammondJ Offline
              (mac)
              works in SU7.. crashes with 8
                d12dozr
                Worked fine for me, the only thing I did was move the branch up a few inches so I could see the horizontal line. I didn't get the green preview wires like I usually do though.
                File is attached.
                branch-o.skp
                http://goo.gl/f7ooYh
                • mariochaM Offline
                  mariocha
                  Great ! Good idea.
                  I will try it in v7.
                  thx a lot.
                  I guess a small update of the plugin will be needed. πŸ˜„
                  %(#008000)[Mario C.
                  • jim smithJ Offline
                    jim smith
                    I haven't run through all the thread since 8 came on the scene, but it doen't work on my laptop with 8. V7.1, it works just fine. Attached is a screen shot of a simple bend, it seems to start and then stalls at 5%. On my V7.1, it bends in a few seconds. I don't get any error message box on startup or when I start the shape bender.
                    "Out of clutter find simplicity,
                    from discord find harmony,
                    In the middle of difficulty lies opportunity"
                    Albert Einstein
                      Looks like I need to poke aroud in this plugin again to get it v8 compatible. I'll see what I can do.
                      • gullfoG Offline
                        gullfo
                        it's working OK for me on SU8 (on fairly complex shapes), but previously on SU7 i had a similar problem and i cleaned things up and removed a number of older plugins and then everything worked OK. i suggest checking to see if you can identify a plugin which may be problematic.
                        Glenn
                        http://www.runnel.com
                        • mariochaM Offline
                          mariocha
                          Hum... I will check.
                          In fact yes, on other shapes it worked ok in 8.
                          Won't be easy to find a non-constant problem.
                          %(#008000)[Mario C.
                            cheriyan
                            Thanks for this plugins
                            • gullfoG Offline
                              gullfo
                              @jasper.middelberg said:
                              yet I discovered that bending will stretch the boards...
                              does anybody know how this can be solved digitally?
                              i usually pre-calculate the length of the target shape. e.g. if i have a 4' length and need to bend it in a arc, i figure out the length of the arc so the bent object is the correct length.
                              it might be simpler to use extrude tools to make the outline of the shape and extrude it. or maybe vertex tools could manipulate the grid correctly...
                              Glenn
                                πŸ‘ +1 Measure the line you are bending to first, and make you straight line the exact same length. (this is all funcionality I have planned to add to the next version of this tool if I ever get around to making it). Then make your board the exactly same length also. Then there should be no stretching.
                                  jasper.middelberg
                                  Hello,
                                  perhaps a shot in the dark, hopefully a suggestion or otherwise a cue for anybody that can point me in a good direction to work with this:
                                  An experiment, using standard plywood boards, bolted together.
                                  the idea is that if bending plywood, the structural capacity of the plywood becomes higher,
                                  thus, being able to make a light weight skin roof that can support itself.
                                  Now, my quest is how to bolt a bunch of plywood boards together to form a sort of
                                  conics tipi roof.
                                  I hoped Shapebender would get me there,
                                  draw up a grid of plywood boards and being able to bend them in a desired shape,
                                  in order to find out:
                                  • optimum plywood pattern
                                  • where to make the bolt holes
                                  • where the cutlines would be for top and bottom of the roof
                                  possible workflow:
                                  • to bend the plywood boards around a surface,
                                  • then to be able to make markings on the different boards,
                                  • then to unbend
                                  • and have straight boards again for scaled drawings for:
                                    cut patterns and bolting positions
                                  yet I discovered that Shapebender will stretch the boards...
                                  does anybody know how this can be solved?
                                  the idea of bending plywood I found at
                                  http://conicshelter.com/
                                  thank you,
                                  Jasper
                                  below image
                                  left back: started testing bending boards,
                                  front: a preferred conic shape:
                                    jasper.middelberg
                                    Thank you Chris and Gullfo,
                                    yet, starting point is the standard size of the plywood
                                    and not having to make cuts before hand.
                                    Making use of standard sized plywood,
                                    bend it onto a desired shape,
                                    with an overlap, to be able to determine the boltpositions
                                    and finally know the cutpatterns for top & bottom
                                    I really don't know how this can be modeled in a way it is easy to experiment.
                                    in Sketchup or any 3d software.
                                    yet I guess this workflow might be a bit too much to ask from your plugin,
                                    anyway, I really appreciate your work,
                                    thanks again,
                                    Jasper
                                      Jasper, I've been having a think about how to draw a curve of known length to make the path for Shape Bender. It occurred to me that one could draw a straight line of known length and then use the Radial Bend function of Fredo's FredoScale extension to bend it as desired. You can make irregular curves with it, too. If the line you are bending is a copy of one that you leave straight, you then end up with both of the lines required for Shape Bender.
                                      Of course you could also use Radial Bend to bend the 'plywood' panel. In some cases, though, it might be easier to work on a single line and get it bent as desired and use shape Bender to do the final bend.
                                      • O Offline
                                        oscarfalcon
                                        Hello, I'm new to this forum. I've been using SU for over two years now and really like how it works, specially with all the plug-ins and scripts there are for making things awesome with it.
                                        I have one problem though, I downloaded the shape bender script and the progressbar.rb file but SU7 doesn't seem to recognize them, any help here would be great. I'm using a mac as of today, I placed the files in the plug-ins folder and can't seem to find them in sketch up.
                                        Cheers, wonderful SU community.
                                        OFL
                                          Oscar, go to Window>Preferences>Extensions and tick the box for Shape Bender. Then go to View>Toolbars and select Shape Bender.
                                            mac1
                                            thanks again,
                                            Jasper
                                            Reality vs Virtual Reality?
                                            Having dealt with some issues with graphic epoxy structures some questions come to mind:
                                            1. What is the max thickness can you bend;
                                            2. What plans are in work to establish knock down factors for bolt holes and when / how will structural allowables be establish and how. (Building and say it does not fall down is not acceptable);
                                            3. Plywood by spec has voids so what plans are in place to insure stress risers can be mitigated. Ultra sound is used some times and since the strength is so much processed controlled vs metal what would be done to insure each panel meets some type of spec. I would guess some plywood that is made from radial sheared layers would be very different. Some same questions about the adhesive interface stress, heat and cold flow.
                                            4. How does one handle the changes in allowables with moisture content;
                                              You have a big hill to climb to get this concept accepted for general use. And then comes the question of analysis capability especially for stress. Have not done any search for plywood to see if any has well established allowables but with its use would hope so.
                                              10/1 23:57 update Note: Did a quick search for plywood allowable stress. One of the returns was a APA plywood spec. One item would have immediate application to your effort. That is the min bend radius for various thickness and they have differnt for the cross grain ( 4 ft) and with grain ( 8 ft) evn for small thickness like 5/32 the numbers are big. ~ 3ft for cross and 8 ft with πŸ‘Ώ
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 63
                                            • 64
                                            • 54 / 64
