    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
    • charly2008C Offline
      charly2008
      Hi Chris, hi TIG,
      I have only just come home. Here's the result:
        So it's returning nil because you don't have RickW's Smustard menu added - OK and shouldn't cause aprobelm...
        You do have the clf's tools menu loaded - Good.
        BUT you don't have clf's youtube menu loading... Strange...
        This could be the problem - it loads from clf's component_stringer / camera_recorder / shape_bender / voodoo_importer
        Try checking you have those...
        Chris ❓
          charly2008
          I'm a little bit confused. That are all the Plugins i have in a PDF-File.
          Charly
          DirPrintOK Document 8 Seite(n).pdf
            So... Chris's tools fall over because one of them hasn't already loaded 'some other menu' when it thinks it has...
            Here's a [possible] simple fix... put it into the correct sub-folder...
            clf_shape_bender.rb
            Chris can sort it 'properly' later... 😒
              charly2008
              Many thanks TIG. I tried the Shape Bender plugin in SketchUp 8 there it works fine. and now with your update it works again in Sketchup 7.
              Charly
              • Chris FullmerC Offline
                Hey TIG, thanks for looking into it. I am without a computer at home for now, so I'm mostly useless. But what was the problem you found? I was able to load shape bender just fine without having any of my other plugins loaded. Did I mess something up in my overly complicated menu system?
                  Wait till you get a proper link in to check what's up... I think it's the way that some of your scripts check if a Plugin is loaded already... I moved the confirmations in that file so each of them is immediately after its the first-run check and its seems to work OK then...
                  You have over-complicated your menu checking somewhat.... but - hey 😎 -join-the-club 😄
                  It seems to depend on which of your scripts a user has loading... and of course it shouldn't 😒
                  It's probably an easy fix BUT it probably affects several of your scripts 😞
                  • mariochaM Offline
                    mariocha
                    Huh ....
                    The shape in the attached file makes Shape Bender crash SU.
                    I tried it several times.
                    (The line I want to use is hard to see, on the red axis)
                    branch-o.skp
                    %(#008000)[Mario C.
                      Bug Splat for me, too. Even after I moved the straight line so it lies on the red axis. It works with a simple long, skinny box. Perhaps there's too much geometry in the branch?
                      • jeff hammondJ Offline
                        (mac)
                        works in SU7.. crashes with 8
                          d12dozr
                          Worked fine for me, the only thing I did was move the branch up a few inches so I could see the horizontal line. I didn't get the green preview wires like I usually do though.
                          File is attached.
                          branch-o.skp
                          http://goo.gl/f7ooYh
                          • mariochaM Offline
                            mariocha
                            Great ! Good idea.
                            I will try it in v7.
                            thx a lot.
                            I guess a small update of the plugin will be needed. 😄
                            %(#008000)[Mario C.
                            • jim smithJ Offline
                              jim smith
                              I haven't run through all the thread since 8 came on the scene, but it doen't work on my laptop with 8. V7.1, it works just fine. Attached is a screen shot of a simple bend, it seems to start and then stalls at 5%. On my V7.1, it bends in a few seconds. I don't get any error message box on startup or when I start the shape bender.
                              "Out of clutter find simplicity,
                              from discord find harmony,
                              In the middle of difficulty lies opportunity"
                              Albert Einstein
                                Looks like I need to poke aroud in this plugin again to get it v8 compatible. I'll see what I can do.
                                • gullfoG Offline
                                  gullfo
                                  it's working OK for me on SU8 (on fairly complex shapes), but previously on SU7 i had a similar problem and i cleaned things up and removed a number of older plugins and then everything worked OK. i suggest checking to see if you can identify a plugin which may be problematic.
                                  Glenn
                                  http://www.runnel.com
                                  • mariochaM Offline
                                    mariocha
                                    Hum... I will check.
                                    In fact yes, on other shapes it worked ok in 8.
                                    Won't be easy to find a non-constant problem.
                                    %(#008000)[Mario C.
                                      cheriyan
                                      Thanks for this plugins
                                      • gullfoG Offline
                                        gullfo
                                        @jasper.middelberg said:
                                        yet I discovered that bending will stretch the boards...
                                        does anybody know how this can be solved digitally?
                                        i usually pre-calculate the length of the target shape. e.g. if i have a 4' length and need to bend it in a arc, i figure out the length of the arc so the bent object is the correct length.
                                        it might be simpler to use extrude tools to make the outline of the shape and extrude it. or maybe vertex tools could manipulate the grid correctly...
                                        Glenn
                                          👍 +1 Measure the line you are bending to first, and make you straight line the exact same length. (this is all funcionality I have planned to add to the next version of this tool if I ever get around to making it). Then make your board the exactly same length also. Then there should be no stretching.
                                            jasper.middelberg
                                            Hello,
                                            perhaps a shot in the dark, hopefully a suggestion or otherwise a cue for anybody that can point me in a good direction to work with this:
                                            An experiment, using standard plywood boards, bolted together.
                                            the idea is that if bending plywood, the structural capacity of the plywood becomes higher,
                                            thus, being able to make a light weight skin roof that can support itself.
                                            Now, my quest is how to bolt a bunch of plywood boards together to form a sort of
                                            conics tipi roof.
                                            I hoped Shapebender would get me there,
                                            draw up a grid of plywood boards and being able to bend them in a desired shape,
                                            in order to find out:
                                            • optimum plywood pattern
                                            • where to make the bolt holes
                                            • where the cutlines would be for top and bottom of the roof
                                            possible workflow:
                                            • to bend the plywood boards around a surface,
                                            • then to be able to make markings on the different boards,
                                            • then to unbend
                                            • and have straight boards again for scaled drawings for:
                                              cut patterns and bolting positions
                                            yet I discovered that Shapebender will stretch the boards...
                                            does anybody know how this can be solved?
                                            the idea of bending plywood I found at
                                            http://conicshelter.com/
                                            thank you,
                                            Jasper
                                            below image
                                            left back: started testing bending boards,
                                            front: a preferred conic shape:
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 63
                                            • 64
                                            • 29 / 64
