    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
    • P
      Plasticbricks
      Hi guys,
      I've installed the SketchyFFD plugin by dropping it into my plugins folder but cannot locate it in SU. How do I access it/ turn it on?
      Thanks.
      • massimoM
        massimo Moderator
        Hi and welcome 😄 . You will find FFD in the context menu (right click). Oh, and remember that this plugin works on grouped geometry.
          markbowen
          Hiya,
          Sorry for effectively bumping this post for everyone again but I'm having a real problem getting this plugin to work so was wondering if someone could possibly help?
          I tried by creating a simple cube, grouping everything and then running the FFD 2x2 on it. I see the point grid appear but then I'm not too sure what to do. I can't select points easily and when I do all that happens is that the points move but the object doesn't change in any way at all, just the points move 😞
          Has anyone ever seen that before and knows what might be causing this?
          Many thanks for any help on this.
          Best wishes,
          Mark
          • soloS
            mark
            Once you have made the cube a group, right click and select the FFD you want, then click on one of the small black crosses to edit the form. Now you can move, scale, rotate one or multiple crosses to deform the shape.
            When completed close group and delete FFD transformer group.
            • soloS
              Here is a video of what I mean.
              http://dl.dropbox.com/u/1129899/ffd.avi
                markbowen
                Thanks. I've finally got the mesh working although sometimes it doesn't always do anything. Probably me being silly or something though.
                Off to give some of that a try now.
                Many thanks for the help on this.
                Best wishes,
                Mark
                • K
                  Kman
                  Great! A little confusing, but great!
                  When life gives you lemons, take them. Because hey... free lemons.
                    daedaluz
                    Cool! It is very useful and amazing tool. Thanks!
                    • C
                      chouaibcl65
                      thank you
                        jeabdc
                        ThankYou for your Plugins.
                        ขอบคุณมากครับ(Thailand is Smile Land)
                        • C
                          chobs
                          Hi to all. Having a problem when I make an FFD Patch.
                          Here's the message:
                          Error: #<ArgumentError: wrong number of arguments(2 for 3)>
                          C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in startFFD' C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in init'
                          C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:83:in `call'
                            Ands43
                            Hi guys, thanks for making this plugin!! I'm new to SKP plugins but experienced enough with sketchup.
                            I have had a quick play with this tool, first on a cube it appeared to do nothing, then on a dome and it worked.
                            Could people explain, where and when this tool would best be used? I'm currently think for floors, but then we already have sandbox.
                            Thanks for your advice.
                            • B
                              bentleykfrog
                              excellent plugin! this combined with soapskinbubble and the sandbox make life in sketchup so much easier
                                Davi Melo
                                This plugin is not working in Sketchup 8
                                Davi Melo
                                http://dm2projetos.blogspot.com/
                                SKP8 - Vray 1.48
                                WIN 7 ULTIMATE 64x
                                INTEL CORE 2 QUAD 2.33GHz
                                RAM 8GB
                                NVIDIA GEFORCE 9600 GT
                                  Are you getting errors?
                                    Try this...
                                    404 Not Found
                                    (forums.sketchucation.com)
                                    It works for me on v8
                                      Davi Melo
                                      Sorry, yesterday was not working, but today it is! 😳 👎
                                      Davi Melo
                                      SKP8 - Vray 1.48
                                      WIN 7 ULTIMATE 64x
                                      RAM 8GB
                                        Davi Melo
                                        Try this...
                                        viewtopic.php?t=25801
                                        I downloaded this file
                                        hmmmmm...
                                        Stopped working again
                                        I do not understand, it works when it want!
                                        Davi Melo
                                        SKP8 - Vray 1.48
                                        WIN 7 ULTIMATE 64x
                                        RAM 8GB
                                          Works fine for me?
                                          [flash=800,600:2vx1cdem]http://www.youtube.com/v/HMWLepzpwds[/flash:2vx1cdem]
                                            Davi Melo
                                            I do not understand, sometimes works, sometimes does not work
                                            Davi Melo
                                            SKP8 - Vray 1.48
                                            WIN 7 ULTIMATE 64x
                                            RAM 8GB
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 20
                                            • 21
                                            • 13 / 21
