    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.8k Views 153 Watching
      jeabdc
      ThankYou for your Plugins.
      ขอบคุณมากครับ(Thailand is Smile Land)
      • C
        chobs
        Hi to all. Having a problem when I make an FFD Patch.
        Here's the message:
        Error: #<ArgumentError: wrong number of arguments(2 for 3)>
        C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in startFFD' C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in init'
        C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:83:in `call'
          Ands43
          Hi guys, thanks for making this plugin!! I'm new to SKP plugins but experienced enough with sketchup.
          I have had a quick play with this tool, first on a cube it appeared to do nothing, then on a dome and it worked.
          Could people explain, where and when this tool would best be used? I'm currently think for floors, but then we already have sandbox.
          Thanks for your advice.
          • B
            bentleykfrog
            excellent plugin! this combined with soapskinbubble and the sandbox make life in sketchup so much easier
              Davi Melo
              This plugin is not working in Sketchup 8
              Davi Melo
              http://dm2projetos.blogspot.com/
              SKP8 - Vray 1.48
              WIN 7 ULTIMATE 64x
              INTEL CORE 2 QUAD 2.33GHz
              RAM 8GB
              NVIDIA GEFORCE 9600 GT
                Are you getting errors?
                  Try this...
                  404 Not Found
                  (forums.sketchucation.com)
                  It works for me on v8
                    Davi Melo
                    Sorry, yesterday was not working, but today it is! 😳 👎
                    Davi Melo
                    SKP8 - Vray 1.48
                    WIN 7 ULTIMATE 64x
                    RAM 8GB
                      Davi Melo
                      Try this...
                      viewtopic.php?t=25801
                      I downloaded this file
                      hmmmmm...
                      Stopped working again
                      I do not understand, it works when it want!
                      Davi Melo
                      SKP8 - Vray 1.48
                      WIN 7 ULTIMATE 64x
                      RAM 8GB
                        Works fine for me?
                        [flash=800,600:2vx1cdem]http://www.youtube.com/v/HMWLepzpwds[/flash:2vx1cdem]
                          Davi Melo
                          I do not understand, sometimes works, sometimes does not work
                          Davi Melo
                          SKP8 - Vray 1.48
                          WIN 7 ULTIMATE 64x
                          RAM 8GB
                            andeciuala
                            Works fine for me?
                            [flash=800,600:1qd2nqzo]http://www.youtube.com/v/HMWLepzpwds[/flash:1qd2nqzo]
                            You need a subdivided mesh man.
                              Not neccessarily. On undivided meshes it works like the standard move tool shifting vertices. Or if you divide an edge it'll also work.
                              It's a cool plugin but I understand what you mean. It works best on subdivision.
                              • P
                                pairpc
                                Thank you 😄
                                  Here is an updated version http://forums.sketchucation.com/viewtopic.php?p=36127#p36127
                                  Some issues with it not being in a module, use of $ variables and a flaky observer have been fixed [I hope]... 🤓
                                    sosegon
                                    I'd like to know if anyone has information about the algorithm used in this plugin.
                                    Cheers.
                                      @sosegon said:
                                      Hi, I'd like to know if anyone has information about the algorithm used in this plugin. Cheers.
                                      Get it and read it - it's a .rb file...
                                        sosegon
                                        @tig said:
                                        Get it and read it - it a .rb file...
                                        Thanks, I tried that, but since I don't speak ruby, it's been very hard to understand what the plugin is doing. That's why I asked for info about the algorithm used in the plugin. I don't necessarily need a piece of code, a brief explanation would be enough.
                                          You make a series of grouped 'control-points' [guide-points] in a 3d grid around the selected group's bounding box, these are given special attributes so they can be 'observed' later.
                                          Now later on when you change any of them [e.g. you might edit the group that contains them and 'move' some] an 'observer' kicks in, and it runs code that adjusts the geometry within the group by distorting all of the vertices relative to the 'control-points' current locations. Thus you can distort a grouped form by changing the 3d grid of 'control-points'.
                                          The rules for determining the amount of the adjustment for each vertex is done by finding the changes in the vectors between the vertices and the 'control-points' and transforming each of the vertices accordingly...
                                            sosegon
                                            That part is the most important for what I need. Now I have a better idea, thanks. If you have any link to other resources about the algorithm, it would be great.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 20
                                            • 21
                                            • 14 / 21
