    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
      @gbabcock said:
      OK, here's the latest update. This one should fix the problems with control points and subdividing being misaligned with the deformation group.
      I'd appreciate any feedback to let me know if it's working well.
      Glenn
      Maybe better to create a new thread - so the download is at the start of the thread - not buried somewhere randomly in between. If you do that I'll tab this one obsolete and add a link to the new version.
      • P
        Plasticbricks
        Hi guys,
        I've installed the SketchyFFD plugin by dropping it into my plugins folder but cannot locate it in SU. How do I access it/ turn it on?
        Thanks.
        • massimoM
          massimo Moderator
          Hi and welcome πŸ˜„ . You will find FFD in the context menu (right click). Oh, and remember that this plugin works on grouped geometry.
            markbowen
            Hiya,
            Sorry for effectively bumping this post for everyone again but I'm having a real problem getting this plugin to work so was wondering if someone could possibly help?
            I tried by creating a simple cube, grouping everything and then running the FFD 2x2 on it. I see the point grid appear but then I'm not too sure what to do. I can't select points easily and when I do all that happens is that the points move but the object doesn't change in any way at all, just the points move 😞
            Has anyone ever seen that before and knows what might be causing this?
            Many thanks for any help on this.
            Best wishes,
            Mark
            • soloS
              mark
              Once you have made the cube a group, right click and select the FFD you want, then click on one of the small black crosses to edit the form. Now you can move, scale, rotate one or multiple crosses to deform the shape.
              When completed close group and delete FFD transformer group.
              • soloS
                Here is a video of what I mean.
                http://dl.dropbox.com/u/1129899/ffd.avi
                  markbowen
                  Thanks. I've finally got the mesh working although sometimes it doesn't always do anything. Probably me being silly or something though.
                  Off to give some of that a try now.
                  Many thanks for the help on this.
                  Best wishes,
                  Mark
                  • K
                    Kman
                    Great! A little confusing, but great!
                    When life gives you lemons, take them. Because hey... free lemons.
                      daedaluz
                      Cool! It is very useful and amazing tool. Thanks!
                      • C
                        chouaibcl65
                        thank you
                          jeabdc
                          ThankYou for your Plugins.
                          ΰΈ‚ΰΈ­ΰΈšΰΈ„ΰΈΈΰΈ“ΰΈ‘ΰΈ²ΰΈΰΈ„ΰΈ£ΰΈ±ΰΈš(Thailand is Smile Land)
                          • C
                            chobs
                            Hi to all. Having a problem when I make an FFD Patch.
                            Here's the message:
                            Error: #<ArgumentError: wrong number of arguments(2 for 3)>
                            C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in startFFD' C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:106:in init'
                            C:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:83:in `call'
                              Ands43
                              Hi guys, thanks for making this plugin!! I'm new to SKP plugins but experienced enough with sketchup.
                              I have had a quick play with this tool, first on a cube it appeared to do nothing, then on a dome and it worked.
                              Could people explain, where and when this tool would best be used? I'm currently think for floors, but then we already have sandbox.
                              Thanks for your advice.
                              • B
                                bentleykfrog
                                excellent plugin! this combined with soapskinbubble and the sandbox make life in sketchup so much easier
                                  Davi Melo
                                  This plugin is not working in Sketchup 8
                                  Davi Melo
                                  http://dm2projetos.blogspot.com/
                                  SKP8 - Vray 1.48
                                  WIN 7 ULTIMATE 64x
                                  INTEL CORE 2 QUAD 2.33GHz
                                  RAM 8GB
                                  NVIDIA GEFORCE 9600 GT
                                    Are you getting errors?
                                      Try this...
                                      404 Not Found
                                      (forums.sketchucation.com)
                                      It works for me on v8
                                        Davi Melo
                                        Sorry, yesterday was not working, but today it is! 😳 πŸ‘Ž
                                        Davi Melo
                                        SKP8 - Vray 1.48
                                        WIN 7 ULTIMATE 64x
                                        RAM 8GB
                                          Davi Melo
                                          Try this...
                                          viewtopic.php?t=25801
                                          I downloaded this file
                                          hmmmmm...
                                          Stopped working again
                                          I do not understand, it works when it want!
                                          Davi Melo
                                          SKP8 - Vray 1.48
                                          WIN 7 ULTIMATE 64x
                                          RAM 8GB
                                            Works fine for me?
                                            [flash=800,600:2vx1cdem]http://www.youtube.com/v/HMWLepzpwds[/flash:2vx1cdem]
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 20
                                            • 21
                                            • 13 / 21
