    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Are the edges Smooth by any chance?
      • brookefoxB Offline
        brookefox
        Well, obviously, I mean, well, er....
        I thought I had checked that but obviously my methodology was seriously flawed.
        Thanks, t.
        ~ Brooke
          Cris999
          Hello
          Is there another place to download this plugin?
          I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
          Thank You, Cris999
            The 2.1c zip is fine I just re-downloaded it to test... Try again.
              Cris999
              I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
              Thank You
              • fredo6F Offline
                Thank You
                Which unzip program do you use?
                  Cris999
                  First: I tried to selfextract the file.
                  Second: it was 7-Zip
                  Third: WinAce
                  Forth: I used a online unzipper service
                  Fifth: I sent the file to somebody, asking him to unzip
                  Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                  Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                  Thank You, Cris999
                  • fredo6F Offline
                    Third: WinAce
                    Thank You, Cris999
                    Maybe you should try to download WinZip (this is what I use to zip the files).
                    In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                    • X Offline
                      xrok1
                      i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. πŸ˜„
                        blair
                        Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                          blair
                          There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                          • X Offline
                            xrok1
                            you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                              Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                                blair
                                Thank you both for excellant ideas. If not for you guys I would have never guessed or know. Rebuilding 28 interior and exterior corners is not the most fun I have ever had. But, I am now ready for next time.
                                  blair
                                  Sorry to bother you for this seemingly simple specific but where can I find "Didier's Ghost Component plugin"? I have searched here, Smustard, Ruby Library Depot and Googled but I must not be typing the best words/word combinations.
                                  • olisheaO Offline
                                    olishea
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=21469
                                    oli
                                      Luix0
                                      Gracias
                                        blair
                                        Thanks Oli
                                          Thanks Oli! πŸ˜‰
                                            lionheart198151
                                            Thanks for sharing,It's so cool!!!
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 73
                                            • 74
                                            • 37 / 74
