    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • brookefoxB
      brookefox
      My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
      S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
      Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
      ~ Brooke
        If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
        I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
        Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
        • ken28875K
          ken28875
          Hi TIG,
          I don't have any problems with the Follow-me tool.
          Sketchup crashes only when I use RoundCorner. 😢
          Thanks,
          _KN
          Follow Your Dreams.
          • fredo6F
            @ken28875 said:
            Hi TIG,
            Thanks,
            _KN
            Ken,
            Could you post or send me the model, so that I can have a look at whatcrashes.
            I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
            • fredo6F
              Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
              I am not clear of what is the bad visual effect. Coul you post a picture or the model.
              • ken28875K
                ken28875
                Ken,
                Hi Fredo,
                I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                Thanks,
                _KN
                Follow Your Dreams.
                • brookefoxB
                  brookefox
                  Sorry, I missed that and will investigate further. Thank you.
                  Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
                  ~ Brooke
                    Are the edges Smooth by any chance?
                    • brookefoxB
                      brookefox
                      Well, obviously, I mean, well, er....
                      I thought I had checked that but obviously my methodology was seriously flawed.
                      Thanks, t.
                      ~ Brooke
                      • C
                        Cris999
                        Hello
                        Is there another place to download this plugin?
                        I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                        Thank You, Cris999
                          The 2.1c zip is fine I just re-downloaded it to test... Try again.
                          • C
                            Cris999
                            I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                            Thank You
                            • fredo6F
                              Thank You
                              Which unzip program do you use?
                              • C
                                Cris999
                                First: I tried to selfextract the file.
                                Second: it was 7-Zip
                                Third: WinAce
                                Forth: I used a online unzipper service
                                Fifth: I sent the file to somebody, asking him to unzip
                                Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                                Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                                Thank You, Cris999
                                • fredo6F
                                  Third: WinAce
                                  Thank You, Cris999
                                  Maybe you should try to download WinZip (this is what I use to zip the files).
                                  In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                                  • X
                                    xrok1
                                    i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. 😄
                                    • B
                                      blair
                                      Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                                      • B
                                        blair
                                        There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                                        • X
                                          xrok1
                                          you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                                          • GaieusG
                                            Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 74
                                            • 75
                                            • 12 / 75
