    1.5k Posts 476 Posters 3.6m Views 476 Watching
      I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments πŸ˜„ )
      • ken28875K Offline
        ken28875
        @tig said:
        Unlikely to result in faces <1mm ?
        What do you mean, TIG?
        Thanks,
        _KN
        Follow Your Dreams.
        • brookefoxB Offline
          brookefox
          My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
          S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
          Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
          ~ Brooke
            If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
            I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
            Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
            • ken28875K Offline
              ken28875
              Hi TIG,
              I don't have any problems with the Follow-me tool.
              Sketchup crashes only when I use RoundCorner. 😒
              Thanks,
              _KN
              Follow Your Dreams.
              • fredo6F Offline
                @ken28875 said:
                Hi TIG,
                Thanks,
                _KN
                Ken,
                Could you post or send me the model, so that I can have a look at whatcrashes.
                I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                • fredo6F Offline
                  Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
                  I am not clear of what is the bad visual effect. Coul you post a picture or the model.
                  • ken28875K Offline
                    ken28875
                    Ken,
                    Hi Fredo,
                    I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                    Thanks,
                    _KN
                    Follow Your Dreams.
                      brookefox
                      Sorry, I missed that and will investigate further. Thank you.
                      Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
                      ~ Brooke
                        Are the edges Smooth by any chance?
                          brookefox
                          Well, obviously, I mean, well, er....
                          I thought I had checked that but obviously my methodology was seriously flawed.
                          Thanks, t.
                          ~ Brooke
                            Cris999
                            Hello
                            Is there another place to download this plugin?
                            I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                            Thank You, Cris999
                              The 2.1c zip is fine I just re-downloaded it to test... Try again.
                                Cris999
                                I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                                Thank You
                                • fredo6F Offline
                                  Thank You
                                  Which unzip program do you use?
                                    Cris999
                                    First: I tried to selfextract the file.
                                    Second: it was 7-Zip
                                    Third: WinAce
                                    Forth: I used a online unzipper service
                                    Fifth: I sent the file to somebody, asking him to unzip
                                    Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                                    Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                                    Thank You, Cris999
                                    • fredo6F Offline
                                      Third: WinAce
                                      Thank You, Cris999
                                      Maybe you should try to download WinZip (this is what I use to zip the files).
                                      In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                                      • X Offline
                                        xrok1
                                        i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. πŸ˜„
                                          blair
                                          Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                                            blair
                                            There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 74
                                            • 75
                                            • 12 / 75
