    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • fredo6F
      @cris999 said:
      I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
      Thank You
      Which unzip program do you use?
      • C
        Cris999
        First: I tried to selfextract the file.
        Second: it was 7-Zip
        Third: WinAce
        Forth: I used a online unzipper service
        Fifth: I sent the file to somebody, asking him to unzip
        Sixth: I downloaded from another PC and tried unsuccessfully to unzip
        Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
        Thank You, Cris999
        • fredo6F
          Third: WinAce
          Thank You, Cris999
          Maybe you should try to download WinZip (this is what I use to zip the files).
          In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
          • X
            xrok1
            i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. ๐Ÿ˜„
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • B
              blair
              Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
              • B
                blair
                There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                • X
                  xrok1
                  you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                  • GaieusG
                    Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                    • B
                      blair
                      Thank you both for excellant ideas. If not for you guys I would have never guessed or know. Rebuilding 28 interior and exterior corners is not the most fun I have ever had. But, I am now ready for next time.
                      • B
                        blair
                        Sorry to bother you for this seemingly simple specific but where can I find "Didier's Ghost Component plugin"? I have searched here, Smustard, Ruby Library Depot and Googled but I must not be typing the best words/word combinations.
                        • olisheaO
                          olishea
                          404 Not Found
                          (forums.sketchucation.com)
                          oli
                          • L
                            Luix0
                            Gracias
                            • B
                              blair
                              Thanks Oli
                              • GaieusG
                                Thanks Oli! ๐Ÿ˜‰
                                • L
                                  lionheart198151
                                  Thanks for sharing,It's so cool!!!
                                  • fredo6F
                                    I know what to do for this type of configuration, but this is not at all a trivial change. So it is on my (big) list of things to do.
                                    In the mean time, I would follow the 'manual' way, as you describe.
                                    • P
                                      push
                                      thank you
                                      • T
                                        thomadeg
                                        first of all, great plugin
                                        but i was wondering wheter it would be possible to precise the corner that needs to be rounded by giving in the radius (similar to the 'fillet' tool in autocad?)
                                        kind regards,
                                        thomas
                                        • fredo6F
                                          @liveview said:
                                          [b]RoundCorner performs the rounding of the edges and corners of 3D shapes along a 2D profile, in 3 modes: Round corners, Sharp corners and Bevel.
                                          Hi Fredo6 ! ๐Ÿ˜„
                                          This ruby made a strong impression on me ! It's very very very useful !
                                          I have a small idea, could you resolve it ?
                                          http://c.upanh.com/upload/7/482/CS0.11694697_1_1.jpg
                                          Many thanks ! ๐Ÿ˜„
                                          This is a good idea. Actually, I should make the lateral edges the same property as the bordering edges. Will do it in a next upgrade.
                                          • fredo6F
                                            @thomadeg said:
                                            kind regards,
                                            thomas
                                            Do you have any illustration of this function or link of the Autocad fillet so that I see if this can be added?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 74
                                            • 75
                                            • 13 / 75
