    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • brookefoxB Offline
      brookefox
      Well, obviously, I mean, well, er....
      I thought I had checked that but obviously my methodology was seriously flawed.
      Thanks, t.
      ~ Brooke
        Cris999
        Hello
        Is there another place to download this plugin?
        I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
        Thank You, Cris999
          The 2.1c zip is fine I just re-downloaded it to test... Try again.
            Cris999
            I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
            Thank You
            • fredo6F Offline
              Thank You
              Which unzip program do you use?
                Cris999
                First: I tried to selfextract the file.
                Second: it was 7-Zip
                Third: WinAce
                Forth: I used a online unzipper service
                Fifth: I sent the file to somebody, asking him to unzip
                Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                Thank You, Cris999
                • fredo6F Offline
                  Third: WinAce
                  Thank You, Cris999
                  Maybe you should try to download WinZip (this is what I use to zip the files).
                  In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                  • X Offline
                    xrok1
                    i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. 😄
                      blair
                      Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                        blair
                        There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                        • X Offline
                          xrok1
                          you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                            Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                              blair
                              Thank you both for excellant ideas. If not for you guys I would have never guessed or know. Rebuilding 28 interior and exterior corners is not the most fun I have ever had. But, I am now ready for next time.
                                blair
                                Sorry to bother you for this seemingly simple specific but where can I find "Didier's Ghost Component plugin"? I have searched here, Smustard, Ruby Library Depot and Googled but I must not be typing the best words/word combinations.
                                • olisheaO Offline
                                  olishea
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  oli
                                    Luix0
                                    Gracias
                                      blair
                                      Thanks Oli
                                        Thanks Oli! 😉
                                          lionheart198151
                                          Thanks for sharing,It's so cool!!!
                                          • fredo6F Offline
                                            I know what to do for this type of configuration, but this is not at all a trivial change. So it is on my (big) list of things to do.
                                            In the mean time, I would follow the 'manual' way, as you describe.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 74
                                            • 75
                                            • 12 / 75
