    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • fredo6F Offline
      @brookefox said:
      S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
      Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
      @brookefox said:
      Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
      I am not clear of what is the bad visual effect. Coul you post a picture or the model.
      • ken28875K Offline
        ken28875
        Ken,
        Could you post or send me the model, so that I can have a look at whatcrashes.
        I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
        Hi Fredo,
        I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
        Thanks,
        _KN
        Follow Your Dreams.
        • brookefoxB Offline
          brookefox
          Sorry, I missed that and will investigate further. Thank you.
          Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
          ~ Brooke
            Are the edges Smooth by any chance?
              brookefox
              Well, obviously, I mean, well, er....
              I thought I had checked that but obviously my methodology was seriously flawed.
              Thanks, t.
              ~ Brooke
                Cris999
                Hello
                Is there another place to download this plugin?
                I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                Thank You, Cris999
                  The 2.1c zip is fine I just re-downloaded it to test... Try again.
                    Cris999
                    I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                    Thank You
                    • fredo6F Offline
                      Thank You
                      Which unzip program do you use?
                        Cris999
                        First: I tried to selfextract the file.
                        Second: it was 7-Zip
                        Third: WinAce
                        Forth: I used a online unzipper service
                        Fifth: I sent the file to somebody, asking him to unzip
                        Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                        Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                        Thank You, Cris999
                        • fredo6F Offline
                          Third: WinAce
                          Thank You, Cris999
                          Maybe you should try to download WinZip (this is what I use to zip the files).
                          In any case, be attentive to the hierarchy of folders that should be recreated. I would suggest you unzip in a neutral place, then check and then copy the folder and small file in the SU Plugin directory.
                          • X Offline
                            xrok1
                            i dblclick to open with 7zip then drag and drop files/folders to SU plugins in another open explorer window. never fails. ๐Ÿ˜„
                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                              blair
                              Some time ago I used Fred06.s "[Plugin] RoundCorner" to round/bevel an edge then saved the file. Now I have decided the round/bevel edge is to large. Is there a way to undo the round/bevel and start over from a square edge and do it all over again without a re-draw?
                                blair
                                There is probably a better way to do the above but I do not know what it is. What I did was go back and re-build each and every corner 1 x 1. Sure makes me hope I get the rounds right next time and have a back up copy just in case.
                                • X Offline
                                  xrok1
                                  you could always make a copy of your original stuff and put it on a hidden layer before you do major edits like round corner.
                                    Or even better; use Didier's Ghost Component plugin to keep the original (unrounded) as ghost and round the "real" to anything. Then you can always get back to the original.
                                      blair
                                      Thank you both for excellant ideas. If not for you guys I would have never guessed or know. Rebuilding 28 interior and exterior corners is not the most fun I have ever had. But, I am now ready for next time.
                                        blair
                                        Sorry to bother you for this seemingly simple specific but where can I find "Didier's Ghost Component plugin"? I have searched here, Smustard, Ruby Library Depot and Googled but I must not be typing the best words/word combinations.
                                        • olisheaO Offline
                                          olishea
                                          http://forums.sketchucation.com/viewtopic.php?f=180&t=21469
                                          oli
                                            Luix0
                                            Gracias
                                            • 73
                                            • 74
                                            • 7 / 74
