    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • ken28875K Offline
      ken28875
      I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😒
      Does anyone have the same problem?
      Thanks,
      _KN
      Follow Your Dreams.
        I have never had that problem [Vista].
        How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
        • ken28875K Offline
          ken28875
          Hi TIG,
          It's only 40cm.
          http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
          Thanks,
          _KN
          Follow Your Dreams.
            Unlikely to result in faces <1mm ?
              I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments πŸ˜„ )
              • ken28875K Offline
                ken28875
                What do you mean, TIG?
                Thanks,
                _KN
                Follow Your Dreams.
                • brookefoxB Offline
                  brookefox
                  My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
                  S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
                  Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
                  ~ Brooke
                    If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
                    I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
                    Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
                    • ken28875K Offline
                      ken28875
                      Hi TIG,
                      I don't have any problems with the Follow-me tool.
                      Sketchup crashes only when I use RoundCorner. 😒
                      Thanks,
                      _KN
                      Follow Your Dreams.
                      • fredo6F Offline
                        @ken28875 said:
                        Hi TIG,
                        Thanks,
                        _KN
                        Ken,
                        Could you post or send me the model, so that I can have a look at whatcrashes.
                        I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                        • fredo6F Offline
                          Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
                          I am not clear of what is the bad visual effect. Coul you post a picture or the model.
                          • ken28875K Offline
                            ken28875
                            Ken,
                            Hi Fredo,
                            I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                            Thanks,
                            _KN
                            Follow Your Dreams.
                              brookefox
                              Sorry, I missed that and will investigate further. Thank you.
                              Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
                              ~ Brooke
                                Are the edges Smooth by any chance?
                                  brookefox
                                  Well, obviously, I mean, well, er....
                                  I thought I had checked that but obviously my methodology was seriously flawed.
                                  Thanks, t.
                                  ~ Brooke
                                    Cris999
                                    Hello
                                    Is there another place to download this plugin?
                                    I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                                    Thank You, Cris999
                                      The 2.1c zip is fine I just re-downloaded it to test... Try again.
                                        Cris999
                                        I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                                        Thank You
                                        • fredo6F Offline
                                          Thank You
                                          Which unzip program do you use?
                                            Cris999
                                            First: I tried to selfextract the file.
                                            Second: it was 7-Zip
                                            Third: WinAce
                                            Forth: I used a online unzipper service
                                            Fifth: I sent the file to somebody, asking him to unzip
                                            Sixth: I downloaded from another PC and tried unsuccessfully to unzip
                                            Only WinAce showed my the 2 "IMAGES" folders and english pdf file (the french one is corrupt) and no other files in "ROUNDCORNER_Dir_21" folder
                                            Thank You, Cris999
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 73
                                            • 74
                                            • 15 / 74
