    1.5k Posts 478 Posters 4.3m Views 478 Watching
      This suggests somethings are so small they appear to be coincident - to SUp - and 'fail'... ❓
      • ken28875K
        ken28875
        I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😒
        Does anyone have the same problem?
        Thanks,
        _KN
        Follow Your Dreams.
          I have never had that problem [Vista].
          How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
          • ken28875K
            ken28875
            Hi TIG,
            It's only 40cm.
            http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
            Thanks,
            _KN
            Follow Your Dreams.
              Unlikely to result in faces <1mm ?
              • GaieusG
                I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments πŸ˜„ )
                • ken28875K
                  ken28875
                  What do you mean, TIG?
                  Thanks,
                  _KN
                  Follow Your Dreams.
                  • brookefoxB
                    brookefox
                    My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
                    S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
                    Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
                    ~ Brooke
                      If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
                      I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
                      Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
                      • ken28875K
                        ken28875
                        Hi TIG,
                        I don't have any problems with the Follow-me tool.
                        Sketchup crashes only when I use RoundCorner. 😒
                        Thanks,
                        _KN
                        Follow Your Dreams.
                        • fredo6F
                          @ken28875 said:
                          Hi TIG,
                          Thanks,
                          _KN
                          Ken,
                          Could you post or send me the model, so that I can have a look at whatcrashes.
                          I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                          • fredo6F
                            Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
                            I am not clear of what is the bad visual effect. Coul you post a picture or the model.
                            • ken28875K
                              ken28875
                              Ken,
                              Hi Fredo,
                              I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                              Thanks,
                              _KN
                              Follow Your Dreams.
                              • brookefoxB
                                brookefox
                                Sorry, I missed that and will investigate further. Thank you.
                                Its only very slightly 'bad'. My understanding is worse, though, and that is what I was wanting to improve.
                                ~ Brooke
                                  Are the edges Smooth by any chance?
                                  • brookefoxB
                                    brookefox
                                    Well, obviously, I mean, well, er....
                                    I thought I had checked that but obviously my methodology was seriously flawed.
                                    Thanks, t.
                                    ~ Brooke
                                    • C
                                      Cris999
                                      Hello
                                      Is there another place to download this plugin?
                                      I tried with this one, but it gave me the message "The Compressed (zipped) Folder is invalid or corrupted".
                                      Thank You, Cris999
                                        The 2.1c zip is fine I just re-downloaded it to test... Try again.
                                        • C
                                          Cris999
                                          I tried on other PC too. Same problem. Can somebody send me the unzipped files on PM?
                                          Thank You
                                          • fredo6F
                                            Thank You
                                            Which unzip program do you use?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 74
                                            • 75
                                            • 12 / 75
