    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • HieruH
      Hieru
      xrok1,
      I'm using SU 7.1.6087 (Free)
      Gaieus,
      When I scaled up the model and applied a 20mm radius, I still used 6 segments. The plugin doesn't appear to have a problem creating the faces and I can select them once created. The problem is that they vanish, along with hidden geometry, when I save the file.
      www.davidhier.co.uk
      • GaieusG
        I have no idea why that is happening. Try something: Go to your Window > Preferences > General tab and uncheck"Automatically fix problems..."
        The plugin mayproduce invalid geometry and upon saving, this option deletes it. If you keep "Automatically check model..." checked, SU should give you a warning. Then "fix" the model and it will present you with a list of what was fixed. Make a screenshot of that window and attach it here - it may help Fredo to improve the plugin (only IF this invalid geometry is the problem of course)
        • HieruH
          Hieru
          Thanks Gaieus, I'll give that a go.
          As an update to the situation I uninstalled SU and then installed the latest version. I then added the RoundCorner plugin (as well as LibFredo) - no other plugins - and I still had the same problem.
          I did however find a way around the issue. By exploding geometry, applying the plugin and then re-grouping the geometry I didn't lose any of the corner faces when saving.
          www.davidhier.co.uk
          • GaieusG
            Hm. That's very interesting.
            • fredo6F
              Hieru,
              I played with your model and could not reproduce the loss of faces, even if a small radius.
              I would recommend you do what Gaieus recommends to see if this is not related to the model (the fact that the faces are computed by RoundCorner, but disappear when saving, seems to be a more general issue with the model than the plugin).
              Also, if this is reproducable, could you try to copy the model within the same file and save to see if both instances have a loss of faces.
              • HieruH
                Hieru
                Hi Fredo6,
                Thanks for taking the time to look at the model.
                I followed Gaieus' instructions, but I don't get a warning when applying the plugin or saving the file.
                Copying the model within the file results in a loss of faces in both sets of geometry. I also tried converting one group of geometry into a component and then applied the plugin. When saving there is a loss of faces for each instance of a component.
                What was odd is the fact that when I loaded the component from the component palette it was reproduced at a much smaller scale than the original object. Presumably that isn't supposed to happen and is another indication that there is something odd about the model?
                Luckily I have been able to apply the plugin using the method mentioned in my previous post, so I haven't had to remodel the light.
                Also I've been working on an architectural model today and haven't had any trouble with the RoundCorner plugin.......so it looks more and more like this was a problem with my model........but can't think what the source of the problem might be.
                www.davidhier.co.uk
                  Daniel S
                  I tried the model and I can´t reproduce the loss of faces... but I get the warning msg.
                  Results of Validity Check.
                  The start and end vertices are identical for CEdge (82816)
                  Entity CEdge (82816) should be erased - done
                  The start and end vertices are identical for CEdge (83152)
                  Entity CEdge (83152) should be erased - done
                  The start and end vertices are identical for CEdge (83230)
                  Entity CEdge (83230) should be erased - done
                  The start and end vertices are identical for CEdge (83324)
                  Entity CEdge (83324) should be erased - done
                  The start and end vertices are identical for CEdge (83738)
                  Entity CEdge (83738) should be erased - done
                  The start and end vertices are identical for CEdge (83879)
                  Entity CEdge (83879) should be erased - done
                  The start and end vertices are identical for CEdge (83965)
                  Entity CEdge (83965) should be erased - done
                  The start and end vertices are identical for CEdge (84015)
                  Entity CEdge (84015) should be erased - done
                  The start and end vertices are identical for CEdge (84124)
                  Entity CEdge (84124) should be erased - done
                  The start and end vertices are identical for CEdge (84399)
                  Entity CEdge (84399) should be erased - done
                  The start and end vertices are identical for CEdge (84751)
                  Entity CEdge (84751) should be erased - done
                  The start and end vertices are identical for CEdge (84763)
                  Entity CEdge (84763) should be erased - done
                  The start and end vertices are identical for CEdge (84903)
                  Entity CEdge (84903) should be erased - done
                  The start and end vertices are identical for CEdge (85017)
                  Entity CEdge (85017) should be erased - done
                  The start and end vertices are identical for CEdge (85186)
                  Entity CEdge (85186) should be erased - done
                  The start and end vertices are identical for CEdge (85351)
                  Entity CEdge (85351) should be erased - done
                  The start and end vertices are identical for CEdge (85757)
                  Entity CEdge (85757) should be erased - done
                  The start and end vertices are identical for CEdge (85918)
                  Entity CEdge (85918) should be erased - done
                  The start and end vertices are identical for CEdge (86032)
                  Entity CEdge (86032) should be erased - done
                  The start and end vertices are identical for CEdge (86082)
                  Entity CEdge (86082) should be erased - done
                  The start and end vertices are identical for CEdge (86191)
                  Entity CEdge (86191) should be erased - done
                  The start and end vertices are identical for CEdge (86771)
                  Entity CEdge (86771) should be erased - done
                  The start and end vertices are identical for CEdge (86783)
                  Entity CEdge (86783) should be erased - done
                  The start and end vertices are identical for CEdge (86923)
                  Entity CEdge (86923) should be erased - done
                  The start and end vertices are identical for CEdge (87075)
                  Entity CEdge (87075) should be erased - done
                  The start and end vertices are identical for CEdge (87361)
                  Entity CEdge (87361) should be erased - done
                  The start and end vertices are identical for CEdge (87852)
                  Entity CEdge (87852) should be erased - done
                  The start and end vertices are identical for CEdge (87928)
                  Entity CEdge (87928) should be erased - done
                  The start and end vertices are identical for CEdge (88080)
                  Entity CEdge (88080) should be erased - done
                  The start and end vertices are identical for CEdge (88168)
                  Entity CEdge (88168) should be erased - done
                  The start and end vertices are identical for CEdge (107162)
                  Entity CEdge (107162) should be erased - done
                  The start and end vertices are identical for CEdge (106469)
                  Entity CEdge (106469) should be erased - done
                  The start and end vertices are identical for CEdge (106305)
                  Entity CEdge (106305) should be erased - done
                  The start and end vertices are identical for CEdge (107454)
                  Entity CEdge (107454) should be erased - done
                  The start and end vertices are identical for CEdge (106457)
                  Entity CEdge (106457) should be erased - done
                  The start and end vertices are identical for CEdge (107568)
                  Entity CEdge (107568) should be erased - done
                  The start and end vertices are identical for CEdge (106656)
                  Entity CEdge (106656) should be erased - done
                  The start and end vertices are identical for CEdge (107720)
                  Entity CEdge (107720) should be erased - done
                  The start and end vertices are identical for CEdge (107884)
                  Entity CEdge (107884) should be erased - done
                  The start and end vertices are identical for CEdge (108509)
                  Entity CEdge (108509) should be erased - done
                  The start and end vertices are identical for CEdge (108623)
                  Entity CEdge (108623) should be erased - done
                  The start and end vertices are identical for CEdge (108635)
                  Entity CEdge (108635) should be erased - done
                  The start and end vertices are identical for CEdge (108775)
                  Entity CEdge (108775) should be erased - done
                  The start and end vertices are identical for CEdge (109357)
                  Entity CEdge (109357) should be erased - done
                  The start and end vertices are identical for CEdge (109611)
                  Entity CEdge (109611) should be erased - done
                  The start and end vertices are identical for CEdge (109763)
                  Entity CEdge (109763) should be erased - done
                  The start and end vertices are identical for CEdge (109877)
                  Entity CEdge (109877) should be erased - done
                  The start and end vertices are identical for CEdge (95020)
                  Entity CEdge (95020) should be erased - done
                  The start and end vertices are identical for CEdge (110032)
                  Entity CEdge (110032) should be erased - done
                  The start and end vertices are identical for CEdge (110695)
                  Entity CEdge (110695) should be erased - done
                  The start and end vertices are identical for CEdge (110809)
                  Entity CEdge (110809) should be erased - done
                  The start and end vertices are identical for CEdge (110821)
                  Entity CEdge (110821) should be erased - done
                  The start and end vertices are identical for CEdge (110961)
                  Entity CEdge (110961) should be erased - done
                  The start and end vertices are identical for CEdge (88876)
                  Entity CEdge (88876) should be erased - done
                  The start and end vertices are identical for CEdge (88978)
                  Entity CEdge (88978) should be erased - done
                  The start and end vertices are identical for CEdge (89060)
                  Entity CEdge (89060) should be erased - done
                  The start and end vertices are identical for CEdge (89213)
                  Entity CEdge (89213) should be erased - done
                  The start and end vertices are identical for CEdge (89373)
                  Entity CEdge (89373) should be erased - done
                  The start and end vertices are identical for CEdge (89462)
                  Entity CEdge (89462) should be erased - done
                  The start and end vertices are identical for CEdge (89982)
                  Entity CEdge (89982) should be erased - done
                  The start and end vertices are identical for CEdge (90134)
                  Entity CEdge (90134) should be erased - done
                  The start and end vertices are identical for CEdge (90184)
                  Entity CEdge (90184) should be erased - done
                  The start and end vertices are identical for CEdge (90715)
                  Entity CEdge (90715) should be erased - done
                  The start and end vertices are identical for CEdge (90918)
                  Entity CEdge (90918) should be erased - done
                  The start and end vertices are identical for CEdge (91058)
                  Entity CEdge (91058) should be erased - done
                  The start and end vertices are identical for CEdge (91100)
                  Entity CEdge (91100) should be erased - done
                  The start and end vertices are identical for CEdge (91177)
                  Entity CEdge (91177) should be erased - done
                  The start and end vertices are identical for CEdge (91409)
                  Entity CEdge (91409) should be erased - done
                  The start and end vertices are identical for CEdge (91536)
                  Entity CEdge (91536) should be erased - done
                  The start and end vertices are identical for CEdge (91796)
                  Entity CEdge (91796) should be erased - done
                  The start and end vertices are identical for CEdge (92101)
                  Entity CEdge (92101) should be erased - done
                  The start and end vertices are identical for CEdge (92258)
                  Entity CEdge (92258) should be erased - done
                  The start and end vertices are identical for CEdge (92308)
                  Entity CEdge (92308) should be erased - done
                  The start and end vertices are identical for CEdge (93001)
                  Entity CEdge (93001) should be erased - done
                  The start and end vertices are identical for CEdge (93179)
                  Entity CEdge (93179) should be erased - done
                  The start and end vertices are identical for CEdge (93255)
                  Entity CEdge (93255) should be erased - done
                  The start and end vertices are identical for CEdge (93533)
                  Entity CEdge (93533) should be erased - done
                  The start and end vertices are identical for CEdge (94062)
                  Entity CEdge (94062) should be erased - done
                  The start and end vertices are identical for CEdge (94138)
                  Entity CEdge (94138) should be erased - done
                  The start and end vertices are identical for CEdge (94150)
                  Entity CEdge (94150) should be erased - done
                  The start and end vertices are identical for CEdge (94834)
                  Entity CEdge (94834) should be erased - done
                  The start and end vertices are identical for CEdge (94974)
                  Entity CEdge (94974) should be erased - done
                  The start and end vertices are identical for CEdge (95135)
                  Entity CEdge (95135) should be erased - done
                  The start and end vertices are identical for CEdge (95451)
                  Entity CEdge (95451) should be erased - done
                  The start and end vertices are identical for CEdge (95933)
                  Entity CEdge (95933) should be erased - done
                  The start and end vertices are identical for CEdge (96000)
                  Entity CEdge (96000) should be erased - done
                  The start and end vertices are identical for CEdge (96050)
                  Entity CEdge (96050) should be erased - done
                  The start and end vertices are identical for CEdge (96734)
                  Entity CEdge (96734) should be erased - done
                  The start and end vertices are identical for CEdge (96874)
                  Entity CEdge (96874) should be erased - done
                  The start and end vertices are identical for CEdge (96959)
                  Entity CEdge (96959) should be erased - done
                  The start and end vertices are identical for CEdge (97360)
                  Entity CEdge (97360) should be erased - done
                  The start and end vertices are identical for CEdge (97766)
                  Entity CEdge (97766) should be erased - done
                  The start and end vertices are identical for CEdge (100599)
                  Entity CEdge (100599) should be erased - done
                  The start and end vertices are identical for CEdge (99944)
                  Entity CEdge (99944) should be erased - done
                  The start and end vertices are identical for CEdge (99704)
                  Entity CEdge (99704) should be erased - done
                  The start and end vertices are identical for CEdge (100815)
                  Entity CEdge (100815) should be erased - done
                  The start and end vertices are identical for CEdge (99932)
                  Entity CEdge (99932) should be erased - done
                  The start and end vertices are identical for CEdge (100967)
                  Entity CEdge (100967) should be erased - done
                  The start and end vertices are identical for CEdge (99361)
                  Entity CEdge (99361) should be erased - done
                  The start and end vertices are identical for CEdge (101148)
                  Entity CEdge (101148) should be erased - done
                  The start and end vertices are identical for CEdge (101350)
                  Entity CEdge (101350) should be erased - done
                  The start and end vertices are identical for CEdge (101870)
                  Entity CEdge (101870) should be erased - done
                  The start and end vertices are identical for CEdge (101984)
                  Entity CEdge (101984) should be erased - done
                  The start and end vertices are identical for CEdge (101996)
                  Entity CEdge (101996) should be erased - done
                  The start and end vertices are identical for CEdge (102259)
                  Entity CEdge (102259) should be erased - done
                  The start and end vertices are identical for CEdge (99251)
                  Entity CEdge (99251) should be erased - done
                  The start and end vertices are identical for CEdge (97880)
                  Entity CEdge (97880) should be erased - done
                  The start and end vertices are identical for CEdge (97930)
                  Entity CEdge (97930) should be erased - done
                  The start and end vertices are identical for CEdge (98643)
                  Entity CEdge (98643) should be erased - done
                  The start and end vertices are identical for CEdge (98745)
                  Entity CEdge (98745) should be erased - done
                  The start and end vertices are identical for CEdge (98935)
                  Entity CEdge (98935) should be erased - done
                  The start and end vertices are identical for CEdge (105709)
                  Entity CEdge (105709) should be erased - done
                  The start and end vertices are identical for CEdge (102803)
                  Entity CEdge (102803) should be erased - done
                  The start and end vertices are identical for CEdge (102981)
                  Entity CEdge (102981) should be erased - done
                  The start and end vertices are identical for CEdge (103133)
                  Entity CEdge (103133) should be erased - done
                  The start and end vertices are identical for CEdge (103323)
                  Entity CEdge (103323) should be erased - done
                  The start and end vertices are identical for CEdge (103525)
                  Entity CEdge (103525) should be erased - done
                  The start and end vertices are identical for CEdge (104092)
                  Entity CEdge (104092) should be erased - done
                  The start and end vertices are identical for CEdge (104206)
                  Entity CEdge (104206) should be erased - done
                  The start and end vertices are identical for CEdge (104218)
                  Entity CEdge (104218) should be erased - done
                  The start and end vertices are identical for CEdge (104443)
                  Entity CEdge (104443) should be erased - done
                  The start and end vertices are identical for CEdge (104987)
                  Entity CEdge (104987) should be erased - done
                  The start and end vertices are identical for CEdge (105250)
                  Entity CEdge (105250) should be erased - done
                  The start and end vertices are identical for CEdge (105364)
                  Entity CEdge (105364) should be erased - done
                  The start and end vertices are identical for CEdge (105545)
                  Entity CEdge (105545) should be erased - done
                  The start and end vertices are identical for CEdge (111514)
                  Entity CEdge (111514) should be erased - done
                  The start and end vertices are identical for CEdge (111768)
                  Entity CEdge (111768) should be erased - done
                  The start and end vertices are identical for CEdge (111882)
                  Entity CEdge (111882) should be erased - done
                  The start and end vertices are identical for CEdge (111987)
                  Entity CEdge (111987) should be erased - done
                  The start and end vertices are identical for CEdge (112113)
                  Entity CEdge (112113) should be erased - done
                  The start and end vertices are identical for CEdge (112747)
                  Entity CEdge (112747) should be erased - done
                  The start and end vertices are identical for CEdge (112899)
                  Entity CEdge (112899) should be erased - done
                  The start and end vertices are identical for CEdge (112911)
                  Entity CEdge (112911) should be erased - done
                  The start and end vertices are identical for CEdge (113089)
                  Entity CEdge (113089) should be erased - done
                  The start and end vertices are identical for CEdge (113557)
                  Entity CEdge (113557) should be erased - done
                  The start and end vertices are identical for CEdge (113811)
                  Entity CEdge (113811) should be erased - done
                  The start and end vertices are identical for CEdge (113925)
                  Entity CEdge (113925) should be erased - done
                  The start and end vertices are identical for CEdge (114077)
                  Entity CEdge (114077) should be erased - done
                  The start and end vertices are identical for CEdge (114279)
                  Entity CEdge (114279) should be erased - done
                  The start and end vertices are identical for CEdge (114866)
                  Entity CEdge (114866) should be erased - done
                  The start and end vertices are identical for CEdge (114942)
                  Entity CEdge (114942) should be erased - done
                  The start and end vertices are identical for CEdge (114954)
                  Entity CEdge (114954) should be erased - done
                  The start and end vertices are identical for CEdge (115132)
                  Entity CEdge (115132) should be erased - done
                  The start and end vertices are identical for CEdge (115524)
                  Entity CEdge (115524) should be erased - done
                  The start and end vertices are identical for CEdge (115769)
                  Entity CEdge (115769) should be erased - done
                  The start and end vertices are identical for CEdge (115883)
                  Entity CEdge (115883) should be erased - done
                  The start and end vertices are identical for CEdge (116082)
                  Entity CEdge (116082) should be erased - done
                  The start and end vertices are identical for CEdge (116246)
                  Entity CEdge (116246) should be erased - done
                  The start and end vertices are identical for CEdge (116737)
                  Entity CEdge (116737) should be erased - done
                  The start and end vertices are identical for CEdge (116854)
                  Entity CEdge (116854) should be erased - done
                  The start and end vertices are identical for CEdge (117032)
                  Entity CEdge (117032) should be erased - done
                  The start and end vertices are identical for CEdge (117462)
                  Entity CEdge (117462) should be erased - done
                  The start and end vertices are identical for CEdge (117716)
                  Entity CEdge (117716) should be erased - done
                  The start and end vertices are identical for CEdge (117953)
                  Entity CEdge (117953) should be erased - done
                  The start and end vertices are identical for CEdge (118108)
                  Entity CEdge (118108) should be erased - done
                  The start and end vertices are identical for CEdge (118628)
                  Entity CEdge (118628) should be erased - done
                  The start and end vertices are identical for CEdge (118716)
                  Entity CEdge (118716) should be erased - done
                  The start and end vertices are identical for CEdge (118894)
                  Entity CEdge (118894) should be erased - done
                  The start and end vertices are identical for CEdge (119324)
                  Entity CEdge (119324) should be erased - done
                  The start and end vertices are identical for CEdge (119540)
                  Entity CEdge (119540) should be erased - done
                  The start and end vertices are identical for CEdge (119797)
                  Entity CEdge (119797) should be erased - done
                  The start and end vertices are identical for CEdge (120443)
                  Entity CEdge (120443) should be erased - done
                  The start and end vertices are identical for CEdge (120633)
                  Entity CEdge (120633) should be erased - done
                  The start and end vertices are identical for CEdge (120814)
                  Entity CEdge (120814) should be erased - done
                  The start and end vertices are identical for CEdge (121308)
                  Entity CEdge (121308) should be erased - done
                  The start and end vertices are identical for CEdge (121498)
                  Entity CEdge (121498) should be erased - done
                  The start and end vertices are identical for CEdge (122258)
                  Entity CEdge (122258) should be erased - done
                  The start and end vertices are identical for CEdge (122296)
                  Entity CEdge (122296) should be erased - done
                  The start and end vertices are identical for CEdge (122410)
                  Entity CEdge (122410) should be erased - done
                  The start and end vertices are identical for CEdge (123161)
                  Entity CEdge (123161) should be erased - done
                  The start and end vertices are identical for CEdge (123199)
                  Entity CEdge (123199) should be erased - done
                  The start and end vertices are identical for CEdge (123313)
                  Entity CEdge (123313) should be erased - done
                  The start and end vertices are identical for CEdge (123363)
                  Entity CEdge (123363) should be erased - done
                  The start and end vertices are identical for CEdge (124035)
                  Entity CEdge (124035) should be erased - done
                  The start and end vertices are identical for CEdge (124073)
                  Entity CEdge (124073) should be erased - done
                  The start and end vertices are identical for CEdge (124225)
                  Entity CEdge (124225) should be erased - done
                  The start and end vertices are identical for CEdge (124655)
                  Entity CEdge (124655) should be erased - done
                  The start and end vertices are identical for CEdge (124985)
                  Entity CEdge (124985) should be erased - done
                  The start and end vertices are identical for CEdge (125023)
                  Entity CEdge (125023) should be erased - done
                  The start and end vertices are identical for CEdge (125137)
                  Entity CEdge (125137) should be erased - done
                  The start and end vertices are identical for CEdge (125263)
                  Entity CEdge (125263) should be erased - done
                  The start and end vertices are identical for CEdge (125935)
                  Entity CEdge (125935) should be erased - done
                  The start and end vertices are identical for CEdge (125947)
                  Entity CEdge (125947) should be erased - done
                  The start and end vertices are identical for CEdge (126011)
                  Entity CEdge (126011) should be erased - done
                  The start and end vertices are identical for CEdge (126055)
                  Entity CEdge (126055) should be erased - done
                  The start and end vertices are identical for CEdge (126170)
                  Entity CEdge (126170) should be erased - done
                  The start and end vertices are identical for CEdge (126600)
                  Entity CEdge (126600) should be erased - done
                  The start and end vertices are identical for CEdge (126892)
                  Entity CEdge (126892) should be erased - done
                  The start and end vertices are identical for CEdge (126930)
                  Entity CEdge (126930) should be erased - done
                  The start and end vertices are identical for CEdge (127010)
                  Entity CEdge (127010) should be erased - done
                  The start and end vertices are identical for CEdge (127125)
                  Entity CEdge (127125) should be erased - done
                  The start and end vertices are identical for CEdge (127213)
                  Entity CEdge (127213) should be erased - done
                  The start and end vertices are identical for CEdge (127905)
                  Entity CEdge (127905) should be erased - done
                  The start and end vertices are identical for CEdge (127917)
                  Entity CEdge (127917) should be erased - done
                  The start and end vertices are identical for CEdge (127981)
                  Entity CEdge (127981) should be erased - done
                  The start and end vertices are identical for CEdge (128025)
                  Entity CEdge (128025) should be erased - done
                  The start and end vertices are identical for CEdge (128140)
                  Entity CEdge (128140) should be erased - done
                  The start and end vertices are identical for CEdge (128523)
                  Entity CEdge (128523) should be erased - done
                  The start and end vertices are identical for CEdge (128844)
                  Entity CEdge (128844) should be erased - done
                  The start and end vertices are identical for CEdge (128886)
                  Entity CEdge (128886) should be erased - done
                  The start and end vertices are identical for CEdge (129001)
                  Entity CEdge (129001) should be erased - done
                  The start and end vertices are identical for CEdge (129176)
                  Entity CEdge (129176) should be erased - done
                  The start and end vertices are identical for CEdge (129273)
                  Entity CEdge (129273) should be erased - done
                  The start and end vertices are identical for CEdge (132246)
                  Entity CEdge (132246) should be erased - done
                  The start and end vertices are identical for CEdge (132255)
                  Entity CEdge (132255) should be erased - done
                  The start and end vertices are identical for CEdge (132261)
                  Entity CEdge (132261) should be erased - done
                  The start and end vertices are identical for CEdge (132267)
                  Entity CEdge (132267) should be erased - done
                  The start and end vertices are identical for CEdge (132270)
                  Entity CEdge (132270) should be erased - done
                  The start and end vertices are identical for CEdge (132279)
                  Entity CEdge (132279) should be erased - done
                  The start and end vertices are identical for CEdge (132291)
                  Entity CEdge (132291) should be erased - done
                  The start and end vertices are identical for CEdge (132294)
                  Entity CEdge (132294) should be erased - done
                  The start and end vertices are identical for CEdge (132297)
                  Entity CEdge (132297) should be erased - done
                  The start and end vertices are identical for CEdge (132315)
                  Entity CEdge (132315) should be erased - done
                  The start and end vertices are identical for CEdge (132324)
                  Entity CEdge (132324) should be erased - done
                  The start and end vertices are identical for CEdge (132342)
                  Entity CEdge (132342) should be erased - done
                  The start and end vertices are identical for CEdge (132345)
                  Entity CEdge (132345) should be erased - done
                  The start and end vertices are identical for CEdge (132363)
                  Entity CEdge (132363) should be erased - done
                  The start and end vertices are identical for CEdge (132378)
                  Entity CEdge (132378) should be erased - done
                  The start and end vertices are identical for CEdge (132381)
                  Entity CEdge (132381) should be erased - done
                  The start and end vertices are identical for CEdge (132384)
                  Entity CEdge (132384) should be erased - done
                  The start and end vertices are identical for CEdge (132411)
                  Entity CEdge (132411) should be erased - done
                  The start and end vertices are identical for CEdge (132414)
                  Entity CEdge (132414) should be erased - done
                  The start and end vertices are identical for CEdge (132420)
                  Entity CEdge (132420) should be erased - done
                  The start and end vertices are identical for CEdge (132435)
                  Entity CEdge (132435) should be erased - done
                  The start and end vertices are identical for CEdge (132438)
                  Entity CEdge (132438) should be erased - done
                  The start and end vertices are identical for CEdge (132459)
                  Entity CEdge (132459) should be erased - done
                  The start and end vertices are identical for CEdge (132474)
                  Entity CEdge (132474) should be erased - done
                  The start and end vertices are identical for CEdge (132486)
                  Entity CEdge (132486) should be erased - done
                  The start and end vertices are identical for CEdge (132495)
                  Entity CEdge (132495) should be erased - done
                  The start and end vertices are identical for CEdge (132501)
                  Entity CEdge (132501) should be erased - done
                  The start and end vertices are identical for CEdge (132513)
                  Entity CEdge (132513) should be erased - done
                  The start and end vertices are identical for CEdge (132516)
                  Entity CEdge (132516) should be erased - done
                  The start and end vertices are identical for CEdge (132531)
                  Entity CEdge (132531) should be erased - done
                  The start and end vertices are identical for CEdge (132540)
                  Entity CEdge (132540) should be erased - done
                  The start and end vertices are identical for CEdge (132546)
                  Entity CEdge (132546) should be erased - done
                  The start and end vertices are identical for CEdge (132549)
                  Entity CEdge (132549) should be erased - done
                  The start and end vertices are identical for CEdge (132564)
                  Entity CEdge (132564) should be erased - done
                  The start and end vertices are identical for CEdge (132579)
                  Entity CEdge (132579) should be erased - done
                  The start and end vertices are identical for CEdge (132591)
                  Entity CEdge (132591) should be erased - done
                  The start and end vertices are identical for CEdge (132600)
                  Entity CEdge (132600) should be erased - done
                  The start and end vertices are identical for CEdge (132609)
                  Entity CEdge (132609) should be erased - done
                  The start and end vertices are identical for CEdge (132621)
                  Entity CEdge (132621) should be erased - done
                  The start and end vertices are identical for CEdge (132624)
                  Entity CEdge (132624) should be erased - done
                  The start and end vertices are identical for CEdge (132636)
                  Entity CEdge (132636) should be erased - done
                  The start and end vertices are identical for CEdge (132642)
                  Entity CEdge (132642) should be erased - done
                  The start and end vertices are identical for CEdge (132648)
                  Entity CEdge (132648) should be erased - done
                  The start and end vertices are identical for CEdge (132651)
                  Entity CEdge (132651) should be erased - done
                  The start and end vertices are identical for CEdge (132654)
                  Entity CEdge (132654) should be erased - done
                  The start and end vertices are identical for CEdge (132657)
                  Entity CEdge (132657) should be erased - done
                  The start and end vertices are identical for CEdge (132684)
                  Entity CEdge (132684) should be erased - done
                  The start and end vertices are identical for CEdge (132690)
                  Entity CEdge (132690) should be erased - done
                  The start and end vertices are identical for CEdge (132708)
                  Entity CEdge (132708) should be erased - done
                  The start and end vertices are identical for CEdge (132717)
                  Entity CEdge (132717) should be erased - done
                  The start and end vertices are identical for CEdge (132720)
                  Entity CEdge (132720) should be erased - done
                  The start and end vertices are identical for CEdge (132735)
                  Entity CEdge (132735) should be erased - done
                  The start and end vertices are identical for CEdge (132738)
                  Entity CEdge (132738) should be erased - done
                  The start and end vertices are identical for CEdge (132753)
                  Entity CEdge (132753) should be erased - done
                  The start and end vertices are identical for CEdge (132759)
                  Entity CEdge (132759) should be erased - done
                  The start and end vertices are identical for CEdge (132774)
                  Entity CEdge (132774) should be erased - done
                  The start and end vertices are identical for CEdge (132777)
                  Entity CEdge (132777) should be erased - done
                  The start and end vertices are identical for CEdge (132792)
                  Entity CEdge (132792) should be erased - done
                  The start and end vertices are identical for CEdge (132810)
                  Entity CEdge (132810) should be erased - done
                  The start and end vertices are identical for CEdge (132825)
                  Entity CEdge (132825) should be erased - done
                  The start and end vertices are identical for CEdge (132843)
                  Entity CEdge (132843) should be erased - done
                  The start and end vertices are identical for CEdge (132858)
                  Entity CEdge (132858) should be erased - done
                  The start and end vertices are identical for CEdge (132876)
                  Entity CEdge (132876) should be erased - done
                  The start and end vertices are identical for CEdge (132888)
                  Entity CEdge (132888) should be erased - done
                  The start and end vertices are identical for CEdge (132903)
                  Entity CEdge (132903) should be erased - done
                  The start and end vertices are identical for CEdge (132915)
                  Entity CEdge (132915) should be erased - done
                  The start and end vertices are identical for CEdge (132927)
                  Entity CEdge (132927) should be erased - done
                  The start and end vertices are identical for CEdge (132939)
                  Entity CEdge (132939) should be erased - done
                  The start and end vertices are identical for CEdge (132948)
                  Entity CEdge (132948) should be erased - done
                  The start and end vertices are identical for CEdge (132960)
                  Entity CEdge (132960) should be erased - done
                  The start and end vertices are identical for CEdge (132975)
                  Entity CEdge (132975) should be erased - done
                  The start and end vertices are identical for CEdge (132987)
                  Entity CEdge (132987) should be erased - done
                  The start and end vertices are identical for CEdge (133005)
                  Entity CEdge (133005) should be erased - done
                  The start and end vertices are identical for CEdge (133017)
                  Entity CEdge (133017) should be erased - done
                  The start and end vertices are identical for CEdge (133026)
                  Entity CEdge (133026) should be erased - done
                  The start and end vertices are identical for CEdge (133041)
                  Entity CEdge (133041) should be erased - done
                  The start and end vertices are identical for CEdge (133050)
                  Entity CEdge (133050) should be erased - done
                  The start and end vertices are identical for CEdge (133062)
                  Entity CEdge (133062) should be erased - done
                  The start and end vertices are identical for CEdge (133071)
                  Entity CEdge (133071) should be erased - done
                  The start and end vertices are identical for CEdge (133080)
                  Entity CEdge (133080) should be erased - done
                  The start and end vertices are identical for CEdge (133092)
                  Entity CEdge (133092) should be erased - done
                  The start and end vertices are identical for CEdge (133098)
                  Entity CEdge (133098) should be erased - done
                  The start and end vertices are identical for CEdge (133101)
                  Entity CEdge (133101) should be erased - done
                  The start and end vertices are identical for CEdge (133104)
                  Entity CEdge (133104) should be erased - done
                  The start and end vertices are identical for CEdge (133107)
                  Entity CEdge (133107) should be erased - done
                  The start and end vertices are identical for CEdge (133110)
                  Entity CEdge (133110) should be erased - done
                  The start and end vertices are identical for CEdge (133113)
                  Entity CEdge (133113) should be erased - done
                  The start and end vertices are identical for CEdge (133116)
                  Entity CEdge (133116) should be erased - done
                  The start and end vertices are identical for CEdge (133119)
                  Entity CEdge (133119) should be erased - done
                  The start and end vertices are identical for CEdge (133122)
                  Entity CEdge (133122) should be erased - done
                  The start and end vertices are identical for CEdge (133125)
                  Entity CEdge (133125) should be erased - done
                  The start and end vertices are identical for CEdge (133128)
                  Entity CEdge (133128) should be erased - done
                  The start and end vertices are identical for CEdge (133131)
                  Entity CEdge (133131) should be erased - done
                  The start and end vertices are identical for CEdge (133134)
                  Entity CEdge (133134) should be erased - done
                  The start and end vertices are identical for CEdge (133137)
                  Entity CEdge (133137) should be erased - done
                  The start and end vertices are identical for CEdge (133140)
                  Entity CEdge (133140) should be erased - done
                  The start and end vertices are identical for CEdge (133143)
                  Entity CEdge (133143) should be erased - done
                  The start and end vertices are identical for CEdge (133146)
                  Entity CEdge (133146) should be erased - done
                  The start and end vertices are identical for CEdge (133149)
                  Entity CEdge (133149) should be erased - done
                  The start and end vertices are identical for CEdge (133152)
                  Entity CEdge (133152) should be erased - done
                  The start and end vertices are identical for CEdge (133155)
                  Entity CEdge (133155) should be erased - done
                  The start and end vertices are identical for CEdge (133158)
                  Entity CEdge (133158) should be erased - done
                  The start and end vertices are identical for CEdge (133161)
                  Entity CEdge (133161) should be erased - done
                  The start and end vertices are identical for CEdge (133164)
                  Entity CEdge (133164) should be erased - done
                  The start and end vertices are identical for CEdge (133167)
                  Entity CEdge (133167) should be erased - done
                  The start and end vertices are identical for CEdge (133170)
                  Entity CEdge (133170) should be erased - done
                  The start and end vertices are identical for CEdge (133173)
                  Entity CEdge (133173) should be erased - done
                  The start and end vertices are identical for CEdge (133176)
                  Entity CEdge (133176) should be erased - done
                  The start and end vertices are identical for CEdge (133179)
                  Entity CEdge (133179) should be erased - done
                  The start and end vertices are identical for CEdge (133182)
                  Entity CEdge (133182) should be erased - done
                  The start and end vertices are identical for CEdge (133185)
                  Entity CEdge (133185) should be erased - done
                  The start and end vertices are identical for CEdge (133188)
                  Entity CEdge (133188) should be erased - done
                  The start and end vertices are identical for CEdge (133191)
                  Entity CEdge (133191) should be erased - done
                  The start and end vertices are identical for CEdge (133194)
                  Entity CEdge (133194) should be erased - done
                  The start and end vertices are identical for CEdge (133197)
                  Entity CEdge (133197) should be erased - done
                  The start and end vertices are identical for CEdge (133200)
                  Entity CEdge (133200) should be erased - done
                  The start and end vertices are identical for CEdge (133203)
                  Entity CEdge (133203) should be erased - done
                  The start and end vertices are identical for CEdge (133206)
                  Entity CEdge (133206) should be erased - done
                  The start and end vertices are identical for CEdge (133209)
                  Entity CEdge (133209) should be erased - done
                  The start and end vertices are identical for CEdge (133212)
                  Entity CEdge (133212) should be erased - done
                  The start and end vertices are identical for CEdge (133215)
                  Entity CEdge (133215) should be erased - done
                  The start and end vertices are identical for CEdge (133218)
                  Entity CEdge (133218) should be erased - done
                  The start and end vertices are identical for CEdge (133221)
                  Entity CEdge (133221) should be erased - done
                  The start and end vertices are identical for CEdge (133224)
                  Entity CEdge (133224) should be erased - done
                  The start and end vertices are identical for CEdge (133227)
                  Entity CEdge (133227) should be erased - done
                  The start and end vertices are identical for CEdge (133230)
                  Entity CEdge (133230) should be erased - done
                  The start and end vertices are identical for CEdge (133233)
                  Entity CEdge (133233) should be erased - done
                  The start and end vertices are identical for CEdge (133236)
                  Entity CEdge (133236) should be erased - done
                  The start and end vertices are identical for CEdge (133239)
                  Entity CEdge (133239) should be erased - done
                  Edges are not connected in CLoop (82820) for CFace (82819)
                  Loop 0 of CFace (82819) is an invalid outer loop
                  Entity CFace (82819) should be erased - done
                  Edges are not connected in CLoop (83154) for CFace (83153)
                  Loop 0 of CFace (83153) is an invalid outer loop
                  Entity CFace (83153) should be erased - done
                  Edges are not connected in CLoop (83234) for CFace (83233)
                  Loop 0 of CFace (83233) is an invalid outer loop
                  Entity CFace (83233) should be erased - done
                  Edges are not connected in CLoop (83328) for CFace (83327)
                  Loop 0 of CFace (83327) is an invalid outer loop
                  Entity CFace (83327) should be erased - done
                  Edges are not connected in CLoop (83742) for CFace (83741)
                  Loop 0 of CFace (83741) is an invalid outer loop
                  Entity CFace (83741) should be erased - done
                  Edges are not connected in CLoop (83883) for CFace (83882)
                  Loop 0 of CFace (83882) is an invalid outer loop
                  Entity CFace (83882) should be erased - done
                  Edges are not connected in CLoop (83968) for CFace (83967)
                  Loop 0 of CFace (83967) is an invalid outer loop
                  Entity CFace (83967) should be erased - done
                  Edges are not connected in CLoop (84017) for CFace (84016)
                  Loop 0 of CFace (84016) is an invalid outer loop
                  Entity CFace (84016) should be erased - done
                  Edges are not connected in CLoop (84128) for CFace (84127)
                  Loop 0 of CFace (84127) is an invalid outer loop
                  Entity CFace (84127) should be erased - done
                  Edges are not connected in CLoop (84318) for CFace (84317)
                  Loop 0 of CFace (84317) is an invalid outer loop
                  Entity CFace (84317) should be erased - done
                  Edges are not connected in CLoop (84403) for CFace (84402)
                  Loop 0 of CFace (84402) is an invalid outer loop
                  Entity CFace (84402) should be erased - done
                  Edges are not connected in CLoop (84754) for CFace (84753)
                  Loop 0 of CFace (84753) is an invalid outer loop
                  Entity CFace (84753) should be erased - done
                  Edges are not connected in CLoop (84765) for CFace (84764)
                  Loop 0 of CFace (84764) is an invalid outer loop
                  Entity CFace (84764) should be erased - done
                  Edges are not connected in CLoop (84906) for CFace (84905)
                  Loop 0 of CFace (84905) is an invalid outer loop
                  Entity CFace (84905) should be erased - done
                  Edges are not connected in CLoop (85020) for CFace (85019)
                  Loop 0 of CFace (85019) is an invalid outer loop
                  Entity CFace (85019) should be erased - done
                  Edges are not connected in CLoop (85190) for CFace (85189)
                  Loop 0 of CFace (85189) is an invalid outer loop
                  Entity CFace (85189) should be erased - done
                  Edges are not connected in CLoop (85353) for CFace (85352)
                  Loop 0 of CFace (85352) is an invalid outer loop
                  Entity CFace (85352) should be erased - done
                  Edges are not connected in CLoop (85418) for CFace (85417)
                  Loop 0 of CFace (85417) is an invalid outer loop
                  Entity CFace (85417) should be erased - done
                  Edges are not connected in CLoop (85760) for CFace (85759)
                  Loop 0 of CFace (85759) is an invalid outer loop
                  Entity CFace (85759) should be erased - done
                  Edges are not connected in CLoop (85921) for CFace (85920)
                  Loop 0 of CFace (85920) is an invalid outer loop
                  Entity CFace (85920) should be erased - done
                  Edges are not connected in CLoop (86035) for CFace (86034)
                  Loop 0 of CFace (86034) is an invalid outer loop
                  Entity CFace (86034) should be erased - done
                  Edges are not connected in CLoop (86084) for CFace (86083)
                  Loop 0 of CFace (86083) is an invalid outer loop
                  Entity CFace (86083) should be erased - done
                  Edges are not connected in CLoop (86195) for CFace (86194)
                  Loop 0 of CFace (86194) is an invalid outer loop
                  Entity CFace (86194) should be erased - done
                  Edges are not connected in CLoop (86385) for CFace (86384)
                  Loop 0 of CFace (86384) is an invalid outer loop
                  Entity CFace (86384) should be erased - done
                  Edges are not connected in CLoop (86774) for CFace (86773)
                  Loop 0 of CFace (86773) is an invalid outer loop
                  Entity CFace (86773) should be erased - done
                  Edges are not connected in CLoop (86785) for CFace (86784)
                  Loop 0 of CFace (86784) is an invalid outer loop
                  Entity CFace (86784) should be erased - done
                  Edges are not connected in CLoop (86926) for CFace (86925)
                  Loop 0 of CFace (86925) is an invalid outer loop
                  Entity CFace (86925) should be erased - done
                  Edges are not connected in CLoop (87078) for CFace (87077)
                  Loop 0 of CFace (87077) is an invalid outer loop
                  Entity CFace (87077) should be erased - done
                  Edges are not connected in CLoop (87363) for CFace (87362)
                  Loop 0 of CFace (87362) is an invalid outer loop
                  Entity CFace (87362) should be erased - done
                  Edges are not connected in CLoop (87428) for CFace (87427)
                  Loop 0 of CFace (87427) is an invalid outer loop
                  Entity CFace (87427) should be erased - done
                  Edges are not connected in CLoop (87855) for CFace (87854)
                  Loop 0 of CFace (87854) is an invalid outer loop
                  Entity CFace (87854) should be erased - done
                  Edges are not connected in CLoop (87931) for CFace (87930)
                  Loop 0 of CFace (87930) is an invalid outer loop
                  Entity CFace (87930) should be erased - done
                  Edges are not connected in CLoop (88083) for CFace (88082)
                  Loop 0 of CFace (88082) is an invalid outer loop
                  Entity CFace (88082) should be erased - done
                  Edges are not connected in CLoop (88170) for CFace (88169)
                  Loop 0 of CFace (88169) is an invalid outer loop
                  Entity CFace (88169) should be erased - done
                  Edges are not connected in CLoop (88433) for CFace (88432)
                  Loop 0 of CFace (88432) is an invalid outer loop
                  Entity CFace (88432) should be erased - done
                  Edges are not connected in CLoop (106963) for CFace (106962)
                  Loop 0 of CFace (106962) is an invalid outer loop
                  Entity CFace (106962) should be erased - done
                  Edges are not connected in CLoop (107164) for CFace (107163)
                  Loop 0 of CFace (107163) is an invalid outer loop
                  Entity CFace (107163) should be erased - done
                  Edges are not connected in CLoop (107457) for CFace (107456)
                  Loop 0 of CFace (107456) is an invalid outer loop
                  Entity CFace (107456) should be erased - done
                  Edges are not connected in CLoop (107571) for CFace (107570)
                  Loop 0 of CFace (107570) is an invalid outer loop
                  Entity CFace (107570) should be erased - done
                  Edges are not connected in CLoop (107723) for CFace (107722)
                  Loop 0 of CFace (107722) is an invalid outer loop
                  Entity CFace (107722) should be erased - done
                  Edges are not connected in CLoop (107837) for CFace (107836)
                  Loop 0 of CFace (107836) is an invalid outer loop
                  Entity CFace (107836) should be erased - done
                  Edges are not connected in CLoop (107886) for CFace (107885)
                  Loop 0 of CFace (107885) is an invalid outer loop
                  Entity CFace (107885) should be erased - done
                  Edges are not connected in CLoop (108170) for CFace (108169)
                  Loop 0 of CFace (108169) is an invalid outer loop
                  Entity CFace (108169) should be erased - done
                  Edges are not connected in CLoop (108512) for CFace (108511)
                  Loop 0 of CFace (108511) is an invalid outer loop
                  Entity CFace (108511) should be erased - done
                  Edges are not connected in CLoop (108626) for CFace (108625)
                  Loop 0 of CFace (108625) is an invalid outer loop
                  Entity CFace (108625) should be erased - done
                  Edges are not connected in CLoop (108637) for CFace (108636)
                  Loop 0 of CFace (108636) is an invalid outer loop
                  Entity CFace (108636) should be erased - done
                  Edges are not connected in CLoop (108778) for CFace (108777)
                  Loop 0 of CFace (108777) is an invalid outer loop
                  Entity CFace (108777) should be erased - done
                  Edges are not connected in CLoop (108930) for CFace (108929)
                  Loop 0 of CFace (108929) is an invalid outer loop
                  Entity CFace (108929) should be erased - done
                  Edges are not connected in CLoop (109272) for CFace (109271)
                  Loop 0 of CFace (109271) is an invalid outer loop
                  Entity CFace (109271) should be erased - done
                  Edges are not connected in CLoop (109359) for CFace (109358)
                  Loop 0 of CFace (109358) is an invalid outer loop
                  Entity CFace (109358) should be erased - done
                  Edges are not connected in CLoop (109614) for CFace (109613)
                  Loop 0 of CFace (109613) is an invalid outer loop
                  Entity CFace (109613) should be erased - done
                  Edges are not connected in CLoop (109766) for CFace (109765)
                  Loop 0 of CFace (109765) is an invalid outer loop
                  Entity CFace (109765) should be erased - done
                  Edges are not connected in CLoop (109880) for CFace (109879)
                  Loop 0 of CFace (109879) is an invalid outer loop
                  Entity CFace (109879) should be erased - done
                  Edges are not connected in CLoop (110023) for CFace (110022)
                  Loop 0 of CFace (110022) is an invalid outer loop
                  Entity CFace (110022) should be erased - done
                  Edges are not connected in CLoop (110034) for CFace (110033)
                  Loop 0 of CFace (110033) is an invalid outer loop
                  Entity CFace (110033) should be erased - done
                  Edges are not connected in CLoop (110356) for CFace (110355)
                  Loop 0 of CFace (110355) is an invalid outer loop
                  Entity CFace (110355) should be erased - done
                  Edges are not connected in CLoop (110698) for CFace (110697)
                  Loop 0 of CFace (110697) is an invalid outer loop
                  Entity CFace (110697) should be erased - done
                  Edges are not connected in CLoop (110812) for CFace (110811)
                  Loop 0 of CFace (110811) is an invalid outer loop
                  Entity CFace (110811) should be erased - done
                  Edges are not connected in CLoop (110823) for CFace (110822)
                  Loop 0 of CFace (110822) is an invalid outer loop
                  Entity CFace (110822) should be erased - done
                  Edges are not connected in CLoop (110964) for CFace (110963)
                  Loop 0 of CFace (110963) is an invalid outer loop
                  Entity CFace (110963) should be erased - done
                  Edges are not connected in CLoop (111391) for CFace (111390)
                  Loop 0 of CFace (111390) is an invalid outer loop
                  Entity CFace (111390) should be erased - done
                  Edges are not connected in CLoop (88878) for CFace (88877)
                  Loop 0 of CFace (88877) is an invalid outer loop
                  Entity CFace (88877) should be erased - done
                  Edges are not connected in CLoop (88981) for CFace (88980)
                  Loop 0 of CFace (88980) is an invalid outer loop
                  Entity CFace (88980) should be erased - done
                  Edges are not connected in CLoop (89064) for CFace (89063)
                  Loop 0 of CFace (89063) is an invalid outer loop
                  Entity CFace (89063) should be erased - done
                  Edges are not connected in CLoop (89216) for CFace (89215)
                  Loop 0 of CFace (89215) is an invalid outer loop
                  Entity CFace (89215) should be erased - done
                  Edges are not connected in CLoop (89377) for CFace (89376)
                  Loop 0 of CFace (89376) is an invalid outer loop
                  Entity CFace (89376) should be erased - done
                  Edges are not connected in CLoop (89464) for CFace (89463)
                  Loop 0 of CFace (89463) is an invalid outer loop
                  Entity CFace (89463) should be erased - done
                  Edges are not connected in CLoop (89529) for CFace (89528)
                  Loop 0 of CFace (89528) is an invalid outer loop
                  Entity CFace (89528) should be erased - done
                  Edges are not connected in CLoop (89985) for CFace (89984)
                  Loop 0 of CFace (89984) is an invalid outer loop
                  Entity CFace (89984) should be erased - done
                  Edges are not connected in CLoop (90137) for CFace (90136)
                  Loop 0 of CFace (90136) is an invalid outer loop
                  Entity CFace (90136) should be erased - done
                  Edges are not connected in CLoop (90186) for CFace (90185)
                  Loop 0 of CFace (90185) is an invalid outer loop
                  Entity CFace (90185) should be erased - done
                  Edges are not connected in CLoop (90486) for CFace (90485)
                  Loop 0 of CFace (90485) is an invalid outer loop
                  Entity CFace (90485) should be erased - done
                  Edges are not connected in CLoop (90719) for CFace (90718)
                  Loop 0 of CFace (90718) is an invalid outer loop
                  Entity CFace (90718) should be erased - done
                  Edges are not connected in CLoop (90920) for CFace (90919)
                  Loop 0 of CFace (90919) is an invalid outer loop
                  Entity CFace (90919) should be erased - done
                  Edges are not connected in CLoop (91061) for CFace (91060)
                  Loop 0 of CFace (91060) is an invalid outer loop
                  Entity CFace (91060) should be erased - done
                  Edges are not connected in CLoop (91104) for CFace (91103)
                  Loop 0 of CFace (91103) is an invalid outer loop
                  Entity CFace (91103) should be erased - done
                  Edges are not connected in CLoop (91180) for CFace (91179)
                  Loop 0 of CFace (91179) is an invalid outer loop
                  Entity CFace (91179) should be erased - done
                  Edges are not connected in CLoop (91413) for CFace (91412)
                  Loop 0 of CFace (91412) is an invalid outer loop
                  Entity CFace (91412) should be erased - done
                  Edges are not connected in CLoop (91538) for CFace (91537)
                  Loop 0 of CFace (91537) is an invalid outer loop
                  Entity CFace (91537) should be erased - done
                  Edges are not connected in CLoop (91603) for CFace (91602)
                  Loop 0 of CFace (91602) is an invalid outer loop
                  Entity CFace (91602) should be erased - done
                  Edges are not connected in CLoop (91800) for CFace (91799)
                  Loop 0 of CFace (91799) is an invalid outer loop
                  Entity CFace (91799) should be erased - done
                  Edges are not connected in CLoop (92104) for CFace (92103)
                  Loop 0 of CFace (92103) is an invalid outer loop
                  Entity CFace (92103) should be erased - done
                  Edges are not connected in CLoop (92261) for CFace (92260)
                  Loop 0 of CFace (92260) is an invalid outer loop
                  Entity CFace (92260) should be erased - done
                  Edges are not connected in CLoop (92310) for CFace (92309)
                  Loop 0 of CFace (92309) is an invalid outer loop
                  Entity CFace (92309) should be erased - done
                  Edges are not connected in CLoop (92603) for CFace (92602)
                  Loop 0 of CFace (92602) is an invalid outer loop
                  Entity CFace (92602) should be erased - done
                  Edges are not connected in CLoop (93003) for CFace (93002)
                  Loop 0 of CFace (93002) is an invalid outer loop
                  Entity CFace (93002) should be erased - done
                  Edges are not connected in CLoop (93182) for CFace (93181)
                  Loop 0 of CFace (93181) is an invalid outer loop
                  Entity CFace (93181) should be erased - done
                  Edges are not connected in CLoop (93258) for CFace (93257)
                  Loop 0 of CFace (93257) is an invalid outer loop
                  Entity CFace (93257) should be erased - done
                  Edges are not connected in CLoop (93535) for CFace (93534)
                  Loop 0 of CFace (93534) is an invalid outer loop
                  Entity CFace (93534) should be erased - done
                  Edges are not connected in CLoop (93600) for CFace (93599)
                  Loop 0 of CFace (93599) is an invalid outer loop
                  Entity CFace (93599) should be erased - done
                  Edges are not connected in CLoop (94065) for CFace (94064)
                  Loop 0 of CFace (94064) is an invalid outer loop
                  Entity CFace (94064) should be erased - done
                  Edges are not connected in CLoop (94141) for CFace (94140)
                  Loop 0 of CFace (94140) is an invalid outer loop
                  Entity CFace (94140) should be erased - done
                  Edges are not connected in CLoop (94152) for CFace (94151)
                  Loop 0 of CFace (94151) is an invalid outer loop
                  Entity CFace (94151) should be erased - done
                  Edges are not connected in CLoop (94521) for CFace (94520)
                  Loop 0 of CFace (94520) is an invalid outer loop
                  Entity CFace (94520) should be erased - done
                  Edges are not connected in CLoop (94836) for CFace (94835)
                  Loop 0 of CFace (94835) is an invalid outer loop
                  Entity CFace (94835) should be erased - done
                  Edges are not connected in CLoop (94977) for CFace (94976)
                  Loop 0 of CFace (94976) is an invalid outer loop
                  Entity CFace (94976) should be erased - done
                  Edges are not connected in CLoop (95024) for CFace (95023)
                  Loop 0 of CFace (95023) is an invalid outer loop
                  Entity CFace (95023) should be erased - done
                  Edges are not connected in CLoop (95138) for CFace (95137)
                  Loop 0 of CFace (95137) is an invalid outer loop
                  Entity CFace (95137) should be erased - done
                  Edges are not connected in CLoop (95453) for CFace (95452)
                  Loop 0 of CFace (95452) is an invalid outer loop
                  Entity CFace (95452) should be erased - done
                  Edges are not connected in CLoop (95518) for CFace (95517)
                  Loop 0 of CFace (95517) is an invalid outer loop
                  Entity CFace (95517) should be erased - done
                  Edges are not connected in CLoop (95936) for CFace (95935)
                  Loop 0 of CFace (95935) is an invalid outer loop
                  Entity CFace (95935) should be erased - done
                  Edges are not connected in CLoop (96003) for CFace (96002)
                  Loop 0 of CFace (96002) is an invalid outer loop
                  Entity CFace (96002) should be erased - done
                  Edges are not connected in CLoop (96052) for CFace (96051)
                  Loop 0 of CFace (96051) is an invalid outer loop
                  Entity CFace (96051) should be erased - done
                  Edges are not connected in CLoop (96383) for CFace (96382)
                  Loop 0 of CFace (96382) is an invalid outer loop
                  Entity CFace (96382) should be erased - done
                  Edges are not connected in CLoop (96535) for CFace (96534)
                  Loop 0 of CFace (96534) is an invalid outer loop
                  Entity CFace (96534) should be erased - done
                  Edges are not connected in CLoop (96736) for CFace (96735)
                  Loop 0 of CFace (96735) is an invalid outer loop
                  Entity CFace (96735) should be erased - done
                  Edges are not connected in CLoop (96877) for CFace (96876)
                  Loop 0 of CFace (96876) is an invalid outer loop
                  Entity CFace (96876) should be erased - done
                  Edges are not connected in CLoop (96962) for CFace (96961)
                  Loop 0 of CFace (96961) is an invalid outer loop
                  Entity CFace (96961) should be erased - done
                  Edges are not connected in CLoop (97351) for CFace (97350)
                  Loop 0 of CFace (97350) is an invalid outer loop
                  Entity CFace (97350) should be erased - done
                  Edges are not connected in CLoop (97362) for CFace (97361)
                  Loop 0 of CFace (97361) is an invalid outer loop
                  Entity CFace (97361) should be erased - done
                  Edges are not connected in CLoop (97503) for CFace (97502)
                  Loop 0 of CFace (97502) is an invalid outer loop
                  Entity CFace (97502) should be erased - done
                  Edges are not connected in CLoop (97769) for CFace (97768)
                  Loop 0 of CFace (97768) is an invalid outer loop
                  Entity CFace (97768) should be erased - done
                  Edges are not connected in CLoop (100248) for CFace (100247)
                  Loop 0 of CFace (100247) is an invalid outer loop
                  Entity CFace (100247) should be erased - done
                  Edges are not connected in CLoop (100400) for CFace (100399)
                  Loop 0 of CFace (100399) is an invalid outer loop
                  Entity CFace (100399) should be erased - done
                  Edges are not connected in CLoop (100601) for CFace (100600)
                  Loop 0 of CFace (100600) is an invalid outer loop
                  Entity CFace (100600) should be erased - done
                  Edges are not connected in CLoop (100818) for CFace (100817)
                  Loop 0 of CFace (100817) is an invalid outer loop
                  Entity CFace (100817) should be erased - done
                  Edges are not connected in CLoop (100970) for CFace (100969)
                  Loop 0 of CFace (100969) is an invalid outer loop
                  Entity CFace (100969) should be erased - done
                  Edges are not connected in CLoop (101151) for CFace (101150)
                  Loop 0 of CFace (101150) is an invalid outer loop
                  Entity CFace (101150) should be erased - done
                  Edges are not connected in CLoop (101265) for CFace (101264)
                  Loop 0 of CFace (101264) is an invalid outer loop
                  Entity CFace (101264) should be erased - done
                  Edges are not connected in CLoop (101352) for CFace (101351)
                  Loop 0 of CFace (101351) is an invalid outer loop
                  Entity CFace (101351) should be erased - done
                  Edges are not connected in CLoop (101455) for CFace (101454)
                  Loop 0 of CFace (101454) is an invalid outer loop
                  Entity CFace (101454) should be erased - done
                  Edges are not connected in CLoop (101873) for CFace (101872)
                  Loop 0 of CFace (101872) is an invalid outer loop
                  Entity CFace (101872) should be erased - done
                  Edges are not connected in CLoop (101987) for CFace (101986)
                  Loop 0 of CFace (101986) is an invalid outer loop
                  Entity CFace (101986) should be erased - done
                  Edges are not connected in CLoop (101998) for CFace (101997)
                  Loop 0 of CFace (101997) is an invalid outer loop
                  Entity CFace (101997) should be erased - done
                  Edges are not connected in CLoop (102262) for CFace (102261)
                  Loop 0 of CFace (102261) is an invalid outer loop
                  Entity CFace (102261) should be erased - done
                  Edges are not connected in CLoop (97883) for CFace (97882)
                  Loop 0 of CFace (97882) is an invalid outer loop
                  Entity CFace (97882) should be erased - done
                  Edges are not connected in CLoop (97932) for CFace (97931)
                  Loop 0 of CFace (97931) is an invalid outer loop
                  Entity CFace (97931) should be erased - done
                  Edges are not connected in CLoop (98263) for CFace (98262)
                  Loop 0 of CFace (98262) is an invalid outer loop
                  Entity CFace (98262) should be erased - done
                  Edges are not connected in CLoop (98415) for CFace (98414)
                  Loop 0 of CFace (98414) is an invalid outer loop
                  Entity CFace (98414) should be erased - done
                  Edges are not connected in CLoop (98645) for CFace (98644)
                  Loop 0 of CFace (98644) is an invalid outer loop
                  Entity CFace (98644) should be erased - done
                  Edges are not connected in CLoop (98748) for CFace (98747)
                  Loop 0 of CFace (98747) is an invalid outer loop
                  Entity CFace (98747) should be erased - done
                  Edges are not connected in CLoop (98938) for CFace (98937)
                  Loop 0 of CFace (98937) is an invalid outer loop
                  Entity CFace (98937) should be erased - done
                  Edges are not connected in CLoop (99166) for CFace (99165)
                  Loop 0 of CFace (99165) is an invalid outer loop
                  Entity CFace (99165) should be erased - done
                  Edges are not connected in CLoop (99253) for CFace (99252)
                  Loop 0 of CFace (99252) is an invalid outer loop
                  Entity CFace (99252) should be erased - done
                  Edges are not connected in CLoop (99365) for CFace (99364)
                  Loop 0 of CFace (99364) is an invalid outer loop
                  Entity CFace (99364) should be erased - done
                  Edges are not connected in CLoop (99441) for CFace (99440)
                  Loop 0 of CFace (99440) is an invalid outer loop
                  Entity CFace (99440) should be erased - done
                  Edges are not connected in CLoop (99707) for CFace (99706)
                  Loop 0 of CFace (99706) is an invalid outer loop
                  Entity CFace (99706) should be erased - done
                  Edges are not connected in CLoop (99935) for CFace (99934)
                  Loop 0 of CFace (99934) is an invalid outer loop
                  Entity CFace (99934) should be erased - done
                  Edges are not connected in CLoop (99946) for CFace (99945)
                  Loop 0 of CFace (99945) is an invalid outer loop
                  Entity CFace (99945) should be erased - done
                  Edges are not connected in CLoop (102376) for CFace (102375)
                  Loop 0 of CFace (102375) is an invalid outer loop
                  Entity CFace (102375) should be erased - done
                  Edges are not connected in CLoop (102566) for CFace (102565)
                  Loop 0 of CFace (102565) is an invalid outer loop
                  Entity CFace (102565) should be erased - done
                  Edges are not connected in CLoop (102805) for CFace (102804)
                  Loop 0 of CFace (102804) is an invalid outer loop
                  Entity CFace (102804) should be erased - done
                  Edges are not connected in CLoop (102984) for CFace (102983)
                  Loop 0 of CFace (102983) is an invalid outer loop
                  Entity CFace (102983) should be erased - done
                  Edges are not connected in CLoop (103136) for CFace (103135)
                  Loop 0 of CFace (103135) is an invalid outer loop
                  Entity CFace (103135) should be erased - done
                  Edges are not connected in CLoop (103326) for CFace (103325)
                  Loop 0 of CFace (103325) is an invalid outer loop
                  Entity CFace (103325) should be erased - done
                  Edges are not connected in CLoop (103440) for CFace (103439)
                  Loop 0 of CFace (103439) is an invalid outer loop
                  Entity CFace (103439) should be erased - done
                  Edges are not connected in CLoop (103527) for CFace (103526)
                  Loop 0 of CFace (103526) is an invalid outer loop
                  Entity CFace (103526) should be erased - done
                  Edges are not connected in CLoop (103630) for CFace (103629)
                  Loop 0 of CFace (103629) is an invalid outer loop
                  Entity CFace (103629) should be erased - done
                  Edges are not connected in CLoop (104095) for CFace (104094)
                  Loop 0 of CFace (104094) is an invalid outer loop
                  Entity CFace (104094) should be erased - done
                  Edges are not connected in CLoop (104209) for CFace (104208)
                  Loop 0 of CFace (104208) is an invalid outer loop
                  Entity CFace (104208) should be erased - done
                  Edges are not connected in CLoop (104220) for CFace (104219)
                  Loop 0 of CFace (104219) is an invalid outer loop
                  Entity CFace (104219) should be erased - done
                  Edges are not connected in CLoop (104446) for CFace (104445)
                  Loop 0 of CFace (104445) is an invalid outer loop
                  Entity CFace (104445) should be erased - done
                  Edges are not connected in CLoop (104560) for CFace (104559)
                  Loop 0 of CFace (104559) is an invalid outer loop
                  Entity CFace (104559) should be erased - done
                  Edges are not connected in CLoop (104712) for CFace (104711)
                  Loop 0 of CFace (104711) is an invalid outer loop
                  Entity CFace (104711) should be erased - done
                  Edges are not connected in CLoop (104989) for CFace (104988)
                  Loop 0 of CFace (104988) is an invalid outer loop
                  Entity CFace (104988) should be erased - done
                  Edges are not connected in CLoop (105253) for CFace (105252)
                  Loop 0 of CFace (105252) is an invalid outer loop
                  Entity CFace (105252) should be erased - done
                  Edges are not connected in CLoop (105367) for CFace (105366)
                  Loop 0 of CFace (105366) is an invalid outer loop
                  Entity CFace (105366) should be erased - done
                  Edges are not connected in CLoop (105548) for CFace (105547)
                  Loop 0 of CFace (105547) is an invalid outer loop
                  Entity CFace (105547) should be erased - done
                  Edges are not connected in CLoop (105662) for CFace (105661)
                  Loop 0 of CFace (105661) is an invalid outer loop
                  Entity CFace (105661) should be erased - done
                  Edges are not connected in CLoop (105711) for CFace (105710)
                  Loop 0 of CFace (105710) is an invalid outer loop
                  Entity CFace (105710) should be erased - done
                  Edges are not connected in CLoop (105852) for CFace (105851)
                  Loop 0 of CFace (105851) is an invalid outer loop
                  Entity CFace (105851) should be erased - done
                  Edges are not connected in CLoop (106308) for CFace (106307)
                  Loop 0 of CFace (106307) is an invalid outer loop
                  Entity CFace (106307) should be erased - done
                  Edges are not connected in CLoop (106460) for CFace (106459)
                  Loop 0 of CFace (106459) is an invalid outer loop
                  Entity CFace (106459) should be erased - done
                  Edges are not connected in CLoop (106471) for CFace (106470)
                  Loop 0 of CFace (106470) is an invalid outer loop
                  Entity CFace (106470) should be erased - done
                  Edges are not connected in CLoop (106659) for CFace (106658)
                  Loop 0 of CFace (106658) is an invalid outer loop
                  Entity CFace (106658) should be erased - done
                  Edges are not connected in CLoop (106773) for CFace (106772)
                  Loop 0 of CFace (106772) is an invalid outer loop
                  Entity CFace (106772) should be erased - done
                  Edges are not connected in CLoop (111516) for CFace (111515)
                  Loop 0 of CFace (111515) is an invalid outer loop
                  Entity CFace (111515) should be erased - done
                  Edges are not connected in CLoop (111771) for CFace (111770)
                  Loop 0 of CFace (111770) is an invalid outer loop
                  Entity CFace (111770) should be erased - done
                  Edges are not connected in CLoop (111885) for CFace (111884)
                  Loop 0 of CFace (111884) is an invalid outer loop
                  Entity CFace (111884) should be erased - done
                  Edges are not connected in CLoop (111990) for CFace (111989)
                  Loop 0 of CFace (111989) is an invalid outer loop
                  Entity CFace (111989) should be erased - done
                  Edges are not connected in CLoop (112115) for CFace (112114)
                  Loop 0 of CFace (112114) is an invalid outer loop
                  Entity CFace (112114) should be erased - done
                  Edges are not connected in CLoop (112408) for CFace (112407)
                  Loop 0 of CFace (112407) is an invalid outer loop
                  Entity CFace (112407) should be erased - done
                  Edges are not connected in CLoop (112750) for CFace (112749)
                  Loop 0 of CFace (112749) is an invalid outer loop
                  Entity CFace (112749) should be erased - done
                  Edges are not connected in CLoop (112902) for CFace (112901)
                  Loop 0 of CFace (112901) is an invalid outer loop
                  Entity CFace (112901) should be erased - done
                  Edges are not connected in CLoop (112913) for CFace (112912)
                  Loop 0 of CFace (112912) is an invalid outer loop
                  Entity CFace (112912) should be erased - done
                  Edges are not connected in CLoop (113092) for CFace (113091)
                  Loop 0 of CFace (113091) is an invalid outer loop
                  Entity CFace (113091) should be erased - done
                  Edges are not connected in CLoop (113434) for CFace (113433)
                  Loop 0 of CFace (113433) is an invalid outer loop
                  Entity CFace (113433) should be erased - done
                  Edges are not connected in CLoop (113559) for CFace (113558)
                  Loop 0 of CFace (113558) is an invalid outer loop
                  Entity CFace (113558) should be erased - done
                  Edges are not connected in CLoop (113814) for CFace (113813)
                  Loop 0 of CFace (113813) is an invalid outer loop
                  Entity CFace (113813) should be erased - done
                  Edges are not connected in CLoop (113928) for CFace (113927)
                  Loop 0 of CFace (113927) is an invalid outer loop
                  Entity CFace (113927) should be erased - done
                  Edges are not connected in CLoop (114080) for CFace (114079)
                  Loop 0 of CFace (114079) is an invalid outer loop
                  Entity CFace (114079) should be erased - done
                  Edges are not connected in CLoop (114281) for CFace (114280)
                  Loop 0 of CFace (114280) is an invalid outer loop
                  Entity CFace (114280) should be erased - done
                  Edges are not connected in CLoop (114460) for CFace (114459)
                  Loop 0 of CFace (114459) is an invalid outer loop
                  Entity CFace (114459) should be erased - done
                  Edges are not connected in CLoop (114869) for CFace (114868)
                  Loop 0 of CFace (114868) is an invalid outer loop
                  Entity CFace (114868) should be erased - done
                  Edges are not connected in CLoop (114945) for CFace (114944)
                  Loop 0 of CFace (114944) is an invalid outer loop
                  Entity CFace (114944) should be erased - done
                  Edges are not connected in CLoop (114956) for CFace (114955)
                  Loop 0 of CFace (114955) is an invalid outer loop
                  Entity CFace (114955) should be erased - done
                  Edges are not connected in CLoop (115135) for CFace (115134)
                  Loop 0 of CFace (115134) is an invalid outer loop
                  Entity CFace (115134) should be erased - done
                  Edges are not connected in CLoop (115439) for CFace (115438)
                  Loop 0 of CFace (115438) is an invalid outer loop
                  Entity CFace (115438) should be erased - done
                  Edges are not connected in CLoop (115526) for CFace (115525)
                  Loop 0 of CFace (115525) is an invalid outer loop
                  Entity CFace (115525) should be erased - done
                  Edges are not connected in CLoop (115772) for CFace (115771)
                  Loop 0 of CFace (115771) is an invalid outer loop
                  Entity CFace (115771) should be erased - done
                  Edges are not connected in CLoop (115886) for CFace (115885)
                  Loop 0 of CFace (115885) is an invalid outer loop
                  Entity CFace (115885) should be erased - done
                  Edges are not connected in CLoop (116085) for CFace (116084)
                  Loop 0 of CFace (116084) is an invalid outer loop
                  Entity CFace (116084) should be erased - done
                  Edges are not connected in CLoop (116248) for CFace (116247)
                  Loop 0 of CFace (116247) is an invalid outer loop
                  Entity CFace (116247) should be erased - done
                  Edges are not connected in CLoop (116427) for CFace (116426)
                  Loop 0 of CFace (116426) is an invalid outer loop
                  Entity CFace (116426) should be erased - done
                  Edges are not connected in CLoop (116740) for CFace (116739)
                  Loop 0 of CFace (116739) is an invalid outer loop
                  Entity CFace (116739) should be erased - done
                  Edges are not connected in CLoop (116845) for CFace (116844)
                  Loop 0 of CFace (116844) is an invalid outer loop
                  Entity CFace (116844) should be erased - done
                  Edges are not connected in CLoop (116856) for CFace (116855)
                  Loop 0 of CFace (116855) is an invalid outer loop
                  Entity CFace (116855) should be erased - done
                  Edges are not connected in CLoop (117035) for CFace (117034)
                  Loop 0 of CFace (117034) is an invalid outer loop
                  Entity CFace (117034) should be erased - done
                  Edges are not connected in CLoop (117339) for CFace (117338)
                  Loop 0 of CFace (117338) is an invalid outer loop
                  Entity CFace (117338) should be erased - done
                  Edges are not connected in CLoop (117464) for CFace (117463)
                  Loop 0 of CFace (117463) is an invalid outer loop
                  Entity CFace (117463) should be erased - done
                  Edges are not connected in CLoop (117719) for CFace (117718)
                  Loop 0 of CFace (117718) is an invalid outer loop
                  Entity CFace (117718) should be erased - done
                  Edges are not connected in CLoop (117956) for CFace (117955)
                  Loop 0 of CFace (117955) is an invalid outer loop
                  Entity CFace (117955) should be erased - done
                  Edges are not connected in CLoop (118110) for CFace (118109)
                  Loop 0 of CFace (118109) is an invalid outer loop
                  Entity CFace (118109) should be erased - done
                  Edges are not connected in CLoop (118327) for CFace (118326)
                  Loop 0 of CFace (118326) is an invalid outer loop
                  Entity CFace (118326) should be erased - done
                  Edges are not connected in CLoop (118631) for CFace (118630)
                  Loop 0 of CFace (118630) is an invalid outer loop
                  Entity CFace (118630) should be erased - done
                  Edges are not connected in CLoop (118718) for CFace (118717)
                  Loop 0 of CFace (118717) is an invalid outer loop
                  Entity CFace (118717) should be erased - done
                  Edges are not connected in CLoop (118897) for CFace (118896)
                  Loop 0 of CFace (118896) is an invalid outer loop
                  Entity CFace (118896) should be erased - done
                  Edges are not connected in CLoop (119201) for CFace (119200)
                  Loop 0 of CFace (119200) is an invalid outer loop
                  Entity CFace (119200) should be erased - done
                  Edges are not connected in CLoop (119326) for CFace (119325)
                  Loop 0 of CFace (119325) is an invalid outer loop
                  Entity CFace (119325) should be erased - done
                  Edges are not connected in CLoop (119543) for CFace (119542)
                  Loop 0 of CFace (119542) is an invalid outer loop
                  Entity CFace (119542) should be erased - done
                  Edges are not connected in CLoop (119800) for CFace (119799)
                  Loop 0 of CFace (119799) is an invalid outer loop
                  Entity CFace (119799) should be erased - done
                  Edges are not connected in CLoop (120104) for CFace (120103)
                  Loop 0 of CFace (120103) is an invalid outer loop
                  Entity CFace (120103) should be erased - done
                  Edges are not connected in CLoop (120446) for CFace (120445)
                  Loop 0 of CFace (120445) is an invalid outer loop
                  Entity CFace (120445) should be erased - done
                  Edges are not connected in CLoop (120636) for CFace (120635)
                  Loop 0 of CFace (120635) is an invalid outer loop
                  Entity CFace (120635) should be erased - done
                  Edges are not connected in CLoop (120817) for CFace (120816)
                  Loop 0 of CFace (120816) is an invalid outer loop
                  Entity CFace (120816) should be erased - done
                  Edges are not connected in CLoop (121007) for CFace (121006)
                  Loop 0 of CFace (121006) is an invalid outer loop
                  Entity CFace (121006) should be erased - done
                  Edges are not connected in CLoop (121311) for CFace (121310)
                  Loop 0 of CFace (121310) is an invalid outer loop
                  Entity CFace (121310) should be erased - done
                  Edges are not connected in CLoop (121501) for CFace (121500)
                  Loop 0 of CFace (121500) is an invalid outer loop
                  Entity CFace (121500) should be erased - done
                  Edges are not connected in CLoop (121843) for CFace (121842)
                  Loop 0 of CFace (121842) is an invalid outer loop
                  Entity CFace (121842) should be erased - done
                  Edges are not connected in CLoop (122261) for CFace (122260)
                  Loop 0 of CFace (122260) is an invalid outer loop
                  Entity CFace (122260) should be erased - done
                  Edges are not connected in CLoop (122299) for CFace (122298)
                  Loop 0 of CFace (122298) is an invalid outer loop
                  Entity CFace (122298) should be erased - done
                  Edges are not connected in CLoop (122413) for CFace (122412)
                  Loop 0 of CFace (122412) is an invalid outer loop
                  Entity CFace (122412) should be erased - done
                  Edges are not connected in CLoop (122755) for CFace (122754)
                  Loop 0 of CFace (122754) is an invalid outer loop
                  Entity CFace (122754) should be erased - done
                  Edges are not connected in CLoop (123164) for CFace (123163)
                  Loop 0 of CFace (123163) is an invalid outer loop
                  Entity CFace (123163) should be erased - done
                  Edges are not connected in CLoop (123202) for CFace (123201)
                  Loop 0 of CFace (123201) is an invalid outer loop
                  Entity CFace (123201) should be erased - done
                  Edges are not connected in CLoop (123316) for CFace (123315)
                  Loop 0 of CFace (123315) is an invalid outer loop
                  Entity CFace (123315) should be erased - done
                  Edges are not connected in CLoop (123365) for CFace (123364)
                  Loop 0 of CFace (123364) is an invalid outer loop
                  Entity CFace (123364) should be erased - done
                  Edges are not connected in CLoop (123696) for CFace (123695)
                  Loop 0 of CFace (123695) is an invalid outer loop
                  Entity CFace (123695) should be erased - done
                  Edges are not connected in CLoop (124038) for CFace (124037)
                  Loop 0 of CFace (124037) is an invalid outer loop
                  Entity CFace (124037) should be erased - done
                  Edges are not connected in CLoop (124076) for CFace (124075)
                  Loop 0 of CFace (124075) is an invalid outer loop
                  Entity CFace (124075) should be erased - done
                  Edges are not connected in CLoop (124228) for CFace (124227)
                  Loop 0 of CFace (124227) is an invalid outer loop
                  Entity CFace (124227) should be erased - done
                  Edges are not connected in CLoop (124570) for CFace (124569)
                  Loop 0 of CFace (124569) is an invalid outer loop
                  Entity CFace (124569) should be erased - done
                  Edges are not connected in CLoop (124657) for CFace (124656)
                  Loop 0 of CFace (124656) is an invalid outer loop
                  Entity CFace (124656) should be erased - done
                  Edges are not connected in CLoop (124988) for CFace (124987)
                  Loop 0 of CFace (124987) is an invalid outer loop
                  Entity CFace (124987) should be erased - done
                  Edges are not connected in CLoop (125026) for CFace (125025)
                  Loop 0 of CFace (125025) is an invalid outer loop
                  Entity CFace (125025) should be erased - done
                  Edges are not connected in CLoop (125140) for CFace (125139)
                  Loop 0 of CFace (125139) is an invalid outer loop
                  Entity CFace (125139) should be erased - done
                  Edges are not connected in CLoop (125265) for CFace (125264)
                  Loop 0 of CFace (125264) is an invalid outer loop
                  Entity CFace (125264) should be erased - done
                  Edges are not connected in CLoop (125558) for CFace (125557)
                  Loop 0 of CFace (125557) is an invalid outer loop
                  Entity CFace (125557) should be erased - done
                  Edges are not connected in CLoop (125938) for CFace (125937)
                  Loop 0 of CFace (125937) is an invalid outer loop
                  Entity CFace (125937) should be erased - done
                  Edges are not connected in CLoop (125949) for CFace (125948)
                  Loop 0 of CFace (125948) is an invalid outer loop
                  Entity CFace (125948) should be erased - done
                  Edges are not connected in CLoop (126014) for CFace (126013)
                  Loop 0 of CFace (126013) is an invalid outer loop
                  Entity CFace (126013) should be erased - done
                  Edges are not connected in CLoop (126059) for CFace (126058)
                  Loop 0 of CFace (126058) is an invalid outer loop
                  Entity CFace (126058) should be erased - done
                  Edges are not connected in CLoop (126173) for CFace (126172)
                  Loop 0 of CFace (126172) is an invalid outer loop
                  Entity CFace (126172) should be erased - done
                  Edges are not connected in CLoop (126553) for CFace (126552)
                  Loop 0 of CFace (126552) is an invalid outer loop
                  Entity CFace (126552) should be erased - done
                  Edges are not connected in CLoop (126602) for CFace (126601)
                  Loop 0 of CFace (126601) is an invalid outer loop
                  Entity CFace (126601) should be erased - done
                  Edges are not connected in CLoop (126895) for CFace (126894)
                  Loop 0 of CFace (126894) is an invalid outer loop
                  Entity CFace (126894) should be erased - done
                  Edges are not connected in CLoop (126933) for CFace (126932)
                  Loop 0 of CFace (126932) is an invalid outer loop
                  Entity CFace (126932) should be erased - done
                  Edges are not connected in CLoop (127014) for CFace (127013)
                  Loop 0 of CFace (127013) is an invalid outer loop
                  Entity CFace (127013) should be erased - done
                  Edges are not connected in CLoop (127128) for CFace (127127)
                  Loop 0 of CFace (127127) is an invalid outer loop
                  Entity CFace (127127) should be erased - done
                  Edges are not connected in CLoop (127215) for CFace (127214)
                  Loop 0 of CFace (127214) is an invalid outer loop
                  Entity CFace (127214) should be erased - done
                  Edges are not connected in CLoop (127575) for CFace (127574)
                  Loop 0 of CFace (127574) is an invalid outer loop
                  Entity CFace (127574) should be erased - done
                  Edges are not connected in CLoop (127908) for CFace (127907)
                  Loop 0 of CFace (127907) is an invalid outer loop
                  Entity CFace (127907) should be erased - done
                  Edges are not connected in CLoop (127919) for CFace (127918)
                  Loop 0 of CFace (127918) is an invalid outer loop
                  Entity CFace (127918) should be erased - done
                  Edges are not connected in CLoop (127984) for CFace (127983)
                  Loop 0 of CFace (127983) is an invalid outer loop
                  Entity CFace (127983) should be erased - done
                  Edges are not connected in CLoop (128029) for CFace (128028)
                  Loop 0 of CFace (128028) is an invalid outer loop
                  Entity CFace (128028) should be erased - done
                  Edges are not connected in CLoop (128143) for CFace (128142)
                  Loop 0 of CFace (128142) is an invalid outer loop
                  Entity CFace (128142) should be erased - done
                  Edges are not connected in CLoop (128476) for CFace (128475)
                  Loop 0 of CFace (128475) is an invalid outer loop
                  Entity CFace (128475) should be erased - done
                  Edges are not connected in CLoop (128525) for CFace (128524)
                  Loop 0 of CFace (128524) is an invalid outer loop
                  Entity CFace (128524) should be erased - done
                  Edges are not connected in CLoop (128847) for CFace (128846)
                  Loop 0 of CFace (128846) is an invalid outer loop
                  Entity CFace (128846) should be erased - done
                  Edges are not connected in CLoop (128890) for CFace (128889)
                  Loop 0 of CFace (128889) is an invalid outer loop
                  Entity CFace (128889) should be erased - done
                  Edges are not connected in CLoop (129004) for CFace (129003)
                  Loop 0 of CFace (129003) is an invalid outer loop
                  Entity CFace (129003) should be erased - done
                  Edges are not connected in CLoop (129071) for CFace (129070)
                  Loop 0 of CFace (129070) is an invalid outer loop
                  Entity CFace (129070) should be erased - done
                  Edges are not connected in CLoop (129178) for CFace (129177)
                  Loop 0 of CFace (129177) is an invalid outer loop
                  Entity CFace (129177) should be erased - done
                  Edges are not connected in CLoop (129277) for CFace (129276)
                  Loop 0 of CFace (129276) is an invalid outer loop
                  Entity CFace (129276) should be erased - done
                  Edges are not connected in CLoop (129489) for CFace (129488)
                  Loop 0 of CFace (129488) is an invalid outer loop
                  Entity CFace (129488) should be erased - done
                  Edges are not connected in CLoop (129735) for CFace (129734)
                  Loop 0 of CFace (129734) is an invalid outer loop
                  Entity CFace (129734) should be erased - done
                  Edges are not connected in CLoop (129743) for CFace (129742)
                  Loop 0 of CFace (129742) is an invalid outer loop
                  Entity CFace (129742) should be erased - done
                  Edges are not connected in CLoop (129880) for CFace (129879)
                  Loop 0 of CFace (129879) is an invalid outer loop
                  Entity CFace (129879) should be erased - done
                  Edges are not connected in CLoop (129989) for CFace (129988)
                  Loop 0 of CFace (129988) is an invalid outer loop
                  Entity CFace (129988) should be erased - done
                  Edges are not connected in CLoop (130005) for CFace (130004)
                  Loop 0 of CFace (130004) is an invalid outer loop
                  Entity CFace (130004) should be erased - done
                  Edges are not connected in CLoop (130021) for CFace (130020)
                  Loop 0 of CFace (130020) is an invalid outer loop
                  Entity CFace (130020) should be erased - done
                  Edges are not connected in CLoop (130034) for CFace (130033)
                  Loop 0 of CFace (130033) is an invalid outer loop
                  Entity CFace (130033) should be erased - done
                  Edges are not connected in CLoop (130114) for CFace (130113)
                  Loop 0 of CFace (130113) is an invalid outer loop
                  Entity CFace (130113) should be erased - done
                  Edges are not connected in CLoop (130130) for CFace (130129)
                  Loop 0 of CFace (130129) is an invalid outer loop
                  Entity CFace (130129) should be erased - done
                  Edges are not connected in CLoop (130146) for CFace (130145)
                  Loop 0 of CFace (130145) is an invalid outer loop
                  Entity CFace (130145) should be erased - done
                  Edges are not connected in CLoop (130159) for CFace (130158)
                  Loop 0 of CFace (130158) is an invalid outer loop
                  Entity CFace (130158) should be erased - done
                  Edges are not connected in CLoop (130239) for CFace (130238)
                  Loop 0 of CFace (130238) is an invalid outer loop
                  Entity CFace (130238) should be erased - done
                  Edges are not connected in CLoop (130255) for CFace (130254)
                  Loop 0 of CFace (130254) is an invalid outer loop
                  Entity CFace (130254) should be erased - done
                  Edges are not connected in CLoop (130271) for CFace (130270)
                  Loop 0 of CFace (130270) is an invalid outer loop
                  Entity CFace (130270) should be erased - done
                  Edges are not connected in CLoop (130284) for CFace (130283)
                  Loop 0 of CFace (130283) is an invalid outer loop
                  Entity CFace (130283) should be erased - done
                  Edges are not connected in CLoop (130364) for CFace (130363)
                  Loop 0 of CFace (130363) is an invalid outer loop
                  Entity CFace (130363) should be erased - done
                  Edges are not connected in CLoop (130380) for CFace (130379)
                  Loop 0 of CFace (130379) is an invalid outer loop
                  Entity CFace (130379) should be erased - done
                  Edges are not connected in CLoop (130396) for CFace (130395)
                  Loop 0 of CFace (130395) is an invalid outer loop
                  Entity CFace (130395) should be erased - done
                  Edges are not connected in CLoop (130409) for CFace (130408)
                  Loop 0 of CFace (130408) is an invalid outer loop
                  Entity CFace (130408) should be erased - done
                  Edges are not connected in CLoop (130489) for CFace (130488)
                  Loop 0 of CFace (130488) is an invalid outer loop
                  Entity CFace (130488) should be erased - done
                  Edges are not connected in CLoop (130505) for CFace (130504)
                  Loop 0 of CFace (130504) is an invalid outer loop
                  Entity CFace (130504) should be erased - done
                  Edges are not connected in CLoop (130521) for CFace (130520)
                  Loop 0 of CFace (130520) is an invalid outer loop
                  Entity CFace (130520) should be erased - done
                  Edges are not connected in CLoop (130534) for CFace (130533)
                  Loop 0 of CFace (130533) is an invalid outer loop
                  Entity CFace (130533) should be erased - done
                  Edges are not connected in CLoop (130614) for CFace (130613)
                  Loop 0 of CFace (130613) is an invalid outer loop
                  Entity CFace (130613) should be erased - done
                  Edges are not connected in CLoop (130630) for CFace (130629)
                  Loop 0 of CFace (130629) is an invalid outer loop
                  Entity CFace (130629) should be erased - done
                  Edges are not connected in CLoop (130646) for CFace (130645)
                  Loop 0 of CFace (130645) is an invalid outer loop
                  Entity CFace (130645) should be erased - done
                  Edges are not connected in CLoop (130659) for CFace (130658)
                  Loop 0 of CFace (130658) is an invalid outer loop
                  Entity CFace (130658) should be erased - done
                  Edges are not connected in CLoop (130739) for CFace (130738)
                  Loop 0 of CFace (130738) is an invalid outer loop
                  Entity CFace (130738) should be erased - done
                  Edges are not connected in CLoop (130755) for CFace (130754)
                  Loop 0 of CFace (130754) is an invalid outer loop
                  Entity CFace (130754) should be erased - done
                  Edges are not connected in CLoop (130771) for CFace (130770)
                  Loop 0 of CFace (130770) is an invalid outer loop
                  Entity CFace (130770) should be erased - done
                  Edges are not connected in CLoop (130784) for CFace (130783)
                  Loop 0 of CFace (130783) is an invalid outer loop
                  Entity CFace (130783) should be erased - done
                  Edges are not connected in CLoop (130864) for CFace (130863)
                  Loop 0 of CFace (130863) is an invalid outer loop
                  Entity CFace (130863) should be erased - done
                  Edges are not connected in CLoop (130880) for CFace (130879)
                  Loop 0 of CFace (130879) is an invalid outer loop
                  Entity CFace (130879) should be erased - done
                  Edges are not connected in CLoop (130896) for CFace (130895)
                  Loop 0 of CFace (130895) is an invalid outer loop
                  Entity CFace (130895) should be erased - done
                  Edges are not connected in CLoop (130909) for CFace (130908)
                  Loop 0 of CFace (130908) is an invalid outer loop
                  Entity CFace (130908) should be erased - done
                  Edges are not connected in CLoop (130989) for CFace (130988)
                  Loop 0 of CFace (130988) is an invalid outer loop
                  Entity CFace (130988) should be erased - done
                  Edges are not connected in CLoop (131005) for CFace (131004)
                  Loop 0 of CFace (131004) is an invalid outer loop
                  Entity CFace (131004) should be erased - done
                  Edges are not connected in CLoop (131021) for CFace (131020)
                  Loop 0 of CFace (131020) is an invalid outer loop
                  Entity CFace (131020) should be erased - done
                  Edges are not connected in CLoop (131034) for CFace (131033)
                  Loop 0 of CFace (131033) is an invalid outer loop
                  Entity CFace (131033) should be erased - done
                  Edges are not connected in CLoop (131114) for CFace (131113)
                  Loop 0 of CFace (131113) is an invalid outer loop
                  Entity CFace (131113) should be erased - done
                  Edges are not connected in CLoop (131130) for CFace (131129)
                  Loop 0 of CFace (131129) is an invalid outer loop
                  Entity CFace (131129) should be erased - done
                  Edges are not connected in CLoop (131146) for CFace (131145)
                  Loop 0 of CFace (131145) is an invalid outer loop
                  Entity CFace (131145) should be erased - done
                  Edges are not connected in CLoop (131159) for CFace (131158)
                  Loop 0 of CFace (131158) is an invalid outer loop
                  Entity CFace (131158) should be erased - done
                  Edges are not connected in CLoop (131239) for CFace (131238)
                  Loop 0 of CFace (131238) is an invalid outer loop
                  Entity CFace (131238) should be erased - done
                  Edges are not connected in CLoop (131255) for CFace (131254)
                  Loop 0 of CFace (131254) is an invalid outer loop
                  Entity CFace (131254) should be erased - done
                  Edges are not connected in CLoop (131271) for CFace (131270)
                  Loop 0 of CFace (131270) is an invalid outer loop
                  Entity CFace (131270) should be erased - done
                  Edges are not connected in CLoop (131284) for CFace (131283)
                  Loop 0 of CFace (131283) is an invalid outer loop
                  Entity CFace (131283) should be erased - done
                  Edges are not connected in CLoop (131364) for CFace (131363)
                  Loop 0 of CFace (131363) is an invalid outer loop
                  Entity CFace (131363) should be erased - done
                  Edges are not connected in CLoop (131380) for CFace (131379)
                  Loop 0 of CFace (131379) is an invalid outer loop
                  Entity CFace (131379) should be erased - done
                  Edges are not connected in CLoop (131396) for CFace (131395)
                  Loop 0 of CFace (131395) is an invalid outer loop
                  Entity CFace (131395) should be erased - done
                  Edges are not connected in CLoop (131409) for CFace (131408)
                  Loop 0 of CFace (131408) is an invalid outer loop
                  Entity CFace (131408) should be erased - done
                  Edges are not connected in CLoop (131489) for CFace (131488)
                  Loop 0 of CFace (131488) is an invalid outer loop
                  Entity CFace (131488) should be erased - done
                  Edges are not connected in CLoop (131505) for CFace (131504)
                  Loop 0 of CFace (131504) is an invalid outer loop
                  Entity CFace (131504) should be erased - done
                  Edges are not connected in CLoop (131521) for CFace (131520)
                  Loop 0 of CFace (131520) is an invalid outer loop
                  Entity CFace (131520) should be erased - done
                  Edges are not connected in CLoop (131534) for CFace (131533)
                  Loop 0 of CFace (131533) is an invalid outer loop
                  Entity CFace (131533) should be erased - done
                  Edges are not connected in CLoop (131614) for CFace (131613)
                  Loop 0 of CFace (131613) is an invalid outer loop
                  Entity CFace (131613) should be erased - done
                  Edges are not connected in CLoop (131630) for CFace (131629)
                  Loop 0 of CFace (131629) is an invalid outer loop
                  Entity CFace (131629) should be erased - done
                  Edges are not connected in CLoop (131646) for CFace (131645)
                  Loop 0 of CFace (131645) is an invalid outer loop
                  Entity CFace (131645) should be erased - done
                  Edges are not connected in CLoop (131659) for CFace (131658)
                  Loop 0 of CFace (131658) is an invalid outer loop
                  Entity CFace (131658) should be erased - done
                  Edges are not connected in CLoop (131739) for CFace (131738)
                  Loop 0 of CFace (131738) is an invalid outer loop
                  Entity CFace (131738) should be erased - done
                  Edges are not connected in CLoop (131755) for CFace (131754)
                  Loop 0 of CFace (131754) is an invalid outer loop
                  Entity CFace (131754) should be erased - done
                  Edges are not connected in CLoop (131771) for CFace (131770)
                  Loop 0 of CFace (131770) is an invalid outer loop
                  Entity CFace (131770) should be erased - done
                  Edges are not connected in CLoop (131784) for CFace (131783)
                  Loop 0 of CFace (131783) is an invalid outer loop
                  Entity CFace (131783) should be erased - done
                  Edges are not connected in CLoop (131864) for CFace (131863)
                  Loop 0 of CFace (131863) is an invalid outer loop
                  Entity CFace (131863) should be erased - done
                  Edges are not connected in CLoop (131880) for CFace (131879)
                  Loop 0 of CFace (131879) is an invalid outer loop
                  Entity CFace (131879) should be erased - done
                  Edges are not connected in CLoop (131896) for CFace (131895)
                  Loop 0 of CFace (131895) is an invalid outer loop
                  Entity CFace (131895) should be erased - done
                  Edges are not connected in CLoop (131909) for CFace (131908)
                  Loop 0 of CFace (131908) is an invalid outer loop
                  Entity CFace (131908) should be erased - done
                  Daniel S
                    This suggests somethings are so small they appear to be coincident - to SUp - and 'fail'... ❓
                    • ken28875K
                      ken28875
                      I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😢
                      Does anyone have the same problem?
                      Thanks,
                      _KN
                      Follow Your Dreams.
                        I have never had that problem [Vista].
                        How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
                        • ken28875K
                          ken28875
                          Hi TIG,
                          It's only 40cm.
                          http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
                          Thanks,
                          _KN
                          Follow Your Dreams.
                            Unlikely to result in faces <1mm ?
                            • GaieusG
                              I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments 😄 )
                              • ken28875K
                                ken28875
                                What do you mean, TIG?
                                Thanks,
                                _KN
                                Follow Your Dreams.
                                • brookefoxB
                                  brookefox
                                  My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
                                  S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
                                  Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
                                  ~ Brooke
                                    If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
                                    I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
                                    Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
                                    • ken28875K
                                      ken28875
                                      Hi TIG,
                                      I don't have any problems with the Follow-me tool.
                                      Sketchup crashes only when I use RoundCorner. 😢
                                      Thanks,
                                      _KN
                                      Follow Your Dreams.
                                      • fredo6F
                                        @ken28875 said:
                                        Hi TIG,
                                        Thanks,
                                        _KN
                                        Ken,
                                        Could you post or send me the model, so that I can have a look at whatcrashes.
                                        I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                                        • fredo6F
                                          Normally the persistence is done for each individual tool, including the custom saving by the icons A, B, C, D
                                          I am not clear of what is the bad visual effect. Coul you post a picture or the model.
                                          • ken28875K
                                            ken28875
                                            Ken,
                                            Hi Fredo,
                                            I just sent you a private message. Unfortunately I could not attach the file. It's bigger than the allowed size of 4mb.
                                            Thanks,
                                            _KN
                                            Follow Your Dreams.
                                            • 11
                                            • 12
                                            • 13
                                            • 74
                                            • 75
                                            • 11 / 75
