    1.5k Posts 470 Posters 3.3m Views 469 Watching
    • X Offline
      xrok1
      i can't seem to reproduce the problems?? what version of SU do you have installed?
        Hi Hieru,
        I have downloaded scaled (up to 10 times) and rounded a corner of your model (with 200 radius and 6 segments which should be quite enough). Note the tape measure tool on the shortest edges which is now ~1.4 mm. If that value were somewhere (or less than) 1 mm, the face would not be created. This could well be the case if you scale it up by 10 but use more segments with the 20 mm radius.
        • HieruH Offline
          Hieru
          xrok1,
          I'm using SU 7.1.6087 (Free)
          Gaieus,
          When I scaled up the model and applied a 20mm radius, I still used 6 segments. The plugin doesn't appear to have a problem creating the faces and I can select them once created. The problem is that they vanish, along with hidden geometry, when I save the file.
          www.davidhier.co.uk
            I have no idea why that is happening. Try something: Go to your Window > Preferences > General tab and uncheck"Automatically fix problems..."
            The plugin mayproduce invalid geometry and upon saving, this option deletes it. If you keep "Automatically check model..." checked, SU should give you a warning. Then "fix" the model and it will present you with a list of what was fixed. Make a screenshot of that window and attach it here - it may help Fredo to improve the plugin (only IF this invalid geometry is the problem of course)
            • HieruH Offline
              Hieru
              Thanks Gaieus, I'll give that a go.
              As an update to the situation I uninstalled SU and then installed the latest version. I then added the RoundCorner plugin (as well as LibFredo) - no other plugins - and I still had the same problem.
              I did however find a way around the issue. By exploding geometry, applying the plugin and then re-grouping the geometry I didn't lose any of the corner faces when saving.
              www.davidhier.co.uk
                Hm. That's very interesting.
                • fredo6F Offline
                  Hieru,
                  I played with your model and could not reproduce the loss of faces, even if a small radius.
                  I would recommend you do what Gaieus recommends to see if this is not related to the model (the fact that the faces are computed by RoundCorner, but disappear when saving, seems to be a more general issue with the model than the plugin).
                  Also, if this is reproducable, could you try to copy the model within the same file and save to see if both instances have a loss of faces.
                  • HieruH Offline
                    Hieru
                    Hi Fredo6,
                    Thanks for taking the time to look at the model.
                    I followed Gaieus' instructions, but I don't get a warning when applying the plugin or saving the file.
                    Copying the model within the file results in a loss of faces in both sets of geometry. I also tried converting one group of geometry into a component and then applied the plugin. When saving there is a loss of faces for each instance of a component.
                    What was odd is the fact that when I loaded the component from the component palette it was reproduced at a much smaller scale than the original object. Presumably that isn't supposed to happen and is another indication that there is something odd about the model?
                    Luckily I have been able to apply the plugin using the method mentioned in my previous post, so I haven't had to remodel the light.
                    Also I've been working on an architectural model today and haven't had any trouble with the RoundCorner plugin.......so it looks more and more like this was a problem with my model........but can't think what the source of the problem might be.
                    www.davidhier.co.uk
                      Daniel S
                      I tried the model and I can´t reproduce the loss of faces... but I get the warning msg.
                      Results of Validity Check.
                      The start and end vertices are identical for CEdge (82816)
                      Entity CEdge (82816) should be erased - done
                      The start and end vertices are identical for CEdge (83152)
                      Entity CEdge (83152) should be erased - done
                      The start and end vertices are identical for CEdge (83230)
                      Entity CEdge (83230) should be erased - done
                      The start and end vertices are identical for CEdge (83324)
                      Entity CEdge (83324) should be erased - done
                      The start and end vertices are identical for CEdge (83738)
                      Entity CEdge (83738) should be erased - done
                      The start and end vertices are identical for CEdge (83879)
                      Entity CEdge (83879) should be erased - done
                      The start and end vertices are identical for CEdge (83965)
                      Entity CEdge (83965) should be erased - done
                      The start and end vertices are identical for CEdge (84015)
                      Entity CEdge (84015) should be erased - done
                      The start and end vertices are identical for CEdge (84124)
                      Entity CEdge (84124) should be erased - done
                      The start and end vertices are identical for CEdge (84399)
                      Entity CEdge (84399) should be erased - done
                      The start and end vertices are identical for CEdge (84751)
                      Entity CEdge (84751) should be erased - done
                      The start and end vertices are identical for CEdge (84763)
                      Entity CEdge (84763) should be erased - done
                      The start and end vertices are identical for CEdge (84903)
                      Entity CEdge (84903) should be erased - done
                      The start and end vertices are identical for CEdge (85017)
                      Entity CEdge (85017) should be erased - done
                      The start and end vertices are identical for CEdge (85186)
                      Entity CEdge (85186) should be erased - done
                      The start and end vertices are identical for CEdge (85351)
                      Entity CEdge (85351) should be erased - done
                      The start and end vertices are identical for CEdge (85757)
                      Entity CEdge (85757) should be erased - done
                      The start and end vertices are identical for CEdge (85918)
                      Entity CEdge (85918) should be erased - done
                      The start and end vertices are identical for CEdge (86032)
                      Entity CEdge (86032) should be erased - done
                      The start and end vertices are identical for CEdge (86082)
                      Entity CEdge (86082) should be erased - done
                      The start and end vertices are identical for CEdge (86191)
                      Entity CEdge (86191) should be erased - done
                      The start and end vertices are identical for CEdge (86771)
                      Entity CEdge (86771) should be erased - done
                      The start and end vertices are identical for CEdge (86783)
                      Entity CEdge (86783) should be erased - done
                      The start and end vertices are identical for CEdge (86923)
                      Entity CEdge (86923) should be erased - done
                      The start and end vertices are identical for CEdge (87075)
                      Entity CEdge (87075) should be erased - done
                      The start and end vertices are identical for CEdge (87361)
                      Entity CEdge (87361) should be erased - done
                      The start and end vertices are identical for CEdge (87852)
                      Entity CEdge (87852) should be erased - done
                      The start and end vertices are identical for CEdge (87928)
                      Entity CEdge (87928) should be erased - done
                      The start and end vertices are identical for CEdge (88080)
                      Entity CEdge (88080) should be erased - done
                      The start and end vertices are identical for CEdge (88168)
                      Entity CEdge (88168) should be erased - done
                      The start and end vertices are identical for CEdge (107162)
                      Entity CEdge (107162) should be erased - done
                      The start and end vertices are identical for CEdge (106469)
                      Entity CEdge (106469) should be erased - done
                      The start and end vertices are identical for CEdge (106305)
                      Entity CEdge (106305) should be erased - done
                      The start and end vertices are identical for CEdge (107454)
                      Entity CEdge (107454) should be erased - done
                      The start and end vertices are identical for CEdge (106457)
                      Entity CEdge (106457) should be erased - done
                      The start and end vertices are identical for CEdge (107568)
                      Entity CEdge (107568) should be erased - done
                      The start and end vertices are identical for CEdge (106656)
                      Entity CEdge (106656) should be erased - done
                      The start and end vertices are identical for CEdge (107720)
                      Entity CEdge (107720) should be erased - done
                      The start and end vertices are identical for CEdge (107884)
                      Entity CEdge (107884) should be erased - done
                      The start and end vertices are identical for CEdge (108509)
                      Entity CEdge (108509) should be erased - done
                      The start and end vertices are identical for CEdge (108623)
                      Entity CEdge (108623) should be erased - done
                      The start and end vertices are identical for CEdge (108635)
                      Entity CEdge (108635) should be erased - done
                      The start and end vertices are identical for CEdge (108775)
                      Entity CEdge (108775) should be erased - done
                      The start and end vertices are identical for CEdge (109357)
                      Entity CEdge (109357) should be erased - done
                      The start and end vertices are identical for CEdge (109611)
                      Entity CEdge (109611) should be erased - done
                      The start and end vertices are identical for CEdge (109763)
                      Entity CEdge (109763) should be erased - done
                      The start and end vertices are identical for CEdge (109877)
                      Entity CEdge (109877) should be erased - done
                      The start and end vertices are identical for CEdge (95020)
                      Entity CEdge (95020) should be erased - done
                      The start and end vertices are identical for CEdge (110032)
                      Entity CEdge (110032) should be erased - done
                      The start and end vertices are identical for CEdge (110695)
                      Entity CEdge (110695) should be erased - done
                      The start and end vertices are identical for CEdge (110809)
                      Entity CEdge (110809) should be erased - done
                      The start and end vertices are identical for CEdge (110821)
                      Entity CEdge (110821) should be erased - done
                      The start and end vertices are identical for CEdge (110961)
                      Entity CEdge (110961) should be erased - done
                      The start and end vertices are identical for CEdge (88876)
                      Entity CEdge (88876) should be erased - done
                      The start and end vertices are identical for CEdge (88978)
                      Entity CEdge (88978) should be erased - done
                      The start and end vertices are identical for CEdge (89060)
                      Entity CEdge (89060) should be erased - done
                      The start and end vertices are identical for CEdge (89213)
                      Entity CEdge (89213) should be erased - done
                      The start and end vertices are identical for CEdge (89373)
                      Entity CEdge (89373) should be erased - done
                      The start and end vertices are identical for CEdge (89462)
                      Entity CEdge (89462) should be erased - done
                      The start and end vertices are identical for CEdge (89982)
                      Entity CEdge (89982) should be erased - done
                      The start and end vertices are identical for CEdge (90134)
                      Entity CEdge (90134) should be erased - done
                      The start and end vertices are identical for CEdge (90184)
                      Entity CEdge (90184) should be erased - done
                      The start and end vertices are identical for CEdge (90715)
                      Entity CEdge (90715) should be erased - done
                      The start and end vertices are identical for CEdge (90918)
                      Entity CEdge (90918) should be erased - done
                      The start and end vertices are identical for CEdge (91058)
                      Entity CEdge (91058) should be erased - done
                      The start and end vertices are identical for CEdge (91100)
                      Entity CEdge (91100) should be erased - done
                      The start and end vertices are identical for CEdge (91177)
                      Entity CEdge (91177) should be erased - done
                      The start and end vertices are identical for CEdge (91409)
                      Entity CEdge (91409) should be erased - done
                      The start and end vertices are identical for CEdge (91536)
                      Entity CEdge (91536) should be erased - done
                      The start and end vertices are identical for CEdge (91796)
                      Entity CEdge (91796) should be erased - done
                      The start and end vertices are identical for CEdge (92101)
                      Entity CEdge (92101) should be erased - done
                      The start and end vertices are identical for CEdge (92258)
                      Entity CEdge (92258) should be erased - done
                      The start and end vertices are identical for CEdge (92308)
                      Entity CEdge (92308) should be erased - done
                      The start and end vertices are identical for CEdge (93001)
                      Entity CEdge (93001) should be erased - done
                      The start and end vertices are identical for CEdge (93179)
                      Entity CEdge (93179) should be erased - done
                      The start and end vertices are identical for CEdge (93255)
                      Entity CEdge (93255) should be erased - done
                      The start and end vertices are identical for CEdge (93533)
                      Entity CEdge (93533) should be erased - done
                      The start and end vertices are identical for CEdge (94062)
                      Entity CEdge (94062) should be erased - done
                      The start and end vertices are identical for CEdge (94138)
                      Entity CEdge (94138) should be erased - done
                      The start and end vertices are identical for CEdge (94150)
                      Entity CEdge (94150) should be erased - done
                      The start and end vertices are identical for CEdge (94834)
                      Entity CEdge (94834) should be erased - done
                      The start and end vertices are identical for CEdge (94974)
                      Entity CEdge (94974) should be erased - done
                      The start and end vertices are identical for CEdge (95135)
                      Entity CEdge (95135) should be erased - done
                      The start and end vertices are identical for CEdge (95451)
                      Entity CEdge (95451) should be erased - done
                      The start and end vertices are identical for CEdge (95933)
                      Entity CEdge (95933) should be erased - done
                      The start and end vertices are identical for CEdge (96000)
                      Entity CEdge (96000) should be erased - done
                      The start and end vertices are identical for CEdge (96050)
                      Entity CEdge (96050) should be erased - done
                      The start and end vertices are identical for CEdge (96734)
                      Entity CEdge (96734) should be erased - done
                      The start and end vertices are identical for CEdge (96874)
                      Entity CEdge (96874) should be erased - done
                      The start and end vertices are identical for CEdge (96959)
                      Entity CEdge (96959) should be erased - done
                      The start and end vertices are identical for CEdge (97360)
                      Entity CEdge (97360) should be erased - done
                      The start and end vertices are identical for CEdge (97766)
                      Entity CEdge (97766) should be erased - done
                      The start and end vertices are identical for CEdge (100599)
                      Entity CEdge (100599) should be erased - done
                      The start and end vertices are identical for CEdge (99944)
                      Entity CEdge (99944) should be erased - done
                      The start and end vertices are identical for CEdge (99704)
                      Entity CEdge (99704) should be erased - done
                      The start and end vertices are identical for CEdge (100815)
                      Entity CEdge (100815) should be erased - done
                      The start and end vertices are identical for CEdge (99932)
                      Entity CEdge (99932) should be erased - done
                      The start and end vertices are identical for CEdge (100967)
                      Entity CEdge (100967) should be erased - done
                      The start and end vertices are identical for CEdge (99361)
                      Entity CEdge (99361) should be erased - done
                      The start and end vertices are identical for CEdge (101148)
                      Entity CEdge (101148) should be erased - done
                      The start and end vertices are identical for CEdge (101350)
                      Entity CEdge (101350) should be erased - done
                      The start and end vertices are identical for CEdge (101870)
                      Entity CEdge (101870) should be erased - done
                      The start and end vertices are identical for CEdge (101984)
                      Entity CEdge (101984) should be erased - done
                      The start and end vertices are identical for CEdge (101996)
                      Entity CEdge (101996) should be erased - done
                      The start and end vertices are identical for CEdge (102259)
                      Entity CEdge (102259) should be erased - done
                      The start and end vertices are identical for CEdge (99251)
                      Entity CEdge (99251) should be erased - done
                      The start and end vertices are identical for CEdge (97880)
                      Entity CEdge (97880) should be erased - done
                      The start and end vertices are identical for CEdge (97930)
                      Entity CEdge (97930) should be erased - done
                      The start and end vertices are identical for CEdge (98643)
                      Entity CEdge (98643) should be erased - done
                      The start and end vertices are identical for CEdge (98745)
                      Entity CEdge (98745) should be erased - done
                      The start and end vertices are identical for CEdge (98935)
                      Entity CEdge (98935) should be erased - done
                      The start and end vertices are identical for CEdge (105709)
                      Entity CEdge (105709) should be erased - done
                      The start and end vertices are identical for CEdge (102803)
                      Entity CEdge (102803) should be erased - done
                      The start and end vertices are identical for CEdge (102981)
                      Entity CEdge (102981) should be erased - done
                      The start and end vertices are identical for CEdge (103133)
                      Entity CEdge (103133) should be erased - done
                      The start and end vertices are identical for CEdge (103323)
                      Entity CEdge (103323) should be erased - done
                      The start and end vertices are identical for CEdge (103525)
                      Entity CEdge (103525) should be erased - done
                      The start and end vertices are identical for CEdge (104092)
                      Entity CEdge (104092) should be erased - done
                      The start and end vertices are identical for CEdge (104206)
                      Entity CEdge (104206) should be erased - done
                      The start and end vertices are identical for CEdge (104218)
                      Entity CEdge (104218) should be erased - done
                      The start and end vertices are identical for CEdge (104443)
                      Entity CEdge (104443) should be erased - done
                      The start and end vertices are identical for CEdge (104987)
                      Entity CEdge (104987) should be erased - done
                      The start and end vertices are identical for CEdge (105250)
                      Entity CEdge (105250) should be erased - done
                      The start and end vertices are identical for CEdge (105364)
                      Entity CEdge (105364) should be erased - done
                      The start and end vertices are identical for CEdge (105545)
                      Entity CEdge (105545) should be erased - done
                      The start and end vertices are identical for CEdge (111514)
                      Entity CEdge (111514) should be erased - done
                      The start and end vertices are identical for CEdge (111768)
                      Entity CEdge (111768) should be erased - done
                      The start and end vertices are identical for CEdge (111882)
                      Entity CEdge (111882) should be erased - done
                      The start and end vertices are identical for CEdge (111987)
                      Entity CEdge (111987) should be erased - done
                      The start and end vertices are identical for CEdge (112113)
                      Entity CEdge (112113) should be erased - done
                      The start and end vertices are identical for CEdge (112747)
                      Entity CEdge (112747) should be erased - done
                      The start and end vertices are identical for CEdge (112899)
                      Entity CEdge (112899) should be erased - done
                      The start and end vertices are identical for CEdge (112911)
                      Entity CEdge (112911) should be erased - done
                      The start and end vertices are identical for CEdge (113089)
                      Entity CEdge (113089) should be erased - done
                      The start and end vertices are identical for CEdge (113557)
                      Entity CEdge (113557) should be erased - done
                      The start and end vertices are identical for CEdge (113811)
                      Entity CEdge (113811) should be erased - done
                      The start and end vertices are identical for CEdge (113925)
                      Entity CEdge (113925) should be erased - done
                      The start and end vertices are identical for CEdge (114077)
                      Entity CEdge (114077) should be erased - done
                      The start and end vertices are identical for CEdge (114279)
                      Entity CEdge (114279) should be erased - done
                      The start and end vertices are identical for CEdge (114866)
                      Entity CEdge (114866) should be erased - done
                      The start and end vertices are identical for CEdge (114942)
                      Entity CEdge (114942) should be erased - done
                      The start and end vertices are identical for CEdge (114954)
                      Entity CEdge (114954) should be erased - done
                      The start and end vertices are identical for CEdge (115132)
                      Entity CEdge (115132) should be erased - done
                      The start and end vertices are identical for CEdge (115524)
                      Entity CEdge (115524) should be erased - done
                      The start and end vertices are identical for CEdge (115769)
                      Entity CEdge (115769) should be erased - done
                      The start and end vertices are identical for CEdge (115883)
                      Entity CEdge (115883) should be erased - done
                      The start and end vertices are identical for CEdge (116082)
                      Entity CEdge (116082) should be erased - done
                      The start and end vertices are identical for CEdge (116246)
                      Entity CEdge (116246) should be erased - done
                      The start and end vertices are identical for CEdge (116737)
                      Entity CEdge (116737) should be erased - done
                      The start and end vertices are identical for CEdge (116854)
                      Entity CEdge (116854) should be erased - done
                      The start and end vertices are identical for CEdge (117032)
                      Entity CEdge (117032) should be erased - done
                      The start and end vertices are identical for CEdge (117462)
                      Entity CEdge (117462) should be erased - done
                      The start and end vertices are identical for CEdge (117716)
                      Entity CEdge (117716) should be erased - done
                      The start and end vertices are identical for CEdge (117953)
                      Entity CEdge (117953) should be erased - done
                      The start and end vertices are identical for CEdge (118108)
                      Entity CEdge (118108) should be erased - done
                      The start and end vertices are identical for CEdge (118628)
                      Entity CEdge (118628) should be erased - done
                      The start and end vertices are identical for CEdge (118716)
                      Entity CEdge (118716) should be erased - done
                      The start and end vertices are identical for CEdge (118894)
                      Entity CEdge (118894) should be erased - done
                      The start and end vertices are identical for CEdge (119324)
                      Entity CEdge (119324) should be erased - done
                      The start and end vertices are identical for CEdge (119540)
                      Entity CEdge (119540) should be erased - done
                      The start and end vertices are identical for CEdge (119797)
                      Entity CEdge (119797) should be erased - done
                      The start and end vertices are identical for CEdge (120443)
                      Entity CEdge (120443) should be erased - done
                      The start and end vertices are identical for CEdge (120633)
                      Entity CEdge (120633) should be erased - done
                      The start and end vertices are identical for CEdge (120814)
                      Entity CEdge (120814) should be erased - done
                      The start and end vertices are identical for CEdge (121308)
                      Entity CEdge (121308) should be erased - done
                      The start and end vertices are identical for CEdge (121498)
                      Entity CEdge (121498) should be erased - done
                      The start and end vertices are identical for CEdge (122258)
                      Entity CEdge (122258) should be erased - done
                      The start and end vertices are identical for CEdge (122296)
                      Entity CEdge (122296) should be erased - done
                      The start and end vertices are identical for CEdge (122410)
                      Entity CEdge (122410) should be erased - done
                      The start and end vertices are identical for CEdge (123161)
                      Entity CEdge (123161) should be erased - done
                      The start and end vertices are identical for CEdge (123199)
                      Entity CEdge (123199) should be erased - done
                      The start and end vertices are identical for CEdge (123313)
                      Entity CEdge (123313) should be erased - done
                      The start and end vertices are identical for CEdge (123363)
                      Entity CEdge (123363) should be erased - done
                      The start and end vertices are identical for CEdge (124035)
                      Entity CEdge (124035) should be erased - done
                      The start and end vertices are identical for CEdge (124073)
                      Entity CEdge (124073) should be erased - done
                      The start and end vertices are identical for CEdge (124225)
                      Entity CEdge (124225) should be erased - done
                      The start and end vertices are identical for CEdge (124655)
                      Entity CEdge (124655) should be erased - done
                      The start and end vertices are identical for CEdge (124985)
                      Entity CEdge (124985) should be erased - done
                      The start and end vertices are identical for CEdge (125023)
                      Entity CEdge (125023) should be erased - done
                      The start and end vertices are identical for CEdge (125137)
                      Entity CEdge (125137) should be erased - done
                      The start and end vertices are identical for CEdge (125263)
                      Entity CEdge (125263) should be erased - done
                      The start and end vertices are identical for CEdge (125935)
                      Entity CEdge (125935) should be erased - done
                      The start and end vertices are identical for CEdge (125947)
                      Entity CEdge (125947) should be erased - done
                      The start and end vertices are identical for CEdge (126011)
                      Entity CEdge (126011) should be erased - done
                      The start and end vertices are identical for CEdge (126055)
                      Entity CEdge (126055) should be erased - done
                      The start and end vertices are identical for CEdge (126170)
                      Entity CEdge (126170) should be erased - done
                      The start and end vertices are identical for CEdge (126600)
                      Entity CEdge (126600) should be erased - done
                      The start and end vertices are identical for CEdge (126892)
                      Entity CEdge (126892) should be erased - done
                      The start and end vertices are identical for CEdge (126930)
                      Entity CEdge (126930) should be erased - done
                      The start and end vertices are identical for CEdge (127010)
                      Entity CEdge (127010) should be erased - done
                      The start and end vertices are identical for CEdge (127125)
                      Entity CEdge (127125) should be erased - done
                      The start and end vertices are identical for CEdge (127213)
                      Entity CEdge (127213) should be erased - done
                      The start and end vertices are identical for CEdge (127905)
                      Entity CEdge (127905) should be erased - done
                      The start and end vertices are identical for CEdge (127917)
                      Entity CEdge (127917) should be erased - done
                      The start and end vertices are identical for CEdge (127981)
                      Entity CEdge (127981) should be erased - done
                      The start and end vertices are identical for CEdge (128025)
                      Entity CEdge (128025) should be erased - done
                      The start and end vertices are identical for CEdge (128140)
                      Entity CEdge (128140) should be erased - done
                      The start and end vertices are identical for CEdge (128523)
                      Entity CEdge (128523) should be erased - done
                      The start and end vertices are identical for CEdge (128844)
                      Entity CEdge (128844) should be erased - done
                      The start and end vertices are identical for CEdge (128886)
                      Entity CEdge (128886) should be erased - done
                      The start and end vertices are identical for CEdge (129001)
                      Entity CEdge (129001) should be erased - done
                      The start and end vertices are identical for CEdge (129176)
                      Entity CEdge (129176) should be erased - done
                      The start and end vertices are identical for CEdge (129273)
                      Entity CEdge (129273) should be erased - done
                      The start and end vertices are identical for CEdge (132246)
                      Entity CEdge (132246) should be erased - done
                      The start and end vertices are identical for CEdge (132255)
                      Entity CEdge (132255) should be erased - done
                      The start and end vertices are identical for CEdge (132261)
                      Entity CEdge (132261) should be erased - done
                      The start and end vertices are identical for CEdge (132267)
                      Entity CEdge (132267) should be erased - done
                      The start and end vertices are identical for CEdge (132270)
                      Entity CEdge (132270) should be erased - done
                      The start and end vertices are identical for CEdge (132279)
                      Entity CEdge (132279) should be erased - done
                      The start and end vertices are identical for CEdge (132291)
                      Entity CEdge (132291) should be erased - done
                      The start and end vertices are identical for CEdge (132294)
                      Entity CEdge (132294) should be erased - done
                      The start and end vertices are identical for CEdge (132297)
                      Entity CEdge (132297) should be erased - done
                      The start and end vertices are identical for CEdge (132315)
                      Entity CEdge (132315) should be erased - done
                      The start and end vertices are identical for CEdge (132324)
                      Entity CEdge (132324) should be erased - done
                      The start and end vertices are identical for CEdge (132342)
                      Entity CEdge (132342) should be erased - done
                      The start and end vertices are identical for CEdge (132345)
                      Entity CEdge (132345) should be erased - done
                      The start and end vertices are identical for CEdge (132363)
                      Entity CEdge (132363) should be erased - done
                      The start and end vertices are identical for CEdge (132378)
                      Entity CEdge (132378) should be erased - done
                      The start and end vertices are identical for CEdge (132381)
                      Entity CEdge (132381) should be erased - done
                      The start and end vertices are identical for CEdge (132384)
                      Entity CEdge (132384) should be erased - done
                      The start and end vertices are identical for CEdge (132411)
                      Entity CEdge (132411) should be erased - done
                      The start and end vertices are identical for CEdge (132414)
                      Entity CEdge (132414) should be erased - done
                      The start and end vertices are identical for CEdge (132420)
                      Entity CEdge (132420) should be erased - done
                      The start and end vertices are identical for CEdge (132435)
                      Entity CEdge (132435) should be erased - done
                      The start and end vertices are identical for CEdge (132438)
                      Entity CEdge (132438) should be erased - done
                      The start and end vertices are identical for CEdge (132459)
                      Entity CEdge (132459) should be erased - done
                      The start and end vertices are identical for CEdge (132474)
                      Entity CEdge (132474) should be erased - done
                      The start and end vertices are identical for CEdge (132486)
                      Entity CEdge (132486) should be erased - done
                      The start and end vertices are identical for CEdge (132495)
                      Entity CEdge (132495) should be erased - done
                      The start and end vertices are identical for CEdge (132501)
                      Entity CEdge (132501) should be erased - done
                      The start and end vertices are identical for CEdge (132513)
                      Entity CEdge (132513) should be erased - done
                      The start and end vertices are identical for CEdge (132516)
                      Entity CEdge (132516) should be erased - done
                      The start and end vertices are identical for CEdge (132531)
                      Entity CEdge (132531) should be erased - done
                      The start and end vertices are identical for CEdge (132540)
                      Entity CEdge (132540) should be erased - done
                      The start and end vertices are identical for CEdge (132546)
                      Entity CEdge (132546) should be erased - done
                      The start and end vertices are identical for CEdge (132549)
                      Entity CEdge (132549) should be erased - done
                      The start and end vertices are identical for CEdge (132564)
                      Entity CEdge (132564) should be erased - done
                      The start and end vertices are identical for CEdge (132579)
                      Entity CEdge (132579) should be erased - done
                      The start and end vertices are identical for CEdge (132591)
                      Entity CEdge (132591) should be erased - done
                      The start and end vertices are identical for CEdge (132600)
                      Entity CEdge (132600) should be erased - done
                      The start and end vertices are identical for CEdge (132609)
                      Entity CEdge (132609) should be erased - done
                      The start and end vertices are identical for CEdge (132621)
                      Entity CEdge (132621) should be erased - done
                      The start and end vertices are identical for CEdge (132624)
                      Entity CEdge (132624) should be erased - done
                      The start and end vertices are identical for CEdge (132636)
                      Entity CEdge (132636) should be erased - done
                      The start and end vertices are identical for CEdge (132642)
                      Entity CEdge (132642) should be erased - done
                      The start and end vertices are identical for CEdge (132648)
                      Entity CEdge (132648) should be erased - done
                      The start and end vertices are identical for CEdge (132651)
                      Entity CEdge (132651) should be erased - done
                      The start and end vertices are identical for CEdge (132654)
                      Entity CEdge (132654) should be erased - done
                      The start and end vertices are identical for CEdge (132657)
                      Entity CEdge (132657) should be erased - done
                      The start and end vertices are identical for CEdge (132684)
                      Entity CEdge (132684) should be erased - done
                      The start and end vertices are identical for CEdge (132690)
                      Entity CEdge (132690) should be erased - done
                      The start and end vertices are identical for CEdge (132708)
                      Entity CEdge (132708) should be erased - done
                      The start and end vertices are identical for CEdge (132717)
                      Entity CEdge (132717) should be erased - done
                      The start and end vertices are identical for CEdge (132720)
                      Entity CEdge (132720) should be erased - done
                      The start and end vertices are identical for CEdge (132735)
                      Entity CEdge (132735) should be erased - done
                      The start and end vertices are identical for CEdge (132738)
                      Entity CEdge (132738) should be erased - done
                      The start and end vertices are identical for CEdge (132753)
                      Entity CEdge (132753) should be erased - done
                      The start and end vertices are identical for CEdge (132759)
                      Entity CEdge (132759) should be erased - done
                      The start and end vertices are identical for CEdge (132774)
                      Entity CEdge (132774) should be erased - done
                      The start and end vertices are identical for CEdge (132777)
                      Entity CEdge (132777) should be erased - done
                      The start and end vertices are identical for CEdge (132792)
                      Entity CEdge (132792) should be erased - done
                      The start and end vertices are identical for CEdge (132810)
                      Entity CEdge (132810) should be erased - done
                      The start and end vertices are identical for CEdge (132825)
                      Entity CEdge (132825) should be erased - done
                      The start and end vertices are identical for CEdge (132843)
                      Entity CEdge (132843) should be erased - done
                      The start and end vertices are identical for CEdge (132858)
                      Entity CEdge (132858) should be erased - done
                      The start and end vertices are identical for CEdge (132876)
                      Entity CEdge (132876) should be erased - done
                      The start and end vertices are identical for CEdge (132888)
                      Entity CEdge (132888) should be erased - done
                      The start and end vertices are identical for CEdge (132903)
                      Entity CEdge (132903) should be erased - done
                      The start and end vertices are identical for CEdge (132915)
                      Entity CEdge (132915) should be erased - done
                      The start and end vertices are identical for CEdge (132927)
                      Entity CEdge (132927) should be erased - done
                      The start and end vertices are identical for CEdge (132939)
                      Entity CEdge (132939) should be erased - done
                      The start and end vertices are identical for CEdge (132948)
                      Entity CEdge (132948) should be erased - done
                      The start and end vertices are identical for CEdge (132960)
                      Entity CEdge (132960) should be erased - done
                      The start and end vertices are identical for CEdge (132975)
                      Entity CEdge (132975) should be erased - done
                      The start and end vertices are identical for CEdge (132987)
                      Entity CEdge (132987) should be erased - done
                      The start and end vertices are identical for CEdge (133005)
                      Entity CEdge (133005) should be erased - done
                      The start and end vertices are identical for CEdge (133017)
                      Entity CEdge (133017) should be erased - done
                      The start and end vertices are identical for CEdge (133026)
                      Entity CEdge (133026) should be erased - done
                      The start and end vertices are identical for CEdge (133041)
                      Entity CEdge (133041) should be erased - done
                      The start and end vertices are identical for CEdge (133050)
                      Entity CEdge (133050) should be erased - done
                      The start and end vertices are identical for CEdge (133062)
                      Entity CEdge (133062) should be erased - done
                      The start and end vertices are identical for CEdge (133071)
                      Entity CEdge (133071) should be erased - done
                      The start and end vertices are identical for CEdge (133080)
                      Entity CEdge (133080) should be erased - done
                      The start and end vertices are identical for CEdge (133092)
                      Entity CEdge (133092) should be erased - done
                      The start and end vertices are identical for CEdge (133098)
                      Entity CEdge (133098) should be erased - done
                      The start and end vertices are identical for CEdge (133101)
                      Entity CEdge (133101) should be erased - done
                      The start and end vertices are identical for CEdge (133104)
                      Entity CEdge (133104) should be erased - done
                      The start and end vertices are identical for CEdge (133107)
                      Entity CEdge (133107) should be erased - done
                      The start and end vertices are identical for CEdge (133110)
                      Entity CEdge (133110) should be erased - done
                      The start and end vertices are identical for CEdge (133113)
                      Entity CEdge (133113) should be erased - done
                      The start and end vertices are identical for CEdge (133116)
                      Entity CEdge (133116) should be erased - done
                      The start and end vertices are identical for CEdge (133119)
                      Entity CEdge (133119) should be erased - done
                      The start and end vertices are identical for CEdge (133122)
                      Entity CEdge (133122) should be erased - done
                      The start and end vertices are identical for CEdge (133125)
                      Entity CEdge (133125) should be erased - done
                      The start and end vertices are identical for CEdge (133128)
                      Entity CEdge (133128) should be erased - done
                      The start and end vertices are identical for CEdge (133131)
                      Entity CEdge (133131) should be erased - done
                      The start and end vertices are identical for CEdge (133134)
                      Entity CEdge (133134) should be erased - done
                      The start and end vertices are identical for CEdge (133137)
                      Entity CEdge (133137) should be erased - done
                      The start and end vertices are identical for CEdge (133140)
                      Entity CEdge (133140) should be erased - done
                      The start and end vertices are identical for CEdge (133143)
                      Entity CEdge (133143) should be erased - done
                      The start and end vertices are identical for CEdge (133146)
                      Entity CEdge (133146) should be erased - done
                      The start and end vertices are identical for CEdge (133149)
                      Entity CEdge (133149) should be erased - done
                      The start and end vertices are identical for CEdge (133152)
                      Entity CEdge (133152) should be erased - done
                      The start and end vertices are identical for CEdge (133155)
                      Entity CEdge (133155) should be erased - done
                      The start and end vertices are identical for CEdge (133158)
                      Entity CEdge (133158) should be erased - done
                      The start and end vertices are identical for CEdge (133161)
                      Entity CEdge (133161) should be erased - done
                      The start and end vertices are identical for CEdge (133164)
                      Entity CEdge (133164) should be erased - done
                      The start and end vertices are identical for CEdge (133167)
                      Entity CEdge (133167) should be erased - done
                      The start and end vertices are identical for CEdge (133170)
                      Entity CEdge (133170) should be erased - done
                      The start and end vertices are identical for CEdge (133173)
                      Entity CEdge (133173) should be erased - done
                      The start and end vertices are identical for CEdge (133176)
                      Entity CEdge (133176) should be erased - done
                      The start and end vertices are identical for CEdge (133179)
                      Entity CEdge (133179) should be erased - done
                      The start and end vertices are identical for CEdge (133182)
                      Entity CEdge (133182) should be erased - done
                      The start and end vertices are identical for CEdge (133185)
                      Entity CEdge (133185) should be erased - done
                      The start and end vertices are identical for CEdge (133188)
                      Entity CEdge (133188) should be erased - done
                      The start and end vertices are identical for CEdge (133191)
                      Entity CEdge (133191) should be erased - done
                      The start and end vertices are identical for CEdge (133194)
                      Entity CEdge (133194) should be erased - done
                      The start and end vertices are identical for CEdge (133197)
                      Entity CEdge (133197) should be erased - done
                      The start and end vertices are identical for CEdge (133200)
                      Entity CEdge (133200) should be erased - done
                      The start and end vertices are identical for CEdge (133203)
                      Entity CEdge (133203) should be erased - done
                      The start and end vertices are identical for CEdge (133206)
                      Entity CEdge (133206) should be erased - done
                      The start and end vertices are identical for CEdge (133209)
                      Entity CEdge (133209) should be erased - done
                      The start and end vertices are identical for CEdge (133212)
                      Entity CEdge (133212) should be erased - done
                      The start and end vertices are identical for CEdge (133215)
                      Entity CEdge (133215) should be erased - done
                      The start and end vertices are identical for CEdge (133218)
                      Entity CEdge (133218) should be erased - done
                      The start and end vertices are identical for CEdge (133221)
                      Entity CEdge (133221) should be erased - done
                      The start and end vertices are identical for CEdge (133224)
                      Entity CEdge (133224) should be erased - done
                      The start and end vertices are identical for CEdge (133227)
                      Entity CEdge (133227) should be erased - done
                      The start and end vertices are identical for CEdge (133230)
                      Entity CEdge (133230) should be erased - done
                      The start and end vertices are identical for CEdge (133233)
                      Entity CEdge (133233) should be erased - done
                      The start and end vertices are identical for CEdge (133236)
                      Entity CEdge (133236) should be erased - done
                      The start and end vertices are identical for CEdge (133239)
                      Entity CEdge (133239) should be erased - done
                      Edges are not connected in CLoop (82820) for CFace (82819)
                      Loop 0 of CFace (82819) is an invalid outer loop
                      Entity CFace (82819) should be erased - done
                      Edges are not connected in CLoop (83154) for CFace (83153)
                      Loop 0 of CFace (83153) is an invalid outer loop
                      Entity CFace (83153) should be erased - done
                      Edges are not connected in CLoop (83234) for CFace (83233)
                      Loop 0 of CFace (83233) is an invalid outer loop
                      Entity CFace (83233) should be erased - done
                      Edges are not connected in CLoop (83328) for CFace (83327)
                      Loop 0 of CFace (83327) is an invalid outer loop
                      Entity CFace (83327) should be erased - done
                      Edges are not connected in CLoop (83742) for CFace (83741)
                      Loop 0 of CFace (83741) is an invalid outer loop
                      Entity CFace (83741) should be erased - done
                      Edges are not connected in CLoop (83883) for CFace (83882)
                      Loop 0 of CFace (83882) is an invalid outer loop
                      Entity CFace (83882) should be erased - done
                      Edges are not connected in CLoop (83968) for CFace (83967)
                      Loop 0 of CFace (83967) is an invalid outer loop
                      Entity CFace (83967) should be erased - done
                      Edges are not connected in CLoop (84017) for CFace (84016)
                      Loop 0 of CFace (84016) is an invalid outer loop
                      Entity CFace (84016) should be erased - done
                      Edges are not connected in CLoop (84128) for CFace (84127)
                      Loop 0 of CFace (84127) is an invalid outer loop
                      Entity CFace (84127) should be erased - done
                      Edges are not connected in CLoop (84318) for CFace (84317)
                      Loop 0 of CFace (84317) is an invalid outer loop
                      Entity CFace (84317) should be erased - done
                      Edges are not connected in CLoop (84403) for CFace (84402)
                      Loop 0 of CFace (84402) is an invalid outer loop
                      Entity CFace (84402) should be erased - done
                      Edges are not connected in CLoop (84754) for CFace (84753)
                      Loop 0 of CFace (84753) is an invalid outer loop
                      Entity CFace (84753) should be erased - done
                      Edges are not connected in CLoop (84765) for CFace (84764)
                      Loop 0 of CFace (84764) is an invalid outer loop
                      Entity CFace (84764) should be erased - done
                      Edges are not connected in CLoop (84906) for CFace (84905)
                      Loop 0 of CFace (84905) is an invalid outer loop
                      Entity CFace (84905) should be erased - done
                      Edges are not connected in CLoop (85020) for CFace (85019)
                      Loop 0 of CFace (85019) is an invalid outer loop
                      Entity CFace (85019) should be erased - done
                      Edges are not connected in CLoop (85190) for CFace (85189)
                      Loop 0 of CFace (85189) is an invalid outer loop
                      Entity CFace (85189) should be erased - done
                      Edges are not connected in CLoop (85353) for CFace (85352)
                      Loop 0 of CFace (85352) is an invalid outer loop
                      Entity CFace (85352) should be erased - done
                      Edges are not connected in CLoop (85418) for CFace (85417)
                      Loop 0 of CFace (85417) is an invalid outer loop
                      Entity CFace (85417) should be erased - done
                      Edges are not connected in CLoop (85760) for CFace (85759)
                      Loop 0 of CFace (85759) is an invalid outer loop
                      Entity CFace (85759) should be erased - done
                      Edges are not connected in CLoop (85921) for CFace (85920)
                      Loop 0 of CFace (85920) is an invalid outer loop
                      Entity CFace (85920) should be erased - done
                      Edges are not connected in CLoop (86035) for CFace (86034)
                      Loop 0 of CFace (86034) is an invalid outer loop
                      Entity CFace (86034) should be erased - done
                      Edges are not connected in CLoop (86084) for CFace (86083)
                      Loop 0 of CFace (86083) is an invalid outer loop
                      Entity CFace (86083) should be erased - done
                      Edges are not connected in CLoop (86195) for CFace (86194)
                      Loop 0 of CFace (86194) is an invalid outer loop
                      Entity CFace (86194) should be erased - done
                      Edges are not connected in CLoop (86385) for CFace (86384)
                      Loop 0 of CFace (86384) is an invalid outer loop
                      Entity CFace (86384) should be erased - done
                      Edges are not connected in CLoop (86774) for CFace (86773)
                      Loop 0 of CFace (86773) is an invalid outer loop
                      Entity CFace (86773) should be erased - done
                      Edges are not connected in CLoop (86785) for CFace (86784)
                      Loop 0 of CFace (86784) is an invalid outer loop
                      Entity CFace (86784) should be erased - done
                      Edges are not connected in CLoop (86926) for CFace (86925)
                      Loop 0 of CFace (86925) is an invalid outer loop
                      Entity CFace (86925) should be erased - done
                      Edges are not connected in CLoop (87078) for CFace (87077)
                      Loop 0 of CFace (87077) is an invalid outer loop
                      Entity CFace (87077) should be erased - done
                      Edges are not connected in CLoop (87363) for CFace (87362)
                      Loop 0 of CFace (87362) is an invalid outer loop
                      Entity CFace (87362) should be erased - done
                      Edges are not connected in CLoop (87428) for CFace (87427)
                      Loop 0 of CFace (87427) is an invalid outer loop
                      Entity CFace (87427) should be erased - done
                      Edges are not connected in CLoop (87855) for CFace (87854)
                      Loop 0 of CFace (87854) is an invalid outer loop
                      Entity CFace (87854) should be erased - done
                      Edges are not connected in CLoop (87931) for CFace (87930)
                      Loop 0 of CFace (87930) is an invalid outer loop
                      Entity CFace (87930) should be erased - done
                      Edges are not connected in CLoop (88083) for CFace (88082)
                      Loop 0 of CFace (88082) is an invalid outer loop
                      Entity CFace (88082) should be erased - done
                      Edges are not connected in CLoop (88170) for CFace (88169)
                      Loop 0 of CFace (88169) is an invalid outer loop
                      Entity CFace (88169) should be erased - done
                      Edges are not connected in CLoop (88433) for CFace (88432)
                      Loop 0 of CFace (88432) is an invalid outer loop
                      Entity CFace (88432) should be erased - done
                      Edges are not connected in CLoop (106963) for CFace (106962)
                      Loop 0 of CFace (106962) is an invalid outer loop
                      Entity CFace (106962) should be erased - done
                      Edges are not connected in CLoop (107164) for CFace (107163)
                      Loop 0 of CFace (107163) is an invalid outer loop
                      Entity CFace (107163) should be erased - done
                      Edges are not connected in CLoop (107457) for CFace (107456)
                      Loop 0 of CFace (107456) is an invalid outer loop
                      Entity CFace (107456) should be erased - done
                      Edges are not connected in CLoop (107571) for CFace (107570)
                      Loop 0 of CFace (107570) is an invalid outer loop
                      Entity CFace (107570) should be erased - done
                      Edges are not connected in CLoop (107723) for CFace (107722)
                      Loop 0 of CFace (107722) is an invalid outer loop
                      Entity CFace (107722) should be erased - done
                      Edges are not connected in CLoop (107837) for CFace (107836)
                      Loop 0 of CFace (107836) is an invalid outer loop
                      Entity CFace (107836) should be erased - done
                      Edges are not connected in CLoop (107886) for CFace (107885)
                      Loop 0 of CFace (107885) is an invalid outer loop
                      Entity CFace (107885) should be erased - done
                      Edges are not connected in CLoop (108170) for CFace (108169)
                      Loop 0 of CFace (108169) is an invalid outer loop
                      Entity CFace (108169) should be erased - done
                      Edges are not connected in CLoop (108512) for CFace (108511)
                      Loop 0 of CFace (108511) is an invalid outer loop
                      Entity CFace (108511) should be erased - done
                      Edges are not connected in CLoop (108626) for CFace (108625)
                      Loop 0 of CFace (108625) is an invalid outer loop
                      Entity CFace (108625) should be erased - done
                      Edges are not connected in CLoop (108637) for CFace (108636)
                      Loop 0 of CFace (108636) is an invalid outer loop
                      Entity CFace (108636) should be erased - done
                      Edges are not connected in CLoop (108778) for CFace (108777)
                      Loop 0 of CFace (108777) is an invalid outer loop
                      Entity CFace (108777) should be erased - done
                      Edges are not connected in CLoop (108930) for CFace (108929)
                      Loop 0 of CFace (108929) is an invalid outer loop
                      Entity CFace (108929) should be erased - done
                      Edges are not connected in CLoop (109272) for CFace (109271)
                      Loop 0 of CFace (109271) is an invalid outer loop
                      Entity CFace (109271) should be erased - done
                      Edges are not connected in CLoop (109359) for CFace (109358)
                      Loop 0 of CFace (109358) is an invalid outer loop
                      Entity CFace (109358) should be erased - done
                      Edges are not connected in CLoop (109614) for CFace (109613)
                      Loop 0 of CFace (109613) is an invalid outer loop
                      Entity CFace (109613) should be erased - done
                      Edges are not connected in CLoop (109766) for CFace (109765)
                      Loop 0 of CFace (109765) is an invalid outer loop
                      Entity CFace (109765) should be erased - done
                      Edges are not connected in CLoop (109880) for CFace (109879)
                      Loop 0 of CFace (109879) is an invalid outer loop
                      Entity CFace (109879) should be erased - done
                      Edges are not connected in CLoop (110023) for CFace (110022)
                      Loop 0 of CFace (110022) is an invalid outer loop
                      Entity CFace (110022) should be erased - done
                      Edges are not connected in CLoop (110034) for CFace (110033)
                      Loop 0 of CFace (110033) is an invalid outer loop
                      Entity CFace (110033) should be erased - done
                      Edges are not connected in CLoop (110356) for CFace (110355)
                      Loop 0 of CFace (110355) is an invalid outer loop
                      Entity CFace (110355) should be erased - done
                      Edges are not connected in CLoop (110698) for CFace (110697)
                      Loop 0 of CFace (110697) is an invalid outer loop
                      Entity CFace (110697) should be erased - done
                      Edges are not connected in CLoop (110812) for CFace (110811)
                      Loop 0 of CFace (110811) is an invalid outer loop
                      Entity CFace (110811) should be erased - done
                      Edges are not connected in CLoop (110823) for CFace (110822)
                      Loop 0 of CFace (110822) is an invalid outer loop
                      Entity CFace (110822) should be erased - done
                      Edges are not connected in CLoop (110964) for CFace (110963)
                      Loop 0 of CFace (110963) is an invalid outer loop
                      Entity CFace (110963) should be erased - done
                      Edges are not connected in CLoop (111391) for CFace (111390)
                      Loop 0 of CFace (111390) is an invalid outer loop
                      Entity CFace (111390) should be erased - done
                      Edges are not connected in CLoop (88878) for CFace (88877)
                      Loop 0 of CFace (88877) is an invalid outer loop
                      Entity CFace (88877) should be erased - done
                      Edges are not connected in CLoop (88981) for CFace (88980)
                      Loop 0 of CFace (88980) is an invalid outer loop
                      Entity CFace (88980) should be erased - done
                      Edges are not connected in CLoop (89064) for CFace (89063)
                      Loop 0 of CFace (89063) is an invalid outer loop
                      Entity CFace (89063) should be erased - done
                      Edges are not connected in CLoop (89216) for CFace (89215)
                      Loop 0 of CFace (89215) is an invalid outer loop
                      Entity CFace (89215) should be erased - done
                      Edges are not connected in CLoop (89377) for CFace (89376)
                      Loop 0 of CFace (89376) is an invalid outer loop
                      Entity CFace (89376) should be erased - done
                      Edges are not connected in CLoop (89464) for CFace (89463)
                      Loop 0 of CFace (89463) is an invalid outer loop
                      Entity CFace (89463) should be erased - done
                      Edges are not connected in CLoop (89529) for CFace (89528)
                      Loop 0 of CFace (89528) is an invalid outer loop
                      Entity CFace (89528) should be erased - done
                      Edges are not connected in CLoop (89985) for CFace (89984)
                      Loop 0 of CFace (89984) is an invalid outer loop
                      Entity CFace (89984) should be erased - done
                      Edges are not connected in CLoop (90137) for CFace (90136)
                      Loop 0 of CFace (90136) is an invalid outer loop
                      Entity CFace (90136) should be erased - done
                      Edges are not connected in CLoop (90186) for CFace (90185)
                      Loop 0 of CFace (90185) is an invalid outer loop
                      Entity CFace (90185) should be erased - done
                      Edges are not connected in CLoop (90486) for CFace (90485)
                      Loop 0 of CFace (90485) is an invalid outer loop
                      Entity CFace (90485) should be erased - done
                      Edges are not connected in CLoop (90719) for CFace (90718)
                      Loop 0 of CFace (90718) is an invalid outer loop
                      Entity CFace (90718) should be erased - done
                      Edges are not connected in CLoop (90920) for CFace (90919)
                      Loop 0 of CFace (90919) is an invalid outer loop
                      Entity CFace (90919) should be erased - done
                      Edges are not connected in CLoop (91061) for CFace (91060)
                      Loop 0 of CFace (91060) is an invalid outer loop
                      Entity CFace (91060) should be erased - done
                      Edges are not connected in CLoop (91104) for CFace (91103)
                      Loop 0 of CFace (91103) is an invalid outer loop
                      Entity CFace (91103) should be erased - done
                      Edges are not connected in CLoop (91180) for CFace (91179)
                      Loop 0 of CFace (91179) is an invalid outer loop
                      Entity CFace (91179) should be erased - done
                      Edges are not connected in CLoop (91413) for CFace (91412)
                      Loop 0 of CFace (91412) is an invalid outer loop
                      Entity CFace (91412) should be erased - done
                      Edges are not connected in CLoop (91538) for CFace (91537)
                      Loop 0 of CFace (91537) is an invalid outer loop
                      Entity CFace (91537) should be erased - done
                      Edges are not connected in CLoop (91603) for CFace (91602)
                      Loop 0 of CFace (91602) is an invalid outer loop
                      Entity CFace (91602) should be erased - done
                      Edges are not connected in CLoop (91800) for CFace (91799)
                      Loop 0 of CFace (91799) is an invalid outer loop
                      Entity CFace (91799) should be erased - done
                      Edges are not connected in CLoop (92104) for CFace (92103)
                      Loop 0 of CFace (92103) is an invalid outer loop
                      Entity CFace (92103) should be erased - done
                      Edges are not connected in CLoop (92261) for CFace (92260)
                      Loop 0 of CFace (92260) is an invalid outer loop
                      Entity CFace (92260) should be erased - done
                      Edges are not connected in CLoop (92310) for CFace (92309)
                      Loop 0 of CFace (92309) is an invalid outer loop
                      Entity CFace (92309) should be erased - done
                      Edges are not connected in CLoop (92603) for CFace (92602)
                      Loop 0 of CFace (92602) is an invalid outer loop
                      Entity CFace (92602) should be erased - done
                      Edges are not connected in CLoop (93003) for CFace (93002)
                      Loop 0 of CFace (93002) is an invalid outer loop
                      Entity CFace (93002) should be erased - done
                      Edges are not connected in CLoop (93182) for CFace (93181)
                      Loop 0 of CFace (93181) is an invalid outer loop
                      Entity CFace (93181) should be erased - done
                      Edges are not connected in CLoop (93258) for CFace (93257)
                      Loop 0 of CFace (93257) is an invalid outer loop
                      Entity CFace (93257) should be erased - done
                      Edges are not connected in CLoop (93535) for CFace (93534)
                      Loop 0 of CFace (93534) is an invalid outer loop
                      Entity CFace (93534) should be erased - done
                      Edges are not connected in CLoop (93600) for CFace (93599)
                      Loop 0 of CFace (93599) is an invalid outer loop
                      Entity CFace (93599) should be erased - done
                      Edges are not connected in CLoop (94065) for CFace (94064)
                      Loop 0 of CFace (94064) is an invalid outer loop
                      Entity CFace (94064) should be erased - done
                      Edges are not connected in CLoop (94141) for CFace (94140)
                      Loop 0 of CFace (94140) is an invalid outer loop
                      Entity CFace (94140) should be erased - done
                      Edges are not connected in CLoop (94152) for CFace (94151)
                      Loop 0 of CFace (94151) is an invalid outer loop
                      Entity CFace (94151) should be erased - done
                      Edges are not connected in CLoop (94521) for CFace (94520)
                      Loop 0 of CFace (94520) is an invalid outer loop
                      Entity CFace (94520) should be erased - done
                      Edges are not connected in CLoop (94836) for CFace (94835)
                      Loop 0 of CFace (94835) is an invalid outer loop
                      Entity CFace (94835) should be erased - done
                      Edges are not connected in CLoop (94977) for CFace (94976)
                      Loop 0 of CFace (94976) is an invalid outer loop
                      Entity CFace (94976) should be erased - done
                      Edges are not connected in CLoop (95024) for CFace (95023)
                      Loop 0 of CFace (95023) is an invalid outer loop
                      Entity CFace (95023) should be erased - done
                      Edges are not connected in CLoop (95138) for CFace (95137)
                      Loop 0 of CFace (95137) is an invalid outer loop
                      Entity CFace (95137) should be erased - done
                      Edges are not connected in CLoop (95453) for CFace (95452)
                      Loop 0 of CFace (95452) is an invalid outer loop
                      Entity CFace (95452) should be erased - done
                      Edges are not connected in CLoop (95518) for CFace (95517)
                      Loop 0 of CFace (95517) is an invalid outer loop
                      Entity CFace (95517) should be erased - done
                      Edges are not connected in CLoop (95936) for CFace (95935)
                      Loop 0 of CFace (95935) is an invalid outer loop
                      Entity CFace (95935) should be erased - done
                      Edges are not connected in CLoop (96003) for CFace (96002)
                      Loop 0 of CFace (96002) is an invalid outer loop
                      Entity CFace (96002) should be erased - done
                      Edges are not connected in CLoop (96052) for CFace (96051)
                      Loop 0 of CFace (96051) is an invalid outer loop
                      Entity CFace (96051) should be erased - done
                      Edges are not connected in CLoop (96383) for CFace (96382)
                      Loop 0 of CFace (96382) is an invalid outer loop
                      Entity CFace (96382) should be erased - done
                      Edges are not connected in CLoop (96535) for CFace (96534)
                      Loop 0 of CFace (96534) is an invalid outer loop
                      Entity CFace (96534) should be erased - done
                      Edges are not connected in CLoop (96736) for CFace (96735)
                      Loop 0 of CFace (96735) is an invalid outer loop
                      Entity CFace (96735) should be erased - done
                      Edges are not connected in CLoop (96877) for CFace (96876)
                      Loop 0 of CFace (96876) is an invalid outer loop
                      Entity CFace (96876) should be erased - done
                      Edges are not connected in CLoop (96962) for CFace (96961)
                      Loop 0 of CFace (96961) is an invalid outer loop
                      Entity CFace (96961) should be erased - done
                      Edges are not connected in CLoop (97351) for CFace (97350)
                      Loop 0 of CFace (97350) is an invalid outer loop
                      Entity CFace (97350) should be erased - done
                      Edges are not connected in CLoop (97362) for CFace (97361)
                      Loop 0 of CFace (97361) is an invalid outer loop
                      Entity CFace (97361) should be erased - done
                      Edges are not connected in CLoop (97503) for CFace (97502)
                      Loop 0 of CFace (97502) is an invalid outer loop
                      Entity CFace (97502) should be erased - done
                      Edges are not connected in CLoop (97769) for CFace (97768)
                      Loop 0 of CFace (97768) is an invalid outer loop
                      Entity CFace (97768) should be erased - done
                      Edges are not connected in CLoop (100248) for CFace (100247)
                      Loop 0 of CFace (100247) is an invalid outer loop
                      Entity CFace (100247) should be erased - done
                      Edges are not connected in CLoop (100400) for CFace (100399)
                      Loop 0 of CFace (100399) is an invalid outer loop
                      Entity CFace (100399) should be erased - done
                      Edges are not connected in CLoop (100601) for CFace (100600)
                      Loop 0 of CFace (100600) is an invalid outer loop
                      Entity CFace (100600) should be erased - done
                      Edges are not connected in CLoop (100818) for CFace (100817)
                      Loop 0 of CFace (100817) is an invalid outer loop
                      Entity CFace (100817) should be erased - done
                      Edges are not connected in CLoop (100970) for CFace (100969)
                      Loop 0 of CFace (100969) is an invalid outer loop
                      Entity CFace (100969) should be erased - done
                      Edges are not connected in CLoop (101151) for CFace (101150)
                      Loop 0 of CFace (101150) is an invalid outer loop
                      Entity CFace (101150) should be erased - done
                      Edges are not connected in CLoop (101265) for CFace (101264)
                      Loop 0 of CFace (101264) is an invalid outer loop
                      Entity CFace (101264) should be erased - done
                      Edges are not connected in CLoop (101352) for CFace (101351)
                      Loop 0 of CFace (101351) is an invalid outer loop
                      Entity CFace (101351) should be erased - done
                      Edges are not connected in CLoop (101455) for CFace (101454)
                      Loop 0 of CFace (101454) is an invalid outer loop
                      Entity CFace (101454) should be erased - done
                      Edges are not connected in CLoop (101873) for CFace (101872)
                      Loop 0 of CFace (101872) is an invalid outer loop
                      Entity CFace (101872) should be erased - done
                      Edges are not connected in CLoop (101987) for CFace (101986)
                      Loop 0 of CFace (101986) is an invalid outer loop
                      Entity CFace (101986) should be erased - done
                      Edges are not connected in CLoop (101998) for CFace (101997)
                      Loop 0 of CFace (101997) is an invalid outer loop
                      Entity CFace (101997) should be erased - done
                      Edges are not connected in CLoop (102262) for CFace (102261)
                      Loop 0 of CFace (102261) is an invalid outer loop
                      Entity CFace (102261) should be erased - done
                      Edges are not connected in CLoop (97883) for CFace (97882)
                      Loop 0 of CFace (97882) is an invalid outer loop
                      Entity CFace (97882) should be erased - done
                      Edges are not connected in CLoop (97932) for CFace (97931)
                      Loop 0 of CFace (97931) is an invalid outer loop
                      Entity CFace (97931) should be erased - done
                      Edges are not connected in CLoop (98263) for CFace (98262)
                      Loop 0 of CFace (98262) is an invalid outer loop
                      Entity CFace (98262) should be erased - done
                      Edges are not connected in CLoop (98415) for CFace (98414)
                      Loop 0 of CFace (98414) is an invalid outer loop
                      Entity CFace (98414) should be erased - done
                      Edges are not connected in CLoop (98645) for CFace (98644)
                      Loop 0 of CFace (98644) is an invalid outer loop
                      Entity CFace (98644) should be erased - done
                      Edges are not connected in CLoop (98748) for CFace (98747)
                      Loop 0 of CFace (98747) is an invalid outer loop
                      Entity CFace (98747) should be erased - done
                      Edges are not connected in CLoop (98938) for CFace (98937)
                      Loop 0 of CFace (98937) is an invalid outer loop
                      Entity CFace (98937) should be erased - done
                      Edges are not connected in CLoop (99166) for CFace (99165)
                      Loop 0 of CFace (99165) is an invalid outer loop
                      Entity CFace (99165) should be erased - done
                      Edges are not connected in CLoop (99253) for CFace (99252)
                      Loop 0 of CFace (99252) is an invalid outer loop
                      Entity CFace (99252) should be erased - done
                      Edges are not connected in CLoop (99365) for CFace (99364)
                      Loop 0 of CFace (99364) is an invalid outer loop
                      Entity CFace (99364) should be erased - done
                      Edges are not connected in CLoop (99441) for CFace (99440)
                      Loop 0 of CFace (99440) is an invalid outer loop
                      Entity CFace (99440) should be erased - done
                      Edges are not connected in CLoop (99707) for CFace (99706)
                      Loop 0 of CFace (99706) is an invalid outer loop
                      Entity CFace (99706) should be erased - done
                      Edges are not connected in CLoop (99935) for CFace (99934)
                      Loop 0 of CFace (99934) is an invalid outer loop
                      Entity CFace (99934) should be erased - done
                      Edges are not connected in CLoop (99946) for CFace (99945)
                      Loop 0 of CFace (99945) is an invalid outer loop
                      Entity CFace (99945) should be erased - done
                      Edges are not connected in CLoop (102376) for CFace (102375)
                      Loop 0 of CFace (102375) is an invalid outer loop
                      Entity CFace (102375) should be erased - done
                      Edges are not connected in CLoop (102566) for CFace (102565)
                      Loop 0 of CFace (102565) is an invalid outer loop
                      Entity CFace (102565) should be erased - done
                      Edges are not connected in CLoop (102805) for CFace (102804)
                      Loop 0 of CFace (102804) is an invalid outer loop
                      Entity CFace (102804) should be erased - done
                      Edges are not connected in CLoop (102984) for CFace (102983)
                      Loop 0 of CFace (102983) is an invalid outer loop
                      Entity CFace (102983) should be erased - done
                      Edges are not connected in CLoop (103136) for CFace (103135)
                      Loop 0 of CFace (103135) is an invalid outer loop
                      Entity CFace (103135) should be erased - done
                      Edges are not connected in CLoop (103326) for CFace (103325)
                      Loop 0 of CFace (103325) is an invalid outer loop
                      Entity CFace (103325) should be erased - done
                      Edges are not connected in CLoop (103440) for CFace (103439)
                      Loop 0 of CFace (103439) is an invalid outer loop
                      Entity CFace (103439) should be erased - done
                      Edges are not connected in CLoop (103527) for CFace (103526)
                      Loop 0 of CFace (103526) is an invalid outer loop
                      Entity CFace (103526) should be erased - done
                      Edges are not connected in CLoop (103630) for CFace (103629)
                      Loop 0 of CFace (103629) is an invalid outer loop
                      Entity CFace (103629) should be erased - done
                      Edges are not connected in CLoop (104095) for CFace (104094)
                      Loop 0 of CFace (104094) is an invalid outer loop
                      Entity CFace (104094) should be erased - done
                      Edges are not connected in CLoop (104209) for CFace (104208)
                      Loop 0 of CFace (104208) is an invalid outer loop
                      Entity CFace (104208) should be erased - done
                      Edges are not connected in CLoop (104220) for CFace (104219)
                      Loop 0 of CFace (104219) is an invalid outer loop
                      Entity CFace (104219) should be erased - done
                      Edges are not connected in CLoop (104446) for CFace (104445)
                      Loop 0 of CFace (104445) is an invalid outer loop
                      Entity CFace (104445) should be erased - done
                      Edges are not connected in CLoop (104560) for CFace (104559)
                      Loop 0 of CFace (104559) is an invalid outer loop
                      Entity CFace (104559) should be erased - done
                      Edges are not connected in CLoop (104712) for CFace (104711)
                      Loop 0 of CFace (104711) is an invalid outer loop
                      Entity CFace (104711) should be erased - done
                      Edges are not connected in CLoop (104989) for CFace (104988)
                      Loop 0 of CFace (104988) is an invalid outer loop
                      Entity CFace (104988) should be erased - done
                      Edges are not connected in CLoop (105253) for CFace (105252)
                      Loop 0 of CFace (105252) is an invalid outer loop
                      Entity CFace (105252) should be erased - done
                      Edges are not connected in CLoop (105367) for CFace (105366)
                      Loop 0 of CFace (105366) is an invalid outer loop
                      Entity CFace (105366) should be erased - done
                      Edges are not connected in CLoop (105548) for CFace (105547)
                      Loop 0 of CFace (105547) is an invalid outer loop
                      Entity CFace (105547) should be erased - done
                      Edges are not connected in CLoop (105662) for CFace (105661)
                      Loop 0 of CFace (105661) is an invalid outer loop
                      Entity CFace (105661) should be erased - done
                      Edges are not connected in CLoop (105711) for CFace (105710)
                      Loop 0 of CFace (105710) is an invalid outer loop
                      Entity CFace (105710) should be erased - done
                      Edges are not connected in CLoop (105852) for CFace (105851)
                      Loop 0 of CFace (105851) is an invalid outer loop
                      Entity CFace (105851) should be erased - done
                      Edges are not connected in CLoop (106308) for CFace (106307)
                      Loop 0 of CFace (106307) is an invalid outer loop
                      Entity CFace (106307) should be erased - done
                      Edges are not connected in CLoop (106460) for CFace (106459)
                      Loop 0 of CFace (106459) is an invalid outer loop
                      Entity CFace (106459) should be erased - done
                      Edges are not connected in CLoop (106471) for CFace (106470)
                      Loop 0 of CFace (106470) is an invalid outer loop
                      Entity CFace (106470) should be erased - done
                      Edges are not connected in CLoop (106659) for CFace (106658)
                      Loop 0 of CFace (106658) is an invalid outer loop
                      Entity CFace (106658) should be erased - done
                      Edges are not connected in CLoop (106773) for CFace (106772)
                      Loop 0 of CFace (106772) is an invalid outer loop
                      Entity CFace (106772) should be erased - done
                      Edges are not connected in CLoop (111516) for CFace (111515)
                      Loop 0 of CFace (111515) is an invalid outer loop
                      Entity CFace (111515) should be erased - done
                      Edges are not connected in CLoop (111771) for CFace (111770)
                      Loop 0 of CFace (111770) is an invalid outer loop
                      Entity CFace (111770) should be erased - done
                      Edges are not connected in CLoop (111885) for CFace (111884)
                      Loop 0 of CFace (111884) is an invalid outer loop
                      Entity CFace (111884) should be erased - done
                      Edges are not connected in CLoop (111990) for CFace (111989)
                      Loop 0 of CFace (111989) is an invalid outer loop
                      Entity CFace (111989) should be erased - done
                      Edges are not connected in CLoop (112115) for CFace (112114)
                      Loop 0 of CFace (112114) is an invalid outer loop
                      Entity CFace (112114) should be erased - done
                      Edges are not connected in CLoop (112408) for CFace (112407)
                      Loop 0 of CFace (112407) is an invalid outer loop
                      Entity CFace (112407) should be erased - done
                      Edges are not connected in CLoop (112750) for CFace (112749)
                      Loop 0 of CFace (112749) is an invalid outer loop
                      Entity CFace (112749) should be erased - done
                      Edges are not connected in CLoop (112902) for CFace (112901)
                      Loop 0 of CFace (112901) is an invalid outer loop
                      Entity CFace (112901) should be erased - done
                      Edges are not connected in CLoop (112913) for CFace (112912)
                      Loop 0 of CFace (112912) is an invalid outer loop
                      Entity CFace (112912) should be erased - done
                      Edges are not connected in CLoop (113092) for CFace (113091)
                      Loop 0 of CFace (113091) is an invalid outer loop
                      Entity CFace (113091) should be erased - done
                      Edges are not connected in CLoop (113434) for CFace (113433)
                      Loop 0 of CFace (113433) is an invalid outer loop
                      Entity CFace (113433) should be erased - done
                      Edges are not connected in CLoop (113559) for CFace (113558)
                      Loop 0 of CFace (113558) is an invalid outer loop
                      Entity CFace (113558) should be erased - done
                      Edges are not connected in CLoop (113814) for CFace (113813)
                      Loop 0 of CFace (113813) is an invalid outer loop
                      Entity CFace (113813) should be erased - done
                      Edges are not connected in CLoop (113928) for CFace (113927)
                      Loop 0 of CFace (113927) is an invalid outer loop
                      Entity CFace (113927) should be erased - done
                      Edges are not connected in CLoop (114080) for CFace (114079)
                      Loop 0 of CFace (114079) is an invalid outer loop
                      Entity CFace (114079) should be erased - done
                      Edges are not connected in CLoop (114281) for CFace (114280)
                      Loop 0 of CFace (114280) is an invalid outer loop
                      Entity CFace (114280) should be erased - done
                      Edges are not connected in CLoop (114460) for CFace (114459)
                      Loop 0 of CFace (114459) is an invalid outer loop
                      Entity CFace (114459) should be erased - done
                      Edges are not connected in CLoop (114869) for CFace (114868)
                      Loop 0 of CFace (114868) is an invalid outer loop
                      Entity CFace (114868) should be erased - done
                      Edges are not connected in CLoop (114945) for CFace (114944)
                      Loop 0 of CFace (114944) is an invalid outer loop
                      Entity CFace (114944) should be erased - done
                      Edges are not connected in CLoop (114956) for CFace (114955)
                      Loop 0 of CFace (114955) is an invalid outer loop
                      Entity CFace (114955) should be erased - done
                      Edges are not connected in CLoop (115135) for CFace (115134)
                      Loop 0 of CFace (115134) is an invalid outer loop
                      Entity CFace (115134) should be erased - done
                      Edges are not connected in CLoop (115439) for CFace (115438)
                      Loop 0 of CFace (115438) is an invalid outer loop
                      Entity CFace (115438) should be erased - done
                      Edges are not connected in CLoop (115526) for CFace (115525)
                      Loop 0 of CFace (115525) is an invalid outer loop
                      Entity CFace (115525) should be erased - done
                      Edges are not connected in CLoop (115772) for CFace (115771)
                      Loop 0 of CFace (115771) is an invalid outer loop
                      Entity CFace (115771) should be erased - done
                      Edges are not connected in CLoop (115886) for CFace (115885)
                      Loop 0 of CFace (115885) is an invalid outer loop
                      Entity CFace (115885) should be erased - done
                      Edges are not connected in CLoop (116085) for CFace (116084)
                      Loop 0 of CFace (116084) is an invalid outer loop
                      Entity CFace (116084) should be erased - done
                      Edges are not connected in CLoop (116248) for CFace (116247)
                      Loop 0 of CFace (116247) is an invalid outer loop
                      Entity CFace (116247) should be erased - done
                      Edges are not connected in CLoop (116427) for CFace (116426)
                      Loop 0 of CFace (116426) is an invalid outer loop
                      Entity CFace (116426) should be erased - done
                      Edges are not connected in CLoop (116740) for CFace (116739)
                      Loop 0 of CFace (116739) is an invalid outer loop
                      Entity CFace (116739) should be erased - done
                      Edges are not connected in CLoop (116845) for CFace (116844)
                      Loop 0 of CFace (116844) is an invalid outer loop
                      Entity CFace (116844) should be erased - done
                      Edges are not connected in CLoop (116856) for CFace (116855)
                      Loop 0 of CFace (116855) is an invalid outer loop
                      Entity CFace (116855) should be erased - done
                      Edges are not connected in CLoop (117035) for CFace (117034)
                      Loop 0 of CFace (117034) is an invalid outer loop
                      Entity CFace (117034) should be erased - done
                      Edges are not connected in CLoop (117339) for CFace (117338)
                      Loop 0 of CFace (117338) is an invalid outer loop
                      Entity CFace (117338) should be erased - done
                      Edges are not connected in CLoop (117464) for CFace (117463)
                      Loop 0 of CFace (117463) is an invalid outer loop
                      Entity CFace (117463) should be erased - done
                      Edges are not connected in CLoop (117719) for CFace (117718)
                      Loop 0 of CFace (117718) is an invalid outer loop
                      Entity CFace (117718) should be erased - done
                      Edges are not connected in CLoop (117956) for CFace (117955)
                      Loop 0 of CFace (117955) is an invalid outer loop
                      Entity CFace (117955) should be erased - done
                      Edges are not connected in CLoop (118110) for CFace (118109)
                      Loop 0 of CFace (118109) is an invalid outer loop
                      Entity CFace (118109) should be erased - done
                      Edges are not connected in CLoop (118327) for CFace (118326)
                      Loop 0 of CFace (118326) is an invalid outer loop
                      Entity CFace (118326) should be erased - done
                      Edges are not connected in CLoop (118631) for CFace (118630)
                      Loop 0 of CFace (118630) is an invalid outer loop
                      Entity CFace (118630) should be erased - done
                      Edges are not connected in CLoop (118718) for CFace (118717)
                      Loop 0 of CFace (118717) is an invalid outer loop
                      Entity CFace (118717) should be erased - done
                      Edges are not connected in CLoop (118897) for CFace (118896)
                      Loop 0 of CFace (118896) is an invalid outer loop
                      Entity CFace (118896) should be erased - done
                      Edges are not connected in CLoop (119201) for CFace (119200)
                      Loop 0 of CFace (119200) is an invalid outer loop
                      Entity CFace (119200) should be erased - done
                      Edges are not connected in CLoop (119326) for CFace (119325)
                      Loop 0 of CFace (119325) is an invalid outer loop
                      Entity CFace (119325) should be erased - done
                      Edges are not connected in CLoop (119543) for CFace (119542)
                      Loop 0 of CFace (119542) is an invalid outer loop
                      Entity CFace (119542) should be erased - done
                      Edges are not connected in CLoop (119800) for CFace (119799)
                      Loop 0 of CFace (119799) is an invalid outer loop
                      Entity CFace (119799) should be erased - done
                      Edges are not connected in CLoop (120104) for CFace (120103)
                      Loop 0 of CFace (120103) is an invalid outer loop
                      Entity CFace (120103) should be erased - done
                      Edges are not connected in CLoop (120446) for CFace (120445)
                      Loop 0 of CFace (120445) is an invalid outer loop
                      Entity CFace (120445) should be erased - done
                      Edges are not connected in CLoop (120636) for CFace (120635)
                      Loop 0 of CFace (120635) is an invalid outer loop
                      Entity CFace (120635) should be erased - done
                      Edges are not connected in CLoop (120817) for CFace (120816)
                      Loop 0 of CFace (120816) is an invalid outer loop
                      Entity CFace (120816) should be erased - done
                      Edges are not connected in CLoop (121007) for CFace (121006)
                      Loop 0 of CFace (121006) is an invalid outer loop
                      Entity CFace (121006) should be erased - done
                      Edges are not connected in CLoop (121311) for CFace (121310)
                      Loop 0 of CFace (121310) is an invalid outer loop
                      Entity CFace (121310) should be erased - done
                      Edges are not connected in CLoop (121501) for CFace (121500)
                      Loop 0 of CFace (121500) is an invalid outer loop
                      Entity CFace (121500) should be erased - done
                      Edges are not connected in CLoop (121843) for CFace (121842)
                      Loop 0 of CFace (121842) is an invalid outer loop
                      Entity CFace (121842) should be erased - done
                      Edges are not connected in CLoop (122261) for CFace (122260)
                      Loop 0 of CFace (122260) is an invalid outer loop
                      Entity CFace (122260) should be erased - done
                      Edges are not connected in CLoop (122299) for CFace (122298)
                      Loop 0 of CFace (122298) is an invalid outer loop
                      Entity CFace (122298) should be erased - done
                      Edges are not connected in CLoop (122413) for CFace (122412)
                      Loop 0 of CFace (122412) is an invalid outer loop
                      Entity CFace (122412) should be erased - done
                      Edges are not connected in CLoop (122755) for CFace (122754)
                      Loop 0 of CFace (122754) is an invalid outer loop
                      Entity CFace (122754) should be erased - done
                      Edges are not connected in CLoop (123164) for CFace (123163)
                      Loop 0 of CFace (123163) is an invalid outer loop
                      Entity CFace (123163) should be erased - done
                      Edges are not connected in CLoop (123202) for CFace (123201)
                      Loop 0 of CFace (123201) is an invalid outer loop
                      Entity CFace (123201) should be erased - done
                      Edges are not connected in CLoop (123316) for CFace (123315)
                      Loop 0 of CFace (123315) is an invalid outer loop
                      Entity CFace (123315) should be erased - done
                      Edges are not connected in CLoop (123365) for CFace (123364)
                      Loop 0 of CFace (123364) is an invalid outer loop
                      Entity CFace (123364) should be erased - done
                      Edges are not connected in CLoop (123696) for CFace (123695)
                      Loop 0 of CFace (123695) is an invalid outer loop
                      Entity CFace (123695) should be erased - done
                      Edges are not connected in CLoop (124038) for CFace (124037)
                      Loop 0 of CFace (124037) is an invalid outer loop
                      Entity CFace (124037) should be erased - done
                      Edges are not connected in CLoop (124076) for CFace (124075)
                      Loop 0 of CFace (124075) is an invalid outer loop
                      Entity CFace (124075) should be erased - done
                      Edges are not connected in CLoop (124228) for CFace (124227)
                      Loop 0 of CFace (124227) is an invalid outer loop
                      Entity CFace (124227) should be erased - done
                      Edges are not connected in CLoop (124570) for CFace (124569)
                      Loop 0 of CFace (124569) is an invalid outer loop
                      Entity CFace (124569) should be erased - done
                      Edges are not connected in CLoop (124657) for CFace (124656)
                      Loop 0 of CFace (124656) is an invalid outer loop
                      Entity CFace (124656) should be erased - done
                      Edges are not connected in CLoop (124988) for CFace (124987)
                      Loop 0 of CFace (124987) is an invalid outer loop
                      Entity CFace (124987) should be erased - done
                      Edges are not connected in CLoop (125026) for CFace (125025)
                      Loop 0 of CFace (125025) is an invalid outer loop
                      Entity CFace (125025) should be erased - done
                      Edges are not connected in CLoop (125140) for CFace (125139)
                      Loop 0 of CFace (125139) is an invalid outer loop
                      Entity CFace (125139) should be erased - done
                      Edges are not connected in CLoop (125265) for CFace (125264)
                      Loop 0 of CFace (125264) is an invalid outer loop
                      Entity CFace (125264) should be erased - done
                      Edges are not connected in CLoop (125558) for CFace (125557)
                      Loop 0 of CFace (125557) is an invalid outer loop
                      Entity CFace (125557) should be erased - done
                      Edges are not connected in CLoop (125938) for CFace (125937)
                      Loop 0 of CFace (125937) is an invalid outer loop
                      Entity CFace (125937) should be erased - done
                      Edges are not connected in CLoop (125949) for CFace (125948)
                      Loop 0 of CFace (125948) is an invalid outer loop
                      Entity CFace (125948) should be erased - done
                      Edges are not connected in CLoop (126014) for CFace (126013)
                      Loop 0 of CFace (126013) is an invalid outer loop
                      Entity CFace (126013) should be erased - done
                      Edges are not connected in CLoop (126059) for CFace (126058)
                      Loop 0 of CFace (126058) is an invalid outer loop
                      Entity CFace (126058) should be erased - done
                      Edges are not connected in CLoop (126173) for CFace (126172)
                      Loop 0 of CFace (126172) is an invalid outer loop
                      Entity CFace (126172) should be erased - done
                      Edges are not connected in CLoop (126553) for CFace (126552)
                      Loop 0 of CFace (126552) is an invalid outer loop
                      Entity CFace (126552) should be erased - done
                      Edges are not connected in CLoop (126602) for CFace (126601)
                      Loop 0 of CFace (126601) is an invalid outer loop
                      Entity CFace (126601) should be erased - done
                      Edges are not connected in CLoop (126895) for CFace (126894)
                      Loop 0 of CFace (126894) is an invalid outer loop
                      Entity CFace (126894) should be erased - done
                      Edges are not connected in CLoop (126933) for CFace (126932)
                      Loop 0 of CFace (126932) is an invalid outer loop
                      Entity CFace (126932) should be erased - done
                      Edges are not connected in CLoop (127014) for CFace (127013)
                      Loop 0 of CFace (127013) is an invalid outer loop
                      Entity CFace (127013) should be erased - done
                      Edges are not connected in CLoop (127128) for CFace (127127)
                      Loop 0 of CFace (127127) is an invalid outer loop
                      Entity CFace (127127) should be erased - done
                      Edges are not connected in CLoop (127215) for CFace (127214)
                      Loop 0 of CFace (127214) is an invalid outer loop
                      Entity CFace (127214) should be erased - done
                      Edges are not connected in CLoop (127575) for CFace (127574)
                      Loop 0 of CFace (127574) is an invalid outer loop
                      Entity CFace (127574) should be erased - done
                      Edges are not connected in CLoop (127908) for CFace (127907)
                      Loop 0 of CFace (127907) is an invalid outer loop
                      Entity CFace (127907) should be erased - done
                      Edges are not connected in CLoop (127919) for CFace (127918)
                      Loop 0 of CFace (127918) is an invalid outer loop
                      Entity CFace (127918) should be erased - done
                      Edges are not connected in CLoop (127984) for CFace (127983)
                      Loop 0 of CFace (127983) is an invalid outer loop
                      Entity CFace (127983) should be erased - done
                      Edges are not connected in CLoop (128029) for CFace (128028)
                      Loop 0 of CFace (128028) is an invalid outer loop
                      Entity CFace (128028) should be erased - done
                      Edges are not connected in CLoop (128143) for CFace (128142)
                      Loop 0 of CFace (128142) is an invalid outer loop
                      Entity CFace (128142) should be erased - done
                      Edges are not connected in CLoop (128476) for CFace (128475)
                      Loop 0 of CFace (128475) is an invalid outer loop
                      Entity CFace (128475) should be erased - done
                      Edges are not connected in CLoop (128525) for CFace (128524)
                      Loop 0 of CFace (128524) is an invalid outer loop
                      Entity CFace (128524) should be erased - done
                      Edges are not connected in CLoop (128847) for CFace (128846)
                      Loop 0 of CFace (128846) is an invalid outer loop
                      Entity CFace (128846) should be erased - done
                      Edges are not connected in CLoop (128890) for CFace (128889)
                      Loop 0 of CFace (128889) is an invalid outer loop
                      Entity CFace (128889) should be erased - done
                      Edges are not connected in CLoop (129004) for CFace (129003)
                      Loop 0 of CFace (129003) is an invalid outer loop
                      Entity CFace (129003) should be erased - done
                      Edges are not connected in CLoop (129071) for CFace (129070)
                      Loop 0 of CFace (129070) is an invalid outer loop
                      Entity CFace (129070) should be erased - done
                      Edges are not connected in CLoop (129178) for CFace (129177)
                      Loop 0 of CFace (129177) is an invalid outer loop
                      Entity CFace (129177) should be erased - done
                      Edges are not connected in CLoop (129277) for CFace (129276)
                      Loop 0 of CFace (129276) is an invalid outer loop
                      Entity CFace (129276) should be erased - done
                      Edges are not connected in CLoop (129489) for CFace (129488)
                      Loop 0 of CFace (129488) is an invalid outer loop
                      Entity CFace (129488) should be erased - done
                      Edges are not connected in CLoop (129735) for CFace (129734)
                      Loop 0 of CFace (129734) is an invalid outer loop
                      Entity CFace (129734) should be erased - done
                      Edges are not connected in CLoop (129743) for CFace (129742)
                      Loop 0 of CFace (129742) is an invalid outer loop
                      Entity CFace (129742) should be erased - done
                      Edges are not connected in CLoop (129880) for CFace (129879)
                      Loop 0 of CFace (129879) is an invalid outer loop
                      Entity CFace (129879) should be erased - done
                      Edges are not connected in CLoop (129989) for CFace (129988)
                      Loop 0 of CFace (129988) is an invalid outer loop
                      Entity CFace (129988) should be erased - done
                      Edges are not connected in CLoop (130005) for CFace (130004)
                      Loop 0 of CFace (130004) is an invalid outer loop
                      Entity CFace (130004) should be erased - done
                      Edges are not connected in CLoop (130021) for CFace (130020)
                      Loop 0 of CFace (130020) is an invalid outer loop
                      Entity CFace (130020) should be erased - done
                      Edges are not connected in CLoop (130034) for CFace (130033)
                      Loop 0 of CFace (130033) is an invalid outer loop
                      Entity CFace (130033) should be erased - done
                      Edges are not connected in CLoop (130114) for CFace (130113)
                      Loop 0 of CFace (130113) is an invalid outer loop
                      Entity CFace (130113) should be erased - done
                      Edges are not connected in CLoop (130130) for CFace (130129)
                      Loop 0 of CFace (130129) is an invalid outer loop
                      Entity CFace (130129) should be erased - done
                      Edges are not connected in CLoop (130146) for CFace (130145)
                      Loop 0 of CFace (130145) is an invalid outer loop
                      Entity CFace (130145) should be erased - done
                      Edges are not connected in CLoop (130159) for CFace (130158)
                      Loop 0 of CFace (130158) is an invalid outer loop
                      Entity CFace (130158) should be erased - done
                      Edges are not connected in CLoop (130239) for CFace (130238)
                      Loop 0 of CFace (130238) is an invalid outer loop
                      Entity CFace (130238) should be erased - done
                      Edges are not connected in CLoop (130255) for CFace (130254)
                      Loop 0 of CFace (130254) is an invalid outer loop
                      Entity CFace (130254) should be erased - done
                      Edges are not connected in CLoop (130271) for CFace (130270)
                      Loop 0 of CFace (130270) is an invalid outer loop
                      Entity CFace (130270) should be erased - done
                      Edges are not connected in CLoop (130284) for CFace (130283)
                      Loop 0 of CFace (130283) is an invalid outer loop
                      Entity CFace (130283) should be erased - done
                      Edges are not connected in CLoop (130364) for CFace (130363)
                      Loop 0 of CFace (130363) is an invalid outer loop
                      Entity CFace (130363) should be erased - done
                      Edges are not connected in CLoop (130380) for CFace (130379)
                      Loop 0 of CFace (130379) is an invalid outer loop
                      Entity CFace (130379) should be erased - done
                      Edges are not connected in CLoop (130396) for CFace (130395)
                      Loop 0 of CFace (130395) is an invalid outer loop
                      Entity CFace (130395) should be erased - done
                      Edges are not connected in CLoop (130409) for CFace (130408)
                      Loop 0 of CFace (130408) is an invalid outer loop
                      Entity CFace (130408) should be erased - done
                      Edges are not connected in CLoop (130489) for CFace (130488)
                      Loop 0 of CFace (130488) is an invalid outer loop
                      Entity CFace (130488) should be erased - done
                      Edges are not connected in CLoop (130505) for CFace (130504)
                      Loop 0 of CFace (130504) is an invalid outer loop
                      Entity CFace (130504) should be erased - done
                      Edges are not connected in CLoop (130521) for CFace (130520)
                      Loop 0 of CFace (130520) is an invalid outer loop
                      Entity CFace (130520) should be erased - done
                      Edges are not connected in CLoop (130534) for CFace (130533)
                      Loop 0 of CFace (130533) is an invalid outer loop
                      Entity CFace (130533) should be erased - done
                      Edges are not connected in CLoop (130614) for CFace (130613)
                      Loop 0 of CFace (130613) is an invalid outer loop
                      Entity CFace (130613) should be erased - done
                      Edges are not connected in CLoop (130630) for CFace (130629)
                      Loop 0 of CFace (130629) is an invalid outer loop
                      Entity CFace (130629) should be erased - done
                      Edges are not connected in CLoop (130646) for CFace (130645)
                      Loop 0 of CFace (130645) is an invalid outer loop
                      Entity CFace (130645) should be erased - done
                      Edges are not connected in CLoop (130659) for CFace (130658)
                      Loop 0 of CFace (130658) is an invalid outer loop
                      Entity CFace (130658) should be erased - done
                      Edges are not connected in CLoop (130739) for CFace (130738)
                      Loop 0 of CFace (130738) is an invalid outer loop
                      Entity CFace (130738) should be erased - done
                      Edges are not connected in CLoop (130755) for CFace (130754)
                      Loop 0 of CFace (130754) is an invalid outer loop
                      Entity CFace (130754) should be erased - done
                      Edges are not connected in CLoop (130771) for CFace (130770)
                      Loop 0 of CFace (130770) is an invalid outer loop
                      Entity CFace (130770) should be erased - done
                      Edges are not connected in CLoop (130784) for CFace (130783)
                      Loop 0 of CFace (130783) is an invalid outer loop
                      Entity CFace (130783) should be erased - done
                      Edges are not connected in CLoop (130864) for CFace (130863)
                      Loop 0 of CFace (130863) is an invalid outer loop
                      Entity CFace (130863) should be erased - done
                      Edges are not connected in CLoop (130880) for CFace (130879)
                      Loop 0 of CFace (130879) is an invalid outer loop
                      Entity CFace (130879) should be erased - done
                      Edges are not connected in CLoop (130896) for CFace (130895)
                      Loop 0 of CFace (130895) is an invalid outer loop
                      Entity CFace (130895) should be erased - done
                      Edges are not connected in CLoop (130909) for CFace (130908)
                      Loop 0 of CFace (130908) is an invalid outer loop
                      Entity CFace (130908) should be erased - done
                      Edges are not connected in CLoop (130989) for CFace (130988)
                      Loop 0 of CFace (130988) is an invalid outer loop
                      Entity CFace (130988) should be erased - done
                      Edges are not connected in CLoop (131005) for CFace (131004)
                      Loop 0 of CFace (131004) is an invalid outer loop
                      Entity CFace (131004) should be erased - done
                      Edges are not connected in CLoop (131021) for CFace (131020)
                      Loop 0 of CFace (131020) is an invalid outer loop
                      Entity CFace (131020) should be erased - done
                      Edges are not connected in CLoop (131034) for CFace (131033)
                      Loop 0 of CFace (131033) is an invalid outer loop
                      Entity CFace (131033) should be erased - done
                      Edges are not connected in CLoop (131114) for CFace (131113)
                      Loop 0 of CFace (131113) is an invalid outer loop
                      Entity CFace (131113) should be erased - done
                      Edges are not connected in CLoop (131130) for CFace (131129)
                      Loop 0 of CFace (131129) is an invalid outer loop
                      Entity CFace (131129) should be erased - done
                      Edges are not connected in CLoop (131146) for CFace (131145)
                      Loop 0 of CFace (131145) is an invalid outer loop
                      Entity CFace (131145) should be erased - done
                      Edges are not connected in CLoop (131159) for CFace (131158)
                      Loop 0 of CFace (131158) is an invalid outer loop
                      Entity CFace (131158) should be erased - done
                      Edges are not connected in CLoop (131239) for CFace (131238)
                      Loop 0 of CFace (131238) is an invalid outer loop
                      Entity CFace (131238) should be erased - done
                      Edges are not connected in CLoop (131255) for CFace (131254)
                      Loop 0 of CFace (131254) is an invalid outer loop
                      Entity CFace (131254) should be erased - done
                      Edges are not connected in CLoop (131271) for CFace (131270)
                      Loop 0 of CFace (131270) is an invalid outer loop
                      Entity CFace (131270) should be erased - done
                      Edges are not connected in CLoop (131284) for CFace (131283)
                      Loop 0 of CFace (131283) is an invalid outer loop
                      Entity CFace (131283) should be erased - done
                      Edges are not connected in CLoop (131364) for CFace (131363)
                      Loop 0 of CFace (131363) is an invalid outer loop
                      Entity CFace (131363) should be erased - done
                      Edges are not connected in CLoop (131380) for CFace (131379)
                      Loop 0 of CFace (131379) is an invalid outer loop
                      Entity CFace (131379) should be erased - done
                      Edges are not connected in CLoop (131396) for CFace (131395)
                      Loop 0 of CFace (131395) is an invalid outer loop
                      Entity CFace (131395) should be erased - done
                      Edges are not connected in CLoop (131409) for CFace (131408)
                      Loop 0 of CFace (131408) is an invalid outer loop
                      Entity CFace (131408) should be erased - done
                      Edges are not connected in CLoop (131489) for CFace (131488)
                      Loop 0 of CFace (131488) is an invalid outer loop
                      Entity CFace (131488) should be erased - done
                      Edges are not connected in CLoop (131505) for CFace (131504)
                      Loop 0 of CFace (131504) is an invalid outer loop
                      Entity CFace (131504) should be erased - done
                      Edges are not connected in CLoop (131521) for CFace (131520)
                      Loop 0 of CFace (131520) is an invalid outer loop
                      Entity CFace (131520) should be erased - done
                      Edges are not connected in CLoop (131534) for CFace (131533)
                      Loop 0 of CFace (131533) is an invalid outer loop
                      Entity CFace (131533) should be erased - done
                      Edges are not connected in CLoop (131614) for CFace (131613)
                      Loop 0 of CFace (131613) is an invalid outer loop
                      Entity CFace (131613) should be erased - done
                      Edges are not connected in CLoop (131630) for CFace (131629)
                      Loop 0 of CFace (131629) is an invalid outer loop
                      Entity CFace (131629) should be erased - done
                      Edges are not connected in CLoop (131646) for CFace (131645)
                      Loop 0 of CFace (131645) is an invalid outer loop
                      Entity CFace (131645) should be erased - done
                      Edges are not connected in CLoop (131659) for CFace (131658)
                      Loop 0 of CFace (131658) is an invalid outer loop
                      Entity CFace (131658) should be erased - done
                      Edges are not connected in CLoop (131739) for CFace (131738)
                      Loop 0 of CFace (131738) is an invalid outer loop
                      Entity CFace (131738) should be erased - done
                      Edges are not connected in CLoop (131755) for CFace (131754)
                      Loop 0 of CFace (131754) is an invalid outer loop
                      Entity CFace (131754) should be erased - done
                      Edges are not connected in CLoop (131771) for CFace (131770)
                      Loop 0 of CFace (131770) is an invalid outer loop
                      Entity CFace (131770) should be erased - done
                      Edges are not connected in CLoop (131784) for CFace (131783)
                      Loop 0 of CFace (131783) is an invalid outer loop
                      Entity CFace (131783) should be erased - done
                      Edges are not connected in CLoop (131864) for CFace (131863)
                      Loop 0 of CFace (131863) is an invalid outer loop
                      Entity CFace (131863) should be erased - done
                      Edges are not connected in CLoop (131880) for CFace (131879)
                      Loop 0 of CFace (131879) is an invalid outer loop
                      Entity CFace (131879) should be erased - done
                      Edges are not connected in CLoop (131896) for CFace (131895)
                      Loop 0 of CFace (131895) is an invalid outer loop
                      Entity CFace (131895) should be erased - done
                      Edges are not connected in CLoop (131909) for CFace (131908)
                      Loop 0 of CFace (131908) is an invalid outer loop
                      Entity CFace (131908) should be erased - done
                      Daniel S
                        This suggests somethings are so small they appear to be coincident - to SUp - and 'fail'... ❓
                        • ken28875K Offline
                          ken28875
                          I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😢
                          Does anyone have the same problem?
                          Thanks,
                          _KN
                          Follow Your Dreams.
                            I have never had that problem [Vista].
                            How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
                            • ken28875K Offline
                              ken28875
                              Hi TIG,
                              It's only 40cm.
                              http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
                              Thanks,
                              _KN
                              Follow Your Dreams.
                                Unlikely to result in faces <1mm ?
                                  I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments 😄 )
                                  • ken28875K Offline
                                    ken28875
                                    What do you mean, TIG?
                                    Thanks,
                                    _KN
                                    Follow Your Dreams.
                                    • brookefoxB Offline
                                      brookefox
                                      My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
                                      S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
                                      Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
                                      ~ Brooke
                                        If a 'followme' type tool makes faces with dims <~1mm it will cause failures - a limitation of OpenGL ?
                                        I thought you might be making the equivalent of a 'followme' around a tight curve that made these small facets and crashed - but maybe not ?
                                        Can you successfully make the equivalent rounded/chamfer using the FollowMe tool 'raw' ?
                                        • ken28875K Offline
                                          ken28875
                                          Hi TIG,
                                          I don't have any problems with the Follow-me tool.
                                          Sketchup crashes only when I use RoundCorner. 😢
                                          Thanks,
                                          _KN
                                          Follow Your Dreams.
                                          • fredo6F Offline
                                            @ken28875 said:
                                            Hi TIG,
                                            Thanks,
                                            _KN
                                            Ken,
                                            Could you post or send me the model, so that I can have a look at whatcrashes.
                                            I assume that you also upgraded to the latest version. There was a previous release that had reported crashes.
                                            • 73
                                            • 74
                                            • 2 / 74
