    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • fredo6F Offline
      @hieru said:
      Yes I did.
      I've just tried remodelling certain elements of the model I'm working on and I'm finding that all sorts of odd geometry is appearing on its own and random bits of geometry keep disappearing in areas where I haven't applied the plugin.
      I'll have to try reinstalling SU.
      Before reinstalling SU, could you post your model, so that I have a look and try to find out where the issue comes from.
      • HieruH Offline
        Hieru
        I'd really appreciate that. Thanks.
        Problem File
        The model has only been scaled up so that it is 10 times the size that it needs to be. I've been trying to use a 2mm bevel on various edges, but if I scale up the model and use a 20mm bevel, I still get the same problem.
        www.davidhier.co.uk
        • X Offline
          xrok1
          nice model but which corners are giving you problems?
          • HieruH Offline
            Hieru
            Hi xrok1,
            The edges pictured in your post are amongst those effected.
            I just realised that it wasn't very helpful to post a model where most of the edges had already been rounded off.
            Here's a sharp edge version (again 10 x final size).
            UFObeamX10.skp
            Even basic shapes like the square blocks and the clear lens on the top of the lighting model are causing me trouble.
            www.davidhier.co.uk
            • X Offline
              xrok1
              i can't seem to reproduce the problems?? what version of SU do you have installed?
                Hi Hieru,
                I have downloaded scaled (up to 10 times) and rounded a corner of your model (with 200 radius and 6 segments which should be quite enough). Note the tape measure tool on the shortest edges which is now ~1.4 mm. If that value were somewhere (or less than) 1 mm, the face would not be created. This could well be the case if you scale it up by 10 but use more segments with the 20 mm radius.
                • HieruH Offline
                  Hieru
                  xrok1,
                  I'm using SU 7.1.6087 (Free)
                  Gaieus,
                  When I scaled up the model and applied a 20mm radius, I still used 6 segments. The plugin doesn't appear to have a problem creating the faces and I can select them once created. The problem is that they vanish, along with hidden geometry, when I save the file.
                  www.davidhier.co.uk
                    I have no idea why that is happening. Try something: Go to your Window > Preferences > General tab and uncheck"Automatically fix problems..."
                    The plugin mayproduce invalid geometry and upon saving, this option deletes it. If you keep "Automatically check model..." checked, SU should give you a warning. Then "fix" the model and it will present you with a list of what was fixed. Make a screenshot of that window and attach it here - it may help Fredo to improve the plugin (only IF this invalid geometry is the problem of course)
                    • HieruH Offline
                      Hieru
                      Thanks Gaieus, I'll give that a go.
                      As an update to the situation I uninstalled SU and then installed the latest version. I then added the RoundCorner plugin (as well as LibFredo) - no other plugins - and I still had the same problem.
                      I did however find a way around the issue. By exploding geometry, applying the plugin and then re-grouping the geometry I didn't lose any of the corner faces when saving.
                      www.davidhier.co.uk
                        Hm. That's very interesting.
                        • fredo6F Offline
                          Hieru,
                          I played with your model and could not reproduce the loss of faces, even if a small radius.
                          I would recommend you do what Gaieus recommends to see if this is not related to the model (the fact that the faces are computed by RoundCorner, but disappear when saving, seems to be a more general issue with the model than the plugin).
                          Also, if this is reproducable, could you try to copy the model within the same file and save to see if both instances have a loss of faces.
                          • HieruH Offline
                            Hieru
                            Hi Fredo6,
                            Thanks for taking the time to look at the model.
                            I followed Gaieus' instructions, but I don't get a warning when applying the plugin or saving the file.
                            Copying the model within the file results in a loss of faces in both sets of geometry. I also tried converting one group of geometry into a component and then applied the plugin. When saving there is a loss of faces for each instance of a component.
                            What was odd is the fact that when I loaded the component from the component palette it was reproduced at a much smaller scale than the original object. Presumably that isn't supposed to happen and is another indication that there is something odd about the model?
                            Luckily I have been able to apply the plugin using the method mentioned in my previous post, so I haven't had to remodel the light.
                            Also I've been working on an architectural model today and haven't had any trouble with the RoundCorner plugin.......so it looks more and more like this was a problem with my model........but can't think what the source of the problem might be.
                            www.davidhier.co.uk
                              Daniel S
                              I tried the model and I can´t reproduce the loss of faces... but I get the warning msg.
                              Results of Validity Check.
                              The start and end vertices are identical for CEdge (82816)
                              Entity CEdge (82816) should be erased - done
                              The start and end vertices are identical for CEdge (83152)
                              Entity CEdge (83152) should be erased - done
                              The start and end vertices are identical for CEdge (83230)
                              Entity CEdge (83230) should be erased - done
                              The start and end vertices are identical for CEdge (83324)
                              Entity CEdge (83324) should be erased - done
                              The start and end vertices are identical for CEdge (83738)
                              Entity CEdge (83738) should be erased - done
                              The start and end vertices are identical for CEdge (83879)
                              Entity CEdge (83879) should be erased - done
                              The start and end vertices are identical for CEdge (83965)
                              Entity CEdge (83965) should be erased - done
                              The start and end vertices are identical for CEdge (84015)
                              Entity CEdge (84015) should be erased - done
                              The start and end vertices are identical for CEdge (84124)
                              Entity CEdge (84124) should be erased - done
                              The start and end vertices are identical for CEdge (84399)
                              Entity CEdge (84399) should be erased - done
                              The start and end vertices are identical for CEdge (84751)
                              Entity CEdge (84751) should be erased - done
                              The start and end vertices are identical for CEdge (84763)
                              Entity CEdge (84763) should be erased - done
                              The start and end vertices are identical for CEdge (84903)
                              Entity CEdge (84903) should be erased - done
                              The start and end vertices are identical for CEdge (85017)
                              Entity CEdge (85017) should be erased - done
                              The start and end vertices are identical for CEdge (85186)
                              Entity CEdge (85186) should be erased - done
                              The start and end vertices are identical for CEdge (85351)
                              Entity CEdge (85351) should be erased - done
                              The start and end vertices are identical for CEdge (85757)
                              Entity CEdge (85757) should be erased - done
                              The start and end vertices are identical for CEdge (85918)
                              Entity CEdge (85918) should be erased - done
                              The start and end vertices are identical for CEdge (86032)
                              Entity CEdge (86032) should be erased - done
                              The start and end vertices are identical for CEdge (86082)
                              Entity CEdge (86082) should be erased - done
                              The start and end vertices are identical for CEdge (86191)
                              Entity CEdge (86191) should be erased - done
                              The start and end vertices are identical for CEdge (86771)
                              Entity CEdge (86771) should be erased - done
                              The start and end vertices are identical for CEdge (86783)
                              Entity CEdge (86783) should be erased - done
                              The start and end vertices are identical for CEdge (86923)
                              Entity CEdge (86923) should be erased - done
                              The start and end vertices are identical for CEdge (87075)
                              Entity CEdge (87075) should be erased - done
                              The start and end vertices are identical for CEdge (87361)
                              Entity CEdge (87361) should be erased - done
                              The start and end vertices are identical for CEdge (87852)
                              Entity CEdge (87852) should be erased - done
                              The start and end vertices are identical for CEdge (87928)
                              Entity CEdge (87928) should be erased - done
                              The start and end vertices are identical for CEdge (88080)
                              Entity CEdge (88080) should be erased - done
                              The start and end vertices are identical for CEdge (88168)
                              Entity CEdge (88168) should be erased - done
                              The start and end vertices are identical for CEdge (107162)
                              Entity CEdge (107162) should be erased - done
                              The start and end vertices are identical for CEdge (106469)
                              Entity CEdge (106469) should be erased - done
                              The start and end vertices are identical for CEdge (106305)
                              Entity CEdge (106305) should be erased - done
                              The start and end vertices are identical for CEdge (107454)
                              Entity CEdge (107454) should be erased - done
                              The start and end vertices are identical for CEdge (106457)
                              Entity CEdge (106457) should be erased - done
                              The start and end vertices are identical for CEdge (107568)
                              Entity CEdge (107568) should be erased - done
                              The start and end vertices are identical for CEdge (106656)
                              Entity CEdge (106656) should be erased - done
                              The start and end vertices are identical for CEdge (107720)
                              Entity CEdge (107720) should be erased - done
                              The start and end vertices are identical for CEdge (107884)
                              Entity CEdge (107884) should be erased - done
                              The start and end vertices are identical for CEdge (108509)
                              Entity CEdge (108509) should be erased - done
                              The start and end vertices are identical for CEdge (108623)
                              Entity CEdge (108623) should be erased - done
                              The start and end vertices are identical for CEdge (108635)
                              Entity CEdge (108635) should be erased - done
                              The start and end vertices are identical for CEdge (108775)
                              Entity CEdge (108775) should be erased - done
                              The start and end vertices are identical for CEdge (109357)
                              Entity CEdge (109357) should be erased - done
                              The start and end vertices are identical for CEdge (109611)
                              Entity CEdge (109611) should be erased - done
                              The start and end vertices are identical for CEdge (109763)
                              Entity CEdge (109763) should be erased - done
                              The start and end vertices are identical for CEdge (109877)
                              Entity CEdge (109877) should be erased - done
                              The start and end vertices are identical for CEdge (95020)
                              Entity CEdge (95020) should be erased - done
                              The start and end vertices are identical for CEdge (110032)
                              Entity CEdge (110032) should be erased - done
                              The start and end vertices are identical for CEdge (110695)
                              Entity CEdge (110695) should be erased - done
                              The start and end vertices are identical for CEdge (110809)
                              Entity CEdge (110809) should be erased - done
                              The start and end vertices are identical for CEdge (110821)
                              Entity CEdge (110821) should be erased - done
                              The start and end vertices are identical for CEdge (110961)
                              Entity CEdge (110961) should be erased - done
                              The start and end vertices are identical for CEdge (88876)
                              Entity CEdge (88876) should be erased - done
                              The start and end vertices are identical for CEdge (88978)
                              Entity CEdge (88978) should be erased - done
                              The start and end vertices are identical for CEdge (89060)
                              Entity CEdge (89060) should be erased - done
                              The start and end vertices are identical for CEdge (89213)
                              Entity CEdge (89213) should be erased - done
                              The start and end vertices are identical for CEdge (89373)
                              Entity CEdge (89373) should be erased - done
                              The start and end vertices are identical for CEdge (89462)
                              Entity CEdge (89462) should be erased - done
                              The start and end vertices are identical for CEdge (89982)
                              Entity CEdge (89982) should be erased - done
                              The start and end vertices are identical for CEdge (90134)
                              Entity CEdge (90134) should be erased - done
                              The start and end vertices are identical for CEdge (90184)
                              Entity CEdge (90184) should be erased - done
                              The start and end vertices are identical for CEdge (90715)
                              Entity CEdge (90715) should be erased - done
                              The start and end vertices are identical for CEdge (90918)
                              Entity CEdge (90918) should be erased - done
                              The start and end vertices are identical for CEdge (91058)
                              Entity CEdge (91058) should be erased - done
                              The start and end vertices are identical for CEdge (91100)
                              Entity CEdge (91100) should be erased - done
                              The start and end vertices are identical for CEdge (91177)
                              Entity CEdge (91177) should be erased - done
                              The start and end vertices are identical for CEdge (91409)
                              Entity CEdge (91409) should be erased - done
                              The start and end vertices are identical for CEdge (91536)
                              Entity CEdge (91536) should be erased - done
                              The start and end vertices are identical for CEdge (91796)
                              Entity CEdge (91796) should be erased - done
                              The start and end vertices are identical for CEdge (92101)
                              Entity CEdge (92101) should be erased - done
                              The start and end vertices are identical for CEdge (92258)
                              Entity CEdge (92258) should be erased - done
                              The start and end vertices are identical for CEdge (92308)
                              Entity CEdge (92308) should be erased - done
                              The start and end vertices are identical for CEdge (93001)
                              Entity CEdge (93001) should be erased - done
                              The start and end vertices are identical for CEdge (93179)
                              Entity CEdge (93179) should be erased - done
                              The start and end vertices are identical for CEdge (93255)
                              Entity CEdge (93255) should be erased - done
                              The start and end vertices are identical for CEdge (93533)
                              Entity CEdge (93533) should be erased - done
                              The start and end vertices are identical for CEdge (94062)
                              Entity CEdge (94062) should be erased - done
                              The start and end vertices are identical for CEdge (94138)
                              Entity CEdge (94138) should be erased - done
                              The start and end vertices are identical for CEdge (94150)
                              Entity CEdge (94150) should be erased - done
                              The start and end vertices are identical for CEdge (94834)
                              Entity CEdge (94834) should be erased - done
                              The start and end vertices are identical for CEdge (94974)
                              Entity CEdge (94974) should be erased - done
                              The start and end vertices are identical for CEdge (95135)
                              Entity CEdge (95135) should be erased - done
                              The start and end vertices are identical for CEdge (95451)
                              Entity CEdge (95451) should be erased - done
                              The start and end vertices are identical for CEdge (95933)
                              Entity CEdge (95933) should be erased - done
                              The start and end vertices are identical for CEdge (96000)
                              Entity CEdge (96000) should be erased - done
                              The start and end vertices are identical for CEdge (96050)
                              Entity CEdge (96050) should be erased - done
                              The start and end vertices are identical for CEdge (96734)
                              Entity CEdge (96734) should be erased - done
                              The start and end vertices are identical for CEdge (96874)
                              Entity CEdge (96874) should be erased - done
                              The start and end vertices are identical for CEdge (96959)
                              Entity CEdge (96959) should be erased - done
                              The start and end vertices are identical for CEdge (97360)
                              Entity CEdge (97360) should be erased - done
                              The start and end vertices are identical for CEdge (97766)
                              Entity CEdge (97766) should be erased - done
                              The start and end vertices are identical for CEdge (100599)
                              Entity CEdge (100599) should be erased - done
                              The start and end vertices are identical for CEdge (99944)
                              Entity CEdge (99944) should be erased - done
                              The start and end vertices are identical for CEdge (99704)
                              Entity CEdge (99704) should be erased - done
                              The start and end vertices are identical for CEdge (100815)
                              Entity CEdge (100815) should be erased - done
                              The start and end vertices are identical for CEdge (99932)
                              Entity CEdge (99932) should be erased - done
                              The start and end vertices are identical for CEdge (100967)
                              Entity CEdge (100967) should be erased - done
                              The start and end vertices are identical for CEdge (99361)
                              Entity CEdge (99361) should be erased - done
                              The start and end vertices are identical for CEdge (101148)
                              Entity CEdge (101148) should be erased - done
                              The start and end vertices are identical for CEdge (101350)
                              Entity CEdge (101350) should be erased - done
                              The start and end vertices are identical for CEdge (101870)
                              Entity CEdge (101870) should be erased - done
                              The start and end vertices are identical for CEdge (101984)
                              Entity CEdge (101984) should be erased - done
                              The start and end vertices are identical for CEdge (101996)
                              Entity CEdge (101996) should be erased - done
                              The start and end vertices are identical for CEdge (102259)
                              Entity CEdge (102259) should be erased - done
                              The start and end vertices are identical for CEdge (99251)
                              Entity CEdge (99251) should be erased - done
                              The start and end vertices are identical for CEdge (97880)
                              Entity CEdge (97880) should be erased - done
                              The start and end vertices are identical for CEdge (97930)
                              Entity CEdge (97930) should be erased - done
                              The start and end vertices are identical for CEdge (98643)
                              Entity CEdge (98643) should be erased - done
                              The start and end vertices are identical for CEdge (98745)
                              Entity CEdge (98745) should be erased - done
                              The start and end vertices are identical for CEdge (98935)
                              Entity CEdge (98935) should be erased - done
                              The start and end vertices are identical for CEdge (105709)
                              Entity CEdge (105709) should be erased - done
                              The start and end vertices are identical for CEdge (102803)
                              Entity CEdge (102803) should be erased - done
                              The start and end vertices are identical for CEdge (102981)
                              Entity CEdge (102981) should be erased - done
                              The start and end vertices are identical for CEdge (103133)
                              Entity CEdge (103133) should be erased - done
                              The start and end vertices are identical for CEdge (103323)
                              Entity CEdge (103323) should be erased - done
                              The start and end vertices are identical for CEdge (103525)
                              Entity CEdge (103525) should be erased - done
                              The start and end vertices are identical for CEdge (104092)
                              Entity CEdge (104092) should be erased - done
                              The start and end vertices are identical for CEdge (104206)
                              Entity CEdge (104206) should be erased - done
                              The start and end vertices are identical for CEdge (104218)
                              Entity CEdge (104218) should be erased - done
                              The start and end vertices are identical for CEdge (104443)
                              Entity CEdge (104443) should be erased - done
                              The start and end vertices are identical for CEdge (104987)
                              Entity CEdge (104987) should be erased - done
                              The start and end vertices are identical for CEdge (105250)
                              Entity CEdge (105250) should be erased - done
                              The start and end vertices are identical for CEdge (105364)
                              Entity CEdge (105364) should be erased - done
                              The start and end vertices are identical for CEdge (105545)
                              Entity CEdge (105545) should be erased - done
                              The start and end vertices are identical for CEdge (111514)
                              Entity CEdge (111514) should be erased - done
                              The start and end vertices are identical for CEdge (111768)
                              Entity CEdge (111768) should be erased - done
                              The start and end vertices are identical for CEdge (111882)
                              Entity CEdge (111882) should be erased - done
                              The start and end vertices are identical for CEdge (111987)
                              Entity CEdge (111987) should be erased - done
                              The start and end vertices are identical for CEdge (112113)
                              Entity CEdge (112113) should be erased - done
                              The start and end vertices are identical for CEdge (112747)
                              Entity CEdge (112747) should be erased - done
                              The start and end vertices are identical for CEdge (112899)
                              Entity CEdge (112899) should be erased - done
                              The start and end vertices are identical for CEdge (112911)
                              Entity CEdge (112911) should be erased - done
                              The start and end vertices are identical for CEdge (113089)
                              Entity CEdge (113089) should be erased - done
                              The start and end vertices are identical for CEdge (113557)
                              Entity CEdge (113557) should be erased - done
                              The start and end vertices are identical for CEdge (113811)
                              Entity CEdge (113811) should be erased - done
                              The start and end vertices are identical for CEdge (113925)
                              Entity CEdge (113925) should be erased - done
                              The start and end vertices are identical for CEdge (114077)
                              Entity CEdge (114077) should be erased - done
                              The start and end vertices are identical for CEdge (114279)
                              Entity CEdge (114279) should be erased - done
                              The start and end vertices are identical for CEdge (114866)
                              Entity CEdge (114866) should be erased - done
                              The start and end vertices are identical for CEdge (114942)
                              Entity CEdge (114942) should be erased - done
                              The start and end vertices are identical for CEdge (114954)
                              Entity CEdge (114954) should be erased - done
                              The start and end vertices are identical for CEdge (115132)
                              Entity CEdge (115132) should be erased - done
                              The start and end vertices are identical for CEdge (115524)
                              Entity CEdge (115524) should be erased - done
                              The start and end vertices are identical for CEdge (115769)
                              Entity CEdge (115769) should be erased - done
                              The start and end vertices are identical for CEdge (115883)
                              Entity CEdge (115883) should be erased - done
                              The start and end vertices are identical for CEdge (116082)
                              Entity CEdge (116082) should be erased - done
                              The start and end vertices are identical for CEdge (116246)
                              Entity CEdge (116246) should be erased - done
                              The start and end vertices are identical for CEdge (116737)
                              Entity CEdge (116737) should be erased - done
                              The start and end vertices are identical for CEdge (116854)
                              Entity CEdge (116854) should be erased - done
                              The start and end vertices are identical for CEdge (117032)
                              Entity CEdge (117032) should be erased - done
                              The start and end vertices are identical for CEdge (117462)
                              Entity CEdge (117462) should be erased - done
                              The start and end vertices are identical for CEdge (117716)
                              Entity CEdge (117716) should be erased - done
                              The start and end vertices are identical for CEdge (117953)
                              Entity CEdge (117953) should be erased - done
                              The start and end vertices are identical for CEdge (118108)
                              Entity CEdge (118108) should be erased - done
                              The start and end vertices are identical for CEdge (118628)
                              Entity CEdge (118628) should be erased - done
                              The start and end vertices are identical for CEdge (118716)
                              Entity CEdge (118716) should be erased - done
                              The start and end vertices are identical for CEdge (118894)
                              Entity CEdge (118894) should be erased - done
                              The start and end vertices are identical for CEdge (119324)
                              Entity CEdge (119324) should be erased - done
                              The start and end vertices are identical for CEdge (119540)
                              Entity CEdge (119540) should be erased - done
                              The start and end vertices are identical for CEdge (119797)
                              Entity CEdge (119797) should be erased - done
                              The start and end vertices are identical for CEdge (120443)
                              Entity CEdge (120443) should be erased - done
                              The start and end vertices are identical for CEdge (120633)
                              Entity CEdge (120633) should be erased - done
                              The start and end vertices are identical for CEdge (120814)
                              Entity CEdge (120814) should be erased - done
                              The start and end vertices are identical for CEdge (121308)
                              Entity CEdge (121308) should be erased - done
                              The start and end vertices are identical for CEdge (121498)
                              Entity CEdge (121498) should be erased - done
                              The start and end vertices are identical for CEdge (122258)
                              Entity CEdge (122258) should be erased - done
                              The start and end vertices are identical for CEdge (122296)
                              Entity CEdge (122296) should be erased - done
                              The start and end vertices are identical for CEdge (122410)
                              Entity CEdge (122410) should be erased - done
                              The start and end vertices are identical for CEdge (123161)
                              Entity CEdge (123161) should be erased - done
                              The start and end vertices are identical for CEdge (123199)
                              Entity CEdge (123199) should be erased - done
                              The start and end vertices are identical for CEdge (123313)
                              Entity CEdge (123313) should be erased - done
                              The start and end vertices are identical for CEdge (123363)
                              Entity CEdge (123363) should be erased - done
                              The start and end vertices are identical for CEdge (124035)
                              Entity CEdge (124035) should be erased - done
                              The start and end vertices are identical for CEdge (124073)
                              Entity CEdge (124073) should be erased - done
                              The start and end vertices are identical for CEdge (124225)
                              Entity CEdge (124225) should be erased - done
                              The start and end vertices are identical for CEdge (124655)
                              Entity CEdge (124655) should be erased - done
                              The start and end vertices are identical for CEdge (124985)
                              Entity CEdge (124985) should be erased - done
                              The start and end vertices are identical for CEdge (125023)
                              Entity CEdge (125023) should be erased - done
                              The start and end vertices are identical for CEdge (125137)
                              Entity CEdge (125137) should be erased - done
                              The start and end vertices are identical for CEdge (125263)
                              Entity CEdge (125263) should be erased - done
                              The start and end vertices are identical for CEdge (125935)
                              Entity CEdge (125935) should be erased - done
                              The start and end vertices are identical for CEdge (125947)
                              Entity CEdge (125947) should be erased - done
                              The start and end vertices are identical for CEdge (126011)
                              Entity CEdge (126011) should be erased - done
                              The start and end vertices are identical for CEdge (126055)
                              Entity CEdge (126055) should be erased - done
                              The start and end vertices are identical for CEdge (126170)
                              Entity CEdge (126170) should be erased - done
                              The start and end vertices are identical for CEdge (126600)
                              Entity CEdge (126600) should be erased - done
                              The start and end vertices are identical for CEdge (126892)
                              Entity CEdge (126892) should be erased - done
                              The start and end vertices are identical for CEdge (126930)
                              Entity CEdge (126930) should be erased - done
                              The start and end vertices are identical for CEdge (127010)
                              Entity CEdge (127010) should be erased - done
                              The start and end vertices are identical for CEdge (127125)
                              Entity CEdge (127125) should be erased - done
                              The start and end vertices are identical for CEdge (127213)
                              Entity CEdge (127213) should be erased - done
                              The start and end vertices are identical for CEdge (127905)
                              Entity CEdge (127905) should be erased - done
                              The start and end vertices are identical for CEdge (127917)
                              Entity CEdge (127917) should be erased - done
                              The start and end vertices are identical for CEdge (127981)
                              Entity CEdge (127981) should be erased - done
                              The start and end vertices are identical for CEdge (128025)
                              Entity CEdge (128025) should be erased - done
                              The start and end vertices are identical for CEdge (128140)
                              Entity CEdge (128140) should be erased - done
                              The start and end vertices are identical for CEdge (128523)
                              Entity CEdge (128523) should be erased - done
                              The start and end vertices are identical for CEdge (128844)
                              Entity CEdge (128844) should be erased - done
                              The start and end vertices are identical for CEdge (128886)
                              Entity CEdge (128886) should be erased - done
                              The start and end vertices are identical for CEdge (129001)
                              Entity CEdge (129001) should be erased - done
                              The start and end vertices are identical for CEdge (129176)
                              Entity CEdge (129176) should be erased - done
                              The start and end vertices are identical for CEdge (129273)
                              Entity CEdge (129273) should be erased - done
                              The start and end vertices are identical for CEdge (132246)
                              Entity CEdge (132246) should be erased - done
                              The start and end vertices are identical for CEdge (132255)
                              Entity CEdge (132255) should be erased - done
                              The start and end vertices are identical for CEdge (132261)
                              Entity CEdge (132261) should be erased - done
                              The start and end vertices are identical for CEdge (132267)
                              Entity CEdge (132267) should be erased - done
                              The start and end vertices are identical for CEdge (132270)
                              Entity CEdge (132270) should be erased - done
                              The start and end vertices are identical for CEdge (132279)
                              Entity CEdge (132279) should be erased - done
                              The start and end vertices are identical for CEdge (132291)
                              Entity CEdge (132291) should be erased - done
                              The start and end vertices are identical for CEdge (132294)
                              Entity CEdge (132294) should be erased - done
                              The start and end vertices are identical for CEdge (132297)
                              Entity CEdge (132297) should be erased - done
                              The start and end vertices are identical for CEdge (132315)
                              Entity CEdge (132315) should be erased - done
                              The start and end vertices are identical for CEdge (132324)
                              Entity CEdge (132324) should be erased - done
                              The start and end vertices are identical for CEdge (132342)
                              Entity CEdge (132342) should be erased - done
                              The start and end vertices are identical for CEdge (132345)
                              Entity CEdge (132345) should be erased - done
                              The start and end vertices are identical for CEdge (132363)
                              Entity CEdge (132363) should be erased - done
                              The start and end vertices are identical for CEdge (132378)
                              Entity CEdge (132378) should be erased - done
                              The start and end vertices are identical for CEdge (132381)
                              Entity CEdge (132381) should be erased - done
                              The start and end vertices are identical for CEdge (132384)
                              Entity CEdge (132384) should be erased - done
                              The start and end vertices are identical for CEdge (132411)
                              Entity CEdge (132411) should be erased - done
                              The start and end vertices are identical for CEdge (132414)
                              Entity CEdge (132414) should be erased - done
                              The start and end vertices are identical for CEdge (132420)
                              Entity CEdge (132420) should be erased - done
                              The start and end vertices are identical for CEdge (132435)
                              Entity CEdge (132435) should be erased - done
                              The start and end vertices are identical for CEdge (132438)
                              Entity CEdge (132438) should be erased - done
                              The start and end vertices are identical for CEdge (132459)
                              Entity CEdge (132459) should be erased - done
                              The start and end vertices are identical for CEdge (132474)
                              Entity CEdge (132474) should be erased - done
                              The start and end vertices are identical for CEdge (132486)
                              Entity CEdge (132486) should be erased - done
                              The start and end vertices are identical for CEdge (132495)
                              Entity CEdge (132495) should be erased - done
                              The start and end vertices are identical for CEdge (132501)
                              Entity CEdge (132501) should be erased - done
                              The start and end vertices are identical for CEdge (132513)
                              Entity CEdge (132513) should be erased - done
                              The start and end vertices are identical for CEdge (132516)
                              Entity CEdge (132516) should be erased - done
                              The start and end vertices are identical for CEdge (132531)
                              Entity CEdge (132531) should be erased - done
                              The start and end vertices are identical for CEdge (132540)
                              Entity CEdge (132540) should be erased - done
                              The start and end vertices are identical for CEdge (132546)
                              Entity CEdge (132546) should be erased - done
                              The start and end vertices are identical for CEdge (132549)
                              Entity CEdge (132549) should be erased - done
                              The start and end vertices are identical for CEdge (132564)
                              Entity CEdge (132564) should be erased - done
                              The start and end vertices are identical for CEdge (132579)
                              Entity CEdge (132579) should be erased - done
                              The start and end vertices are identical for CEdge (132591)
                              Entity CEdge (132591) should be erased - done
                              The start and end vertices are identical for CEdge (132600)
                              Entity CEdge (132600) should be erased - done
                              The start and end vertices are identical for CEdge (132609)
                              Entity CEdge (132609) should be erased - done
                              The start and end vertices are identical for CEdge (132621)
                              Entity CEdge (132621) should be erased - done
                              The start and end vertices are identical for CEdge (132624)
                              Entity CEdge (132624) should be erased - done
                              The start and end vertices are identical for CEdge (132636)
                              Entity CEdge (132636) should be erased - done
                              The start and end vertices are identical for CEdge (132642)
                              Entity CEdge (132642) should be erased - done
                              The start and end vertices are identical for CEdge (132648)
                              Entity CEdge (132648) should be erased - done
                              The start and end vertices are identical for CEdge (132651)
                              Entity CEdge (132651) should be erased - done
                              The start and end vertices are identical for CEdge (132654)
                              Entity CEdge (132654) should be erased - done
                              The start and end vertices are identical for CEdge (132657)
                              Entity CEdge (132657) should be erased - done
                              The start and end vertices are identical for CEdge (132684)
                              Entity CEdge (132684) should be erased - done
                              The start and end vertices are identical for CEdge (132690)
                              Entity CEdge (132690) should be erased - done
                              The start and end vertices are identical for CEdge (132708)
                              Entity CEdge (132708) should be erased - done
                              The start and end vertices are identical for CEdge (132717)
                              Entity CEdge (132717) should be erased - done
                              The start and end vertices are identical for CEdge (132720)
                              Entity CEdge (132720) should be erased - done
                              The start and end vertices are identical for CEdge (132735)
                              Entity CEdge (132735) should be erased - done
                              The start and end vertices are identical for CEdge (132738)
                              Entity CEdge (132738) should be erased - done
                              The start and end vertices are identical for CEdge (132753)
                              Entity CEdge (132753) should be erased - done
                              The start and end vertices are identical for CEdge (132759)
                              Entity CEdge (132759) should be erased - done
                              The start and end vertices are identical for CEdge (132774)
                              Entity CEdge (132774) should be erased - done
                              The start and end vertices are identical for CEdge (132777)
                              Entity CEdge (132777) should be erased - done
                              The start and end vertices are identical for CEdge (132792)
                              Entity CEdge (132792) should be erased - done
                              The start and end vertices are identical for CEdge (132810)
                              Entity CEdge (132810) should be erased - done
                              The start and end vertices are identical for CEdge (132825)
                              Entity CEdge (132825) should be erased - done
                              The start and end vertices are identical for CEdge (132843)
                              Entity CEdge (132843) should be erased - done
                              The start and end vertices are identical for CEdge (132858)
                              Entity CEdge (132858) should be erased - done
                              The start and end vertices are identical for CEdge (132876)
                              Entity CEdge (132876) should be erased - done
                              The start and end vertices are identical for CEdge (132888)
                              Entity CEdge (132888) should be erased - done
                              The start and end vertices are identical for CEdge (132903)
                              Entity CEdge (132903) should be erased - done
                              The start and end vertices are identical for CEdge (132915)
                              Entity CEdge (132915) should be erased - done
                              The start and end vertices are identical for CEdge (132927)
                              Entity CEdge (132927) should be erased - done
                              The start and end vertices are identical for CEdge (132939)
                              Entity CEdge (132939) should be erased - done
                              The start and end vertices are identical for CEdge (132948)
                              Entity CEdge (132948) should be erased - done
                              The start and end vertices are identical for CEdge (132960)
                              Entity CEdge (132960) should be erased - done
                              The start and end vertices are identical for CEdge (132975)
                              Entity CEdge (132975) should be erased - done
                              The start and end vertices are identical for CEdge (132987)
                              Entity CEdge (132987) should be erased - done
                              The start and end vertices are identical for CEdge (133005)
                              Entity CEdge (133005) should be erased - done
                              The start and end vertices are identical for CEdge (133017)
                              Entity CEdge (133017) should be erased - done
                              The start and end vertices are identical for CEdge (133026)
                              Entity CEdge (133026) should be erased - done
                              The start and end vertices are identical for CEdge (133041)
                              Entity CEdge (133041) should be erased - done
                              The start and end vertices are identical for CEdge (133050)
                              Entity CEdge (133050) should be erased - done
                              The start and end vertices are identical for CEdge (133062)
                              Entity CEdge (133062) should be erased - done
                              The start and end vertices are identical for CEdge (133071)
                              Entity CEdge (133071) should be erased - done
                              The start and end vertices are identical for CEdge (133080)
                              Entity CEdge (133080) should be erased - done
                              The start and end vertices are identical for CEdge (133092)
                              Entity CEdge (133092) should be erased - done
                              The start and end vertices are identical for CEdge (133098)
                              Entity CEdge (133098) should be erased - done
                              The start and end vertices are identical for CEdge (133101)
                              Entity CEdge (133101) should be erased - done
                              The start and end vertices are identical for CEdge (133104)
                              Entity CEdge (133104) should be erased - done
                              The start and end vertices are identical for CEdge (133107)
                              Entity CEdge (133107) should be erased - done
                              The start and end vertices are identical for CEdge (133110)
                              Entity CEdge (133110) should be erased - done
                              The start and end vertices are identical for CEdge (133113)
                              Entity CEdge (133113) should be erased - done
                              The start and end vertices are identical for CEdge (133116)
                              Entity CEdge (133116) should be erased - done
                              The start and end vertices are identical for CEdge (133119)
                              Entity CEdge (133119) should be erased - done
                              The start and end vertices are identical for CEdge (133122)
                              Entity CEdge (133122) should be erased - done
                              The start and end vertices are identical for CEdge (133125)
                              Entity CEdge (133125) should be erased - done
                              The start and end vertices are identical for CEdge (133128)
                              Entity CEdge (133128) should be erased - done
                              The start and end vertices are identical for CEdge (133131)
                              Entity CEdge (133131) should be erased - done
                              The start and end vertices are identical for CEdge (133134)
                              Entity CEdge (133134) should be erased - done
                              The start and end vertices are identical for CEdge (133137)
                              Entity CEdge (133137) should be erased - done
                              The start and end vertices are identical for CEdge (133140)
                              Entity CEdge (133140) should be erased - done
                              The start and end vertices are identical for CEdge (133143)
                              Entity CEdge (133143) should be erased - done
                              The start and end vertices are identical for CEdge (133146)
                              Entity CEdge (133146) should be erased - done
                              The start and end vertices are identical for CEdge (133149)
                              Entity CEdge (133149) should be erased - done
                              The start and end vertices are identical for CEdge (133152)
                              Entity CEdge (133152) should be erased - done
                              The start and end vertices are identical for CEdge (133155)
                              Entity CEdge (133155) should be erased - done
                              The start and end vertices are identical for CEdge (133158)
                              Entity CEdge (133158) should be erased - done
                              The start and end vertices are identical for CEdge (133161)
                              Entity CEdge (133161) should be erased - done
                              The start and end vertices are identical for CEdge (133164)
                              Entity CEdge (133164) should be erased - done
                              The start and end vertices are identical for CEdge (133167)
                              Entity CEdge (133167) should be erased - done
                              The start and end vertices are identical for CEdge (133170)
                              Entity CEdge (133170) should be erased - done
                              The start and end vertices are identical for CEdge (133173)
                              Entity CEdge (133173) should be erased - done
                              The start and end vertices are identical for CEdge (133176)
                              Entity CEdge (133176) should be erased - done
                              The start and end vertices are identical for CEdge (133179)
                              Entity CEdge (133179) should be erased - done
                              The start and end vertices are identical for CEdge (133182)
                              Entity CEdge (133182) should be erased - done
                              The start and end vertices are identical for CEdge (133185)
                              Entity CEdge (133185) should be erased - done
                              The start and end vertices are identical for CEdge (133188)
                              Entity CEdge (133188) should be erased - done
                              The start and end vertices are identical for CEdge (133191)
                              Entity CEdge (133191) should be erased - done
                              The start and end vertices are identical for CEdge (133194)
                              Entity CEdge (133194) should be erased - done
                              The start and end vertices are identical for CEdge (133197)
                              Entity CEdge (133197) should be erased - done
                              The start and end vertices are identical for CEdge (133200)
                              Entity CEdge (133200) should be erased - done
                              The start and end vertices are identical for CEdge (133203)
                              Entity CEdge (133203) should be erased - done
                              The start and end vertices are identical for CEdge (133206)
                              Entity CEdge (133206) should be erased - done
                              The start and end vertices are identical for CEdge (133209)
                              Entity CEdge (133209) should be erased - done
                              The start and end vertices are identical for CEdge (133212)
                              Entity CEdge (133212) should be erased - done
                              The start and end vertices are identical for CEdge (133215)
                              Entity CEdge (133215) should be erased - done
                              The start and end vertices are identical for CEdge (133218)
                              Entity CEdge (133218) should be erased - done
                              The start and end vertices are identical for CEdge (133221)
                              Entity CEdge (133221) should be erased - done
                              The start and end vertices are identical for CEdge (133224)
                              Entity CEdge (133224) should be erased - done
                              The start and end vertices are identical for CEdge (133227)
                              Entity CEdge (133227) should be erased - done
                              The start and end vertices are identical for CEdge (133230)
                              Entity CEdge (133230) should be erased - done
                              The start and end vertices are identical for CEdge (133233)
                              Entity CEdge (133233) should be erased - done
                              The start and end vertices are identical for CEdge (133236)
                              Entity CEdge (133236) should be erased - done
                              The start and end vertices are identical for CEdge (133239)
                              Entity CEdge (133239) should be erased - done
                              Edges are not connected in CLoop (82820) for CFace (82819)
                              Loop 0 of CFace (82819) is an invalid outer loop
                              Entity CFace (82819) should be erased - done
                              Edges are not connected in CLoop (83154) for CFace (83153)
                              Loop 0 of CFace (83153) is an invalid outer loop
                              Entity CFace (83153) should be erased - done
                              Edges are not connected in CLoop (83234) for CFace (83233)
                              Loop 0 of CFace (83233) is an invalid outer loop
                              Entity CFace (83233) should be erased - done
                              Edges are not connected in CLoop (83328) for CFace (83327)
                              Loop 0 of CFace (83327) is an invalid outer loop
                              Entity CFace (83327) should be erased - done
                              Edges are not connected in CLoop (83742) for CFace (83741)
                              Loop 0 of CFace (83741) is an invalid outer loop
                              Entity CFace (83741) should be erased - done
                              Edges are not connected in CLoop (83883) for CFace (83882)
                              Loop 0 of CFace (83882) is an invalid outer loop
                              Entity CFace (83882) should be erased - done
                              Edges are not connected in CLoop (83968) for CFace (83967)
                              Loop 0 of CFace (83967) is an invalid outer loop
                              Entity CFace (83967) should be erased - done
                              Edges are not connected in CLoop (84017) for CFace (84016)
                              Loop 0 of CFace (84016) is an invalid outer loop
                              Entity CFace (84016) should be erased - done
                              Edges are not connected in CLoop (84128) for CFace (84127)
                              Loop 0 of CFace (84127) is an invalid outer loop
                              Entity CFace (84127) should be erased - done
                              Edges are not connected in CLoop (84318) for CFace (84317)
                              Loop 0 of CFace (84317) is an invalid outer loop
                              Entity CFace (84317) should be erased - done
                              Edges are not connected in CLoop (84403) for CFace (84402)
                              Loop 0 of CFace (84402) is an invalid outer loop
                              Entity CFace (84402) should be erased - done
                              Edges are not connected in CLoop (84754) for CFace (84753)
                              Loop 0 of CFace (84753) is an invalid outer loop
                              Entity CFace (84753) should be erased - done
                              Edges are not connected in CLoop (84765) for CFace (84764)
                              Loop 0 of CFace (84764) is an invalid outer loop
                              Entity CFace (84764) should be erased - done
                              Edges are not connected in CLoop (84906) for CFace (84905)
                              Loop 0 of CFace (84905) is an invalid outer loop
                              Entity CFace (84905) should be erased - done
                              Edges are not connected in CLoop (85020) for CFace (85019)
                              Loop 0 of CFace (85019) is an invalid outer loop
                              Entity CFace (85019) should be erased - done
                              Edges are not connected in CLoop (85190) for CFace (85189)
                              Loop 0 of CFace (85189) is an invalid outer loop
                              Entity CFace (85189) should be erased - done
                              Edges are not connected in CLoop (85353) for CFace (85352)
                              Loop 0 of CFace (85352) is an invalid outer loop
                              Entity CFace (85352) should be erased - done
                              Edges are not connected in CLoop (85418) for CFace (85417)
                              Loop 0 of CFace (85417) is an invalid outer loop
                              Entity CFace (85417) should be erased - done
                              Edges are not connected in CLoop (85760) for CFace (85759)
                              Loop 0 of CFace (85759) is an invalid outer loop
                              Entity CFace (85759) should be erased - done
                              Edges are not connected in CLoop (85921) for CFace (85920)
                              Loop 0 of CFace (85920) is an invalid outer loop
                              Entity CFace (85920) should be erased - done
                              Edges are not connected in CLoop (86035) for CFace (86034)
                              Loop 0 of CFace (86034) is an invalid outer loop
                              Entity CFace (86034) should be erased - done
                              Edges are not connected in CLoop (86084) for CFace (86083)
                              Loop 0 of CFace (86083) is an invalid outer loop
                              Entity CFace (86083) should be erased - done
                              Edges are not connected in CLoop (86195) for CFace (86194)
                              Loop 0 of CFace (86194) is an invalid outer loop
                              Entity CFace (86194) should be erased - done
                              Edges are not connected in CLoop (86385) for CFace (86384)
                              Loop 0 of CFace (86384) is an invalid outer loop
                              Entity CFace (86384) should be erased - done
                              Edges are not connected in CLoop (86774) for CFace (86773)
                              Loop 0 of CFace (86773) is an invalid outer loop
                              Entity CFace (86773) should be erased - done
                              Edges are not connected in CLoop (86785) for CFace (86784)
                              Loop 0 of CFace (86784) is an invalid outer loop
                              Entity CFace (86784) should be erased - done
                              Edges are not connected in CLoop (86926) for CFace (86925)
                              Loop 0 of CFace (86925) is an invalid outer loop
                              Entity CFace (86925) should be erased - done
                              Edges are not connected in CLoop (87078) for CFace (87077)
                              Loop 0 of CFace (87077) is an invalid outer loop
                              Entity CFace (87077) should be erased - done
                              Edges are not connected in CLoop (87363) for CFace (87362)
                              Loop 0 of CFace (87362) is an invalid outer loop
                              Entity CFace (87362) should be erased - done
                              Edges are not connected in CLoop (87428) for CFace (87427)
                              Loop 0 of CFace (87427) is an invalid outer loop
                              Entity CFace (87427) should be erased - done
                              Edges are not connected in CLoop (87855) for CFace (87854)
                              Loop 0 of CFace (87854) is an invalid outer loop
                              Entity CFace (87854) should be erased - done
                              Edges are not connected in CLoop (87931) for CFace (87930)
                              Loop 0 of CFace (87930) is an invalid outer loop
                              Entity CFace (87930) should be erased - done
                              Edges are not connected in CLoop (88083) for CFace (88082)
                              Loop 0 of CFace (88082) is an invalid outer loop
                              Entity CFace (88082) should be erased - done
                              Edges are not connected in CLoop (88170) for CFace (88169)
                              Loop 0 of CFace (88169) is an invalid outer loop
                              Entity CFace (88169) should be erased - done
                              Edges are not connected in CLoop (88433) for CFace (88432)
                              Loop 0 of CFace (88432) is an invalid outer loop
                              Entity CFace (88432) should be erased - done
                              Edges are not connected in CLoop (106963) for CFace (106962)
                              Loop 0 of CFace (106962) is an invalid outer loop
                              Entity CFace (106962) should be erased - done
                              Edges are not connected in CLoop (107164) for CFace (107163)
                              Loop 0 of CFace (107163) is an invalid outer loop
                              Entity CFace (107163) should be erased - done
                              Edges are not connected in CLoop (107457) for CFace (107456)
                              Loop 0 of CFace (107456) is an invalid outer loop
                              Entity CFace (107456) should be erased - done
                              Edges are not connected in CLoop (107571) for CFace (107570)
                              Loop 0 of CFace (107570) is an invalid outer loop
                              Entity CFace (107570) should be erased - done
                              Edges are not connected in CLoop (107723) for CFace (107722)
                              Loop 0 of CFace (107722) is an invalid outer loop
                              Entity CFace (107722) should be erased - done
                              Edges are not connected in CLoop (107837) for CFace (107836)
                              Loop 0 of CFace (107836) is an invalid outer loop
                              Entity CFace (107836) should be erased - done
                              Edges are not connected in CLoop (107886) for CFace (107885)
                              Loop 0 of CFace (107885) is an invalid outer loop
                              Entity CFace (107885) should be erased - done
                              Edges are not connected in CLoop (108170) for CFace (108169)
                              Loop 0 of CFace (108169) is an invalid outer loop
                              Entity CFace (108169) should be erased - done
                              Edges are not connected in CLoop (108512) for CFace (108511)
                              Loop 0 of CFace (108511) is an invalid outer loop
                              Entity CFace (108511) should be erased - done
                              Edges are not connected in CLoop (108626) for CFace (108625)
                              Loop 0 of CFace (108625) is an invalid outer loop
                              Entity CFace (108625) should be erased - done
                              Edges are not connected in CLoop (108637) for CFace (108636)
                              Loop 0 of CFace (108636) is an invalid outer loop
                              Entity CFace (108636) should be erased - done
                              Edges are not connected in CLoop (108778) for CFace (108777)
                              Loop 0 of CFace (108777) is an invalid outer loop
                              Entity CFace (108777) should be erased - done
                              Edges are not connected in CLoop (108930) for CFace (108929)
                              Loop 0 of CFace (108929) is an invalid outer loop
                              Entity CFace (108929) should be erased - done
                              Edges are not connected in CLoop (109272) for CFace (109271)
                              Loop 0 of CFace (109271) is an invalid outer loop
                              Entity CFace (109271) should be erased - done
                              Edges are not connected in CLoop (109359) for CFace (109358)
                              Loop 0 of CFace (109358) is an invalid outer loop
                              Entity CFace (109358) should be erased - done
                              Edges are not connected in CLoop (109614) for CFace (109613)
                              Loop 0 of CFace (109613) is an invalid outer loop
                              Entity CFace (109613) should be erased - done
                              Edges are not connected in CLoop (109766) for CFace (109765)
                              Loop 0 of CFace (109765) is an invalid outer loop
                              Entity CFace (109765) should be erased - done
                              Edges are not connected in CLoop (109880) for CFace (109879)
                              Loop 0 of CFace (109879) is an invalid outer loop
                              Entity CFace (109879) should be erased - done
                              Edges are not connected in CLoop (110023) for CFace (110022)
                              Loop 0 of CFace (110022) is an invalid outer loop
                              Entity CFace (110022) should be erased - done
                              Edges are not connected in CLoop (110034) for CFace (110033)
                              Loop 0 of CFace (110033) is an invalid outer loop
                              Entity CFace (110033) should be erased - done
                              Edges are not connected in CLoop (110356) for CFace (110355)
                              Loop 0 of CFace (110355) is an invalid outer loop
                              Entity CFace (110355) should be erased - done
                              Edges are not connected in CLoop (110698) for CFace (110697)
                              Loop 0 of CFace (110697) is an invalid outer loop
                              Entity CFace (110697) should be erased - done
                              Edges are not connected in CLoop (110812) for CFace (110811)
                              Loop 0 of CFace (110811) is an invalid outer loop
                              Entity CFace (110811) should be erased - done
                              Edges are not connected in CLoop (110823) for CFace (110822)
                              Loop 0 of CFace (110822) is an invalid outer loop
                              Entity CFace (110822) should be erased - done
                              Edges are not connected in CLoop (110964) for CFace (110963)
                              Loop 0 of CFace (110963) is an invalid outer loop
                              Entity CFace (110963) should be erased - done
                              Edges are not connected in CLoop (111391) for CFace (111390)
                              Loop 0 of CFace (111390) is an invalid outer loop
                              Entity CFace (111390) should be erased - done
                              Edges are not connected in CLoop (88878) for CFace (88877)
                              Loop 0 of CFace (88877) is an invalid outer loop
                              Entity CFace (88877) should be erased - done
                              Edges are not connected in CLoop (88981) for CFace (88980)
                              Loop 0 of CFace (88980) is an invalid outer loop
                              Entity CFace (88980) should be erased - done
                              Edges are not connected in CLoop (89064) for CFace (89063)
                              Loop 0 of CFace (89063) is an invalid outer loop
                              Entity CFace (89063) should be erased - done
                              Edges are not connected in CLoop (89216) for CFace (89215)
                              Loop 0 of CFace (89215) is an invalid outer loop
                              Entity CFace (89215) should be erased - done
                              Edges are not connected in CLoop (89377) for CFace (89376)
                              Loop 0 of CFace (89376) is an invalid outer loop
                              Entity CFace (89376) should be erased - done
                              Edges are not connected in CLoop (89464) for CFace (89463)
                              Loop 0 of CFace (89463) is an invalid outer loop
                              Entity CFace (89463) should be erased - done
                              Edges are not connected in CLoop (89529) for CFace (89528)
                              Loop 0 of CFace (89528) is an invalid outer loop
                              Entity CFace (89528) should be erased - done
                              Edges are not connected in CLoop (89985) for CFace (89984)
                              Loop 0 of CFace (89984) is an invalid outer loop
                              Entity CFace (89984) should be erased - done
                              Edges are not connected in CLoop (90137) for CFace (90136)
                              Loop 0 of CFace (90136) is an invalid outer loop
                              Entity CFace (90136) should be erased - done
                              Edges are not connected in CLoop (90186) for CFace (90185)
                              Loop 0 of CFace (90185) is an invalid outer loop
                              Entity CFace (90185) should be erased - done
                              Edges are not connected in CLoop (90486) for CFace (90485)
                              Loop 0 of CFace (90485) is an invalid outer loop
                              Entity CFace (90485) should be erased - done
                              Edges are not connected in CLoop (90719) for CFace (90718)
                              Loop 0 of CFace (90718) is an invalid outer loop
                              Entity CFace (90718) should be erased - done
                              Edges are not connected in CLoop (90920) for CFace (90919)
                              Loop 0 of CFace (90919) is an invalid outer loop
                              Entity CFace (90919) should be erased - done
                              Edges are not connected in CLoop (91061) for CFace (91060)
                              Loop 0 of CFace (91060) is an invalid outer loop
                              Entity CFace (91060) should be erased - done
                              Edges are not connected in CLoop (91104) for CFace (91103)
                              Loop 0 of CFace (91103) is an invalid outer loop
                              Entity CFace (91103) should be erased - done
                              Edges are not connected in CLoop (91180) for CFace (91179)
                              Loop 0 of CFace (91179) is an invalid outer loop
                              Entity CFace (91179) should be erased - done
                              Edges are not connected in CLoop (91413) for CFace (91412)
                              Loop 0 of CFace (91412) is an invalid outer loop
                              Entity CFace (91412) should be erased - done
                              Edges are not connected in CLoop (91538) for CFace (91537)
                              Loop 0 of CFace (91537) is an invalid outer loop
                              Entity CFace (91537) should be erased - done
                              Edges are not connected in CLoop (91603) for CFace (91602)
                              Loop 0 of CFace (91602) is an invalid outer loop
                              Entity CFace (91602) should be erased - done
                              Edges are not connected in CLoop (91800) for CFace (91799)
                              Loop 0 of CFace (91799) is an invalid outer loop
                              Entity CFace (91799) should be erased - done
                              Edges are not connected in CLoop (92104) for CFace (92103)
                              Loop 0 of CFace (92103) is an invalid outer loop
                              Entity CFace (92103) should be erased - done
                              Edges are not connected in CLoop (92261) for CFace (92260)
                              Loop 0 of CFace (92260) is an invalid outer loop
                              Entity CFace (92260) should be erased - done
                              Edges are not connected in CLoop (92310) for CFace (92309)
                              Loop 0 of CFace (92309) is an invalid outer loop
                              Entity CFace (92309) should be erased - done
                              Edges are not connected in CLoop (92603) for CFace (92602)
                              Loop 0 of CFace (92602) is an invalid outer loop
                              Entity CFace (92602) should be erased - done
                              Edges are not connected in CLoop (93003) for CFace (93002)
                              Loop 0 of CFace (93002) is an invalid outer loop
                              Entity CFace (93002) should be erased - done
                              Edges are not connected in CLoop (93182) for CFace (93181)
                              Loop 0 of CFace (93181) is an invalid outer loop
                              Entity CFace (93181) should be erased - done
                              Edges are not connected in CLoop (93258) for CFace (93257)
                              Loop 0 of CFace (93257) is an invalid outer loop
                              Entity CFace (93257) should be erased - done
                              Edges are not connected in CLoop (93535) for CFace (93534)
                              Loop 0 of CFace (93534) is an invalid outer loop
                              Entity CFace (93534) should be erased - done
                              Edges are not connected in CLoop (93600) for CFace (93599)
                              Loop 0 of CFace (93599) is an invalid outer loop
                              Entity CFace (93599) should be erased - done
                              Edges are not connected in CLoop (94065) for CFace (94064)
                              Loop 0 of CFace (94064) is an invalid outer loop
                              Entity CFace (94064) should be erased - done
                              Edges are not connected in CLoop (94141) for CFace (94140)
                              Loop 0 of CFace (94140) is an invalid outer loop
                              Entity CFace (94140) should be erased - done
                              Edges are not connected in CLoop (94152) for CFace (94151)
                              Loop 0 of CFace (94151) is an invalid outer loop
                              Entity CFace (94151) should be erased - done
                              Edges are not connected in CLoop (94521) for CFace (94520)
                              Loop 0 of CFace (94520) is an invalid outer loop
                              Entity CFace (94520) should be erased - done
                              Edges are not connected in CLoop (94836) for CFace (94835)
                              Loop 0 of CFace (94835) is an invalid outer loop
                              Entity CFace (94835) should be erased - done
                              Edges are not connected in CLoop (94977) for CFace (94976)
                              Loop 0 of CFace (94976) is an invalid outer loop
                              Entity CFace (94976) should be erased - done
                              Edges are not connected in CLoop (95024) for CFace (95023)
                              Loop 0 of CFace (95023) is an invalid outer loop
                              Entity CFace (95023) should be erased - done
                              Edges are not connected in CLoop (95138) for CFace (95137)
                              Loop 0 of CFace (95137) is an invalid outer loop
                              Entity CFace (95137) should be erased - done
                              Edges are not connected in CLoop (95453) for CFace (95452)
                              Loop 0 of CFace (95452) is an invalid outer loop
                              Entity CFace (95452) should be erased - done
                              Edges are not connected in CLoop (95518) for CFace (95517)
                              Loop 0 of CFace (95517) is an invalid outer loop
                              Entity CFace (95517) should be erased - done
                              Edges are not connected in CLoop (95936) for CFace (95935)
                              Loop 0 of CFace (95935) is an invalid outer loop
                              Entity CFace (95935) should be erased - done
                              Edges are not connected in CLoop (96003) for CFace (96002)
                              Loop 0 of CFace (96002) is an invalid outer loop
                              Entity CFace (96002) should be erased - done
                              Edges are not connected in CLoop (96052) for CFace (96051)
                              Loop 0 of CFace (96051) is an invalid outer loop
                              Entity CFace (96051) should be erased - done
                              Edges are not connected in CLoop (96383) for CFace (96382)
                              Loop 0 of CFace (96382) is an invalid outer loop
                              Entity CFace (96382) should be erased - done
                              Edges are not connected in CLoop (96535) for CFace (96534)
                              Loop 0 of CFace (96534) is an invalid outer loop
                              Entity CFace (96534) should be erased - done
                              Edges are not connected in CLoop (96736) for CFace (96735)
                              Loop 0 of CFace (96735) is an invalid outer loop
                              Entity CFace (96735) should be erased - done
                              Edges are not connected in CLoop (96877) for CFace (96876)
                              Loop 0 of CFace (96876) is an invalid outer loop
                              Entity CFace (96876) should be erased - done
                              Edges are not connected in CLoop (96962) for CFace (96961)
                              Loop 0 of CFace (96961) is an invalid outer loop
                              Entity CFace (96961) should be erased - done
                              Edges are not connected in CLoop (97351) for CFace (97350)
                              Loop 0 of CFace (97350) is an invalid outer loop
                              Entity CFace (97350) should be erased - done
                              Edges are not connected in CLoop (97362) for CFace (97361)
                              Loop 0 of CFace (97361) is an invalid outer loop
                              Entity CFace (97361) should be erased - done
                              Edges are not connected in CLoop (97503) for CFace (97502)
                              Loop 0 of CFace (97502) is an invalid outer loop
                              Entity CFace (97502) should be erased - done
                              Edges are not connected in CLoop (97769) for CFace (97768)
                              Loop 0 of CFace (97768) is an invalid outer loop
                              Entity CFace (97768) should be erased - done
                              Edges are not connected in CLoop (100248) for CFace (100247)
                              Loop 0 of CFace (100247) is an invalid outer loop
                              Entity CFace (100247) should be erased - done
                              Edges are not connected in CLoop (100400) for CFace (100399)
                              Loop 0 of CFace (100399) is an invalid outer loop
                              Entity CFace (100399) should be erased - done
                              Edges are not connected in CLoop (100601) for CFace (100600)
                              Loop 0 of CFace (100600) is an invalid outer loop
                              Entity CFace (100600) should be erased - done
                              Edges are not connected in CLoop (100818) for CFace (100817)
                              Loop 0 of CFace (100817) is an invalid outer loop
                              Entity CFace (100817) should be erased - done
                              Edges are not connected in CLoop (100970) for CFace (100969)
                              Loop 0 of CFace (100969) is an invalid outer loop
                              Entity CFace (100969) should be erased - done
                              Edges are not connected in CLoop (101151) for CFace (101150)
                              Loop 0 of CFace (101150) is an invalid outer loop
                              Entity CFace (101150) should be erased - done
                              Edges are not connected in CLoop (101265) for CFace (101264)
                              Loop 0 of CFace (101264) is an invalid outer loop
                              Entity CFace (101264) should be erased - done
                              Edges are not connected in CLoop (101352) for CFace (101351)
                              Loop 0 of CFace (101351) is an invalid outer loop
                              Entity CFace (101351) should be erased - done
                              Edges are not connected in CLoop (101455) for CFace (101454)
                              Loop 0 of CFace (101454) is an invalid outer loop
                              Entity CFace (101454) should be erased - done
                              Edges are not connected in CLoop (101873) for CFace (101872)
                              Loop 0 of CFace (101872) is an invalid outer loop
                              Entity CFace (101872) should be erased - done
                              Edges are not connected in CLoop (101987) for CFace (101986)
                              Loop 0 of CFace (101986) is an invalid outer loop
                              Entity CFace (101986) should be erased - done
                              Edges are not connected in CLoop (101998) for CFace (101997)
                              Loop 0 of CFace (101997) is an invalid outer loop
                              Entity CFace (101997) should be erased - done
                              Edges are not connected in CLoop (102262) for CFace (102261)
                              Loop 0 of CFace (102261) is an invalid outer loop
                              Entity CFace (102261) should be erased - done
                              Edges are not connected in CLoop (97883) for CFace (97882)
                              Loop 0 of CFace (97882) is an invalid outer loop
                              Entity CFace (97882) should be erased - done
                              Edges are not connected in CLoop (97932) for CFace (97931)
                              Loop 0 of CFace (97931) is an invalid outer loop
                              Entity CFace (97931) should be erased - done
                              Edges are not connected in CLoop (98263) for CFace (98262)
                              Loop 0 of CFace (98262) is an invalid outer loop
                              Entity CFace (98262) should be erased - done
                              Edges are not connected in CLoop (98415) for CFace (98414)
                              Loop 0 of CFace (98414) is an invalid outer loop
                              Entity CFace (98414) should be erased - done
                              Edges are not connected in CLoop (98645) for CFace (98644)
                              Loop 0 of CFace (98644) is an invalid outer loop
                              Entity CFace (98644) should be erased - done
                              Edges are not connected in CLoop (98748) for CFace (98747)
                              Loop 0 of CFace (98747) is an invalid outer loop
                              Entity CFace (98747) should be erased - done
                              Edges are not connected in CLoop (98938) for CFace (98937)
                              Loop 0 of CFace (98937) is an invalid outer loop
                              Entity CFace (98937) should be erased - done
                              Edges are not connected in CLoop (99166) for CFace (99165)
                              Loop 0 of CFace (99165) is an invalid outer loop
                              Entity CFace (99165) should be erased - done
                              Edges are not connected in CLoop (99253) for CFace (99252)
                              Loop 0 of CFace (99252) is an invalid outer loop
                              Entity CFace (99252) should be erased - done
                              Edges are not connected in CLoop (99365) for CFace (99364)
                              Loop 0 of CFace (99364) is an invalid outer loop
                              Entity CFace (99364) should be erased - done
                              Edges are not connected in CLoop (99441) for CFace (99440)
                              Loop 0 of CFace (99440) is an invalid outer loop
                              Entity CFace (99440) should be erased - done
                              Edges are not connected in CLoop (99707) for CFace (99706)
                              Loop 0 of CFace (99706) is an invalid outer loop
                              Entity CFace (99706) should be erased - done
                              Edges are not connected in CLoop (99935) for CFace (99934)
                              Loop 0 of CFace (99934) is an invalid outer loop
                              Entity CFace (99934) should be erased - done
                              Edges are not connected in CLoop (99946) for CFace (99945)
                              Loop 0 of CFace (99945) is an invalid outer loop
                              Entity CFace (99945) should be erased - done
                              Edges are not connected in CLoop (102376) for CFace (102375)
                              Loop 0 of CFace (102375) is an invalid outer loop
                              Entity CFace (102375) should be erased - done
                              Edges are not connected in CLoop (102566) for CFace (102565)
                              Loop 0 of CFace (102565) is an invalid outer loop
                              Entity CFace (102565) should be erased - done
                              Edges are not connected in CLoop (102805) for CFace (102804)
                              Loop 0 of CFace (102804) is an invalid outer loop
                              Entity CFace (102804) should be erased - done
                              Edges are not connected in CLoop (102984) for CFace (102983)
                              Loop 0 of CFace (102983) is an invalid outer loop
                              Entity CFace (102983) should be erased - done
                              Edges are not connected in CLoop (103136) for CFace (103135)
                              Loop 0 of CFace (103135) is an invalid outer loop
                              Entity CFace (103135) should be erased - done
                              Edges are not connected in CLoop (103326) for CFace (103325)
                              Loop 0 of CFace (103325) is an invalid outer loop
                              Entity CFace (103325) should be erased - done
                              Edges are not connected in CLoop (103440) for CFace (103439)
                              Loop 0 of CFace (103439) is an invalid outer loop
                              Entity CFace (103439) should be erased - done
                              Edges are not connected in CLoop (103527) for CFace (103526)
                              Loop 0 of CFace (103526) is an invalid outer loop
                              Entity CFace (103526) should be erased - done
                              Edges are not connected in CLoop (103630) for CFace (103629)
                              Loop 0 of CFace (103629) is an invalid outer loop
                              Entity CFace (103629) should be erased - done
                              Edges are not connected in CLoop (104095) for CFace (104094)
                              Loop 0 of CFace (104094) is an invalid outer loop
                              Entity CFace (104094) should be erased - done
                              Edges are not connected in CLoop (104209) for CFace (104208)
                              Loop 0 of CFace (104208) is an invalid outer loop
                              Entity CFace (104208) should be erased - done
                              Edges are not connected in CLoop (104220) for CFace (104219)
                              Loop 0 of CFace (104219) is an invalid outer loop
                              Entity CFace (104219) should be erased - done
                              Edges are not connected in CLoop (104446) for CFace (104445)
                              Loop 0 of CFace (104445) is an invalid outer loop
                              Entity CFace (104445) should be erased - done
                              Edges are not connected in CLoop (104560) for CFace (104559)
                              Loop 0 of CFace (104559) is an invalid outer loop
                              Entity CFace (104559) should be erased - done
                              Edges are not connected in CLoop (104712) for CFace (104711)
                              Loop 0 of CFace (104711) is an invalid outer loop
                              Entity CFace (104711) should be erased - done
                              Edges are not connected in CLoop (104989) for CFace (104988)
                              Loop 0 of CFace (104988) is an invalid outer loop
                              Entity CFace (104988) should be erased - done
                              Edges are not connected in CLoop (105253) for CFace (105252)
                              Loop 0 of CFace (105252) is an invalid outer loop
                              Entity CFace (105252) should be erased - done
                              Edges are not connected in CLoop (105367) for CFace (105366)
                              Loop 0 of CFace (105366) is an invalid outer loop
                              Entity CFace (105366) should be erased - done
                              Edges are not connected in CLoop (105548) for CFace (105547)
                              Loop 0 of CFace (105547) is an invalid outer loop
                              Entity CFace (105547) should be erased - done
                              Edges are not connected in CLoop (105662) for CFace (105661)
                              Loop 0 of CFace (105661) is an invalid outer loop
                              Entity CFace (105661) should be erased - done
                              Edges are not connected in CLoop (105711) for CFace (105710)
                              Loop 0 of CFace (105710) is an invalid outer loop
                              Entity CFace (105710) should be erased - done
                              Edges are not connected in CLoop (105852) for CFace (105851)
                              Loop 0 of CFace (105851) is an invalid outer loop
                              Entity CFace (105851) should be erased - done
                              Edges are not connected in CLoop (106308) for CFace (106307)
                              Loop 0 of CFace (106307) is an invalid outer loop
                              Entity CFace (106307) should be erased - done
                              Edges are not connected in CLoop (106460) for CFace (106459)
                              Loop 0 of CFace (106459) is an invalid outer loop
                              Entity CFace (106459) should be erased - done
                              Edges are not connected in CLoop (106471) for CFace (106470)
                              Loop 0 of CFace (106470) is an invalid outer loop
                              Entity CFace (106470) should be erased - done
                              Edges are not connected in CLoop (106659) for CFace (106658)
                              Loop 0 of CFace (106658) is an invalid outer loop
                              Entity CFace (106658) should be erased - done
                              Edges are not connected in CLoop (106773) for CFace (106772)
                              Loop 0 of CFace (106772) is an invalid outer loop
                              Entity CFace (106772) should be erased - done
                              Edges are not connected in CLoop (111516) for CFace (111515)
                              Loop 0 of CFace (111515) is an invalid outer loop
                              Entity CFace (111515) should be erased - done
                              Edges are not connected in CLoop (111771) for CFace (111770)
                              Loop 0 of CFace (111770) is an invalid outer loop
                              Entity CFace (111770) should be erased - done
                              Edges are not connected in CLoop (111885) for CFace (111884)
                              Loop 0 of CFace (111884) is an invalid outer loop
                              Entity CFace (111884) should be erased - done
                              Edges are not connected in CLoop (111990) for CFace (111989)
                              Loop 0 of CFace (111989) is an invalid outer loop
                              Entity CFace (111989) should be erased - done
                              Edges are not connected in CLoop (112115) for CFace (112114)
                              Loop 0 of CFace (112114) is an invalid outer loop
                              Entity CFace (112114) should be erased - done
                              Edges are not connected in CLoop (112408) for CFace (112407)
                              Loop 0 of CFace (112407) is an invalid outer loop
                              Entity CFace (112407) should be erased - done
                              Edges are not connected in CLoop (112750) for CFace (112749)
                              Loop 0 of CFace (112749) is an invalid outer loop
                              Entity CFace (112749) should be erased - done
                              Edges are not connected in CLoop (112902) for CFace (112901)
                              Loop 0 of CFace (112901) is an invalid outer loop
                              Entity CFace (112901) should be erased - done
                              Edges are not connected in CLoop (112913) for CFace (112912)
                              Loop 0 of CFace (112912) is an invalid outer loop
                              Entity CFace (112912) should be erased - done
                              Edges are not connected in CLoop (113092) for CFace (113091)
                              Loop 0 of CFace (113091) is an invalid outer loop
                              Entity CFace (113091) should be erased - done
                              Edges are not connected in CLoop (113434) for CFace (113433)
                              Loop 0 of CFace (113433) is an invalid outer loop
                              Entity CFace (113433) should be erased - done
                              Edges are not connected in CLoop (113559) for CFace (113558)
                              Loop 0 of CFace (113558) is an invalid outer loop
                              Entity CFace (113558) should be erased - done
                              Edges are not connected in CLoop (113814) for CFace (113813)
                              Loop 0 of CFace (113813) is an invalid outer loop
                              Entity CFace (113813) should be erased - done
                              Edges are not connected in CLoop (113928) for CFace (113927)
                              Loop 0 of CFace (113927) is an invalid outer loop
                              Entity CFace (113927) should be erased - done
                              Edges are not connected in CLoop (114080) for CFace (114079)
                              Loop 0 of CFace (114079) is an invalid outer loop
                              Entity CFace (114079) should be erased - done
                              Edges are not connected in CLoop (114281) for CFace (114280)
                              Loop 0 of CFace (114280) is an invalid outer loop
                              Entity CFace (114280) should be erased - done
                              Edges are not connected in CLoop (114460) for CFace (114459)
                              Loop 0 of CFace (114459) is an invalid outer loop
                              Entity CFace (114459) should be erased - done
                              Edges are not connected in CLoop (114869) for CFace (114868)
                              Loop 0 of CFace (114868) is an invalid outer loop
                              Entity CFace (114868) should be erased - done
                              Edges are not connected in CLoop (114945) for CFace (114944)
                              Loop 0 of CFace (114944) is an invalid outer loop
                              Entity CFace (114944) should be erased - done
                              Edges are not connected in CLoop (114956) for CFace (114955)
                              Loop 0 of CFace (114955) is an invalid outer loop
                              Entity CFace (114955) should be erased - done
                              Edges are not connected in CLoop (115135) for CFace (115134)
                              Loop 0 of CFace (115134) is an invalid outer loop
                              Entity CFace (115134) should be erased - done
                              Edges are not connected in CLoop (115439) for CFace (115438)
                              Loop 0 of CFace (115438) is an invalid outer loop
                              Entity CFace (115438) should be erased - done
                              Edges are not connected in CLoop (115526) for CFace (115525)
                              Loop 0 of CFace (115525) is an invalid outer loop
                              Entity CFace (115525) should be erased - done
                              Edges are not connected in CLoop (115772) for CFace (115771)
                              Loop 0 of CFace (115771) is an invalid outer loop
                              Entity CFace (115771) should be erased - done
                              Edges are not connected in CLoop (115886) for CFace (115885)
                              Loop 0 of CFace (115885) is an invalid outer loop
                              Entity CFace (115885) should be erased - done
                              Edges are not connected in CLoop (116085) for CFace (116084)
                              Loop 0 of CFace (116084) is an invalid outer loop
                              Entity CFace (116084) should be erased - done
                              Edges are not connected in CLoop (116248) for CFace (116247)
                              Loop 0 of CFace (116247) is an invalid outer loop
                              Entity CFace (116247) should be erased - done
                              Edges are not connected in CLoop (116427) for CFace (116426)
                              Loop 0 of CFace (116426) is an invalid outer loop
                              Entity CFace (116426) should be erased - done
                              Edges are not connected in CLoop (116740) for CFace (116739)
                              Loop 0 of CFace (116739) is an invalid outer loop
                              Entity CFace (116739) should be erased - done
                              Edges are not connected in CLoop (116845) for CFace (116844)
                              Loop 0 of CFace (116844) is an invalid outer loop
                              Entity CFace (116844) should be erased - done
                              Edges are not connected in CLoop (116856) for CFace (116855)
                              Loop 0 of CFace (116855) is an invalid outer loop
                              Entity CFace (116855) should be erased - done
                              Edges are not connected in CLoop (117035) for CFace (117034)
                              Loop 0 of CFace (117034) is an invalid outer loop
                              Entity CFace (117034) should be erased - done
                              Edges are not connected in CLoop (117339) for CFace (117338)
                              Loop 0 of CFace (117338) is an invalid outer loop
                              Entity CFace (117338) should be erased - done
                              Edges are not connected in CLoop (117464) for CFace (117463)
                              Loop 0 of CFace (117463) is an invalid outer loop
                              Entity CFace (117463) should be erased - done
                              Edges are not connected in CLoop (117719) for CFace (117718)
                              Loop 0 of CFace (117718) is an invalid outer loop
                              Entity CFace (117718) should be erased - done
                              Edges are not connected in CLoop (117956) for CFace (117955)
                              Loop 0 of CFace (117955) is an invalid outer loop
                              Entity CFace (117955) should be erased - done
                              Edges are not connected in CLoop (118110) for CFace (118109)
                              Loop 0 of CFace (118109) is an invalid outer loop
                              Entity CFace (118109) should be erased - done
                              Edges are not connected in CLoop (118327) for CFace (118326)
                              Loop 0 of CFace (118326) is an invalid outer loop
                              Entity CFace (118326) should be erased - done
                              Edges are not connected in CLoop (118631) for CFace (118630)
                              Loop 0 of CFace (118630) is an invalid outer loop
                              Entity CFace (118630) should be erased - done
                              Edges are not connected in CLoop (118718) for CFace (118717)
                              Loop 0 of CFace (118717) is an invalid outer loop
                              Entity CFace (118717) should be erased - done
                              Edges are not connected in CLoop (118897) for CFace (118896)
                              Loop 0 of CFace (118896) is an invalid outer loop
                              Entity CFace (118896) should be erased - done
                              Edges are not connected in CLoop (119201) for CFace (119200)
                              Loop 0 of CFace (119200) is an invalid outer loop
                              Entity CFace (119200) should be erased - done
                              Edges are not connected in CLoop (119326) for CFace (119325)
                              Loop 0 of CFace (119325) is an invalid outer loop
                              Entity CFace (119325) should be erased - done
                              Edges are not connected in CLoop (119543) for CFace (119542)
                              Loop 0 of CFace (119542) is an invalid outer loop
                              Entity CFace (119542) should be erased - done
                              Edges are not connected in CLoop (119800) for CFace (119799)
                              Loop 0 of CFace (119799) is an invalid outer loop
                              Entity CFace (119799) should be erased - done
                              Edges are not connected in CLoop (120104) for CFace (120103)
                              Loop 0 of CFace (120103) is an invalid outer loop
                              Entity CFace (120103) should be erased - done
                              Edges are not connected in CLoop (120446) for CFace (120445)
                              Loop 0 of CFace (120445) is an invalid outer loop
                              Entity CFace (120445) should be erased - done
                              Edges are not connected in CLoop (120636) for CFace (120635)
                              Loop 0 of CFace (120635) is an invalid outer loop
                              Entity CFace (120635) should be erased - done
                              Edges are not connected in CLoop (120817) for CFace (120816)
                              Loop 0 of CFace (120816) is an invalid outer loop
                              Entity CFace (120816) should be erased - done
                              Edges are not connected in CLoop (121007) for CFace (121006)
                              Loop 0 of CFace (121006) is an invalid outer loop
                              Entity CFace (121006) should be erased - done
                              Edges are not connected in CLoop (121311) for CFace (121310)
                              Loop 0 of CFace (121310) is an invalid outer loop
                              Entity CFace (121310) should be erased - done
                              Edges are not connected in CLoop (121501) for CFace (121500)
                              Loop 0 of CFace (121500) is an invalid outer loop
                              Entity CFace (121500) should be erased - done
                              Edges are not connected in CLoop (121843) for CFace (121842)
                              Loop 0 of CFace (121842) is an invalid outer loop
                              Entity CFace (121842) should be erased - done
                              Edges are not connected in CLoop (122261) for CFace (122260)
                              Loop 0 of CFace (122260) is an invalid outer loop
                              Entity CFace (122260) should be erased - done
                              Edges are not connected in CLoop (122299) for CFace (122298)
                              Loop 0 of CFace (122298) is an invalid outer loop
                              Entity CFace (122298) should be erased - done
                              Edges are not connected in CLoop (122413) for CFace (122412)
                              Loop 0 of CFace (122412) is an invalid outer loop
                              Entity CFace (122412) should be erased - done
                              Edges are not connected in CLoop (122755) for CFace (122754)
                              Loop 0 of CFace (122754) is an invalid outer loop
                              Entity CFace (122754) should be erased - done
                              Edges are not connected in CLoop (123164) for CFace (123163)
                              Loop 0 of CFace (123163) is an invalid outer loop
                              Entity CFace (123163) should be erased - done
                              Edges are not connected in CLoop (123202) for CFace (123201)
                              Loop 0 of CFace (123201) is an invalid outer loop
                              Entity CFace (123201) should be erased - done
                              Edges are not connected in CLoop (123316) for CFace (123315)
                              Loop 0 of CFace (123315) is an invalid outer loop
                              Entity CFace (123315) should be erased - done
                              Edges are not connected in CLoop (123365) for CFace (123364)
                              Loop 0 of CFace (123364) is an invalid outer loop
                              Entity CFace (123364) should be erased - done
                              Edges are not connected in CLoop (123696) for CFace (123695)
                              Loop 0 of CFace (123695) is an invalid outer loop
                              Entity CFace (123695) should be erased - done
                              Edges are not connected in CLoop (124038) for CFace (124037)
                              Loop 0 of CFace (124037) is an invalid outer loop
                              Entity CFace (124037) should be erased - done
                              Edges are not connected in CLoop (124076) for CFace (124075)
                              Loop 0 of CFace (124075) is an invalid outer loop
                              Entity CFace (124075) should be erased - done
                              Edges are not connected in CLoop (124228) for CFace (124227)
                              Loop 0 of CFace (124227) is an invalid outer loop
                              Entity CFace (124227) should be erased - done
                              Edges are not connected in CLoop (124570) for CFace (124569)
                              Loop 0 of CFace (124569) is an invalid outer loop
                              Entity CFace (124569) should be erased - done
                              Edges are not connected in CLoop (124657) for CFace (124656)
                              Loop 0 of CFace (124656) is an invalid outer loop
                              Entity CFace (124656) should be erased - done
                              Edges are not connected in CLoop (124988) for CFace (124987)
                              Loop 0 of CFace (124987) is an invalid outer loop
                              Entity CFace (124987) should be erased - done
                              Edges are not connected in CLoop (125026) for CFace (125025)
                              Loop 0 of CFace (125025) is an invalid outer loop
                              Entity CFace (125025) should be erased - done
                              Edges are not connected in CLoop (125140) for CFace (125139)
                              Loop 0 of CFace (125139) is an invalid outer loop
                              Entity CFace (125139) should be erased - done
                              Edges are not connected in CLoop (125265) for CFace (125264)
                              Loop 0 of CFace (125264) is an invalid outer loop
                              Entity CFace (125264) should be erased - done
                              Edges are not connected in CLoop (125558) for CFace (125557)
                              Loop 0 of CFace (125557) is an invalid outer loop
                              Entity CFace (125557) should be erased - done
                              Edges are not connected in CLoop (125938) for CFace (125937)
                              Loop 0 of CFace (125937) is an invalid outer loop
                              Entity CFace (125937) should be erased - done
                              Edges are not connected in CLoop (125949) for CFace (125948)
                              Loop 0 of CFace (125948) is an invalid outer loop
                              Entity CFace (125948) should be erased - done
                              Edges are not connected in CLoop (126014) for CFace (126013)
                              Loop 0 of CFace (126013) is an invalid outer loop
                              Entity CFace (126013) should be erased - done
                              Edges are not connected in CLoop (126059) for CFace (126058)
                              Loop 0 of CFace (126058) is an invalid outer loop
                              Entity CFace (126058) should be erased - done
                              Edges are not connected in CLoop (126173) for CFace (126172)
                              Loop 0 of CFace (126172) is an invalid outer loop
                              Entity CFace (126172) should be erased - done
                              Edges are not connected in CLoop (126553) for CFace (126552)
                              Loop 0 of CFace (126552) is an invalid outer loop
                              Entity CFace (126552) should be erased - done
                              Edges are not connected in CLoop (126602) for CFace (126601)
                              Loop 0 of CFace (126601) is an invalid outer loop
                              Entity CFace (126601) should be erased - done
                              Edges are not connected in CLoop (126895) for CFace (126894)
                              Loop 0 of CFace (126894) is an invalid outer loop
                              Entity CFace (126894) should be erased - done
                              Edges are not connected in CLoop (126933) for CFace (126932)
                              Loop 0 of CFace (126932) is an invalid outer loop
                              Entity CFace (126932) should be erased - done
                              Edges are not connected in CLoop (127014) for CFace (127013)
                              Loop 0 of CFace (127013) is an invalid outer loop
                              Entity CFace (127013) should be erased - done
                              Edges are not connected in CLoop (127128) for CFace (127127)
                              Loop 0 of CFace (127127) is an invalid outer loop
                              Entity CFace (127127) should be erased - done
                              Edges are not connected in CLoop (127215) for CFace (127214)
                              Loop 0 of CFace (127214) is an invalid outer loop
                              Entity CFace (127214) should be erased - done
                              Edges are not connected in CLoop (127575) for CFace (127574)
                              Loop 0 of CFace (127574) is an invalid outer loop
                              Entity CFace (127574) should be erased - done
                              Edges are not connected in CLoop (127908) for CFace (127907)
                              Loop 0 of CFace (127907) is an invalid outer loop
                              Entity CFace (127907) should be erased - done
                              Edges are not connected in CLoop (127919) for CFace (127918)
                              Loop 0 of CFace (127918) is an invalid outer loop
                              Entity CFace (127918) should be erased - done
                              Edges are not connected in CLoop (127984) for CFace (127983)
                              Loop 0 of CFace (127983) is an invalid outer loop
                              Entity CFace (127983) should be erased - done
                              Edges are not connected in CLoop (128029) for CFace (128028)
                              Loop 0 of CFace (128028) is an invalid outer loop
                              Entity CFace (128028) should be erased - done
                              Edges are not connected in CLoop (128143) for CFace (128142)
                              Loop 0 of CFace (128142) is an invalid outer loop
                              Entity CFace (128142) should be erased - done
                              Edges are not connected in CLoop (128476) for CFace (128475)
                              Loop 0 of CFace (128475) is an invalid outer loop
                              Entity CFace (128475) should be erased - done
                              Edges are not connected in CLoop (128525) for CFace (128524)
                              Loop 0 of CFace (128524) is an invalid outer loop
                              Entity CFace (128524) should be erased - done
                              Edges are not connected in CLoop (128847) for CFace (128846)
                              Loop 0 of CFace (128846) is an invalid outer loop
                              Entity CFace (128846) should be erased - done
                              Edges are not connected in CLoop (128890) for CFace (128889)
                              Loop 0 of CFace (128889) is an invalid outer loop
                              Entity CFace (128889) should be erased - done
                              Edges are not connected in CLoop (129004) for CFace (129003)
                              Loop 0 of CFace (129003) is an invalid outer loop
                              Entity CFace (129003) should be erased - done
                              Edges are not connected in CLoop (129071) for CFace (129070)
                              Loop 0 of CFace (129070) is an invalid outer loop
                              Entity CFace (129070) should be erased - done
                              Edges are not connected in CLoop (129178) for CFace (129177)
                              Loop 0 of CFace (129177) is an invalid outer loop
                              Entity CFace (129177) should be erased - done
                              Edges are not connected in CLoop (129277) for CFace (129276)
                              Loop 0 of CFace (129276) is an invalid outer loop
                              Entity CFace (129276) should be erased - done
                              Edges are not connected in CLoop (129489) for CFace (129488)
                              Loop 0 of CFace (129488) is an invalid outer loop
                              Entity CFace (129488) should be erased - done
                              Edges are not connected in CLoop (129735) for CFace (129734)
                              Loop 0 of CFace (129734) is an invalid outer loop
                              Entity CFace (129734) should be erased - done
                              Edges are not connected in CLoop (129743) for CFace (129742)
                              Loop 0 of CFace (129742) is an invalid outer loop
                              Entity CFace (129742) should be erased - done
                              Edges are not connected in CLoop (129880) for CFace (129879)
                              Loop 0 of CFace (129879) is an invalid outer loop
                              Entity CFace (129879) should be erased - done
                              Edges are not connected in CLoop (129989) for CFace (129988)
                              Loop 0 of CFace (129988) is an invalid outer loop
                              Entity CFace (129988) should be erased - done
                              Edges are not connected in CLoop (130005) for CFace (130004)
                              Loop 0 of CFace (130004) is an invalid outer loop
                              Entity CFace (130004) should be erased - done
                              Edges are not connected in CLoop (130021) for CFace (130020)
                              Loop 0 of CFace (130020) is an invalid outer loop
                              Entity CFace (130020) should be erased - done
                              Edges are not connected in CLoop (130034) for CFace (130033)
                              Loop 0 of CFace (130033) is an invalid outer loop
                              Entity CFace (130033) should be erased - done
                              Edges are not connected in CLoop (130114) for CFace (130113)
                              Loop 0 of CFace (130113) is an invalid outer loop
                              Entity CFace (130113) should be erased - done
                              Edges are not connected in CLoop (130130) for CFace (130129)
                              Loop 0 of CFace (130129) is an invalid outer loop
                              Entity CFace (130129) should be erased - done
                              Edges are not connected in CLoop (130146) for CFace (130145)
                              Loop 0 of CFace (130145) is an invalid outer loop
                              Entity CFace (130145) should be erased - done
                              Edges are not connected in CLoop (130159) for CFace (130158)
                              Loop 0 of CFace (130158) is an invalid outer loop
                              Entity CFace (130158) should be erased - done
                              Edges are not connected in CLoop (130239) for CFace (130238)
                              Loop 0 of CFace (130238) is an invalid outer loop
                              Entity CFace (130238) should be erased - done
                              Edges are not connected in CLoop (130255) for CFace (130254)
                              Loop 0 of CFace (130254) is an invalid outer loop
                              Entity CFace (130254) should be erased - done
                              Edges are not connected in CLoop (130271) for CFace (130270)
                              Loop 0 of CFace (130270) is an invalid outer loop
                              Entity CFace (130270) should be erased - done
                              Edges are not connected in CLoop (130284) for CFace (130283)
                              Loop 0 of CFace (130283) is an invalid outer loop
                              Entity CFace (130283) should be erased - done
                              Edges are not connected in CLoop (130364) for CFace (130363)
                              Loop 0 of CFace (130363) is an invalid outer loop
                              Entity CFace (130363) should be erased - done
                              Edges are not connected in CLoop (130380) for CFace (130379)
                              Loop 0 of CFace (130379) is an invalid outer loop
                              Entity CFace (130379) should be erased - done
                              Edges are not connected in CLoop (130396) for CFace (130395)
                              Loop 0 of CFace (130395) is an invalid outer loop
                              Entity CFace (130395) should be erased - done
                              Edges are not connected in CLoop (130409) for CFace (130408)
                              Loop 0 of CFace (130408) is an invalid outer loop
                              Entity CFace (130408) should be erased - done
                              Edges are not connected in CLoop (130489) for CFace (130488)
                              Loop 0 of CFace (130488) is an invalid outer loop
                              Entity CFace (130488) should be erased - done
                              Edges are not connected in CLoop (130505) for CFace (130504)
                              Loop 0 of CFace (130504) is an invalid outer loop
                              Entity CFace (130504) should be erased - done
                              Edges are not connected in CLoop (130521) for CFace (130520)
                              Loop 0 of CFace (130520) is an invalid outer loop
                              Entity CFace (130520) should be erased - done
                              Edges are not connected in CLoop (130534) for CFace (130533)
                              Loop 0 of CFace (130533) is an invalid outer loop
                              Entity CFace (130533) should be erased - done
                              Edges are not connected in CLoop (130614) for CFace (130613)
                              Loop 0 of CFace (130613) is an invalid outer loop
                              Entity CFace (130613) should be erased - done
                              Edges are not connected in CLoop (130630) for CFace (130629)
                              Loop 0 of CFace (130629) is an invalid outer loop
                              Entity CFace (130629) should be erased - done
                              Edges are not connected in CLoop (130646) for CFace (130645)
                              Loop 0 of CFace (130645) is an invalid outer loop
                              Entity CFace (130645) should be erased - done
                              Edges are not connected in CLoop (130659) for CFace (130658)
                              Loop 0 of CFace (130658) is an invalid outer loop
                              Entity CFace (130658) should be erased - done
                              Edges are not connected in CLoop (130739) for CFace (130738)
                              Loop 0 of CFace (130738) is an invalid outer loop
                              Entity CFace (130738) should be erased - done
                              Edges are not connected in CLoop (130755) for CFace (130754)
                              Loop 0 of CFace (130754) is an invalid outer loop
                              Entity CFace (130754) should be erased - done
                              Edges are not connected in CLoop (130771) for CFace (130770)
                              Loop 0 of CFace (130770) is an invalid outer loop
                              Entity CFace (130770) should be erased - done
                              Edges are not connected in CLoop (130784) for CFace (130783)
                              Loop 0 of CFace (130783) is an invalid outer loop
                              Entity CFace (130783) should be erased - done
                              Edges are not connected in CLoop (130864) for CFace (130863)
                              Loop 0 of CFace (130863) is an invalid outer loop
                              Entity CFace (130863) should be erased - done
                              Edges are not connected in CLoop (130880) for CFace (130879)
                              Loop 0 of CFace (130879) is an invalid outer loop
                              Entity CFace (130879) should be erased - done
                              Edges are not connected in CLoop (130896) for CFace (130895)
                              Loop 0 of CFace (130895) is an invalid outer loop
                              Entity CFace (130895) should be erased - done
                              Edges are not connected in CLoop (130909) for CFace (130908)
                              Loop 0 of CFace (130908) is an invalid outer loop
                              Entity CFace (130908) should be erased - done
                              Edges are not connected in CLoop (130989) for CFace (130988)
                              Loop 0 of CFace (130988) is an invalid outer loop
                              Entity CFace (130988) should be erased - done
                              Edges are not connected in CLoop (131005) for CFace (131004)
                              Loop 0 of CFace (131004) is an invalid outer loop
                              Entity CFace (131004) should be erased - done
                              Edges are not connected in CLoop (131021) for CFace (131020)
                              Loop 0 of CFace (131020) is an invalid outer loop
                              Entity CFace (131020) should be erased - done
                              Edges are not connected in CLoop (131034) for CFace (131033)
                              Loop 0 of CFace (131033) is an invalid outer loop
                              Entity CFace (131033) should be erased - done
                              Edges are not connected in CLoop (131114) for CFace (131113)
                              Loop 0 of CFace (131113) is an invalid outer loop
                              Entity CFace (131113) should be erased - done
                              Edges are not connected in CLoop (131130) for CFace (131129)
                              Loop 0 of CFace (131129) is an invalid outer loop
                              Entity CFace (131129) should be erased - done
                              Edges are not connected in CLoop (131146) for CFace (131145)
                              Loop 0 of CFace (131145) is an invalid outer loop
                              Entity CFace (131145) should be erased - done
                              Edges are not connected in CLoop (131159) for CFace (131158)
                              Loop 0 of CFace (131158) is an invalid outer loop
                              Entity CFace (131158) should be erased - done
                              Edges are not connected in CLoop (131239) for CFace (131238)
                              Loop 0 of CFace (131238) is an invalid outer loop
                              Entity CFace (131238) should be erased - done
                              Edges are not connected in CLoop (131255) for CFace (131254)
                              Loop 0 of CFace (131254) is an invalid outer loop
                              Entity CFace (131254) should be erased - done
                              Edges are not connected in CLoop (131271) for CFace (131270)
                              Loop 0 of CFace (131270) is an invalid outer loop
                              Entity CFace (131270) should be erased - done
                              Edges are not connected in CLoop (131284) for CFace (131283)
                              Loop 0 of CFace (131283) is an invalid outer loop
                              Entity CFace (131283) should be erased - done
                              Edges are not connected in CLoop (131364) for CFace (131363)
                              Loop 0 of CFace (131363) is an invalid outer loop
                              Entity CFace (131363) should be erased - done
                              Edges are not connected in CLoop (131380) for CFace (131379)
                              Loop 0 of CFace (131379) is an invalid outer loop
                              Entity CFace (131379) should be erased - done
                              Edges are not connected in CLoop (131396) for CFace (131395)
                              Loop 0 of CFace (131395) is an invalid outer loop
                              Entity CFace (131395) should be erased - done
                              Edges are not connected in CLoop (131409) for CFace (131408)
                              Loop 0 of CFace (131408) is an invalid outer loop
                              Entity CFace (131408) should be erased - done
                              Edges are not connected in CLoop (131489) for CFace (131488)
                              Loop 0 of CFace (131488) is an invalid outer loop
                              Entity CFace (131488) should be erased - done
                              Edges are not connected in CLoop (131505) for CFace (131504)
                              Loop 0 of CFace (131504) is an invalid outer loop
                              Entity CFace (131504) should be erased - done
                              Edges are not connected in CLoop (131521) for CFace (131520)
                              Loop 0 of CFace (131520) is an invalid outer loop
                              Entity CFace (131520) should be erased - done
                              Edges are not connected in CLoop (131534) for CFace (131533)
                              Loop 0 of CFace (131533) is an invalid outer loop
                              Entity CFace (131533) should be erased - done
                              Edges are not connected in CLoop (131614) for CFace (131613)
                              Loop 0 of CFace (131613) is an invalid outer loop
                              Entity CFace (131613) should be erased - done
                              Edges are not connected in CLoop (131630) for CFace (131629)
                              Loop 0 of CFace (131629) is an invalid outer loop
                              Entity CFace (131629) should be erased - done
                              Edges are not connected in CLoop (131646) for CFace (131645)
                              Loop 0 of CFace (131645) is an invalid outer loop
                              Entity CFace (131645) should be erased - done
                              Edges are not connected in CLoop (131659) for CFace (131658)
                              Loop 0 of CFace (131658) is an invalid outer loop
                              Entity CFace (131658) should be erased - done
                              Edges are not connected in CLoop (131739) for CFace (131738)
                              Loop 0 of CFace (131738) is an invalid outer loop
                              Entity CFace (131738) should be erased - done
                              Edges are not connected in CLoop (131755) for CFace (131754)
                              Loop 0 of CFace (131754) is an invalid outer loop
                              Entity CFace (131754) should be erased - done
                              Edges are not connected in CLoop (131771) for CFace (131770)
                              Loop 0 of CFace (131770) is an invalid outer loop
                              Entity CFace (131770) should be erased - done
                              Edges are not connected in CLoop (131784) for CFace (131783)
                              Loop 0 of CFace (131783) is an invalid outer loop
                              Entity CFace (131783) should be erased - done
                              Edges are not connected in CLoop (131864) for CFace (131863)
                              Loop 0 of CFace (131863) is an invalid outer loop
                              Entity CFace (131863) should be erased - done
                              Edges are not connected in CLoop (131880) for CFace (131879)
                              Loop 0 of CFace (131879) is an invalid outer loop
                              Entity CFace (131879) should be erased - done
                              Edges are not connected in CLoop (131896) for CFace (131895)
                              Loop 0 of CFace (131895) is an invalid outer loop
                              Entity CFace (131895) should be erased - done
                              Edges are not connected in CLoop (131909) for CFace (131908)
                              Loop 0 of CFace (131908) is an invalid outer loop
                              Entity CFace (131908) should be erased - done
                              Daniel S
                                This suggests somethings are so small they appear to be coincident - to SUp - and 'fail'... ❓
                                • ken28875K Offline
                                  ken28875
                                  I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😢
                                  Does anyone have the same problem?
                                  Thanks,
                                  _KN
                                  Follow Your Dreams.
                                    I have never had that problem [Vista].
                                    How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
                                    • ken28875K Offline
                                      ken28875
                                      Hi TIG,
                                      It's only 40cm.
                                      http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
                                      Thanks,
                                      _KN
                                      Follow Your Dreams.
                                        Unlikely to result in faces <1mm ?
                                          I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments 😄 )
                                          • ken28875K Offline
                                            ken28875
                                            What do you mean, TIG?
                                            Thanks,
                                            _KN
                                            Follow Your Dreams.
                                            • 11
                                            • 12
                                            • 13
                                            • 74
                                            • 75
                                            • 11 / 75
