ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
1.5k Posts 467 Posters 3.3m Views
  • H Offline
    Hieru
    I'd really appreciate that. Thanks.
    Problem File
    The model has only been scaled up so that it is 10 times the size that it needs to be. I've been trying to use a 2mm bevel on various edges, but if I scale up the model and use a 20mm bevel, I still get the same problem.
    www.davidhier.co.uk
    • X Offline
      xrok1
      nice model but which corners are giving you problems?
      • H Offline
        Hieru
        Hi xrok1,
        The edges pictured in your post are amongst those effected.
        I just realised that it wasn't very helpful to post a model where most of the edges had already been rounded off.
        Here's a sharp edge version (again 10 x final size).
        UFObeamX10.skp
        Even basic shapes like the square blocks and the clear lens on the top of the lighting model are causing me trouble.
        www.davidhier.co.uk
        • X Offline
          xrok1
          i can't seem to reproduce the problems?? what version of SU do you have installed?
            Hi Hieru,
            I have downloaded scaled (up to 10 times) and rounded a corner of your model (with 200 radius and 6 segments which should be quite enough). Note the tape measure tool on the shortest edges which is now ~1.4 mm. If that value were somewhere (or less than) 1 mm, the face would not be created. This could well be the case if you scale it up by 10 but use more segments with the 20 mm radius.
            • H Offline
              Hieru
              xrok1,
              I'm using SU 7.1.6087 (Free)
              Gaieus,
              When I scaled up the model and applied a 20mm radius, I still used 6 segments. The plugin doesn't appear to have a problem creating the faces and I can select them once created. The problem is that they vanish, along with hidden geometry, when I save the file.
              www.davidhier.co.uk
                I have no idea why that is happening. Try something: Go to your Window > Preferences > General tab and uncheck"Automatically fix problems..."
                The plugin mayproduce invalid geometry and upon saving, this option deletes it. If you keep "Automatically check model..." checked, SU should give you a warning. Then "fix" the model and it will present you with a list of what was fixed. Make a screenshot of that window and attach it here - it may help Fredo to improve the plugin (only IF this invalid geometry is the problem of course)
                • H Offline
                  Hieru
                  Thanks Gaieus, I'll give that a go.
                  As an update to the situation I uninstalled SU and then installed the latest version. I then added the RoundCorner plugin (as well as LibFredo) - no other plugins - and I still had the same problem.
                  I did however find a way around the issue. By exploding geometry, applying the plugin and then re-grouping the geometry I didn't lose any of the corner faces when saving.
                  www.davidhier.co.uk
                    Hm. That's very interesting.
                    • F Offline
                      Hieru,
                      I played with your model and could not reproduce the loss of faces, even if a small radius.
                      I would recommend you do what Gaieus recommends to see if this is not related to the model (the fact that the faces are computed by RoundCorner, but disappear when saving, seems to be a more general issue with the model than the plugin).
                      Also, if this is reproducable, could you try to copy the model within the same file and save to see if both instances have a loss of faces.
                      • H Offline
                        Hieru
                        Hi Fredo6,
                        Thanks for taking the time to look at the model.
                        I followed Gaieus' instructions, but I don't get a warning when applying the plugin or saving the file.
                        Copying the model within the file results in a loss of faces in both sets of geometry. I also tried converting one group of geometry into a component and then applied the plugin. When saving there is a loss of faces for each instance of a component.
                        What was odd is the fact that when I loaded the component from the component palette it was reproduced at a much smaller scale than the original object. Presumably that isn't supposed to happen and is another indication that there is something odd about the model?
                        Luckily I have been able to apply the plugin using the method mentioned in my previous post, so I haven't had to remodel the light.
                        Also I've been working on an architectural model today and haven't had any trouble with the RoundCorner plugin.......so it looks more and more like this was a problem with my model........but can't think what the source of the problem might be.
                        www.davidhier.co.uk
                          Daniel S
                          I tried the model and I can´t reproduce the loss of faces... but I get the warning msg.
                          Results of Validity Check.
                          The start and end vertices are identical for CEdge (82816)
                          Entity CEdge (82816) should be erased - done
                          The start and end vertices are identical for CEdge (83152)
                          Entity CEdge (83152) should be erased - done
                          The start and end vertices are identical for CEdge (83230)
                          Entity CEdge (83230) should be erased - done
                          The start and end vertices are identical for CEdge (83324)
                          Entity CEdge (83324) should be erased - done
                          The start and end vertices are identical for CEdge (83738)
                          Entity CEdge (83738) should be erased - done
                          The start and end vertices are identical for CEdge (83879)
                          Entity CEdge (83879) should be erased - done
                          The start and end vertices are identical for CEdge (83965)
                          Entity CEdge (83965) should be erased - done
                          The start and end vertices are identical for CEdge (84015)
                          Entity CEdge (84015) should be erased - done
                          The start and end vertices are identical for CEdge (84124)
                          Entity CEdge (84124) should be erased - done
                          The start and end vertices are identical for CEdge (84399)
                          Entity CEdge (84399) should be erased - done
                          The start and end vertices are identical for CEdge (84751)
                          Entity CEdge (84751) should be erased - done
                          The start and end vertices are identical for CEdge (84763)
                          Entity CEdge (84763) should be erased - done
                          The start and end vertices are identical for CEdge (84903)
                          Entity CEdge (84903) should be erased - done
                          The start and end vertices are identical for CEdge (85017)
                          Entity CEdge (85017) should be erased - done
                          The start and end vertices are identical for CEdge (85186)
                          Entity CEdge (85186) should be erased - done
                          The start and end vertices are identical for CEdge (85351)
                          Entity CEdge (85351) should be erased - done
                          The start and end vertices are identical for CEdge (85757)
                          Entity CEdge (85757) should be erased - done
                          The start and end vertices are identical for CEdge (85918)
                          Entity CEdge (85918) should be erased - done
                          The start and end vertices are identical for CEdge (86032)
                          Entity CEdge (86032) should be erased - done
                          The start and end vertices are identical for CEdge (86082)
                          Entity CEdge (86082) should be erased - done
                          The start and end vertices are identical for CEdge (86191)
                          Entity CEdge (86191) should be erased - done
                          The start and end vertices are identical for CEdge (86771)
                          Entity CEdge (86771) should be erased - done
                          The start and end vertices are identical for CEdge (86783)
                          Entity CEdge (86783) should be erased - done
                          The start and end vertices are identical for CEdge (86923)
                          Entity CEdge (86923) should be erased - done
                          The start and end vertices are identical for CEdge (87075)
                          Entity CEdge (87075) should be erased - done
                          The start and end vertices are identical for CEdge (87361)
                          Entity CEdge (87361) should be erased - done
                          The start and end vertices are identical for CEdge (87852)
                          Entity CEdge (87852) should be erased - done
                          The start and end vertices are identical for CEdge (87928)
                          Entity CEdge (87928) should be erased - done
                          The start and end vertices are identical for CEdge (88080)
                          Entity CEdge (88080) should be erased - done
                          The start and end vertices are identical for CEdge (88168)
                          Entity CEdge (88168) should be erased - done
                          The start and end vertices are identical for CEdge (107162)
                          Entity CEdge (107162) should be erased - done
                          The start and end vertices are identical for CEdge (106469)
                          Entity CEdge (106469) should be erased - done
                          The start and end vertices are identical for CEdge (106305)
                          Entity CEdge (106305) should be erased - done
                          The start and end vertices are identical for CEdge (107454)
                          Entity CEdge (107454) should be erased - done
                          The start and end vertices are identical for CEdge (106457)
                          Entity CEdge (106457) should be erased - done
                          The start and end vertices are identical for CEdge (107568)
                          Entity CEdge (107568) should be erased - done
                          The start and end vertices are identical for CEdge (106656)
                          Entity CEdge (106656) should be erased - done
                          The start and end vertices are identical for CEdge (107720)
                          Entity CEdge (107720) should be erased - done
                          The start and end vertices are identical for CEdge (107884)
                          Entity CEdge (107884) should be erased - done
                          The start and end vertices are identical for CEdge (108509)
                          Entity CEdge (108509) should be erased - done
                          The start and end vertices are identical for CEdge (108623)
                          Entity CEdge (108623) should be erased - done
                          The start and end vertices are identical for CEdge (108635)
                          Entity CEdge (108635) should be erased - done
                          The start and end vertices are identical for CEdge (108775)
                          Entity CEdge (108775) should be erased - done
                          The start and end vertices are identical for CEdge (109357)
                          Entity CEdge (109357) should be erased - done
                          The start and end vertices are identical for CEdge (109611)
                          Entity CEdge (109611) should be erased - done
                          The start and end vertices are identical for CEdge (109763)
                          Entity CEdge (109763) should be erased - done
                          The start and end vertices are identical for CEdge (109877)
                          Entity CEdge (109877) should be erased - done
                          The start and end vertices are identical for CEdge (95020)
                          Entity CEdge (95020) should be erased - done
                          The start and end vertices are identical for CEdge (110032)
                          Entity CEdge (110032) should be erased - done
                          The start and end vertices are identical for CEdge (110695)
                          Entity CEdge (110695) should be erased - done
                          The start and end vertices are identical for CEdge (110809)
                          Entity CEdge (110809) should be erased - done
                          The start and end vertices are identical for CEdge (110821)
                          Entity CEdge (110821) should be erased - done
                          The start and end vertices are identical for CEdge (110961)
                          Entity CEdge (110961) should be erased - done
                          The start and end vertices are identical for CEdge (88876)
                          Entity CEdge (88876) should be erased - done
                          The start and end vertices are identical for CEdge (88978)
                          Entity CEdge (88978) should be erased - done
                          The start and end vertices are identical for CEdge (89060)
                          Entity CEdge (89060) should be erased - done
                          The start and end vertices are identical for CEdge (89213)
                          Entity CEdge (89213) should be erased - done
                          The start and end vertices are identical for CEdge (89373)
                          Entity CEdge (89373) should be erased - done
                          The start and end vertices are identical for CEdge (89462)
                          Entity CEdge (89462) should be erased - done
                          The start and end vertices are identical for CEdge (89982)
                          Entity CEdge (89982) should be erased - done
                          The start and end vertices are identical for CEdge (90134)
                          Entity CEdge (90134) should be erased - done
                          The start and end vertices are identical for CEdge (90184)
                          Entity CEdge (90184) should be erased - done
                          The start and end vertices are identical for CEdge (90715)
                          Entity CEdge (90715) should be erased - done
                          The start and end vertices are identical for CEdge (90918)
                          Entity CEdge (90918) should be erased - done
                          The start and end vertices are identical for CEdge (91058)
                          Entity CEdge (91058) should be erased - done
                          The start and end vertices are identical for CEdge (91100)
                          Entity CEdge (91100) should be erased - done
                          The start and end vertices are identical for CEdge (91177)
                          Entity CEdge (91177) should be erased - done
                          The start and end vertices are identical for CEdge (91409)
                          Entity CEdge (91409) should be erased - done
                          The start and end vertices are identical for CEdge (91536)
                          Entity CEdge (91536) should be erased - done
                          The start and end vertices are identical for CEdge (91796)
                          Entity CEdge (91796) should be erased - done
                          The start and end vertices are identical for CEdge (92101)
                          Entity CEdge (92101) should be erased - done
                          The start and end vertices are identical for CEdge (92258)
                          Entity CEdge (92258) should be erased - done
                          The start and end vertices are identical for CEdge (92308)
                          Entity CEdge (92308) should be erased - done
                          The start and end vertices are identical for CEdge (93001)
                          Entity CEdge (93001) should be erased - done
                          The start and end vertices are identical for CEdge (93179)
                          Entity CEdge (93179) should be erased - done
                          The start and end vertices are identical for CEdge (93255)
                          Entity CEdge (93255) should be erased - done
                          The start and end vertices are identical for CEdge (93533)
                          Entity CEdge (93533) should be erased - done
                          The start and end vertices are identical for CEdge (94062)
                          Entity CEdge (94062) should be erased - done
                          The start and end vertices are identical for CEdge (94138)
                          Entity CEdge (94138) should be erased - done
                          The start and end vertices are identical for CEdge (94150)
                          Entity CEdge (94150) should be erased - done
                          The start and end vertices are identical for CEdge (94834)
                          Entity CEdge (94834) should be erased - done
                          The start and end vertices are identical for CEdge (94974)
                          Entity CEdge (94974) should be erased - done
                          The start and end vertices are identical for CEdge (95135)
                          Entity CEdge (95135) should be erased - done
                          The start and end vertices are identical for CEdge (95451)
                          Entity CEdge (95451) should be erased - done
                          The start and end vertices are identical for CEdge (95933)
                          Entity CEdge (95933) should be erased - done
                          The start and end vertices are identical for CEdge (96000)
                          Entity CEdge (96000) should be erased - done
                          The start and end vertices are identical for CEdge (96050)
                          Entity CEdge (96050) should be erased - done
                          The start and end vertices are identical for CEdge (96734)
                          Entity CEdge (96734) should be erased - done
                          The start and end vertices are identical for CEdge (96874)
                          Entity CEdge (96874) should be erased - done
                          The start and end vertices are identical for CEdge (96959)
                          Entity CEdge (96959) should be erased - done
                          The start and end vertices are identical for CEdge (97360)
                          Entity CEdge (97360) should be erased - done
                          The start and end vertices are identical for CEdge (97766)
                          Entity CEdge (97766) should be erased - done
                          The start and end vertices are identical for CEdge (100599)
                          Entity CEdge (100599) should be erased - done
                          The start and end vertices are identical for CEdge (99944)
                          Entity CEdge (99944) should be erased - done
                          The start and end vertices are identical for CEdge (99704)
                          Entity CEdge (99704) should be erased - done
                          The start and end vertices are identical for CEdge (100815)
                          Entity CEdge (100815) should be erased - done
                          The start and end vertices are identical for CEdge (99932)
                          Entity CEdge (99932) should be erased - done
                          The start and end vertices are identical for CEdge (100967)
                          Entity CEdge (100967) should be erased - done
                          The start and end vertices are identical for CEdge (99361)
                          Entity CEdge (99361) should be erased - done
                          The start and end vertices are identical for CEdge (101148)
                          Entity CEdge (101148) should be erased - done
                          The start and end vertices are identical for CEdge (101350)
                          Entity CEdge (101350) should be erased - done
                          The start and end vertices are identical for CEdge (101870)
                          Entity CEdge (101870) should be erased - done
                          The start and end vertices are identical for CEdge (101984)
                          Entity CEdge (101984) should be erased - done
                          The start and end vertices are identical for CEdge (101996)
                          Entity CEdge (101996) should be erased - done
                          The start and end vertices are identical for CEdge (102259)
                          Entity CEdge (102259) should be erased - done
                          The start and end vertices are identical for CEdge (99251)
                          Entity CEdge (99251) should be erased - done
                          The start and end vertices are identical for CEdge (97880)
                          Entity CEdge (97880) should be erased - done
                          The start and end vertices are identical for CEdge (97930)
                          Entity CEdge (97930) should be erased - done
                          The start and end vertices are identical for CEdge (98643)
                          Entity CEdge (98643) should be erased - done
                          The start and end vertices are identical for CEdge (98745)
                          Entity CEdge (98745) should be erased - done
                          The start and end vertices are identical for CEdge (98935)
                          Entity CEdge (98935) should be erased - done
                          The start and end vertices are identical for CEdge (105709)
                          Entity CEdge (105709) should be erased - done
                          The start and end vertices are identical for CEdge (102803)
                          Entity CEdge (102803) should be erased - done
                          The start and end vertices are identical for CEdge (102981)
                          Entity CEdge (102981) should be erased - done
                          The start and end vertices are identical for CEdge (103133)
                          Entity CEdge (103133) should be erased - done
                          The start and end vertices are identical for CEdge (103323)
                          Entity CEdge (103323) should be erased - done
                          The start and end vertices are identical for CEdge (103525)
                          Entity CEdge (103525) should be erased - done
                          The start and end vertices are identical for CEdge (104092)
                          Entity CEdge (104092) should be erased - done
                          The start and end vertices are identical for CEdge (104206)
                          Entity CEdge (104206) should be erased - done
                          The start and end vertices are identical for CEdge (104218)
                          Entity CEdge (104218) should be erased - done
                          The start and end vertices are identical for CEdge (104443)
                          Entity CEdge (104443) should be erased - done
                          The start and end vertices are identical for CEdge (104987)
                          Entity CEdge (104987) should be erased - done
                          The start and end vertices are identical for CEdge (105250)
                          Entity CEdge (105250) should be erased - done
                          The start and end vertices are identical for CEdge (105364)
                          Entity CEdge (105364) should be erased - done
                          The start and end vertices are identical for CEdge (105545)
                          Entity CEdge (105545) should be erased - done
                          The start and end vertices are identical for CEdge (111514)
                          Entity CEdge (111514) should be erased - done
                          The start and end vertices are identical for CEdge (111768)
                          Entity CEdge (111768) should be erased - done
                          The start and end vertices are identical for CEdge (111882)
                          Entity CEdge (111882) should be erased - done
                          The start and end vertices are identical for CEdge (111987)
                          Entity CEdge (111987) should be erased - done
                          The start and end vertices are identical for CEdge (112113)
                          Entity CEdge (112113) should be erased - done
                          The start and end vertices are identical for CEdge (112747)
                          Entity CEdge (112747) should be erased - done
                          The start and end vertices are identical for CEdge (112899)
                          Entity CEdge (112899) should be erased - done
                          The start and end vertices are identical for CEdge (112911)
                          Entity CEdge (112911) should be erased - done
                          The start and end vertices are identical for CEdge (113089)
                          Entity CEdge (113089) should be erased - done
                          The start and end vertices are identical for CEdge (113557)
                          Entity CEdge (113557) should be erased - done
                          The start and end vertices are identical for CEdge (113811)
                          Entity CEdge (113811) should be erased - done
                          The start and end vertices are identical for CEdge (113925)
                          Entity CEdge (113925) should be erased - done
                          The start and end vertices are identical for CEdge (114077)
                          Entity CEdge (114077) should be erased - done
                          The start and end vertices are identical for CEdge (114279)
                          Entity CEdge (114279) should be erased - done
                          The start and end vertices are identical for CEdge (114866)
                          Entity CEdge (114866) should be erased - done
                          The start and end vertices are identical for CEdge (114942)
                          Entity CEdge (114942) should be erased - done
                          The start and end vertices are identical for CEdge (114954)
                          Entity CEdge (114954) should be erased - done
                          The start and end vertices are identical for CEdge (115132)
                          Entity CEdge (115132) should be erased - done
                          The start and end vertices are identical for CEdge (115524)
                          Entity CEdge (115524) should be erased - done
                          The start and end vertices are identical for CEdge (115769)
                          Entity CEdge (115769) should be erased - done
                          The start and end vertices are identical for CEdge (115883)
                          Entity CEdge (115883) should be erased - done
                          The start and end vertices are identical for CEdge (116082)
                          Entity CEdge (116082) should be erased - done
                          The start and end vertices are identical for CEdge (116246)
                          Entity CEdge (116246) should be erased - done
                          The start and end vertices are identical for CEdge (116737)
                          Entity CEdge (116737) should be erased - done
                          The start and end vertices are identical for CEdge (116854)
                          Entity CEdge (116854) should be erased - done
                          The start and end vertices are identical for CEdge (117032)
                          Entity CEdge (117032) should be erased - done
                          The start and end vertices are identical for CEdge (117462)
                          Entity CEdge (117462) should be erased - done
                          The start and end vertices are identical for CEdge (117716)
                          Entity CEdge (117716) should be erased - done
                          The start and end vertices are identical for CEdge (117953)
                          Entity CEdge (117953) should be erased - done
                          The start and end vertices are identical for CEdge (118108)
                          Entity CEdge (118108) should be erased - done
                          The start and end vertices are identical for CEdge (118628)
                          Entity CEdge (118628) should be erased - done
                          The start and end vertices are identical for CEdge (118716)
                          Entity CEdge (118716) should be erased - done
                          The start and end vertices are identical for CEdge (118894)
                          Entity CEdge (118894) should be erased - done
                          The start and end vertices are identical for CEdge (119324)
                          Entity CEdge (119324) should be erased - done
                          The start and end vertices are identical for CEdge (119540)
                          Entity CEdge (119540) should be erased - done
                          The start and end vertices are identical for CEdge (119797)
                          Entity CEdge (119797) should be erased - done
                          The start and end vertices are identical for CEdge (120443)
                          Entity CEdge (120443) should be erased - done
                          The start and end vertices are identical for CEdge (120633)
                          Entity CEdge (120633) should be erased - done
                          The start and end vertices are identical for CEdge (120814)
                          Entity CEdge (120814) should be erased - done
                          The start and end vertices are identical for CEdge (121308)
                          Entity CEdge (121308) should be erased - done
                          The start and end vertices are identical for CEdge (121498)
                          Entity CEdge (121498) should be erased - done
                          The start and end vertices are identical for CEdge (122258)
                          Entity CEdge (122258) should be erased - done
                          The start and end vertices are identical for CEdge (122296)
                          Entity CEdge (122296) should be erased - done
                          The start and end vertices are identical for CEdge (122410)
                          Entity CEdge (122410) should be erased - done
                          The start and end vertices are identical for CEdge (123161)
                          Entity CEdge (123161) should be erased - done
                          The start and end vertices are identical for CEdge (123199)
                          Entity CEdge (123199) should be erased - done
                          The start and end vertices are identical for CEdge (123313)
                          Entity CEdge (123313) should be erased - done
                          The start and end vertices are identical for CEdge (123363)
                          Entity CEdge (123363) should be erased - done
                          The start and end vertices are identical for CEdge (124035)
                          Entity CEdge (124035) should be erased - done
                          The start and end vertices are identical for CEdge (124073)
                          Entity CEdge (124073) should be erased - done
                          The start and end vertices are identical for CEdge (124225)
                          Entity CEdge (124225) should be erased - done
                          The start and end vertices are identical for CEdge (124655)
                          Entity CEdge (124655) should be erased - done
                          The start and end vertices are identical for CEdge (124985)
                          Entity CEdge (124985) should be erased - done
                          The start and end vertices are identical for CEdge (125023)
                          Entity CEdge (125023) should be erased - done
                          The start and end vertices are identical for CEdge (125137)
                          Entity CEdge (125137) should be erased - done
                          The start and end vertices are identical for CEdge (125263)
                          Entity CEdge (125263) should be erased - done
                          The start and end vertices are identical for CEdge (125935)
                          Entity CEdge (125935) should be erased - done
                          The start and end vertices are identical for CEdge (125947)
                          Entity CEdge (125947) should be erased - done
                          The start and end vertices are identical for CEdge (126011)
                          Entity CEdge (126011) should be erased - done
                          The start and end vertices are identical for CEdge (126055)
                          Entity CEdge (126055) should be erased - done
                          The start and end vertices are identical for CEdge (126170)
                          Entity CEdge (126170) should be erased - done
                          The start and end vertices are identical for CEdge (126600)
                          Entity CEdge (126600) should be erased - done
                          The start and end vertices are identical for CEdge (126892)
                          Entity CEdge (126892) should be erased - done
                          The start and end vertices are identical for CEdge (126930)
                          Entity CEdge (126930) should be erased - done
                          The start and end vertices are identical for CEdge (127010)
                          Entity CEdge (127010) should be erased - done
                          The start and end vertices are identical for CEdge (127125)
                          Entity CEdge (127125) should be erased - done
                          The start and end vertices are identical for CEdge (127213)
                          Entity CEdge (127213) should be erased - done
                          The start and end vertices are identical for CEdge (127905)
                          Entity CEdge (127905) should be erased - done
                          The start and end vertices are identical for CEdge (127917)
                          Entity CEdge (127917) should be erased - done
                          The start and end vertices are identical for CEdge (127981)
                          Entity CEdge (127981) should be erased - done
                          The start and end vertices are identical for CEdge (128025)
                          Entity CEdge (128025) should be erased - done
                          The start and end vertices are identical for CEdge (128140)
                          Entity CEdge (128140) should be erased - done
                          The start and end vertices are identical for CEdge (128523)
                          Entity CEdge (128523) should be erased - done
                          The start and end vertices are identical for CEdge (128844)
                          Entity CEdge (128844) should be erased - done
                          The start and end vertices are identical for CEdge (128886)
                          Entity CEdge (128886) should be erased - done
                          The start and end vertices are identical for CEdge (129001)
                          Entity CEdge (129001) should be erased - done
                          The start and end vertices are identical for CEdge (129176)
                          Entity CEdge (129176) should be erased - done
                          The start and end vertices are identical for CEdge (129273)
                          Entity CEdge (129273) should be erased - done
                          The start and end vertices are identical for CEdge (132246)
                          Entity CEdge (132246) should be erased - done
                          The start and end vertices are identical for CEdge (132255)
                          Entity CEdge (132255) should be erased - done
                          The start and end vertices are identical for CEdge (132261)
                          Entity CEdge (132261) should be erased - done
                          The start and end vertices are identical for CEdge (132267)
                          Entity CEdge (132267) should be erased - done
                          The start and end vertices are identical for CEdge (132270)
                          Entity CEdge (132270) should be erased - done
                          The start and end vertices are identical for CEdge (132279)
                          Entity CEdge (132279) should be erased - done
                          The start and end vertices are identical for CEdge (132291)
                          Entity CEdge (132291) should be erased - done
                          The start and end vertices are identical for CEdge (132294)
                          Entity CEdge (132294) should be erased - done
                          The start and end vertices are identical for CEdge (132297)
                          Entity CEdge (132297) should be erased - done
                          The start and end vertices are identical for CEdge (132315)
                          Entity CEdge (132315) should be erased - done
                          The start and end vertices are identical for CEdge (132324)
                          Entity CEdge (132324) should be erased - done
                          The start and end vertices are identical for CEdge (132342)
                          Entity CEdge (132342) should be erased - done
                          The start and end vertices are identical for CEdge (132345)
                          Entity CEdge (132345) should be erased - done
                          The start and end vertices are identical for CEdge (132363)
                          Entity CEdge (132363) should be erased - done
                          The start and end vertices are identical for CEdge (132378)
                          Entity CEdge (132378) should be erased - done
                          The start and end vertices are identical for CEdge (132381)
                          Entity CEdge (132381) should be erased - done
                          The start and end vertices are identical for CEdge (132384)
                          Entity CEdge (132384) should be erased - done
                          The start and end vertices are identical for CEdge (132411)
                          Entity CEdge (132411) should be erased - done
                          The start and end vertices are identical for CEdge (132414)
                          Entity CEdge (132414) should be erased - done
                          The start and end vertices are identical for CEdge (132420)
                          Entity CEdge (132420) should be erased - done
                          The start and end vertices are identical for CEdge (132435)
                          Entity CEdge (132435) should be erased - done
                          The start and end vertices are identical for CEdge (132438)
                          Entity CEdge (132438) should be erased - done
                          The start and end vertices are identical for CEdge (132459)
                          Entity CEdge (132459) should be erased - done
                          The start and end vertices are identical for CEdge (132474)
                          Entity CEdge (132474) should be erased - done
                          The start and end vertices are identical for CEdge (132486)
                          Entity CEdge (132486) should be erased - done
                          The start and end vertices are identical for CEdge (132495)
                          Entity CEdge (132495) should be erased - done
                          The start and end vertices are identical for CEdge (132501)
                          Entity CEdge (132501) should be erased - done
                          The start and end vertices are identical for CEdge (132513)
                          Entity CEdge (132513) should be erased - done
                          The start and end vertices are identical for CEdge (132516)
                          Entity CEdge (132516) should be erased - done
                          The start and end vertices are identical for CEdge (132531)
                          Entity CEdge (132531) should be erased - done
                          The start and end vertices are identical for CEdge (132540)
                          Entity CEdge (132540) should be erased - done
                          The start and end vertices are identical for CEdge (132546)
                          Entity CEdge (132546) should be erased - done
                          The start and end vertices are identical for CEdge (132549)
                          Entity CEdge (132549) should be erased - done
                          The start and end vertices are identical for CEdge (132564)
                          Entity CEdge (132564) should be erased - done
                          The start and end vertices are identical for CEdge (132579)
                          Entity CEdge (132579) should be erased - done
                          The start and end vertices are identical for CEdge (132591)
                          Entity CEdge (132591) should be erased - done
                          The start and end vertices are identical for CEdge (132600)
                          Entity CEdge (132600) should be erased - done
                          The start and end vertices are identical for CEdge (132609)
                          Entity CEdge (132609) should be erased - done
                          The start and end vertices are identical for CEdge (132621)
                          Entity CEdge (132621) should be erased - done
                          The start and end vertices are identical for CEdge (132624)
                          Entity CEdge (132624) should be erased - done
                          The start and end vertices are identical for CEdge (132636)
                          Entity CEdge (132636) should be erased - done
                          The start and end vertices are identical for CEdge (132642)
                          Entity CEdge (132642) should be erased - done
                          The start and end vertices are identical for CEdge (132648)
                          Entity CEdge (132648) should be erased - done
                          The start and end vertices are identical for CEdge (132651)
                          Entity CEdge (132651) should be erased - done
                          The start and end vertices are identical for CEdge (132654)
                          Entity CEdge (132654) should be erased - done
                          The start and end vertices are identical for CEdge (132657)
                          Entity CEdge (132657) should be erased - done
                          The start and end vertices are identical for CEdge (132684)
                          Entity CEdge (132684) should be erased - done
                          The start and end vertices are identical for CEdge (132690)
                          Entity CEdge (132690) should be erased - done
                          The start and end vertices are identical for CEdge (132708)
                          Entity CEdge (132708) should be erased - done
                          The start and end vertices are identical for CEdge (132717)
                          Entity CEdge (132717) should be erased - done
                          The start and end vertices are identical for CEdge (132720)
                          Entity CEdge (132720) should be erased - done
                          The start and end vertices are identical for CEdge (132735)
                          Entity CEdge (132735) should be erased - done
                          The start and end vertices are identical for CEdge (132738)
                          Entity CEdge (132738) should be erased - done
                          The start and end vertices are identical for CEdge (132753)
                          Entity CEdge (132753) should be erased - done
                          The start and end vertices are identical for CEdge (132759)
                          Entity CEdge (132759) should be erased - done
                          The start and end vertices are identical for CEdge (132774)
                          Entity CEdge (132774) should be erased - done
                          The start and end vertices are identical for CEdge (132777)
                          Entity CEdge (132777) should be erased - done
                          The start and end vertices are identical for CEdge (132792)
                          Entity CEdge (132792) should be erased - done
                          The start and end vertices are identical for CEdge (132810)
                          Entity CEdge (132810) should be erased - done
                          The start and end vertices are identical for CEdge (132825)
                          Entity CEdge (132825) should be erased - done
                          The start and end vertices are identical for CEdge (132843)
                          Entity CEdge (132843) should be erased - done
                          The start and end vertices are identical for CEdge (132858)
                          Entity CEdge (132858) should be erased - done
                          The start and end vertices are identical for CEdge (132876)
                          Entity CEdge (132876) should be erased - done
                          The start and end vertices are identical for CEdge (132888)
                          Entity CEdge (132888) should be erased - done
                          The start and end vertices are identical for CEdge (132903)
                          Entity CEdge (132903) should be erased - done
                          The start and end vertices are identical for CEdge (132915)
                          Entity CEdge (132915) should be erased - done
                          The start and end vertices are identical for CEdge (132927)
                          Entity CEdge (132927) should be erased - done
                          The start and end vertices are identical for CEdge (132939)
                          Entity CEdge (132939) should be erased - done
                          The start and end vertices are identical for CEdge (132948)
                          Entity CEdge (132948) should be erased - done
                          The start and end vertices are identical for CEdge (132960)
                          Entity CEdge (132960) should be erased - done
                          The start and end vertices are identical for CEdge (132975)
                          Entity CEdge (132975) should be erased - done
                          The start and end vertices are identical for CEdge (132987)
                          Entity CEdge (132987) should be erased - done
                          The start and end vertices are identical for CEdge (133005)
                          Entity CEdge (133005) should be erased - done
                          The start and end vertices are identical for CEdge (133017)
                          Entity CEdge (133017) should be erased - done
                          The start and end vertices are identical for CEdge (133026)
                          Entity CEdge (133026) should be erased - done
                          The start and end vertices are identical for CEdge (133041)
                          Entity CEdge (133041) should be erased - done
                          The start and end vertices are identical for CEdge (133050)
                          Entity CEdge (133050) should be erased - done
                          The start and end vertices are identical for CEdge (133062)
                          Entity CEdge (133062) should be erased - done
                          The start and end vertices are identical for CEdge (133071)
                          Entity CEdge (133071) should be erased - done
                          The start and end vertices are identical for CEdge (133080)
                          Entity CEdge (133080) should be erased - done
                          The start and end vertices are identical for CEdge (133092)
                          Entity CEdge (133092) should be erased - done
                          The start and end vertices are identical for CEdge (133098)
                          Entity CEdge (133098) should be erased - done
                          The start and end vertices are identical for CEdge (133101)
                          Entity CEdge (133101) should be erased - done
                          The start and end vertices are identical for CEdge (133104)
                          Entity CEdge (133104) should be erased - done
                          The start and end vertices are identical for CEdge (133107)
                          Entity CEdge (133107) should be erased - done
                          The start and end vertices are identical for CEdge (133110)
                          Entity CEdge (133110) should be erased - done
                          The start and end vertices are identical for CEdge (133113)
                          Entity CEdge (133113) should be erased - done
                          The start and end vertices are identical for CEdge (133116)
                          Entity CEdge (133116) should be erased - done
                          The start and end vertices are identical for CEdge (133119)
                          Entity CEdge (133119) should be erased - done
                          The start and end vertices are identical for CEdge (133122)
                          Entity CEdge (133122) should be erased - done
                          The start and end vertices are identical for CEdge (133125)
                          Entity CEdge (133125) should be erased - done
                          The start and end vertices are identical for CEdge (133128)
                          Entity CEdge (133128) should be erased - done
                          The start and end vertices are identical for CEdge (133131)
                          Entity CEdge (133131) should be erased - done
                          The start and end vertices are identical for CEdge (133134)
                          Entity CEdge (133134) should be erased - done
                          The start and end vertices are identical for CEdge (133137)
                          Entity CEdge (133137) should be erased - done
                          The start and end vertices are identical for CEdge (133140)
                          Entity CEdge (133140) should be erased - done
                          The start and end vertices are identical for CEdge (133143)
                          Entity CEdge (133143) should be erased - done
                          The start and end vertices are identical for CEdge (133146)
                          Entity CEdge (133146) should be erased - done
                          The start and end vertices are identical for CEdge (133149)
                          Entity CEdge (133149) should be erased - done
                          The start and end vertices are identical for CEdge (133152)
                          Entity CEdge (133152) should be erased - done
                          The start and end vertices are identical for CEdge (133155)
                          Entity CEdge (133155) should be erased - done
                          The start and end vertices are identical for CEdge (133158)
                          Entity CEdge (133158) should be erased - done
                          The start and end vertices are identical for CEdge (133161)
                          Entity CEdge (133161) should be erased - done
                          The start and end vertices are identical for CEdge (133164)
                          Entity CEdge (133164) should be erased - done
                          The start and end vertices are identical for CEdge (133167)
                          Entity CEdge (133167) should be erased - done
                          The start and end vertices are identical for CEdge (133170)
                          Entity CEdge (133170) should be erased - done
                          The start and end vertices are identical for CEdge (133173)
                          Entity CEdge (133173) should be erased - done
                          The start and end vertices are identical for CEdge (133176)
                          Entity CEdge (133176) should be erased - done
                          The start and end vertices are identical for CEdge (133179)
                          Entity CEdge (133179) should be erased - done
                          The start and end vertices are identical for CEdge (133182)
                          Entity CEdge (133182) should be erased - done
                          The start and end vertices are identical for CEdge (133185)
                          Entity CEdge (133185) should be erased - done
                          The start and end vertices are identical for CEdge (133188)
                          Entity CEdge (133188) should be erased - done
                          The start and end vertices are identical for CEdge (133191)
                          Entity CEdge (133191) should be erased - done
                          The start and end vertices are identical for CEdge (133194)
                          Entity CEdge (133194) should be erased - done
                          The start and end vertices are identical for CEdge (133197)
                          Entity CEdge (133197) should be erased - done
                          The start and end vertices are identical for CEdge (133200)
                          Entity CEdge (133200) should be erased - done
                          The start and end vertices are identical for CEdge (133203)
                          Entity CEdge (133203) should be erased - done
                          The start and end vertices are identical for CEdge (133206)
                          Entity CEdge (133206) should be erased - done
                          The start and end vertices are identical for CEdge (133209)
                          Entity CEdge (133209) should be erased - done
                          The start and end vertices are identical for CEdge (133212)
                          Entity CEdge (133212) should be erased - done
                          The start and end vertices are identical for CEdge (133215)
                          Entity CEdge (133215) should be erased - done
                          The start and end vertices are identical for CEdge (133218)
                          Entity CEdge (133218) should be erased - done
                          The start and end vertices are identical for CEdge (133221)
                          Entity CEdge (133221) should be erased - done
                          The start and end vertices are identical for CEdge (133224)
                          Entity CEdge (133224) should be erased - done
                          The start and end vertices are identical for CEdge (133227)
                          Entity CEdge (133227) should be erased - done
                          The start and end vertices are identical for CEdge (133230)
                          Entity CEdge (133230) should be erased - done
                          The start and end vertices are identical for CEdge (133233)
                          Entity CEdge (133233) should be erased - done
                          The start and end vertices are identical for CEdge (133236)
                          Entity CEdge (133236) should be erased - done
                          The start and end vertices are identical for CEdge (133239)
                          Entity CEdge (133239) should be erased - done
                          Edges are not connected in CLoop (82820) for CFace (82819)
                          Loop 0 of CFace (82819) is an invalid outer loop
                          Entity CFace (82819) should be erased - done
                          Edges are not connected in CLoop (83154) for CFace (83153)
                          Loop 0 of CFace (83153) is an invalid outer loop
                          Entity CFace (83153) should be erased - done
                          Edges are not connected in CLoop (83234) for CFace (83233)
                          Loop 0 of CFace (83233) is an invalid outer loop
                          Entity CFace (83233) should be erased - done
                          Edges are not connected in CLoop (83328) for CFace (83327)
                          Loop 0 of CFace (83327) is an invalid outer loop
                          Entity CFace (83327) should be erased - done
                          Edges are not connected in CLoop (83742) for CFace (83741)
                          Loop 0 of CFace (83741) is an invalid outer loop
                          Entity CFace (83741) should be erased - done
                          Edges are not connected in CLoop (83883) for CFace (83882)
                          Loop 0 of CFace (83882) is an invalid outer loop
                          Entity CFace (83882) should be erased - done
                          Edges are not connected in CLoop (83968) for CFace (83967)
                          Loop 0 of CFace (83967) is an invalid outer loop
                          Entity CFace (83967) should be erased - done
                          Edges are not connected in CLoop (84017) for CFace (84016)
                          Loop 0 of CFace (84016) is an invalid outer loop
                          Entity CFace (84016) should be erased - done
                          Edges are not connected in CLoop (84128) for CFace (84127)
                          Loop 0 of CFace (84127) is an invalid outer loop
                          Entity CFace (84127) should be erased - done
                          Edges are not connected in CLoop (84318) for CFace (84317)
                          Loop 0 of CFace (84317) is an invalid outer loop
                          Entity CFace (84317) should be erased - done
                          Edges are not connected in CLoop (84403) for CFace (84402)
                          Loop 0 of CFace (84402) is an invalid outer loop
                          Entity CFace (84402) should be erased - done
                          Edges are not connected in CLoop (84754) for CFace (84753)
                          Loop 0 of CFace (84753) is an invalid outer loop
                          Entity CFace (84753) should be erased - done
                          Edges are not connected in CLoop (84765) for CFace (84764)
                          Loop 0 of CFace (84764) is an invalid outer loop
                          Entity CFace (84764) should be erased - done
                          Edges are not connected in CLoop (84906) for CFace (84905)
                          Loop 0 of CFace (84905) is an invalid outer loop
                          Entity CFace (84905) should be erased - done
                          Edges are not connected in CLoop (85020) for CFace (85019)
                          Loop 0 of CFace (85019) is an invalid outer loop
                          Entity CFace (85019) should be erased - done
                          Edges are not connected in CLoop (85190) for CFace (85189)
                          Loop 0 of CFace (85189) is an invalid outer loop
                          Entity CFace (85189) should be erased - done
                          Edges are not connected in CLoop (85353) for CFace (85352)
                          Loop 0 of CFace (85352) is an invalid outer loop
                          Entity CFace (85352) should be erased - done
                          Edges are not connected in CLoop (85418) for CFace (85417)
                          Loop 0 of CFace (85417) is an invalid outer loop
                          Entity CFace (85417) should be erased - done
                          Edges are not connected in CLoop (85760) for CFace (85759)
                          Loop 0 of CFace (85759) is an invalid outer loop
                          Entity CFace (85759) should be erased - done
                          Edges are not connected in CLoop (85921) for CFace (85920)
                          Loop 0 of CFace (85920) is an invalid outer loop
                          Entity CFace (85920) should be erased - done
                          Edges are not connected in CLoop (86035) for CFace (86034)
                          Loop 0 of CFace (86034) is an invalid outer loop
                          Entity CFace (86034) should be erased - done
                          Edges are not connected in CLoop (86084) for CFace (86083)
                          Loop 0 of CFace (86083) is an invalid outer loop
                          Entity CFace (86083) should be erased - done
                          Edges are not connected in CLoop (86195) for CFace (86194)
                          Loop 0 of CFace (86194) is an invalid outer loop
                          Entity CFace (86194) should be erased - done
                          Edges are not connected in CLoop (86385) for CFace (86384)
                          Loop 0 of CFace (86384) is an invalid outer loop
                          Entity CFace (86384) should be erased - done
                          Edges are not connected in CLoop (86774) for CFace (86773)
                          Loop 0 of CFace (86773) is an invalid outer loop
                          Entity CFace (86773) should be erased - done
                          Edges are not connected in CLoop (86785) for CFace (86784)
                          Loop 0 of CFace (86784) is an invalid outer loop
                          Entity CFace (86784) should be erased - done
                          Edges are not connected in CLoop (86926) for CFace (86925)
                          Loop 0 of CFace (86925) is an invalid outer loop
                          Entity CFace (86925) should be erased - done
                          Edges are not connected in CLoop (87078) for CFace (87077)
                          Loop 0 of CFace (87077) is an invalid outer loop
                          Entity CFace (87077) should be erased - done
                          Edges are not connected in CLoop (87363) for CFace (87362)
                          Loop 0 of CFace (87362) is an invalid outer loop
                          Entity CFace (87362) should be erased - done
                          Edges are not connected in CLoop (87428) for CFace (87427)
                          Loop 0 of CFace (87427) is an invalid outer loop
                          Entity CFace (87427) should be erased - done
                          Edges are not connected in CLoop (87855) for CFace (87854)
                          Loop 0 of CFace (87854) is an invalid outer loop
                          Entity CFace (87854) should be erased - done
                          Edges are not connected in CLoop (87931) for CFace (87930)
                          Loop 0 of CFace (87930) is an invalid outer loop
                          Entity CFace (87930) should be erased - done
                          Edges are not connected in CLoop (88083) for CFace (88082)
                          Loop 0 of CFace (88082) is an invalid outer loop
                          Entity CFace (88082) should be erased - done
                          Edges are not connected in CLoop (88170) for CFace (88169)
                          Loop 0 of CFace (88169) is an invalid outer loop
                          Entity CFace (88169) should be erased - done
                          Edges are not connected in CLoop (88433) for CFace (88432)
                          Loop 0 of CFace (88432) is an invalid outer loop
                          Entity CFace (88432) should be erased - done
                          Edges are not connected in CLoop (106963) for CFace (106962)
                          Loop 0 of CFace (106962) is an invalid outer loop
                          Entity CFace (106962) should be erased - done
                          Edges are not connected in CLoop (107164) for CFace (107163)
                          Loop 0 of CFace (107163) is an invalid outer loop
                          Entity CFace (107163) should be erased - done
                          Edges are not connected in CLoop (107457) for CFace (107456)
                          Loop 0 of CFace (107456) is an invalid outer loop
                          Entity CFace (107456) should be erased - done
                          Edges are not connected in CLoop (107571) for CFace (107570)
                          Loop 0 of CFace (107570) is an invalid outer loop
                          Entity CFace (107570) should be erased - done
                          Edges are not connected in CLoop (107723) for CFace (107722)
                          Loop 0 of CFace (107722) is an invalid outer loop
                          Entity CFace (107722) should be erased - done
                          Edges are not connected in CLoop (107837) for CFace (107836)
                          Loop 0 of CFace (107836) is an invalid outer loop
                          Entity CFace (107836) should be erased - done
                          Edges are not connected in CLoop (107886) for CFace (107885)
                          Loop 0 of CFace (107885) is an invalid outer loop
                          Entity CFace (107885) should be erased - done
                          Edges are not connected in CLoop (108170) for CFace (108169)
                          Loop 0 of CFace (108169) is an invalid outer loop
                          Entity CFace (108169) should be erased - done
                          Edges are not connected in CLoop (108512) for CFace (108511)
                          Loop 0 of CFace (108511) is an invalid outer loop
                          Entity CFace (108511) should be erased - done
                          Edges are not connected in CLoop (108626) for CFace (108625)
                          Loop 0 of CFace (108625) is an invalid outer loop
                          Entity CFace (108625) should be erased - done
                          Edges are not connected in CLoop (108637) for CFace (108636)
                          Loop 0 of CFace (108636) is an invalid outer loop
                          Entity CFace (108636) should be erased - done
                          Edges are not connected in CLoop (108778) for CFace (108777)
                          Loop 0 of CFace (108777) is an invalid outer loop
                          Entity CFace (108777) should be erased - done
                          Edges are not connected in CLoop (108930) for CFace (108929)
                          Loop 0 of CFace (108929) is an invalid outer loop
                          Entity CFace (108929) should be erased - done
                          Edges are not connected in CLoop (109272) for CFace (109271)
                          Loop 0 of CFace (109271) is an invalid outer loop
                          Entity CFace (109271) should be erased - done
                          Edges are not connected in CLoop (109359) for CFace (109358)
                          Loop 0 of CFace (109358) is an invalid outer loop
                          Entity CFace (109358) should be erased - done
                          Edges are not connected in CLoop (109614) for CFace (109613)
                          Loop 0 of CFace (109613) is an invalid outer loop
                          Entity CFace (109613) should be erased - done
                          Edges are not connected in CLoop (109766) for CFace (109765)
                          Loop 0 of CFace (109765) is an invalid outer loop
                          Entity CFace (109765) should be erased - done
                          Edges are not connected in CLoop (109880) for CFace (109879)
                          Loop 0 of CFace (109879) is an invalid outer loop
                          Entity CFace (109879) should be erased - done
                          Edges are not connected in CLoop (110023) for CFace (110022)
                          Loop 0 of CFace (110022) is an invalid outer loop
                          Entity CFace (110022) should be erased - done
                          Edges are not connected in CLoop (110034) for CFace (110033)
                          Loop 0 of CFace (110033) is an invalid outer loop
                          Entity CFace (110033) should be erased - done
                          Edges are not connected in CLoop (110356) for CFace (110355)
                          Loop 0 of CFace (110355) is an invalid outer loop
                          Entity CFace (110355) should be erased - done
                          Edges are not connected in CLoop (110698) for CFace (110697)
                          Loop 0 of CFace (110697) is an invalid outer loop
                          Entity CFace (110697) should be erased - done
                          Edges are not connected in CLoop (110812) for CFace (110811)
                          Loop 0 of CFace (110811) is an invalid outer loop
                          Entity CFace (110811) should be erased - done
                          Edges are not connected in CLoop (110823) for CFace (110822)
                          Loop 0 of CFace (110822) is an invalid outer loop
                          Entity CFace (110822) should be erased - done
                          Edges are not connected in CLoop (110964) for CFace (110963)
                          Loop 0 of CFace (110963) is an invalid outer loop
                          Entity CFace (110963) should be erased - done
                          Edges are not connected in CLoop (111391) for CFace (111390)
                          Loop 0 of CFace (111390) is an invalid outer loop
                          Entity CFace (111390) should be erased - done
                          Edges are not connected in CLoop (88878) for CFace (88877)
                          Loop 0 of CFace (88877) is an invalid outer loop
                          Entity CFace (88877) should be erased - done
                          Edges are not connected in CLoop (88981) for CFace (88980)
                          Loop 0 of CFace (88980) is an invalid outer loop
                          Entity CFace (88980) should be erased - done
                          Edges are not connected in CLoop (89064) for CFace (89063)
                          Loop 0 of CFace (89063) is an invalid outer loop
                          Entity CFace (89063) should be erased - done
                          Edges are not connected in CLoop (89216) for CFace (89215)
                          Loop 0 of CFace (89215) is an invalid outer loop
                          Entity CFace (89215) should be erased - done
                          Edges are not connected in CLoop (89377) for CFace (89376)
                          Loop 0 of CFace (89376) is an invalid outer loop
                          Entity CFace (89376) should be erased - done
                          Edges are not connected in CLoop (89464) for CFace (89463)
                          Loop 0 of CFace (89463) is an invalid outer loop
                          Entity CFace (89463) should be erased - done
                          Edges are not connected in CLoop (89529) for CFace (89528)
                          Loop 0 of CFace (89528) is an invalid outer loop
                          Entity CFace (89528) should be erased - done
                          Edges are not connected in CLoop (89985) for CFace (89984)
                          Loop 0 of CFace (89984) is an invalid outer loop
                          Entity CFace (89984) should be erased - done
                          Edges are not connected in CLoop (90137) for CFace (90136)
                          Loop 0 of CFace (90136) is an invalid outer loop
                          Entity CFace (90136) should be erased - done
                          Edges are not connected in CLoop (90186) for CFace (90185)
                          Loop 0 of CFace (90185) is an invalid outer loop
                          Entity CFace (90185) should be erased - done
                          Edges are not connected in CLoop (90486) for CFace (90485)
                          Loop 0 of CFace (90485) is an invalid outer loop
                          Entity CFace (90485) should be erased - done
                          Edges are not connected in CLoop (90719) for CFace (90718)
                          Loop 0 of CFace (90718) is an invalid outer loop
                          Entity CFace (90718) should be erased - done
                          Edges are not connected in CLoop (90920) for CFace (90919)
                          Loop 0 of CFace (90919) is an invalid outer loop
                          Entity CFace (90919) should be erased - done
                          Edges are not connected in CLoop (91061) for CFace (91060)
                          Loop 0 of CFace (91060) is an invalid outer loop
                          Entity CFace (91060) should be erased - done
                          Edges are not connected in CLoop (91104) for CFace (91103)
                          Loop 0 of CFace (91103) is an invalid outer loop
                          Entity CFace (91103) should be erased - done
                          Edges are not connected in CLoop (91180) for CFace (91179)
                          Loop 0 of CFace (91179) is an invalid outer loop
                          Entity CFace (91179) should be erased - done
                          Edges are not connected in CLoop (91413) for CFace (91412)
                          Loop 0 of CFace (91412) is an invalid outer loop
                          Entity CFace (91412) should be erased - done
                          Edges are not connected in CLoop (91538) for CFace (91537)
                          Loop 0 of CFace (91537) is an invalid outer loop
                          Entity CFace (91537) should be erased - done
                          Edges are not connected in CLoop (91603) for CFace (91602)
                          Loop 0 of CFace (91602) is an invalid outer loop
                          Entity CFace (91602) should be erased - done
                          Edges are not connected in CLoop (91800) for CFace (91799)
                          Loop 0 of CFace (91799) is an invalid outer loop
                          Entity CFace (91799) should be erased - done
                          Edges are not connected in CLoop (92104) for CFace (92103)
                          Loop 0 of CFace (92103) is an invalid outer loop
                          Entity CFace (92103) should be erased - done
                          Edges are not connected in CLoop (92261) for CFace (92260)
                          Loop 0 of CFace (92260) is an invalid outer loop
                          Entity CFace (92260) should be erased - done
                          Edges are not connected in CLoop (92310) for CFace (92309)
                          Loop 0 of CFace (92309) is an invalid outer loop
                          Entity CFace (92309) should be erased - done
                          Edges are not connected in CLoop (92603) for CFace (92602)
                          Loop 0 of CFace (92602) is an invalid outer loop
                          Entity CFace (92602) should be erased - done
                          Edges are not connected in CLoop (93003) for CFace (93002)
                          Loop 0 of CFace (93002) is an invalid outer loop
                          Entity CFace (93002) should be erased - done
                          Edges are not connected in CLoop (93182) for CFace (93181)
                          Loop 0 of CFace (93181) is an invalid outer loop
                          Entity CFace (93181) should be erased - done
                          Edges are not connected in CLoop (93258) for CFace (93257)
                          Loop 0 of CFace (93257) is an invalid outer loop
                          Entity CFace (93257) should be erased - done
                          Edges are not connected in CLoop (93535) for CFace (93534)
                          Loop 0 of CFace (93534) is an invalid outer loop
                          Entity CFace (93534) should be erased - done
                          Edges are not connected in CLoop (93600) for CFace (93599)
                          Loop 0 of CFace (93599) is an invalid outer loop
                          Entity CFace (93599) should be erased - done
                          Edges are not connected in CLoop (94065) for CFace (94064)
                          Loop 0 of CFace (94064) is an invalid outer loop
                          Entity CFace (94064) should be erased - done
                          Edges are not connected in CLoop (94141) for CFace (94140)
                          Loop 0 of CFace (94140) is an invalid outer loop
                          Entity CFace (94140) should be erased - done
                          Edges are not connected in CLoop (94152) for CFace (94151)
                          Loop 0 of CFace (94151) is an invalid outer loop
                          Entity CFace (94151) should be erased - done
                          Edges are not connected in CLoop (94521) for CFace (94520)
                          Loop 0 of CFace (94520) is an invalid outer loop
                          Entity CFace (94520) should be erased - done
                          Edges are not connected in CLoop (94836) for CFace (94835)
                          Loop 0 of CFace (94835) is an invalid outer loop
                          Entity CFace (94835) should be erased - done
                          Edges are not connected in CLoop (94977) for CFace (94976)
                          Loop 0 of CFace (94976) is an invalid outer loop
                          Entity CFace (94976) should be erased - done
                          Edges are not connected in CLoop (95024) for CFace (95023)
                          Loop 0 of CFace (95023) is an invalid outer loop
                          Entity CFace (95023) should be erased - done
                          Edges are not connected in CLoop (95138) for CFace (95137)
                          Loop 0 of CFace (95137) is an invalid outer loop
                          Entity CFace (95137) should be erased - done
                          Edges are not connected in CLoop (95453) for CFace (95452)
                          Loop 0 of CFace (95452) is an invalid outer loop
                          Entity CFace (95452) should be erased - done
                          Edges are not connected in CLoop (95518) for CFace (95517)
                          Loop 0 of CFace (95517) is an invalid outer loop
                          Entity CFace (95517) should be erased - done
                          Edges are not connected in CLoop (95936) for CFace (95935)
                          Loop 0 of CFace (95935) is an invalid outer loop
                          Entity CFace (95935) should be erased - done
                          Edges are not connected in CLoop (96003) for CFace (96002)
                          Loop 0 of CFace (96002) is an invalid outer loop
                          Entity CFace (96002) should be erased - done
                          Edges are not connected in CLoop (96052) for CFace (96051)
                          Loop 0 of CFace (96051) is an invalid outer loop
                          Entity CFace (96051) should be erased - done
                          Edges are not connected in CLoop (96383) for CFace (96382)
                          Loop 0 of CFace (96382) is an invalid outer loop
                          Entity CFace (96382) should be erased - done
                          Edges are not connected in CLoop (96535) for CFace (96534)
                          Loop 0 of CFace (96534) is an invalid outer loop
                          Entity CFace (96534) should be erased - done
                          Edges are not connected in CLoop (96736) for CFace (96735)
                          Loop 0 of CFace (96735) is an invalid outer loop
                          Entity CFace (96735) should be erased - done
                          Edges are not connected in CLoop (96877) for CFace (96876)
                          Loop 0 of CFace (96876) is an invalid outer loop
                          Entity CFace (96876) should be erased - done
                          Edges are not connected in CLoop (96962) for CFace (96961)
                          Loop 0 of CFace (96961) is an invalid outer loop
                          Entity CFace (96961) should be erased - done
                          Edges are not connected in CLoop (97351) for CFace (97350)
                          Loop 0 of CFace (97350) is an invalid outer loop
                          Entity CFace (97350) should be erased - done
                          Edges are not connected in CLoop (97362) for CFace (97361)
                          Loop 0 of CFace (97361) is an invalid outer loop
                          Entity CFace (97361) should be erased - done
                          Edges are not connected in CLoop (97503) for CFace (97502)
                          Loop 0 of CFace (97502) is an invalid outer loop
                          Entity CFace (97502) should be erased - done
                          Edges are not connected in CLoop (97769) for CFace (97768)
                          Loop 0 of CFace (97768) is an invalid outer loop
                          Entity CFace (97768) should be erased - done
                          Edges are not connected in CLoop (100248) for CFace (100247)
                          Loop 0 of CFace (100247) is an invalid outer loop
                          Entity CFace (100247) should be erased - done
                          Edges are not connected in CLoop (100400) for CFace (100399)
                          Loop 0 of CFace (100399) is an invalid outer loop
                          Entity CFace (100399) should be erased - done
                          Edges are not connected in CLoop (100601) for CFace (100600)
                          Loop 0 of CFace (100600) is an invalid outer loop
                          Entity CFace (100600) should be erased - done
                          Edges are not connected in CLoop (100818) for CFace (100817)
                          Loop 0 of CFace (100817) is an invalid outer loop
                          Entity CFace (100817) should be erased - done
                          Edges are not connected in CLoop (100970) for CFace (100969)
                          Loop 0 of CFace (100969) is an invalid outer loop
                          Entity CFace (100969) should be erased - done
                          Edges are not connected in CLoop (101151) for CFace (101150)
                          Loop 0 of CFace (101150) is an invalid outer loop
                          Entity CFace (101150) should be erased - done
                          Edges are not connected in CLoop (101265) for CFace (101264)
                          Loop 0 of CFace (101264) is an invalid outer loop
                          Entity CFace (101264) should be erased - done
                          Edges are not connected in CLoop (101352) for CFace (101351)
                          Loop 0 of CFace (101351) is an invalid outer loop
                          Entity CFace (101351) should be erased - done
                          Edges are not connected in CLoop (101455) for CFace (101454)
                          Loop 0 of CFace (101454) is an invalid outer loop
                          Entity CFace (101454) should be erased - done
                          Edges are not connected in CLoop (101873) for CFace (101872)
                          Loop 0 of CFace (101872) is an invalid outer loop
                          Entity CFace (101872) should be erased - done
                          Edges are not connected in CLoop (101987) for CFace (101986)
                          Loop 0 of CFace (101986) is an invalid outer loop
                          Entity CFace (101986) should be erased - done
                          Edges are not connected in CLoop (101998) for CFace (101997)
                          Loop 0 of CFace (101997) is an invalid outer loop
                          Entity CFace (101997) should be erased - done
                          Edges are not connected in CLoop (102262) for CFace (102261)
                          Loop 0 of CFace (102261) is an invalid outer loop
                          Entity CFace (102261) should be erased - done
                          Edges are not connected in CLoop (97883) for CFace (97882)
                          Loop 0 of CFace (97882) is an invalid outer loop
                          Entity CFace (97882) should be erased - done
                          Edges are not connected in CLoop (97932) for CFace (97931)
                          Loop 0 of CFace (97931) is an invalid outer loop
                          Entity CFace (97931) should be erased - done
                          Edges are not connected in CLoop (98263) for CFace (98262)
                          Loop 0 of CFace (98262) is an invalid outer loop
                          Entity CFace (98262) should be erased - done
                          Edges are not connected in CLoop (98415) for CFace (98414)
                          Loop 0 of CFace (98414) is an invalid outer loop
                          Entity CFace (98414) should be erased - done
                          Edges are not connected in CLoop (98645) for CFace (98644)
                          Loop 0 of CFace (98644) is an invalid outer loop
                          Entity CFace (98644) should be erased - done
                          Edges are not connected in CLoop (98748) for CFace (98747)
                          Loop 0 of CFace (98747) is an invalid outer loop
                          Entity CFace (98747) should be erased - done
                          Edges are not connected in CLoop (98938) for CFace (98937)
                          Loop 0 of CFace (98937) is an invalid outer loop
                          Entity CFace (98937) should be erased - done
                          Edges are not connected in CLoop (99166) for CFace (99165)
                          Loop 0 of CFace (99165) is an invalid outer loop
                          Entity CFace (99165) should be erased - done
                          Edges are not connected in CLoop (99253) for CFace (99252)
                          Loop 0 of CFace (99252) is an invalid outer loop
                          Entity CFace (99252) should be erased - done
                          Edges are not connected in CLoop (99365) for CFace (99364)
                          Loop 0 of CFace (99364) is an invalid outer loop
                          Entity CFace (99364) should be erased - done
                          Edges are not connected in CLoop (99441) for CFace (99440)
                          Loop 0 of CFace (99440) is an invalid outer loop
                          Entity CFace (99440) should be erased - done
                          Edges are not connected in CLoop (99707) for CFace (99706)
                          Loop 0 of CFace (99706) is an invalid outer loop
                          Entity CFace (99706) should be erased - done
                          Edges are not connected in CLoop (99935) for CFace (99934)
                          Loop 0 of CFace (99934) is an invalid outer loop
                          Entity CFace (99934) should be erased - done
                          Edges are not connected in CLoop (99946) for CFace (99945)
                          Loop 0 of CFace (99945) is an invalid outer loop
                          Entity CFace (99945) should be erased - done
                          Edges are not connected in CLoop (102376) for CFace (102375)
                          Loop 0 of CFace (102375) is an invalid outer loop
                          Entity CFace (102375) should be erased - done
                          Edges are not connected in CLoop (102566) for CFace (102565)
                          Loop 0 of CFace (102565) is an invalid outer loop
                          Entity CFace (102565) should be erased - done
                          Edges are not connected in CLoop (102805) for CFace (102804)
                          Loop 0 of CFace (102804) is an invalid outer loop
                          Entity CFace (102804) should be erased - done
                          Edges are not connected in CLoop (102984) for CFace (102983)
                          Loop 0 of CFace (102983) is an invalid outer loop
                          Entity CFace (102983) should be erased - done
                          Edges are not connected in CLoop (103136) for CFace (103135)
                          Loop 0 of CFace (103135) is an invalid outer loop
                          Entity CFace (103135) should be erased - done
                          Edges are not connected in CLoop (103326) for CFace (103325)
                          Loop 0 of CFace (103325) is an invalid outer loop
                          Entity CFace (103325) should be erased - done
                          Edges are not connected in CLoop (103440) for CFace (103439)
                          Loop 0 of CFace (103439) is an invalid outer loop
                          Entity CFace (103439) should be erased - done
                          Edges are not connected in CLoop (103527) for CFace (103526)
                          Loop 0 of CFace (103526) is an invalid outer loop
                          Entity CFace (103526) should be erased - done
                          Edges are not connected in CLoop (103630) for CFace (103629)
                          Loop 0 of CFace (103629) is an invalid outer loop
                          Entity CFace (103629) should be erased - done
                          Edges are not connected in CLoop (104095) for CFace (104094)
                          Loop 0 of CFace (104094) is an invalid outer loop
                          Entity CFace (104094) should be erased - done
                          Edges are not connected in CLoop (104209) for CFace (104208)
                          Loop 0 of CFace (104208) is an invalid outer loop
                          Entity CFace (104208) should be erased - done
                          Edges are not connected in CLoop (104220) for CFace (104219)
                          Loop 0 of CFace (104219) is an invalid outer loop
                          Entity CFace (104219) should be erased - done
                          Edges are not connected in CLoop (104446) for CFace (104445)
                          Loop 0 of CFace (104445) is an invalid outer loop
                          Entity CFace (104445) should be erased - done
                          Edges are not connected in CLoop (104560) for CFace (104559)
                          Loop 0 of CFace (104559) is an invalid outer loop
                          Entity CFace (104559) should be erased - done
                          Edges are not connected in CLoop (104712) for CFace (104711)
                          Loop 0 of CFace (104711) is an invalid outer loop
                          Entity CFace (104711) should be erased - done
                          Edges are not connected in CLoop (104989) for CFace (104988)
                          Loop 0 of CFace (104988) is an invalid outer loop
                          Entity CFace (104988) should be erased - done
                          Edges are not connected in CLoop (105253) for CFace (105252)
                          Loop 0 of CFace (105252) is an invalid outer loop
                          Entity CFace (105252) should be erased - done
                          Edges are not connected in CLoop (105367) for CFace (105366)
                          Loop 0 of CFace (105366) is an invalid outer loop
                          Entity CFace (105366) should be erased - done
                          Edges are not connected in CLoop (105548) for CFace (105547)
                          Loop 0 of CFace (105547) is an invalid outer loop
                          Entity CFace (105547) should be erased - done
                          Edges are not connected in CLoop (105662) for CFace (105661)
                          Loop 0 of CFace (105661) is an invalid outer loop
                          Entity CFace (105661) should be erased - done
                          Edges are not connected in CLoop (105711) for CFace (105710)
                          Loop 0 of CFace (105710) is an invalid outer loop
                          Entity CFace (105710) should be erased - done
                          Edges are not connected in CLoop (105852) for CFace (105851)
                          Loop 0 of CFace (105851) is an invalid outer loop
                          Entity CFace (105851) should be erased - done
                          Edges are not connected in CLoop (106308) for CFace (106307)
                          Loop 0 of CFace (106307) is an invalid outer loop
                          Entity CFace (106307) should be erased - done
                          Edges are not connected in CLoop (106460) for CFace (106459)
                          Loop 0 of CFace (106459) is an invalid outer loop
                          Entity CFace (106459) should be erased - done
                          Edges are not connected in CLoop (106471) for CFace (106470)
                          Loop 0 of CFace (106470) is an invalid outer loop
                          Entity CFace (106470) should be erased - done
                          Edges are not connected in CLoop (106659) for CFace (106658)
                          Loop 0 of CFace (106658) is an invalid outer loop
                          Entity CFace (106658) should be erased - done
                          Edges are not connected in CLoop (106773) for CFace (106772)
                          Loop 0 of CFace (106772) is an invalid outer loop
                          Entity CFace (106772) should be erased - done
                          Edges are not connected in CLoop (111516) for CFace (111515)
                          Loop 0 of CFace (111515) is an invalid outer loop
                          Entity CFace (111515) should be erased - done
                          Edges are not connected in CLoop (111771) for CFace (111770)
                          Loop 0 of CFace (111770) is an invalid outer loop
                          Entity CFace (111770) should be erased - done
                          Edges are not connected in CLoop (111885) for CFace (111884)
                          Loop 0 of CFace (111884) is an invalid outer loop
                          Entity CFace (111884) should be erased - done
                          Edges are not connected in CLoop (111990) for CFace (111989)
                          Loop 0 of CFace (111989) is an invalid outer loop
                          Entity CFace (111989) should be erased - done
                          Edges are not connected in CLoop (112115) for CFace (112114)
                          Loop 0 of CFace (112114) is an invalid outer loop
                          Entity CFace (112114) should be erased - done
                          Edges are not connected in CLoop (112408) for CFace (112407)
                          Loop 0 of CFace (112407) is an invalid outer loop
                          Entity CFace (112407) should be erased - done
                          Edges are not connected in CLoop (112750) for CFace (112749)
                          Loop 0 of CFace (112749) is an invalid outer loop
                          Entity CFace (112749) should be erased - done
                          Edges are not connected in CLoop (112902) for CFace (112901)
                          Loop 0 of CFace (112901) is an invalid outer loop
                          Entity CFace (112901) should be erased - done
                          Edges are not connected in CLoop (112913) for CFace (112912)
                          Loop 0 of CFace (112912) is an invalid outer loop
                          Entity CFace (112912) should be erased - done
                          Edges are not connected in CLoop (113092) for CFace (113091)
                          Loop 0 of CFace (113091) is an invalid outer loop
                          Entity CFace (113091) should be erased - done
                          Edges are not connected in CLoop (113434) for CFace (113433)
                          Loop 0 of CFace (113433) is an invalid outer loop
                          Entity CFace (113433) should be erased - done
                          Edges are not connected in CLoop (113559) for CFace (113558)
                          Loop 0 of CFace (113558) is an invalid outer loop
                          Entity CFace (113558) should be erased - done
                          Edges are not connected in CLoop (113814) for CFace (113813)
                          Loop 0 of CFace (113813) is an invalid outer loop
                          Entity CFace (113813) should be erased - done
                          Edges are not connected in CLoop (113928) for CFace (113927)
                          Loop 0 of CFace (113927) is an invalid outer loop
                          Entity CFace (113927) should be erased - done
                          Edges are not connected in CLoop (114080) for CFace (114079)
                          Loop 0 of CFace (114079) is an invalid outer loop
                          Entity CFace (114079) should be erased - done
                          Edges are not connected in CLoop (114281) for CFace (114280)
                          Loop 0 of CFace (114280) is an invalid outer loop
                          Entity CFace (114280) should be erased - done
                          Edges are not connected in CLoop (114460) for CFace (114459)
                          Loop 0 of CFace (114459) is an invalid outer loop
                          Entity CFace (114459) should be erased - done
                          Edges are not connected in CLoop (114869) for CFace (114868)
                          Loop 0 of CFace (114868) is an invalid outer loop
                          Entity CFace (114868) should be erased - done
                          Edges are not connected in CLoop (114945) for CFace (114944)
                          Loop 0 of CFace (114944) is an invalid outer loop
                          Entity CFace (114944) should be erased - done
                          Edges are not connected in CLoop (114956) for CFace (114955)
                          Loop 0 of CFace (114955) is an invalid outer loop
                          Entity CFace (114955) should be erased - done
                          Edges are not connected in CLoop (115135) for CFace (115134)
                          Loop 0 of CFace (115134) is an invalid outer loop
                          Entity CFace (115134) should be erased - done
                          Edges are not connected in CLoop (115439) for CFace (115438)
                          Loop 0 of CFace (115438) is an invalid outer loop
                          Entity CFace (115438) should be erased - done
                          Edges are not connected in CLoop (115526) for CFace (115525)
                          Loop 0 of CFace (115525) is an invalid outer loop
                          Entity CFace (115525) should be erased - done
                          Edges are not connected in CLoop (115772) for CFace (115771)
                          Loop 0 of CFace (115771) is an invalid outer loop
                          Entity CFace (115771) should be erased - done
                          Edges are not connected in CLoop (115886) for CFace (115885)
                          Loop 0 of CFace (115885) is an invalid outer loop
                          Entity CFace (115885) should be erased - done
                          Edges are not connected in CLoop (116085) for CFace (116084)
                          Loop 0 of CFace (116084) is an invalid outer loop
                          Entity CFace (116084) should be erased - done
                          Edges are not connected in CLoop (116248) for CFace (116247)
                          Loop 0 of CFace (116247) is an invalid outer loop
                          Entity CFace (116247) should be erased - done
                          Edges are not connected in CLoop (116427) for CFace (116426)
                          Loop 0 of CFace (116426) is an invalid outer loop
                          Entity CFace (116426) should be erased - done
                          Edges are not connected in CLoop (116740) for CFace (116739)
                          Loop 0 of CFace (116739) is an invalid outer loop
                          Entity CFace (116739) should be erased - done
                          Edges are not connected in CLoop (116845) for CFace (116844)
                          Loop 0 of CFace (116844) is an invalid outer loop
                          Entity CFace (116844) should be erased - done
                          Edges are not connected in CLoop (116856) for CFace (116855)
                          Loop 0 of CFace (116855) is an invalid outer loop
                          Entity CFace (116855) should be erased - done
                          Edges are not connected in CLoop (117035) for CFace (117034)
                          Loop 0 of CFace (117034) is an invalid outer loop
                          Entity CFace (117034) should be erased - done
                          Edges are not connected in CLoop (117339) for CFace (117338)
                          Loop 0 of CFace (117338) is an invalid outer loop
                          Entity CFace (117338) should be erased - done
                          Edges are not connected in CLoop (117464) for CFace (117463)
                          Loop 0 of CFace (117463) is an invalid outer loop
                          Entity CFace (117463) should be erased - done
                          Edges are not connected in CLoop (117719) for CFace (117718)
                          Loop 0 of CFace (117718) is an invalid outer loop
                          Entity CFace (117718) should be erased - done
                          Edges are not connected in CLoop (117956) for CFace (117955)
                          Loop 0 of CFace (117955) is an invalid outer loop
                          Entity CFace (117955) should be erased - done
                          Edges are not connected in CLoop (118110) for CFace (118109)
                          Loop 0 of CFace (118109) is an invalid outer loop
                          Entity CFace (118109) should be erased - done
                          Edges are not connected in CLoop (118327) for CFace (118326)
                          Loop 0 of CFace (118326) is an invalid outer loop
                          Entity CFace (118326) should be erased - done
                          Edges are not connected in CLoop (118631) for CFace (118630)
                          Loop 0 of CFace (118630) is an invalid outer loop
                          Entity CFace (118630) should be erased - done
                          Edges are not connected in CLoop (118718) for CFace (118717)
                          Loop 0 of CFace (118717) is an invalid outer loop
                          Entity CFace (118717) should be erased - done
                          Edges are not connected in CLoop (118897) for CFace (118896)
                          Loop 0 of CFace (118896) is an invalid outer loop
                          Entity CFace (118896) should be erased - done
                          Edges are not connected in CLoop (119201) for CFace (119200)
                          Loop 0 of CFace (119200) is an invalid outer loop
                          Entity CFace (119200) should be erased - done
                          Edges are not connected in CLoop (119326) for CFace (119325)
                          Loop 0 of CFace (119325) is an invalid outer loop
                          Entity CFace (119325) should be erased - done
                          Edges are not connected in CLoop (119543) for CFace (119542)
                          Loop 0 of CFace (119542) is an invalid outer loop
                          Entity CFace (119542) should be erased - done
                          Edges are not connected in CLoop (119800) for CFace (119799)
                          Loop 0 of CFace (119799) is an invalid outer loop
                          Entity CFace (119799) should be erased - done
                          Edges are not connected in CLoop (120104) for CFace (120103)
                          Loop 0 of CFace (120103) is an invalid outer loop
                          Entity CFace (120103) should be erased - done
                          Edges are not connected in CLoop (120446) for CFace (120445)
                          Loop 0 of CFace (120445) is an invalid outer loop
                          Entity CFace (120445) should be erased - done
                          Edges are not connected in CLoop (120636) for CFace (120635)
                          Loop 0 of CFace (120635) is an invalid outer loop
                          Entity CFace (120635) should be erased - done
                          Edges are not connected in CLoop (120817) for CFace (120816)
                          Loop 0 of CFace (120816) is an invalid outer loop
                          Entity CFace (120816) should be erased - done
                          Edges are not connected in CLoop (121007) for CFace (121006)
                          Loop 0 of CFace (121006) is an invalid outer loop
                          Entity CFace (121006) should be erased - done
                          Edges are not connected in CLoop (121311) for CFace (121310)
                          Loop 0 of CFace (121310) is an invalid outer loop
                          Entity CFace (121310) should be erased - done
                          Edges are not connected in CLoop (121501) for CFace (121500)
                          Loop 0 of CFace (121500) is an invalid outer loop
                          Entity CFace (121500) should be erased - done
                          Edges are not connected in CLoop (121843) for CFace (121842)
                          Loop 0 of CFace (121842) is an invalid outer loop
                          Entity CFace (121842) should be erased - done
                          Edges are not connected in CLoop (122261) for CFace (122260)
                          Loop 0 of CFace (122260) is an invalid outer loop
                          Entity CFace (122260) should be erased - done
                          Edges are not connected in CLoop (122299) for CFace (122298)
                          Loop 0 of CFace (122298) is an invalid outer loop
                          Entity CFace (122298) should be erased - done
                          Edges are not connected in CLoop (122413) for CFace (122412)
                          Loop 0 of CFace (122412) is an invalid outer loop
                          Entity CFace (122412) should be erased - done
                          Edges are not connected in CLoop (122755) for CFace (122754)
                          Loop 0 of CFace (122754) is an invalid outer loop
                          Entity CFace (122754) should be erased - done
                          Edges are not connected in CLoop (123164) for CFace (123163)
                          Loop 0 of CFace (123163) is an invalid outer loop
                          Entity CFace (123163) should be erased - done
                          Edges are not connected in CLoop (123202) for CFace (123201)
                          Loop 0 of CFace (123201) is an invalid outer loop
                          Entity CFace (123201) should be erased - done
                          Edges are not connected in CLoop (123316) for CFace (123315)
                          Loop 0 of CFace (123315) is an invalid outer loop
                          Entity CFace (123315) should be erased - done
                          Edges are not connected in CLoop (123365) for CFace (123364)
                          Loop 0 of CFace (123364) is an invalid outer loop
                          Entity CFace (123364) should be erased - done
                          Edges are not connected in CLoop (123696) for CFace (123695)
                          Loop 0 of CFace (123695) is an invalid outer loop
                          Entity CFace (123695) should be erased - done
                          Edges are not connected in CLoop (124038) for CFace (124037)
                          Loop 0 of CFace (124037) is an invalid outer loop
                          Entity CFace (124037) should be erased - done
                          Edges are not connected in CLoop (124076) for CFace (124075)
                          Loop 0 of CFace (124075) is an invalid outer loop
                          Entity CFace (124075) should be erased - done
                          Edges are not connected in CLoop (124228) for CFace (124227)
                          Loop 0 of CFace (124227) is an invalid outer loop
                          Entity CFace (124227) should be erased - done
                          Edges are not connected in CLoop (124570) for CFace (124569)
                          Loop 0 of CFace (124569) is an invalid outer loop
                          Entity CFace (124569) should be erased - done
                          Edges are not connected in CLoop (124657) for CFace (124656)
                          Loop 0 of CFace (124656) is an invalid outer loop
                          Entity CFace (124656) should be erased - done
                          Edges are not connected in CLoop (124988) for CFace (124987)
                          Loop 0 of CFace (124987) is an invalid outer loop
                          Entity CFace (124987) should be erased - done
                          Edges are not connected in CLoop (125026) for CFace (125025)
                          Loop 0 of CFace (125025) is an invalid outer loop
                          Entity CFace (125025) should be erased - done
                          Edges are not connected in CLoop (125140) for CFace (125139)
                          Loop 0 of CFace (125139) is an invalid outer loop
                          Entity CFace (125139) should be erased - done
                          Edges are not connected in CLoop (125265) for CFace (125264)
                          Loop 0 of CFace (125264) is an invalid outer loop
                          Entity CFace (125264) should be erased - done
                          Edges are not connected in CLoop (125558) for CFace (125557)
                          Loop 0 of CFace (125557) is an invalid outer loop
                          Entity CFace (125557) should be erased - done
                          Edges are not connected in CLoop (125938) for CFace (125937)
                          Loop 0 of CFace (125937) is an invalid outer loop
                          Entity CFace (125937) should be erased - done
                          Edges are not connected in CLoop (125949) for CFace (125948)
                          Loop 0 of CFace (125948) is an invalid outer loop
                          Entity CFace (125948) should be erased - done
                          Edges are not connected in CLoop (126014) for CFace (126013)
                          Loop 0 of CFace (126013) is an invalid outer loop
                          Entity CFace (126013) should be erased - done
                          Edges are not connected in CLoop (126059) for CFace (126058)
                          Loop 0 of CFace (126058) is an invalid outer loop
                          Entity CFace (126058) should be erased - done
                          Edges are not connected in CLoop (126173) for CFace (126172)
                          Loop 0 of CFace (126172) is an invalid outer loop
                          Entity CFace (126172) should be erased - done
                          Edges are not connected in CLoop (126553) for CFace (126552)
                          Loop 0 of CFace (126552) is an invalid outer loop
                          Entity CFace (126552) should be erased - done
                          Edges are not connected in CLoop (126602) for CFace (126601)
                          Loop 0 of CFace (126601) is an invalid outer loop
                          Entity CFace (126601) should be erased - done
                          Edges are not connected in CLoop (126895) for CFace (126894)
                          Loop 0 of CFace (126894) is an invalid outer loop
                          Entity CFace (126894) should be erased - done
                          Edges are not connected in CLoop (126933) for CFace (126932)
                          Loop 0 of CFace (126932) is an invalid outer loop
                          Entity CFace (126932) should be erased - done
                          Edges are not connected in CLoop (127014) for CFace (127013)
                          Loop 0 of CFace (127013) is an invalid outer loop
                          Entity CFace (127013) should be erased - done
                          Edges are not connected in CLoop (127128) for CFace (127127)
                          Loop 0 of CFace (127127) is an invalid outer loop
                          Entity CFace (127127) should be erased - done
                          Edges are not connected in CLoop (127215) for CFace (127214)
                          Loop 0 of CFace (127214) is an invalid outer loop
                          Entity CFace (127214) should be erased - done
                          Edges are not connected in CLoop (127575) for CFace (127574)
                          Loop 0 of CFace (127574) is an invalid outer loop
                          Entity CFace (127574) should be erased - done
                          Edges are not connected in CLoop (127908) for CFace (127907)
                          Loop 0 of CFace (127907) is an invalid outer loop
                          Entity CFace (127907) should be erased - done
                          Edges are not connected in CLoop (127919) for CFace (127918)
                          Loop 0 of CFace (127918) is an invalid outer loop
                          Entity CFace (127918) should be erased - done
                          Edges are not connected in CLoop (127984) for CFace (127983)
                          Loop 0 of CFace (127983) is an invalid outer loop
                          Entity CFace (127983) should be erased - done
                          Edges are not connected in CLoop (128029) for CFace (128028)
                          Loop 0 of CFace (128028) is an invalid outer loop
                          Entity CFace (128028) should be erased - done
                          Edges are not connected in CLoop (128143) for CFace (128142)
                          Loop 0 of CFace (128142) is an invalid outer loop
                          Entity CFace (128142) should be erased - done
                          Edges are not connected in CLoop (128476) for CFace (128475)
                          Loop 0 of CFace (128475) is an invalid outer loop
                          Entity CFace (128475) should be erased - done
                          Edges are not connected in CLoop (128525) for CFace (128524)
                          Loop 0 of CFace (128524) is an invalid outer loop
                          Entity CFace (128524) should be erased - done
                          Edges are not connected in CLoop (128847) for CFace (128846)
                          Loop 0 of CFace (128846) is an invalid outer loop
                          Entity CFace (128846) should be erased - done
                          Edges are not connected in CLoop (128890) for CFace (128889)
                          Loop 0 of CFace (128889) is an invalid outer loop
                          Entity CFace (128889) should be erased - done
                          Edges are not connected in CLoop (129004) for CFace (129003)
                          Loop 0 of CFace (129003) is an invalid outer loop
                          Entity CFace (129003) should be erased - done
                          Edges are not connected in CLoop (129071) for CFace (129070)
                          Loop 0 of CFace (129070) is an invalid outer loop
                          Entity CFace (129070) should be erased - done
                          Edges are not connected in CLoop (129178) for CFace (129177)
                          Loop 0 of CFace (129177) is an invalid outer loop
                          Entity CFace (129177) should be erased - done
                          Edges are not connected in CLoop (129277) for CFace (129276)
                          Loop 0 of CFace (129276) is an invalid outer loop
                          Entity CFace (129276) should be erased - done
                          Edges are not connected in CLoop (129489) for CFace (129488)
                          Loop 0 of CFace (129488) is an invalid outer loop
                          Entity CFace (129488) should be erased - done
                          Edges are not connected in CLoop (129735) for CFace (129734)
                          Loop 0 of CFace (129734) is an invalid outer loop
                          Entity CFace (129734) should be erased - done
                          Edges are not connected in CLoop (129743) for CFace (129742)
                          Loop 0 of CFace (129742) is an invalid outer loop
                          Entity CFace (129742) should be erased - done
                          Edges are not connected in CLoop (129880) for CFace (129879)
                          Loop 0 of CFace (129879) is an invalid outer loop
                          Entity CFace (129879) should be erased - done
                          Edges are not connected in CLoop (129989) for CFace (129988)
                          Loop 0 of CFace (129988) is an invalid outer loop
                          Entity CFace (129988) should be erased - done
                          Edges are not connected in CLoop (130005) for CFace (130004)
                          Loop 0 of CFace (130004) is an invalid outer loop
                          Entity CFace (130004) should be erased - done
                          Edges are not connected in CLoop (130021) for CFace (130020)
                          Loop 0 of CFace (130020) is an invalid outer loop
                          Entity CFace (130020) should be erased - done
                          Edges are not connected in CLoop (130034) for CFace (130033)
                          Loop 0 of CFace (130033) is an invalid outer loop
                          Entity CFace (130033) should be erased - done
                          Edges are not connected in CLoop (130114) for CFace (130113)
                          Loop 0 of CFace (130113) is an invalid outer loop
                          Entity CFace (130113) should be erased - done
                          Edges are not connected in CLoop (130130) for CFace (130129)
                          Loop 0 of CFace (130129) is an invalid outer loop
                          Entity CFace (130129) should be erased - done
                          Edges are not connected in CLoop (130146) for CFace (130145)
                          Loop 0 of CFace (130145) is an invalid outer loop
                          Entity CFace (130145) should be erased - done
                          Edges are not connected in CLoop (130159) for CFace (130158)
                          Loop 0 of CFace (130158) is an invalid outer loop
                          Entity CFace (130158) should be erased - done
                          Edges are not connected in CLoop (130239) for CFace (130238)
                          Loop 0 of CFace (130238) is an invalid outer loop
                          Entity CFace (130238) should be erased - done
                          Edges are not connected in CLoop (130255) for CFace (130254)
                          Loop 0 of CFace (130254) is an invalid outer loop
                          Entity CFace (130254) should be erased - done
                          Edges are not connected in CLoop (130271) for CFace (130270)
                          Loop 0 of CFace (130270) is an invalid outer loop
                          Entity CFace (130270) should be erased - done
                          Edges are not connected in CLoop (130284) for CFace (130283)
                          Loop 0 of CFace (130283) is an invalid outer loop
                          Entity CFace (130283) should be erased - done
                          Edges are not connected in CLoop (130364) for CFace (130363)
                          Loop 0 of CFace (130363) is an invalid outer loop
                          Entity CFace (130363) should be erased - done
                          Edges are not connected in CLoop (130380) for CFace (130379)
                          Loop 0 of CFace (130379) is an invalid outer loop
                          Entity CFace (130379) should be erased - done
                          Edges are not connected in CLoop (130396) for CFace (130395)
                          Loop 0 of CFace (130395) is an invalid outer loop
                          Entity CFace (130395) should be erased - done
                          Edges are not connected in CLoop (130409) for CFace (130408)
                          Loop 0 of CFace (130408) is an invalid outer loop
                          Entity CFace (130408) should be erased - done
                          Edges are not connected in CLoop (130489) for CFace (130488)
                          Loop 0 of CFace (130488) is an invalid outer loop
                          Entity CFace (130488) should be erased - done
                          Edges are not connected in CLoop (130505) for CFace (130504)
                          Loop 0 of CFace (130504) is an invalid outer loop
                          Entity CFace (130504) should be erased - done
                          Edges are not connected in CLoop (130521) for CFace (130520)
                          Loop 0 of CFace (130520) is an invalid outer loop
                          Entity CFace (130520) should be erased - done
                          Edges are not connected in CLoop (130534) for CFace (130533)
                          Loop 0 of CFace (130533) is an invalid outer loop
                          Entity CFace (130533) should be erased - done
                          Edges are not connected in CLoop (130614) for CFace (130613)
                          Loop 0 of CFace (130613) is an invalid outer loop
                          Entity CFace (130613) should be erased - done
                          Edges are not connected in CLoop (130630) for CFace (130629)
                          Loop 0 of CFace (130629) is an invalid outer loop
                          Entity CFace (130629) should be erased - done
                          Edges are not connected in CLoop (130646) for CFace (130645)
                          Loop 0 of CFace (130645) is an invalid outer loop
                          Entity CFace (130645) should be erased - done
                          Edges are not connected in CLoop (130659) for CFace (130658)
                          Loop 0 of CFace (130658) is an invalid outer loop
                          Entity CFace (130658) should be erased - done
                          Edges are not connected in CLoop (130739) for CFace (130738)
                          Loop 0 of CFace (130738) is an invalid outer loop
                          Entity CFace (130738) should be erased - done
                          Edges are not connected in CLoop (130755) for CFace (130754)
                          Loop 0 of CFace (130754) is an invalid outer loop
                          Entity CFace (130754) should be erased - done
                          Edges are not connected in CLoop (130771) for CFace (130770)
                          Loop 0 of CFace (130770) is an invalid outer loop
                          Entity CFace (130770) should be erased - done
                          Edges are not connected in CLoop (130784) for CFace (130783)
                          Loop 0 of CFace (130783) is an invalid outer loop
                          Entity CFace (130783) should be erased - done
                          Edges are not connected in CLoop (130864) for CFace (130863)
                          Loop 0 of CFace (130863) is an invalid outer loop
                          Entity CFace (130863) should be erased - done
                          Edges are not connected in CLoop (130880) for CFace (130879)
                          Loop 0 of CFace (130879) is an invalid outer loop
                          Entity CFace (130879) should be erased - done
                          Edges are not connected in CLoop (130896) for CFace (130895)
                          Loop 0 of CFace (130895) is an invalid outer loop
                          Entity CFace (130895) should be erased - done
                          Edges are not connected in CLoop (130909) for CFace (130908)
                          Loop 0 of CFace (130908) is an invalid outer loop
                          Entity CFace (130908) should be erased - done
                          Edges are not connected in CLoop (130989) for CFace (130988)
                          Loop 0 of CFace (130988) is an invalid outer loop
                          Entity CFace (130988) should be erased - done
                          Edges are not connected in CLoop (131005) for CFace (131004)
                          Loop 0 of CFace (131004) is an invalid outer loop
                          Entity CFace (131004) should be erased - done
                          Edges are not connected in CLoop (131021) for CFace (131020)
                          Loop 0 of CFace (131020) is an invalid outer loop
                          Entity CFace (131020) should be erased - done
                          Edges are not connected in CLoop (131034) for CFace (131033)
                          Loop 0 of CFace (131033) is an invalid outer loop
                          Entity CFace (131033) should be erased - done
                          Edges are not connected in CLoop (131114) for CFace (131113)
                          Loop 0 of CFace (131113) is an invalid outer loop
                          Entity CFace (131113) should be erased - done
                          Edges are not connected in CLoop (131130) for CFace (131129)
                          Loop 0 of CFace (131129) is an invalid outer loop
                          Entity CFace (131129) should be erased - done
                          Edges are not connected in CLoop (131146) for CFace (131145)
                          Loop 0 of CFace (131145) is an invalid outer loop
                          Entity CFace (131145) should be erased - done
                          Edges are not connected in CLoop (131159) for CFace (131158)
                          Loop 0 of CFace (131158) is an invalid outer loop
                          Entity CFace (131158) should be erased - done
                          Edges are not connected in CLoop (131239) for CFace (131238)
                          Loop 0 of CFace (131238) is an invalid outer loop
                          Entity CFace (131238) should be erased - done
                          Edges are not connected in CLoop (131255) for CFace (131254)
                          Loop 0 of CFace (131254) is an invalid outer loop
                          Entity CFace (131254) should be erased - done
                          Edges are not connected in CLoop (131271) for CFace (131270)
                          Loop 0 of CFace (131270) is an invalid outer loop
                          Entity CFace (131270) should be erased - done
                          Edges are not connected in CLoop (131284) for CFace (131283)
                          Loop 0 of CFace (131283) is an invalid outer loop
                          Entity CFace (131283) should be erased - done
                          Edges are not connected in CLoop (131364) for CFace (131363)
                          Loop 0 of CFace (131363) is an invalid outer loop
                          Entity CFace (131363) should be erased - done
                          Edges are not connected in CLoop (131380) for CFace (131379)
                          Loop 0 of CFace (131379) is an invalid outer loop
                          Entity CFace (131379) should be erased - done
                          Edges are not connected in CLoop (131396) for CFace (131395)
                          Loop 0 of CFace (131395) is an invalid outer loop
                          Entity CFace (131395) should be erased - done
                          Edges are not connected in CLoop (131409) for CFace (131408)
                          Loop 0 of CFace (131408) is an invalid outer loop
                          Entity CFace (131408) should be erased - done
                          Edges are not connected in CLoop (131489) for CFace (131488)
                          Loop 0 of CFace (131488) is an invalid outer loop
                          Entity CFace (131488) should be erased - done
                          Edges are not connected in CLoop (131505) for CFace (131504)
                          Loop 0 of CFace (131504) is an invalid outer loop
                          Entity CFace (131504) should be erased - done
                          Edges are not connected in CLoop (131521) for CFace (131520)
                          Loop 0 of CFace (131520) is an invalid outer loop
                          Entity CFace (131520) should be erased - done
                          Edges are not connected in CLoop (131534) for CFace (131533)
                          Loop 0 of CFace (131533) is an invalid outer loop
                          Entity CFace (131533) should be erased - done
                          Edges are not connected in CLoop (131614) for CFace (131613)
                          Loop 0 of CFace (131613) is an invalid outer loop
                          Entity CFace (131613) should be erased - done
                          Edges are not connected in CLoop (131630) for CFace (131629)
                          Loop 0 of CFace (131629) is an invalid outer loop
                          Entity CFace (131629) should be erased - done
                          Edges are not connected in CLoop (131646) for CFace (131645)
                          Loop 0 of CFace (131645) is an invalid outer loop
                          Entity CFace (131645) should be erased - done
                          Edges are not connected in CLoop (131659) for CFace (131658)
                          Loop 0 of CFace (131658) is an invalid outer loop
                          Entity CFace (131658) should be erased - done
                          Edges are not connected in CLoop (131739) for CFace (131738)
                          Loop 0 of CFace (131738) is an invalid outer loop
                          Entity CFace (131738) should be erased - done
                          Edges are not connected in CLoop (131755) for CFace (131754)
                          Loop 0 of CFace (131754) is an invalid outer loop
                          Entity CFace (131754) should be erased - done
                          Edges are not connected in CLoop (131771) for CFace (131770)
                          Loop 0 of CFace (131770) is an invalid outer loop
                          Entity CFace (131770) should be erased - done
                          Edges are not connected in CLoop (131784) for CFace (131783)
                          Loop 0 of CFace (131783) is an invalid outer loop
                          Entity CFace (131783) should be erased - done
                          Edges are not connected in CLoop (131864) for CFace (131863)
                          Loop 0 of CFace (131863) is an invalid outer loop
                          Entity CFace (131863) should be erased - done
                          Edges are not connected in CLoop (131880) for CFace (131879)
                          Loop 0 of CFace (131879) is an invalid outer loop
                          Entity CFace (131879) should be erased - done
                          Edges are not connected in CLoop (131896) for CFace (131895)
                          Loop 0 of CFace (131895) is an invalid outer loop
                          Entity CFace (131895) should be erased - done
                          Edges are not connected in CLoop (131909) for CFace (131908)
                          Loop 0 of CFace (131908) is an invalid outer loop
                          Entity CFace (131908) should be erased - done
                          Daniel S
                            This suggests somethings are so small they appear to be coincident - to SUp - and 'fail'... ❓
                            • ken28875K Offline
                              ken28875
                              I used that plugin everyday and I love it. However, it crashes Sketchup a lot. Whenever I use the round corner, Sketchup seems to freeze then shuts down. It happens maybe 70% of the time. 😢
                              Does anyone have the same problem?
                              Thanks,
                              _KN
                              Follow Your Dreams.
                                I have never had that problem [Vista].
                                How big are these 'chamfers' etc when it fails - is it a minimum size thing ?
                                • ken28875K Offline
                                  ken28875
                                  Hi TIG,
                                  It's only 40cm.
                                  http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/round_corner_crash.jpg
                                  Thanks,
                                  _KN
                                  Follow Your Dreams.
                                    Unlikely to result in faces <1mm ?
                                      I have also had a couple of crashes but definitely not 70%. In fact, other plugins can also cause crashes (especially when I do not "notice" how big task I want to feed the plugin with) so at least I am used to saving before I run anything (except of course at the most crucial moments 😄 )
                                      • ken28875K Offline
                                        ken28875
                                        What do you mean, TIG?
                                        Thanks,
                                        _KN
                                        Follow Your Dreams.
                                        • brookefoxB Offline
                                          brookefox
                                          My first use of this wonderful tool leads me to make a newb suggestion and ask a newb question.
                                          S: It would be nice to have persistent settings for each of the three round types independently as, for instance, I generally want beveled edges unsmoothed but the others likely not.
                                          Q: With a surface whose edges have been beveled and unsmoothed and which appears flat and untextured, what causes the slightly modeled appearance (slight shading effects not visible elsewhere)?
                                          ~ Brooke
                                          • 11
                                          • 12
                                          • 13
                                          • 73
                                          • 74
                                          • 11 / 74
                                          11 / 74
