    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
      Mouais
      as in the video I select the cylinder -> right click -> UV map tool -> cylindrical...
        agamemnus
        • V Offline
          viewrick
          Awesome! Using your rb with Lithunwrap (free). Lithunwrap is pretty easy to use and I'll have to agree with some of the other posts about UV tools being difficult to use and not user friendly, but this one is.
          Your UVtool helped me big time modeling some furniture with texture UV requirements.
          Thanks,
          Rick
            REGIS
            Hi Whaat
            I'm trying your plugin now and it seems to works fine on mac.
            Cheetah3D doesn't deal with mtl file it only opens the obj and only export obj file without mtl file
            Blender 2.52 doesn't open the obj file.
            Perhaps I've got to try an UVmapping app.
            Hope it can help you
            cheers
              REGIS
              LOL, I think I can do something with your plugin and Cheetah3D, I've got try a little bit more
              Thanks Whaat
              • EarthMoverE Offline
                EarthMover
                Here's a quick screen capture I made of using Whaat's plugin to demonstrate going from SU to Max (2009) for UV. It's a bit tricky as there are a lot of options in the .obj exporter that make the re-import not work properly. I've found the best preset to use in the Max .obj exporter is the one for Bryce with the default settings. This seems to be the only one that gives consistent success which I believe is due to the scale adjustment applied in that preset. I've had a couple people ask me privately so I figured I'd make a quick video - http://www.screencast.com/t/NWM0YzRiNTU
                Content Creator at Skapeup
                  Thiago Luz
                  THANKSSS my friend!
                  • charly2008C Offline
                    charly2008
                    Hi Dale,
                    Many thanks for this tool, a great tool!
                    But I would like to place the files in my own Project folder. Is there a way to change the memory location?
                    Karlheinz
                    • TIGT Online
                      @charly2008 said:
                      Hi Dale,
                      Karlheinz
                      ###get the default path to write the OBJ to
                      def self.get_obj_path
                      obj_name="su_uv_bridge.obj"
                      on_mac=(Object;;RUBY_PLATFORM =~ /mswin/i) ? false ; ((Object;;RUBY_PLATFORM =~ /darwin/i) ? true ; ;other)
                      if on_mac
                      	path=File.join(ENV['HOME'],"Library","Application Support","UVTools")
                      else
                      	path=File.join(ENV['APPDATA'],"UVTools")
                      Dir.mkdir(path) unless FileTest.exist?(path)
                      return File.join(path,obj_name)
                      Is the code near the end that sets the 'path' to the folder where the stuff is saved... find this code and change it to suit your desires...
                      So on a PC path=File.join(ENV['APPDATA'],"UVTools") could become
                      path="C:/MyFolder1/MyFolder2/etc/etc" or whatever..............
                        charly2008
                        Hi TIG,
                        thanks for your help. I changed according to your example. Works perfectly.
                        Karlheinz
                          Analdin
                          Hi!
                          I've got a problem with UV Tools:
                          I want to create a palm (~400 tris), i export it, uvmap it, re-import it and it works. Now, i only make one leaf model, uvmap it and then i go lik copy/paste. BUT: Sketchup or UV Tools are messing up some of the faces (not visible inside sketchup, but once i look at it in LithUnwrap or Unreal Development Kit, its messed up.)
                          Does anyone know how to fix that?
                          BTW: I'm using the newest version of Sketchup 7.
                            CoreMaster
                            Hey... 😄
                            I have a problem with exporting my my model. I export it like sayd and then i open it in somekinda other program to make UV but my model is messed up.. and that only happens to .obj files... why? how do i fix it? help!
                            • W Offline
                              Whaat
                              @coremaster said:
                              Hey... 😄
                              Hi, what program are you using to import the OBJ? Maybe try another program or adjust the OBJ import settings on your program. Some screenshots would help explain the issue, or you could post the SKP model that you are trying to export.
                              • W Offline
                                Whaat
                                @analdin said:
                                Hi!
                                That's a strange issue. I really don't know what the problem would be. I need to spend some time testing UV mapped models that are copy/pasted. Can anyone else confirm this issue?
                                  charly2008
                                  i have a problem. I tried to export a Texture from a simple rectangle face. The message appears but nothing is exported. My folder is empty. I followed strictly the work instructions.
                                  Now i made a further test and selected a face from SANG and it worked.
                                  What could be wrong?
                                  • W Offline
                                    Whaat
                                    @charly2008 said:
                                    Not sure....any error messages in the Ruby Console when you try to export the rectangle face?
                                    • CoreMaster110C Offline
                                      CoreMaster110
                                      @whaat said:
                                      @coremaster said:
                                      Hey... 😄
                                      Well ok the problem is that .obj exporter in sketchup but i got it fixed by exporting my model first into .3ds and then open in another program to export it into .obj file.
                                      but now i have new problem when i import my model back in sketchup useing this plugin it tells me that 174 faces failed and nothing is imported.
                                        Khai
                                        @xefhs said:
                                        Whaat, Can you update your plugin for Sketchup 7, please? 😛
                                        it works on 7 😉
                                          It works for SU7, the reason it says 'Updated for SU6' is because it previously only worked with SU7
                                          As mentioned here
                                          • X Offline
                                            xefhs
                                            Whaat, Can you update your plugin for Sketchup 7, please? 😕
                                            Sorry for this short message but I don't speak english very well... 😐
                                            • 3 / 10
