    How to use Ruby API
    28 Posts 5 Posters 3.5k Views 5 Watching
      @chris fullmer said:
      module names always must start with a capital letter. methods do not start with a cap. Classes start with a cap. That is the basic rule. Constants are variables that start with a capital letter, and should remain constant - like Pi.
      Normal convention is to type constants in all caps.
        Sorry for the confusion 😳 - I didn't realise there was an enclosing module / class. They need initial CAPITAL letter; whereas defs and variables need lowercase. Consonants ion caps e.g. ORIGIN...
        • honoluludesktopH
          honoluludesktop
          OK I am stuck again. Problem is with the last box of code below:
          This is the main proc, methods below are at the bottom of the code in this section:
          model = Sketchup.active_model
          entities = model.active_entities
          selection = model.selection
          if model.selection.empty?
          else
            entities = model.selection
          entities.each do |e|
            if e.is_a? Sketchup;;ComponentInstance
              the_name=e.definition.name
              stuff=e.definition.entities
              counter=0
              faces=[]
              stuff.each do |e|
                if e.is_a? Sketchup;;Face
                  counter=counter+1
                  faces.push e
                end ###if
              end ###loop
              points=[]
              add_face_vert_to_file(faces,points)
              make_comp_face_file(the_name,faces,counter,model,points)
            end ###if
          end ###loop
          Method to make a collection of face.vertices
          ###make vertices file of faces in component
          def add_face_vert_to_file(faces,points)
            faces.each do |e|
              points.push e.vertices
            end ###end loop
          Method to make empty text file, then (where I fail) to take the face.vertices and copy them as string to the text file.
          ###create file ComponentName.txt
          def make_comp_face_file(the_name,faces,counter,model,points)
            the_line=the_name+" ",counter," faces"
            UI.messagebox(the_line)
            model_filename = File.basename(model.path)
            path=File.dirname(model.path)+"\\"
            out_name=the_name+".txt"
            out_path=path+out_name
            $mesh_file=File.new(out_path,"w")
            #HERE is problem code. How do I take the collection
            #of face.vertices and copy as strings to the text file.
            points.each do |e|
              $mesh_file.puts(e.x.to_s)
              $mesh_file.puts(e.y.to_s)
              $mesh_file.puts(e.z.to_s)
            end ###loop
          Am writing with the Web Console, and having some problems. Saving seems to drop characters, and the indents are gone. Any ideas?
            points.each do |e|
            end ###loop
            Adds x/y/z into file on separate lines...
            to test if it's at least getting the points values use plain puts so it appears in the console
            points.each do |e|
                puts(e.x.to_s)
                puts(e.y.to_s)
                puts(e.z.to_s)
            end ###loop
            To write an xyz line use
            points.each do |e|
                $mesh_file.puts(e.x.to_s+","+e.y.to_s+","+e.z.to_s)
            end ###loop
            Does
            actually make the file ?
            You need to open the file for writing AND then close it after you are done writing to it.
            $mesh_file.close
            perhaps it's still open and so a second [separate] attempt to write to it fails...
            • Chris FullmerC
              Oh yeah! I rarely intialize them. Thanks Thom,
              • honoluludesktopH
                honoluludesktop
                TIG, Just got up, and finished reading at your post. Thanks I think I understand, and have a lot to work with.
                Made a 0 byte file that I can see in "My Computer". I assumed it was open, guess it wasn't:-). Looks like a lot of stuff to work on later today. Good advice about using "puts" to check output. I use the messagebox a lot but that is slow.
                puts(e.x.to_s) prints Sketchup::Vertex:0xea24668 ?-(, Crossed this bridge once before, but don't recall how to get output as a number.
                • Chris FullmerC
                  puts(e.x.to_s) should return a numerical "x" position if e is a Point3d object. if e is a vertex, it should return an error. If e is a vertex, you can do e.position.x and that will return the x position of the vertex.
                  That sounded confusing to me. A few more lines of your code and I could give a slightly more complete example.
                  Great job so far!
                  • honoluludesktopH
                    honoluludesktop
                    "oops: - I" πŸ™‚ A little slow this morning, didn't get it until now. Thanks guys, lets see how far I can get with what I have before I, OOPS:-(, need help getting off the floor. Might not take too long.
                    Tig, I can now open, write to, and close files:-)
                    Chris above here is where I stumbled on the code.
                    It occurred to me that a "method", a "function" in other languages (I missed this one), was in my day know as a "procedure", having evolved from a "[C}all". Before this I did a Basic "sub routine", itself born out of "jump xxxx:xxxx, where xxxx:xxxx began a set of instruction that ended in "return". Before "Buddha" it was all 1111's and 0000's πŸ™‚
                    • honoluludesktopH
                      honoluludesktop
                      Help! How do I get a number that repersents the location of a face vertices? The following is setup for Web Console. When I output to UI.messagebox(e.vertices), I get:
                      #Sketchup::Vertex:0xfc83800#Sketchup::Vertex:0xfc837e8#Sketchup::Vertex:0xfc837d0
                      The main proc is at the bottom, and the methods are above it.
                      ### Test is selection made
                      else
                      def make_comp_face_file(the_name,faces,counter,model)
                      ###make vertices collection of faces in component
                      def add_face_vertices_collect(faces,points)
                        faces.each do |e|
                          points.push e.outer_loop
                        end ### loop
                      ###make 3dpoint from vertex HELP HERE!!!! I think
                      def print_vertices_collect(points)
                        points.each do |e|
                          UI.messagebox(e.vertices)       ###puts to test will be
                          ###$points_file.puts(e.vertices)###put here when works
                      ###Get su;;component collection
                          faces=[]
                          counter=0
                          ###Locate faces in each component and make faces collection
                          stuff.each do |e|
                      	  counter=counter+1
                      	  faces.push e
                      	end ###if
                          end ###loop
                          make_comp_face_file(the_name,faces,counter,model)####Have to
                          points=[]
                          add_face_vertices_collect(faces,points)          ####nest these
                          print_vertices_collect(points)                   ####later
                          $points_file.close
                        end ###if
                      end ###loop
                        Jim
                        The Vertex entity has a position.
                        point = vertex.position
                        The position will be relative to parent container, and not relative the SketchUp axes.
                          ### points>>>vertices
                          vertices.each do |vertex|
                            $points_file.puts(vertex.vertices.point.to_a)
                            ### FILE of VERTICES POINTS AS AN ARRAY ONE PER LINE...
                          • honoluludesktopH
                            honoluludesktop
                            Hi guys, Thanks for your help. I stumbled on e.vertices.x.position after starting over. Now how do I read the SU Ruby API to make this easier to understand?-(
                            entities = model.entities
                            else
                            		ci_name=e.definition.name
                            		#UI.messagebox(ci_name)
                            		ci_collection=e.definition.entities
                            		#UI.messagebox(ci_collection)
                            		ci_collection.each do |e|
                            			ci_faces_collection=[]
                            				ci_faces_collection.push e
                            				ci_faces_collection.each do |e|
                            					faces_vertices_collection=[]
                            					if e.vertices
                            						faces_vertices_collection.push e
                            						puts(e.vertices.x.position)
                              Edges, Loops, Curves, Faces, etc have vertices and those vertices have a position vertices.position (i.e. a point)
                              points have x/y/z values vertices.position.x
                              DON'T muddle them up! ❗
                              • honoluludesktopH
                                honoluludesktop
                                OK, so how do I get the coordinate values for each vertex on each face.vertices? I think I understand vertex.position, and face.vertices, but how do I get a collection of vertex for each vertices.
                                Can't be impossible, can it?
                                • Chris FullmerC
                                  look at the Face.vertices here:
                                  Error 404 (Not Found)!!1
                                  (code.google.com)
                                  it says what it returns - an array of vertx objects. So to get positions for all those vertices, you need to loop through that array. Something like this:
                                  ` vert_array = my_face.vertices
                                  position_array = []
                                  x_position_array = []
                                  vert_array.each do |v|
                                  position_array << v.position
                                  x_position_array << v.position.x
                                  end`
                                    That is not logical ❗
                                    If you have run vertices=face.vertices you already have a collection [i.e. an array] of the face's vertices !
                                    If you then look at each of them you can get their positions as another array,
                                    e.g. positions=[]; vertices.each{|v|positions<< v.position}
                                    Now you can look at each 'position' in that array (i.e. it's a point) and get the x/y/z values etc
                                    positions.each{|p|puts p.x;puts p.y;puts p.z}
                                    You seem to making this more complicated than it needs to be...
                                    • honoluludesktopH
                                      honoluludesktop
                                      AGH!!!, Thats what happens when you don't really know what you are doing. I think I got it, again:-) puts(face_pts.position.to_a) almost at the bottom. Basically, I took a "vertices", got tne number of points by "vertices.length", then extracted each "vertex" by "This_number=vertices[0 to (length-1)]". The following runs in Web Console.
                                      else
                                      def open_comp_inst_file(comp_inst_name,model)
                                      	comp_inst_file_name=File.basename(model.path)
                                      	out_name=comp_inst_name+".txt"
                                      	$dxf_ci_file=File.open(out_path,"w")
                                      		puts("Component")
                                      		comp_inst_name=e.definition.name
                                      		comp_inst_collection=e.definition.entities
                                      		#open text file for output
                                      		#open_comp_inst_file(comp_inst_name,model)
                                      		comp_inst_collection.each do |e|
                                      			comp_inst_faces_collection=[]
                                      				#make collection of faces
                                      				comp_inst_faces_collection.push e
                                      				comp_inst_faces_collection.each do |e|
                                      						if e.vertices
                                      							#vertice collection
                                      							vertices_collection.push e.vertices
                                      							vertices_collection.each do |e|
                                      								no_vert=e.length
                                      								cnt_vert=no_vert
                                      								puts("Vertices")
                                      								no_vert.times do
                                      									face_pts=(e[no_vert-cnt_vert])
                                      									cnt_vert=cnt_vert-1
                                      									puts("Vertex")
                                      				end #loop
                                      			end #if
                                      		end #loop
                                      		#close text file
                                      		#$dxf_ci_file.close
                                      Here is some sample output:
                                      %(#408000)[Start Component
                                      Starts Vertices
                                      Start Vertex
                                      69.6952995222671
                                      5.52489094225734
                                      0.0
                                      Start Vertex
                                      26.421563780178
                                      0.0
                                      0.0
                                      Start Vertex
                                      0.0
                                      34.7137089981752
                                      0.0
                                      Start Vertex
                                      16.8521719619112
                                      74.9523089386077
                                      0.0
                                      Looks OK?
                                        Jim
                                        Well, what are you doing? Try to make a precise statement of the purpose of the routine. In
                                        English first, then Ruby.
                                        This prints a summary of faces and vertices in the Definitions.
                                            else
                                            instance_count = 0
                                                    instance_count += 1
                                                    puts("Component; #{instance_count} #{e.definition.name}")
                                                    face_count = 0
                                                    e.definition.entities.each do |e|
                                                            face_count += 1
                                                            puts "  face; #{face_count}"
                                                            vertex_count = 0
                                                            e.vertices.each do |v|
        vertex_count += 1
        puts "    vertex #{vertex_count} id;#{v.object_id}  pos;#{v.position}"
                                        Note since some faces share vertices, and all vertices are listed, some vertives will be duplicated.
                                        Component; 2 Component#2
                                          face; 1
                                            vertex 1 id;48589944  pos;(2.160711", 1.853015", 0")
                                            vertex 2 id;48589932  pos;(0", 1.853015", 0")
                                            vertex 3 id;48589920  pos;(0", 1.853015", 2.160338")
                                            vertex 4 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                          face; 2
                                            vertex 2 id;48589692  pos;(2.160711", 0", 0")
                                            vertex 3 id;48589680  pos;(0", 0", 0")
                                            vertex 4 id;48589932  pos;(0", 1.853015", 0")
                                          face; 3
                                            vertex 1 id;48589680  pos;(0", 0", 0")
                                            vertex 3 id;48589464  pos;(2.160711", 0", 2.160338")
                                            vertex 4 id;48589452  pos;(0", 0", 2.160338")
                                          face; 4
                                            vertex 1 id;48589932  pos;(0", 1.853015", 0")
                                            vertex 2 id;48589680  pos;(0", 0", 0")
                                            vertex 3 id;48589452  pos;(0", 0", 2.160338")
                                            vertex 4 id;48589920  pos;(0", 1.853015", 2.160338")
                                          face; 5
                                            vertex 1 id;48589464  pos;(2.160711", 0", 2.160338")
                                            vertex 2 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                          face; 6
                                            vertex 1 id;48589692  pos;(2.160711", 0", 0")
                                            vertex 2 id;48589944  pos;(2.160711", 1.853015", 0")
                                            vertex 3 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                            vertex 4 id;48589464  pos;(2.160711", 0", 2.160338")
                                        • honoluludesktopH
                                          honoluludesktop
                                          WOW! very compact, and fast, I will take a hard look at your code, and learn from it. Lets see how far I can get before having to post for help πŸ™‚
                                          Addenda: Well, I did have redundant code, and really need to learn how to format output. Would have never figured out Puts "#{e.position.x.to_f}" by myself.
                                          • honoluludesktopH
                                            honoluludesktop
                                            Darn, I finished coding only to discover the "putdxf" I use for my CAD import has a bug that fails to locate multiple blocks correctly. I confirmed this by being unable to "putdxf" with the system's "getdxf". Will have to rewrite as a "command line" script. Thanks for everything, sorry I couldn't understand much of what you tried to explain to me. But, because of your help, I will get better in time πŸ™‚
