    How to use Ruby API
    28 Posts 5 Posters 3.0k Views 5 Watching
      ### points>>>vertices
      vertices.each do |vertex|
        $points_file.puts(vertex.vertices.point.to_a)
        ### FILE of VERTICES POINTS AS AN ARRAY ONE PER LINE...
      • honoluludesktopH
        honoluludesktop
        Hi guys, Thanks for your help. I stumbled on e.vertices.x.position after starting over. Now how do I read the SU Ruby API to make this easier to understand?-(
        model = Sketchup.active_model
        entities = model.entities
        selection = model.selection
        if model.selection.empty?
        	entities = model.active_entities
        else
        	entities = model.selection
        entities.each do |e|
        	if e.is_a? Sketchup;;ComponentInstance
        		ci_name=e.definition.name
        		#UI.messagebox(ci_name)
        		ci_collection=e.definition.entities
        		#UI.messagebox(ci_collection)
        		ci_collection.each do |e|
        			ci_faces_collection=[]
        			if e.is_a? Sketchup;;Face
        				ci_faces_collection.push e
        				ci_faces_collection.each do |e|
        					faces_vertices_collection=[]
        					if e.vertices
        						faces_vertices_collection.push e
        						puts(e.vertices.x.position)
          Edges, Loops, Curves, Faces, etc have vertices and those vertices have a position vertices.position (i.e. a point)
          points have x/y/z values vertices.position.x
          DON'T muddle them up! ❗
          • honoluludesktopH
            honoluludesktop
            OK, so how do I get the coordinate values for each vertex on each face.vertices? I think I understand vertex.position, and face.vertices, but how do I get a collection of vertex for each vertices.
            Can't be impossible, can it?
            • Chris FullmerC
              look at the Face.vertices here:
              Error 404 (Not Found)!!1
              (code.google.com)
              it says what it returns - an array of vertx objects. So to get positions for all those vertices, you need to loop through that array. Something like this:
              ` vert_array = my_face.vertices
              position_array = []
              x_position_array = []
              vert_array.each do |v|
              position_array << v.position
              x_position_array << v.position.x
              end`
                That is not logical ❗
                If you have run vertices=face.vertices you already have a collection [i.e. an array] of the face's vertices !
                If you then look at each of them you can get their positions as another array,
                e.g. positions=[]; vertices.each{|v|positions<< v.position}
                Now you can look at each 'position' in that array (i.e. it's a point) and get the x/y/z values etc
                positions.each{|p|puts p.x;puts p.y;puts p.z}
                You seem to making this more complicated than it needs to be...
                • honoluludesktopH
                  honoluludesktop
                  AGH!!!, Thats what happens when you don't really know what you are doing. I think I got it, again:-) puts(face_pts.position.to_a) almost at the bottom. Basically, I took a "vertices", got tne number of points by "vertices.length", then extracted each "vertex" by "This_number=vertices[0 to (length-1)]". The following runs in Web Console.
                  else
                  def open_comp_inst_file(comp_inst_name,model)
                  	comp_inst_file_name=File.basename(model.path)
                  	path=File.dirname(model.path)+"\\"
                  	out_name=comp_inst_name+".txt"
                  	out_path=path+out_name
                  	$dxf_ci_file=File.open(out_path,"w")
                  		puts("Component")
                  		comp_inst_name=e.definition.name
                  		comp_inst_collection=e.definition.entities
                  		#open text file for output
                  		#open_comp_inst_file(comp_inst_name,model)
                  		comp_inst_collection.each do |e|
                  			comp_inst_faces_collection=[]
                  				#make collection of faces
                  				comp_inst_faces_collection.push e
                  				comp_inst_faces_collection.each do |e|
                  						if e.vertices
                  							#vertice collection
                  							vertices_collection.push e.vertices
                  							vertices_collection.each do |e|
                  								no_vert=e.length
                  								cnt_vert=no_vert
                  								puts("Vertices")
                  								no_vert.times do
                  									face_pts=(e[no_vert-cnt_vert])
                  									cnt_vert=cnt_vert-1
                  									puts("Vertex")
                  				end #loop
                  			end #if
                  		end #loop
                  		#close text file
                  		#$dxf_ci_file.close
                  Here is some sample output:
                  %(#408000)[Start Component
                  Starts Vertices
                  Start Vertex
                  69.6952995222671
                  5.52489094225734
                  0.0
                  Start Vertex
                  26.421563780178
                  0.0
                  0.0
                  Start Vertex
                  0.0
                  34.7137089981752
                  0.0
                  Start Vertex
                  16.8521719619112
                  74.9523089386077
                  0.0
                  Looks OK?
                    Jim
                    Well, what are you doing? Try to make a precise statement of the purpose of the routine. In
                    English first, then Ruby.
                    This prints a summary of faces and vertices in the Definitions.
                        else
                        instance_count = 0
                                instance_count += 1
                                puts("Component; #{instance_count} #{e.definition.name}")
                                face_count = 0
                                e.definition.entities.each do |e|
                                        face_count += 1
                                        puts "  face; #{face_count}"
                                        vertex_count = 0
                                        e.vertices.each do |v|
                                            vertex_count += 1
                                            puts "    vertex #{vertex_count} id;#{v.object_id}  pos;#{v.position}"
                    Note since some faces share vertices, and all vertices are listed, some vertives will be duplicated.
                    Component; 2 Component#2
                      face; 1
                        vertex 1 id;48589944  pos;(2.160711", 1.853015", 0")
                        vertex 2 id;48589932  pos;(0", 1.853015", 0")
                        vertex 3 id;48589920  pos;(0", 1.853015", 2.160338")
                        vertex 4 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                      face; 2
                        vertex 2 id;48589692  pos;(2.160711", 0", 0")
                        vertex 3 id;48589680  pos;(0", 0", 0")
                        vertex 4 id;48589932  pos;(0", 1.853015", 0")
                      face; 3
                        vertex 1 id;48589680  pos;(0", 0", 0")
                        vertex 3 id;48589464  pos;(2.160711", 0", 2.160338")
                        vertex 4 id;48589452  pos;(0", 0", 2.160338")
                      face; 4
                        vertex 1 id;48589932  pos;(0", 1.853015", 0")
                        vertex 2 id;48589680  pos;(0", 0", 0")
                        vertex 3 id;48589452  pos;(0", 0", 2.160338")
                        vertex 4 id;48589920  pos;(0", 1.853015", 2.160338")
                      face; 5
                        vertex 1 id;48589464  pos;(2.160711", 0", 2.160338")
                        vertex 2 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                      face; 6
                        vertex 1 id;48589692  pos;(2.160711", 0", 0")
                        vertex 2 id;48589944  pos;(2.160711", 1.853015", 0")
                        vertex 3 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                        vertex 4 id;48589464  pos;(2.160711", 0", 2.160338")
                    • honoluludesktopH
                      honoluludesktop
                      WOW! very compact, and fast, I will take a hard look at your code, and learn from it. Lets see how far I can get before having to post for help 🙂
                      Addenda: Well, I did have redundant code, and really need to learn how to format output. Would have never figured out Puts "#{e.position.x.to_f}" by myself.
                      • honoluludesktopH
                        honoluludesktop
                        Darn, I finished coding only to discover the "putdxf" I use for my CAD import has a bug that fails to locate multiple blocks correctly. I confirmed this by being unable to "putdxf" with the system's "getdxf". Will have to rewrite as a "command line" script. Thanks for everything, sorry I couldn't understand much of what you tried to explain to me. But, because of your help, I will get better in time 🙂
                        • 2 / 2
