    How to use Ruby API
    28 Posts 5 Posters 2.7k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      OK, so now all I have to do is search the new collection for faces? Lets see if I can figure that out:-)
        This makes a 'list' called faces of all of the faces inside the group...
        faces=[]
        ### *** note how the list must be defined outside of the {...} block
        group.entities.each{|e|faces<<e if e.class==Sketchup;;Face}
        This approach can be adjusted to suit any type of 'entities' list and any type of 'class' of thing you want to extract from it - faces, edges, cpoints, clines, text...
        Then of course you can loop through you faces for say a particular material (or any other property)...
        red_faces=[] ### ***
        faces.each{|f|red_faces<<f if f.material.name=="Red"}
        red_faces now contains all of the group's faces that are "Red" etc etc...
        PS: Note that the .entities method returns all of the entities associated with the specified object - i.e. model/group/definition... There is another list of entities: model.active_entities that applies to the current set of entities available in the present edit session - this could equivalent ot the model.entities or if you are editing a group or component-definition the available entities within that - e.g. group.entities...
          honoluludesktop
          OK, I put:
             if e.is_a? Sketchup;;ComponentInstance
                 name=e.definition.name#e.typename
                 faces=e.definition.entities
                 WMY_putdxf.get_faces(name,faces)
          And:
          def WMY_putdxf.get_faces(name,faces)# procedure or method
             faces.each do |e|
               info = e.typename
               if e.is_a? Sketchup;;Face
                 UI.messagebox(name+"; "+info)
               end #endif
             end #end do
          end #end method
          So, you declare a array=[], but a collection (something like an array) makes itself?
          OK, how do I make a collection of the geometric imformation inside each face so that I can access it later? Wild guess to start below:
             faces.each do |e| #why do we use e; can I use f?
               info = e.typename
                  facegeo=e.something #get face geo collection goes here?
               end #endif
             end #end do
          end #end method
            @honoluludesktop said:
            OK, I put:
            I USE CAPITALS FOR EASE OF READING ONLY !!!
            >        name=e.definition.name#e.typename### NAME IS THE 'NAME' - LIKE 'BED' TYPENAME IS THE CLASS/KIND_OF ETC
            >        faces=e.definition.entities### THERE WILL BE MORE THAN FACES IN ENTITIES - AT LEAST EDGES TO FORM THE FACES
            >        WMY_putdxf.get_faces(name,faces)### IF YOU WANT TO PASS THE DEFINITION THEN PASS E.DEFINITION NOT ITS 'NAME'
            >        ### REMEMBER THAT 'FACES' IS 'ENTITIES' THAT WILL INCLUDE FACES BUT NOT JUST FACES ALONE...
            >    end
            And:
            > ### START DEF WITH lowercase LETTERS !!! wmy_putdxf etc
            > ### THIS GETS YOU NOTHING EXCEPT A MESSAGE LISTING THE DEF'S NAME AND EACH FACE IN TURN...
            >    faces.each do |e|
            >      info = e.typename
            >      end #endif
            >    end #end do
            > end #end method
            AN ARRAY FACES=[] IS A LIST
              ### REMEMBER THE lowercase LETTERS TA THE START
            >    faces.each do |e| #why do we use e; can I use f? ### CAN USE ANY VARIBALE 'E' IS OFTEN USED FOR 'EntitY'
            >      info = e.typename
            >      end #endif
            >    end #end do
            > end #end method
            HERE IS MY GET FACE VERSION...
            if object.class==Sketchup;;ComponentInstance
              faces=[]
              object.definition.entities.each{|entity|
                faces<< entity if entity.class==Sketchup;;Face
              ### now do stuff to these faces...
            end#if
            Done with sub-defs or anything... Tests if the object is an Instance and if so make an Array [list] of its Definition's Entities' Faces to process...
              honoluludesktop
              Thanks guys. Will work on this later tonight after I get home. About the lowercase, if the def is inside a module, will it make a difference?
              This runs ok on my system:
              require 'sketchup.rb'
              module WMY_putdxf
                def WMY_putdxf.main
                  model = Sketchup.active_model # make db of active model
              	entities = model.active_entities
                  selection = model.selection # make db of selections
                 if model.selection.empty?
                 else
                    entities = model.selection
               	# test if selection made
                  entities.each do |e| # do loop through database and place entities in type array
              			#comp_file_name=e.definition.name
                end # .main method
              	faces.each do |e|
              	   info = e.typename
              	   end #ednif
              	end #end do
              end # WMY_putdxf module
              #----------------menu------------------
              if !file_loaded?(__FILE__) #_FILE_  permits renaming the file
                UI.menu("Plugins").add_item("Yet Another Test") { WMY_putdxf.main }
              file_loaded(__FILE__)
              But with WMY_ as wmy_ this error message:
              Error Loading File yet_another_script.rb
              C:/PROGRA~1/Google/GO2494~1/Plugins/yet_another_script.rb:3: class/module name must be CONSTANT
              Sorry for the uneven indenting, when I copy from notepad++ and paste, the indent spacing changes.
              • Chris FullmerC Offline
                module names always must start with a capital letter. methods do not start with a cap. Classes start with a cap. That is the basic rule. Constants are variables that start with a capital letter, and should remain constant - like Pi.
                  Normal convention is to type constants in all caps.
                    Sorry for the confusion 😳 - I didn't realise there was an enclosing module / class. They need initial CAPITAL letter; whereas defs and variables need lowercase. Consonants ion caps e.g. ORIGIN...
                      honoluludesktop
                      OK I am stuck again. Problem is with the last box of code below:
                      This is the main proc, methods below are at the bottom of the code in this section:
                      else
                          the_name=e.definition.name
                          stuff=e.definition.entities
                          counter=0
                          faces=[]
                          stuff.each do |e|
                              counter=counter+1
                              faces.push e
                            end ###if
                          end ###loop
                          points=[]
                          add_face_vert_to_file(faces,points)
                          make_comp_face_file(the_name,faces,counter,model,points)
                        end ###if
                      end ###loop
                      Method to make a collection of face.vertices
                      ###make vertices file of faces in component
                      def add_face_vert_to_file(faces,points)
                        faces.each do |e|
                          points.push e.vertices
                        end ###end loop
                      Method to make empty text file, then (where I fail) to take the face.vertices and copy them as string to the text file.
                      ###create file ComponentName.txt
                      def make_comp_face_file(the_name,faces,counter,model,points)
                        the_line=the_name+" ",counter," faces"
                        UI.messagebox(the_line)
                        model_filename = File.basename(model.path)
                        path=File.dirname(model.path)+"\\"
                        out_name=the_name+".txt"
                        out_path=path+out_name
                        $mesh_file=File.new(out_path,"w")
                        #HERE is problem code. How do I take the collection
                        #of face.vertices and copy as strings to the text file.
                        points.each do |e|
                          $mesh_file.puts(e.x.to_s)
                          $mesh_file.puts(e.y.to_s)
                          $mesh_file.puts(e.z.to_s)
                        end ###loop
                      Am writing with the Web Console, and having some problems. Saving seems to drop characters, and the indents are gone. Any ideas?
                        points.each do |e|
                        end ###loop
                        Adds x/y/z into file on separate lines...
                        to test if it's at least getting the points values use plain puts so it appears in the console
                        points.each do |e|
                            puts(e.x.to_s)
                            puts(e.y.to_s)
                            puts(e.z.to_s)
                        end ###loop
                        To write an xyz line use
                        points.each do |e|
                            $mesh_file.puts(e.x.to_s+","+e.y.to_s+","+e.z.to_s)
                        end ###loop
                        Does
                        actually make the file ?
                        You need to open the file for writing AND then close it after you are done writing to it.
                        $mesh_file.close
                        perhaps it's still open and so a second [separate] attempt to write to it fails...
                          Oh yeah! I rarely intialize them. Thanks Thom,
                            honoluludesktop
                            TIG, Just got up, and finished reading at your post. Thanks I think I understand, and have a lot to work with.
                            Made a 0 byte file that I can see in "My Computer". I assumed it was open, guess it wasn't:-). Looks like a lot of stuff to work on later today. Good advice about using "puts" to check output. I use the messagebox a lot but that is slow.
                            puts(e.x.to_s) prints Sketchup::Vertex:0xea24668 ?-(, Crossed this bridge once before, but don't recall how to get output as a number.
                              puts(e.x.to_s) should return a numerical "x" position if e is a Point3d object. if e is a vertex, it should return an error. If e is a vertex, you can do e.position.x and that will return the x position of the vertex.
                              That sounded confusing to me. A few more lines of your code and I could give a slightly more complete example.
                              Great job so far!
                                honoluludesktop
                                "oops: - I" πŸ™‚ A little slow this morning, didn't get it until now. Thanks guys, lets see how far I can get with what I have before I, OOPS:-(, need help getting off the floor. Might not take too long.
                                Tig, I can now open, write to, and close files:-)
                                Chris above here is where I stumbled on the code.
                                It occurred to me that a "method", a "function" in other languages (I missed this one), was in my day know as a "procedure", having evolved from a "[C}all". Before this I did a Basic "sub routine", itself born out of "jump xxxx:xxxx, where xxxx:xxxx began a set of instruction that ended in "return". Before "Buddha" it was all 1111's and 0000's πŸ™‚
                                  honoluludesktop
                                  Help! How do I get a number that repersents the location of a face vertices? The following is setup for Web Console. When I output to UI.messagebox(e.vertices), I get:
                                  #Sketchup::Vertex:0xfc83800#Sketchup::Vertex:0xfc837e8#Sketchup::Vertex:0xfc837d0
                                  The main proc is at the bottom, and the methods are above it.
                                  ### Test is selection made
                                  else
                                  def make_comp_face_file(the_name,faces,counter,model)
                                  ###make vertices collection of faces in component
                                  def add_face_vertices_collect(faces,points)
                                    faces.each do |e|
                                      points.push e.outer_loop
                                    end ### loop
                                  ###make 3dpoint from vertex HELP HERE!!!! I think
                                  def print_vertices_collect(points)
                                    points.each do |e|
                                      UI.messagebox(e.vertices)       ###puts to test will be
                                      ###$points_file.puts(e.vertices)###put here when works
                                  ###Get su;;component collection
                                      faces=[]
                                      counter=0
                                      ###Locate faces in each component and make faces collection
                                      stuff.each do |e|
                                  	  counter=counter+1
                                  	  faces.push e
                                  	end ###if
                                      end ###loop
                                      make_comp_face_file(the_name,faces,counter,model)####Have to
                                      points=[]
                                      add_face_vertices_collect(faces,points)          ####nest these
                                      print_vertices_collect(points)                   ####later
                                      $points_file.close
                                    end ###if
                                  end ###loop
                                    Jim
                                    The Vertex entity has a position.
                                    point = vertex.position
                                    The position will be relative to parent container, and not relative the SketchUp axes.
                                      ### points>>>vertices
                                      vertices.each do |vertex|
                                        $points_file.puts(vertex.vertices.point.to_a)
                                        ### FILE of VERTICES POINTS AS AN ARRAY ONE PER LINE...
                                        honoluludesktop
                                        Hi guys, Thanks for your help. I stumbled on e.vertices.x.position after starting over. Now how do I read the SU Ruby API to make this easier to understand?-(
                                        entities = model.entities
                                        else
                                        		ci_name=e.definition.name
                                        		#UI.messagebox(ci_name)
                                        		ci_collection=e.definition.entities
                                        		#UI.messagebox(ci_collection)
                                        		ci_collection.each do |e|
                                        			ci_faces_collection=[]
                                        				ci_faces_collection.push e
                                        				ci_faces_collection.each do |e|
                                        					faces_vertices_collection=[]
                                        					if e.vertices
                                        						faces_vertices_collection.push e
                                        						puts(e.vertices.x.position)
                                          Edges, Loops, Curves, Faces, etc have vertices and those vertices have a position vertices.position (i.e. a point)
                                          points have x/y/z values vertices.position.x
                                          DON'T muddle them up! ❗
                                            honoluludesktop
                                            OK, so how do I get the coordinate values for each vertex on each face.vertices? I think I understand vertex.position, and face.vertices, but how do I get a collection of vertex for each vertices.
                                            Can't be impossible, can it?
