    How to use Ruby API
    28 Posts 5 Posters 3.5k Views 5 Watching
    • honoluludesktopH
      honoluludesktop
      Thanks guys. Will work on this later tonight after I get home. About the lowercase, if the def is inside a module, will it make a difference?
      This runs ok on my system:
      require 'sketchup.rb'
      module WMY_putdxf
        def WMY_putdxf.main
          model = Sketchup.active_model # make db of active model
      	entities = model.active_entities
          selection = model.selection # make db of selections
         if model.selection.empty?
         else
            entities = model.selection
       	# test if selection made
          entities.each do |e| # do loop through database and place entities in type array
      	    if e.is_a? Sketchup;;ComponentInstance
      			#comp_file_name=e.definition.name
      			name=e.definition.name#e.typename
      			faces=e.definition.entities
      			WMY_putdxf.get_faces(name,faces)
        end # .main method
        def WMY_putdxf.get_faces(name,faces)# procedure or method
      	faces.each do |e|
      	   info = e.typename
      	   if e.is_a? Sketchup;;Face
      			UI.messagebox(name+"; "+info)
      	   end #ednif
      	end #end do
      end # WMY_putdxf module
      #----------------menu------------------
      if !file_loaded?(__FILE__) #_FILE_  permits renaming the file
        UI.menu("Plugins").add_item("Yet Another Test") { WMY_putdxf.main }
      file_loaded(__FILE__)
      But with WMY_ as wmy_ this error message:
      Error Loading File yet_another_script.rb
      C:/PROGRA~1/Google/GO2494~1/Plugins/yet_another_script.rb:3: class/module name must be CONSTANT
      Sorry for the uneven indenting, when I copy from notepad++ and paste, the indent spacing changes.
      • Chris FullmerC
        module names always must start with a capital letter. methods do not start with a cap. Classes start with a cap. That is the basic rule. Constants are variables that start with a capital letter, and should remain constant - like Pi.
          Normal convention is to type constants in all caps.
            Sorry for the confusion 😳 - I didn't realise there was an enclosing module / class. They need initial CAPITAL letter; whereas defs and variables need lowercase. Consonants ion caps e.g. ORIGIN...
            • honoluludesktopH
              honoluludesktop
              OK I am stuck again. Problem is with the last box of code below:
              This is the main proc, methods below are at the bottom of the code in this section:
              else
                  the_name=e.definition.name
                  stuff=e.definition.entities
                  counter=0
                  faces=[]
                  stuff.each do |e|
                      counter=counter+1
                      faces.push e
                    end ###if
                  end ###loop
                  points=[]
                  add_face_vert_to_file(faces,points)
                  make_comp_face_file(the_name,faces,counter,model,points)
                end ###if
              end ###loop
              Method to make a collection of face.vertices
              ###make vertices file of faces in component
              def add_face_vert_to_file(faces,points)
                faces.each do |e|
                  points.push e.vertices
                end ###end loop
              Method to make empty text file, then (where I fail) to take the face.vertices and copy them as string to the text file.
              ###create file ComponentName.txt
              def make_comp_face_file(the_name,faces,counter,model,points)
                the_line=the_name+" ",counter," faces"
                UI.messagebox(the_line)
                model_filename = File.basename(model.path)
                path=File.dirname(model.path)+"\\"
                out_name=the_name+".txt"
                out_path=path+out_name
                $mesh_file=File.new(out_path,"w")
                #HERE is problem code. How do I take the collection
                #of face.vertices and copy as strings to the text file.
                points.each do |e|
                  $mesh_file.puts(e.x.to_s)
                  $mesh_file.puts(e.y.to_s)
                  $mesh_file.puts(e.z.to_s)
                end ###loop
              Am writing with the Web Console, and having some problems. Saving seems to drop characters, and the indents are gone. Any ideas?
                points.each do |e|
                end ###loop
                Adds x/y/z into file on separate lines...
                to test if it's at least getting the points values use plain puts so it appears in the console
                points.each do |e|
                    puts(e.x.to_s)
                    puts(e.y.to_s)
                    puts(e.z.to_s)
                end ###loop
                To write an xyz line use
                points.each do |e|
                    $mesh_file.puts(e.x.to_s+","+e.y.to_s+","+e.z.to_s)
                end ###loop
                Does
                actually make the file ?
                You need to open the file for writing AND then close it after you are done writing to it.
                $mesh_file.close
                perhaps it's still open and so a second [separate] attempt to write to it fails...
                • Chris FullmerC
                  Oh yeah! I rarely intialize them. Thanks Thom,
                  • honoluludesktopH
                    honoluludesktop
                    TIG, Just got up, and finished reading at your post. Thanks I think I understand, and have a lot to work with.
                    Made a 0 byte file that I can see in "My Computer". I assumed it was open, guess it wasn't:-). Looks like a lot of stuff to work on later today. Good advice about using "puts" to check output. I use the messagebox a lot but that is slow.
                    puts(e.x.to_s) prints Sketchup::Vertex:0xea24668 ?-(, Crossed this bridge once before, but don't recall how to get output as a number.
                    • Chris FullmerC
                      puts(e.x.to_s) should return a numerical "x" position if e is a Point3d object. if e is a vertex, it should return an error. If e is a vertex, you can do e.position.x and that will return the x position of the vertex.
                      That sounded confusing to me. A few more lines of your code and I could give a slightly more complete example.
                      Great job so far!
                      • honoluludesktopH
                        honoluludesktop
                        "oops: - I" πŸ™‚ A little slow this morning, didn't get it until now. Thanks guys, lets see how far I can get with what I have before I, OOPS:-(, need help getting off the floor. Might not take too long.
                        Tig, I can now open, write to, and close files:-)
                        Chris above here is where I stumbled on the code.
                        It occurred to me that a "method", a "function" in other languages (I missed this one), was in my day know as a "procedure", having evolved from a "[C}all". Before this I did a Basic "sub routine", itself born out of "jump xxxx:xxxx, where xxxx:xxxx began a set of instruction that ended in "return". Before "Buddha" it was all 1111's and 0000's πŸ™‚
                        • honoluludesktopH
                          honoluludesktop
                          Help! How do I get a number that repersents the location of a face vertices? The following is setup for Web Console. When I output to UI.messagebox(e.vertices), I get:
                          #Sketchup::Vertex:0xfc83800#Sketchup::Vertex:0xfc837e8#Sketchup::Vertex:0xfc837d0
                          The main proc is at the bottom, and the methods are above it.
                          ### Test is selection made
                          else
                          def make_comp_face_file(the_name,faces,counter,model)
                          ###make vertices collection of faces in component
                          def add_face_vertices_collect(faces,points)
                            faces.each do |e|
                              points.push e.outer_loop
                            end ### loop
                          ###make 3dpoint from vertex HELP HERE!!!! I think
                          def print_vertices_collect(points)
                            points.each do |e|
                              UI.messagebox(e.vertices)       ###puts to test will be
                              ###$points_file.puts(e.vertices)###put here when works
                          ###Get su;;component collection
                              faces=[]
                              counter=0
                              ###Locate faces in each component and make faces collection
                              stuff.each do |e|
                          	  counter=counter+1
                          	  faces.push e
                          	end ###if
                              end ###loop
                              make_comp_face_file(the_name,faces,counter,model)####Have to
                              points=[]
                              add_face_vertices_collect(faces,points)          ####nest these
                              print_vertices_collect(points)                   ####later
                              $points_file.close
                            end ###if
                          end ###loop
                            Jim
                            The Vertex entity has a position.
                            point = vertex.position
                            The position will be relative to parent container, and not relative the SketchUp axes.
                              ### points>>>vertices
                              vertices.each do |vertex|
                                $points_file.puts(vertex.vertices.point.to_a)
                                ### FILE of VERTICES POINTS AS AN ARRAY ONE PER LINE...
                              • honoluludesktopH
                                honoluludesktop
                                Hi guys, Thanks for your help. I stumbled on e.vertices.x.position after starting over. Now how do I read the SU Ruby API to make this easier to understand?-(
                                entities = model.entities
                                else
                                		ci_name=e.definition.name
                                		#UI.messagebox(ci_name)
                                		ci_collection=e.definition.entities
                                		#UI.messagebox(ci_collection)
                                		ci_collection.each do |e|
                                			ci_faces_collection=[]
                                				ci_faces_collection.push e
                                				ci_faces_collection.each do |e|
                                					faces_vertices_collection=[]
                                					if e.vertices
                                						faces_vertices_collection.push e
                                						puts(e.vertices.x.position)
                                  Edges, Loops, Curves, Faces, etc have vertices and those vertices have a position vertices.position (i.e. a point)
                                  points have x/y/z values vertices.position.x
                                  DON'T muddle them up! ❗
                                  • honoluludesktopH
                                    honoluludesktop
                                    OK, so how do I get the coordinate values for each vertex on each face.vertices? I think I understand vertex.position, and face.vertices, but how do I get a collection of vertex for each vertices.
                                    Can't be impossible, can it?
                                    • Chris FullmerC
                                      look at the Face.vertices here:
                                      Error 404 (Not Found)!!1
                                      (code.google.com)
                                      it says what it returns - an array of vertx objects. So to get positions for all those vertices, you need to loop through that array. Something like this:
                                      ` vert_array = my_face.vertices
                                      position_array = []
                                      x_position_array = []
                                      vert_array.each do |v|
                                      position_array << v.position
                                      x_position_array << v.position.x
                                      end`
                                        That is not logical ❗
                                        If you have run vertices=face.vertices you already have a collection [i.e. an array] of the face's vertices !
                                        If you then look at each of them you can get their positions as another array,
                                        e.g. positions=[]; vertices.each{|v|positions<< v.position}
                                        Now you can look at each 'position' in that array (i.e. it's a point) and get the x/y/z values etc
                                        positions.each{|p|puts p.x;puts p.y;puts p.z}
                                        You seem to making this more complicated than it needs to be...
                                        • honoluludesktopH
                                          honoluludesktop
                                          AGH!!!, Thats what happens when you don't really know what you are doing. I think I got it, again:-) puts(face_pts.position.to_a) almost at the bottom. Basically, I took a "vertices", got tne number of points by "vertices.length", then extracted each "vertex" by "This_number=vertices[0 to (length-1)]". The following runs in Web Console.
                                          else
                                          def open_comp_inst_file(comp_inst_name,model)
                                          	comp_inst_file_name=File.basename(model.path)
                                          	out_name=comp_inst_name+".txt"
                                          	$dxf_ci_file=File.open(out_path,"w")
                                          		puts("Component")
                                          		comp_inst_name=e.definition.name
                                          		comp_inst_collection=e.definition.entities
                                          		#open text file for output
                                          		#open_comp_inst_file(comp_inst_name,model)
                                          		comp_inst_collection.each do |e|
                                          			comp_inst_faces_collection=[]
                                          				#make collection of faces
                                          				comp_inst_faces_collection.push e
                                          				comp_inst_faces_collection.each do |e|
                                          						if e.vertices
                                          							#vertice collection
                                          							vertices_collection.push e.vertices
                                          							vertices_collection.each do |e|
                                          								no_vert=e.length
                                          								cnt_vert=no_vert
                                          								puts("Vertices")
                                          								no_vert.times do
                                          									face_pts=(e[no_vert-cnt_vert])
                                          									cnt_vert=cnt_vert-1
                                          									puts("Vertex")
                                          				end #loop
                                          			end #if
                                          		end #loop
                                          		#close text file
                                          		#$dxf_ci_file.close
                                          Here is some sample output:
                                          %(#408000)[Start Component
                                          Starts Vertices
                                          Start Vertex
                                          69.6952995222671
                                          5.52489094225734
                                          0.0
                                          Start Vertex
                                          26.421563780178
                                          0.0
                                          0.0
                                          Start Vertex
                                          0.0
                                          34.7137089981752
                                          0.0
                                          Start Vertex
                                          16.8521719619112
                                          74.9523089386077
                                          0.0
                                          Looks OK?
                                            Jim
                                            Well, what are you doing? Try to make a precise statement of the purpose of the routine. In
                                            English first, then Ruby.
                                            This prints a summary of faces and vertices in the Definitions.
                                                else
                                                instance_count = 0
                                                        instance_count += 1
                                                        puts("Component; #{instance_count} #{e.definition.name}")
                                                        face_count = 0
                                                        e.definition.entities.each do |e|
        face_count += 1
        puts "  face; #{face_count}"
        vertex_count = 0
        e.vertices.each do |v|
        vertex_count += 1
        puts "    vertex #{vertex_count} id;#{v.object_id}  pos;#{v.position}"
                                            Note since some faces share vertices, and all vertices are listed, some vertives will be duplicated.
                                            Component; 2 Component#2
                                              face; 1
                                                vertex 1 id;48589944  pos;(2.160711", 1.853015", 0")
                                                vertex 2 id;48589932  pos;(0", 1.853015", 0")
                                                vertex 3 id;48589920  pos;(0", 1.853015", 2.160338")
                                                vertex 4 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                              face; 2
                                                vertex 2 id;48589692  pos;(2.160711", 0", 0")
                                                vertex 3 id;48589680  pos;(0", 0", 0")
                                                vertex 4 id;48589932  pos;(0", 1.853015", 0")
                                              face; 3
                                                vertex 1 id;48589680  pos;(0", 0", 0")
                                                vertex 3 id;48589464  pos;(2.160711", 0", 2.160338")
                                                vertex 4 id;48589452  pos;(0", 0", 2.160338")
                                              face; 4
                                                vertex 1 id;48589932  pos;(0", 1.853015", 0")
                                                vertex 2 id;48589680  pos;(0", 0", 0")
                                                vertex 3 id;48589452  pos;(0", 0", 2.160338")
                                                vertex 4 id;48589920  pos;(0", 1.853015", 2.160338")
                                              face; 5
                                                vertex 1 id;48589464  pos;(2.160711", 0", 2.160338")
                                                vertex 2 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                              face; 6
                                                vertex 1 id;48589692  pos;(2.160711", 0", 0")
                                                vertex 2 id;48589944  pos;(2.160711", 1.853015", 0")
                                                vertex 3 id;48589908  pos;(2.160711", 1.853015", 2.160338")
                                                vertex 4 id;48589464  pos;(2.160711", 0", 2.160338")
