    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • fredo6F
      @daniel s said:
      Fredo:
      I think that ZLoader__OnSurface.rb is missing in the .zip
      Thanks Daniel, you are the best tester!
      I included the file in the main post (v1.5b)
      • utilerU
        utiler
        Thanks in advance, Fredo. You ROCK!!!!
        Just Curious...
        • X
          xrok1
          KUDO'S 😍
          • EarthMoverE
            EarthMover
            Wow Fredo. That freehand tool looks incredible. I'm wondering if a similar algorithm could be used to automatically extract a traced cutout from a transparent .png image....by locating the pixel data. Make a rectangle, drop a .png texture on it, run the plugin and be left with a polygon the shape of the transparent image.
            Sorry for the digression, just thinking of how amazing that pixel identification technique is and what other purposes it could serve.
            Thanks for the update for TOS!!! πŸ‘ πŸ‘
            Content Creator at Skapeup
            • fredo6F
              No clue whether this can be done (but this would be very different from Freehand). The minimum would be to be able to read a PNG encoded file. There is a Ruby library for that (RMagick by Tim Hunter) but it's probably a lot of processing.
              • kenK
                ken
                I believe Page 13, "Drawing without a surface" one of the following lines is incorrect.
                LEFT: for vertical plane defined by Red and Blue axis
                RIGTH: for vertical plane defined by Red and Blue axis - I think this should be Green and Blue axis
                So thanks for the great plugin
                Ken
                  Daniel S
                  Thank you Fredo!!!
                  Great update!!
                  Here I made alternative icons and cursors
                  Download from:
                  IMAGES_DanielS.zip
                  Tools On Surface has 13 tools... I'm not superstitious but I vote for a new tool (Tape measure on Surface?)
                  Daniel S
                  • fredo6F
                    Thanks Daniel,
                    I integrated them in the version 1.5c, updated in the main post
                    • soloS
                      Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
                        Can the TOS_Dir_13 folder be removed?
                          The Any button is brilliant! Save so much precious space. πŸ‘
                          btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
                          And how do you draw coloured filled areas?
                          • N
                            notareal
                            • CadFatherC
                              CadFather
                              to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
                              also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
                              [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
                              Fredo (Thanks) will know better but this works here
                                j_forrester
                                Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
                                Many thanks.
                                  dylan
                                  Thanks, really nice improvement πŸ‘
                                  Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
                                  http://dmdarchitecture.co.uk/
                                  • fredo6F
                                    YES, I forgot to say it.
                                    Anyway, the folder is passive, as no loader is pointing at it.
                                    • FrederikF
                                      Frederik
                                      Thanks for this, Fredo...! πŸ˜„
                                      Cheers
                                      Kim Frederik
                                        Dan
                                        I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
                                          Dan
                                          I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! 😍
                                          A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
                                          • takesh hT
                                            takesh h
                                            Yes the trick did the job, thanks Dan. πŸ‘
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
