    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • soloS
      Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
        Can the TOS_Dir_13 folder be removed?
          The Any button is brilliant! Save so much precious space. ๐Ÿ‘
          btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
          And how do you draw coloured filled areas?
          • N
            notareal
            • CadFatherC
              CadFather
              to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
              also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
              [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
              Fredo (Thanks) will know better but this works here
                j_forrester
                Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
                Many thanks.
                  dylan
                  Thanks, really nice improvement ๐Ÿ‘
                  Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
                  http://dmdarchitecture.co.uk/
                  • fredo6F
                    YES, I forgot to say it.
                    Anyway, the folder is passive, as no loader is pointing at it.
                    • FrederikF
                      Frederik
                      Thanks for this, Fredo...! ๐Ÿ˜„
                      Cheers
                      Kim Frederik
                        Dan
                        I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
                          Dan
                          I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! ๐Ÿ˜
                          A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
                          • takesh hT
                            takesh h
                            Yes the trick did the job, thanks Dan. ๐Ÿ‘
                              dylan
                              Thanks Dan, perfect!
                              I was trying to replace them in images DanielS.
                              • olisheaO
                                olishea
                                I love this tool, I use it all the time.
                                Endless thanks ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                                oli
                                • fredo6F
                                  You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
                                  • fredo6F
                                    It seems there is a problem with that, but only on Mac.
                                    I am checking this issue.
                                    • MALAISEM
                                      MALAISE
                                      Merci Fredo, I watched the video, that gives us new horizons.... ๐Ÿ‘
                                      MALAISE
                                      La Connaissance n'a de valeur que partagรฉe
                                        Dan
                                        Thanks a lot, Fredo!
                                        I completely forgot I can use it to change the default parameters... ๐Ÿ˜ณ
                                        This is one of the most complete plugins I see.
                                        Thanks again!
                                        • L
                                          lorca
                                          That did the trick:)------> Thanks.
                                          • fredo6F
                                            Dan and Dylan (and any others having the problem of non-persistence of the choice of Icons)
                                            I have a few questions:
                                            1. does it happen on Mac only?
                                            2. Are all other parameters shown in the Button palettes saved across Sketchup sessions (i.e. nb of segments, options, etc...) ?
                                            3. Could someone send me by PM the file ToolsOnSurface.def in the subfolder DEFPARAM_Dir.
                                            • 11
                                            • 12
                                            • 13
                                            • 31
                                            • 32
                                            • 11 / 32
