    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • B
      Ben Ritter
      Never mind, I found it. My settings were preventing me from going back to the first page.
      By the way, thank you very much.
        Daniel S
        Fredo:
        I think that ZLoader__OnSurface.rb is missing in the .zip
        Daniel S
        • soloS
          Yeah, I'm having an issue with z-loader also
          • CadFatherC
            CadFather
            wow, Fredo is back - better sit down...
            • fredo6F
              @daniel s said:
              Fredo:
              Thanks Daniel, you are the best tester!
              I included the file in the main post (v1.5b)
              • utilerU
                utiler
                Thanks in advance, Fredo. You ROCK!!!!
                Just Curious...
                • X
                  xrok1
                  KUDO'S 😍
                  • EarthMoverE
                    EarthMover
                    Wow Fredo. That freehand tool looks incredible. I'm wondering if a similar algorithm could be used to automatically extract a traced cutout from a transparent .png image....by locating the pixel data. Make a rectangle, drop a .png texture on it, run the plugin and be left with a polygon the shape of the transparent image.
                    Sorry for the digression, just thinking of how amazing that pixel identification technique is and what other purposes it could serve.
                    Thanks for the update for TOS!!! πŸ‘ πŸ‘
                    Content Creator at Skapeup
                    • fredo6F
                      No clue whether this can be done (but this would be very different from Freehand). The minimum would be to be able to read a PNG encoded file. There is a Ruby library for that (RMagick by Tim Hunter) but it's probably a lot of processing.
                      • kenK
                        ken
                        I believe Page 13, "Drawing without a surface" one of the following lines is incorrect.
                        LEFT: for vertical plane defined by Red and Blue axis
                        RIGTH: for vertical plane defined by Red and Blue axis - I think this should be Green and Blue axis
                        So thanks for the great plugin
                        Ken
                          Daniel S
                          Thank you Fredo!!!
                          Great update!!
                          Here I made alternative icons and cursors
                          Download from:
                          IMAGES_DanielS.zip
                          Tools On Surface has 13 tools... I'm not superstitious but I vote for a new tool (Tape measure on Surface?)
                          Daniel S
                          • fredo6F
                            Thanks Daniel,
                            I integrated them in the version 1.5c, updated in the main post
                            • soloS
                              Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
                                Can the TOS_Dir_13 folder be removed?
                                  The Any button is brilliant! Save so much precious space. πŸ‘
                                  btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
                                  And how do you draw coloured filled areas?
                                  • N
                                    notareal
                                    • CadFatherC
                                      CadFather
                                      to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
                                      also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
                                      [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
                                      Fredo (Thanks) will know better but this works here
                                        j_forrester
                                        Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
                                        Many thanks.
                                          dylan
                                          Thanks, really nice improvement πŸ‘
                                          Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
                                          http://dmdarchitecture.co.uk/
                                          • fredo6F
                                            YES, I forgot to say it.
                                            Anyway, the folder is passive, as no loader is pointing at it.
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
