    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • kenK
      ken
      I believe Page 13, "Drawing without a surface" one of the following lines is incorrect.
      LEFT: for vertical plane defined by Red and Blue axis
      RIGTH: for vertical plane defined by Red and Blue axis - I think this should be Green and Blue axis
      So thanks for the great plugin
      Ken
        Daniel S
        Thank you Fredo!!!
        Great update!!
        Here I made alternative icons and cursors
        Download from:
        IMAGES_DanielS.zip
        Tools On Surface has 13 tools... I'm not superstitious but I vote for a new tool (Tape measure on Surface?)
        Daniel S
        • fredo6F
          Thanks Daniel,
          I integrated them in the version 1.5c, updated in the main post
          • soloS
            Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
              Can the TOS_Dir_13 folder be removed?
                The Any button is brilliant! Save so much precious space. ๐Ÿ‘
                btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
                And how do you draw coloured filled areas?
                • N
                  notareal
                  • CadFatherC
                    CadFather
                    to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
                    also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
                    [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
                    Fredo (Thanks) will know better but this works here
                      j_forrester
                      Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
                      Many thanks.
                        dylan
                        Thanks, really nice improvement ๐Ÿ‘
                        Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
                        http://dmdarchitecture.co.uk/
                        • fredo6F
                          YES, I forgot to say it.
                          Anyway, the folder is passive, as no loader is pointing at it.
                          • FrederikF
                            Frederik
                            Thanks for this, Fredo...! ๐Ÿ˜„
                            Cheers
                            Kim Frederik
                              Dan
                              I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
                                Dan
                                I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! ๐Ÿ˜
                                A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
                                • takesh hT
                                  takesh h
                                  Yes the trick did the job, thanks Dan. ๐Ÿ‘
                                    dylan
                                    Thanks Dan, perfect!
                                    I was trying to replace them in images DanielS.
                                    • olisheaO
                                      olishea
                                      I love this tool, I use it all the time.
                                      Endless thanks ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                                      oli
                                      • fredo6F
                                        You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
                                        • fredo6F
                                          It seems there is a problem with that, but only on Mac.
                                          I am checking this issue.
                                          • MALAISEM
                                            MALAISE
                                            Merci Fredo, I watched the video, that gives us new horizons.... ๐Ÿ‘
                                            MALAISE
                                            La Connaissance n'a de valeur que partagรฉe
                                            • 11
                                            • 12
                                            • 13
                                            • 31
                                            • 32
                                            • 11 / 32
