    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • fredo6F
      Thanks Daniel,
      I integrated them in the version 1.5c, updated in the main post
      • soloS
        Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
          Can the TOS_Dir_13 folder be removed?
            The Any button is brilliant! Save so much precious space. πŸ‘
            btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
            And how do you draw coloured filled areas?
            • N
              notareal
              • CadFatherC
                CadFather
                to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
                also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
                [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
                Fredo (Thanks) will know better but this works here
                  j_forrester
                  Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
                  Many thanks.
                    dylan
                    Thanks, really nice improvement πŸ‘
                    Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
                    http://dmdarchitecture.co.uk/
                    • fredo6F
                      YES, I forgot to say it.
                      Anyway, the folder is passive, as no loader is pointing at it.
                      • FrederikF
                        Frederik
                        Thanks for this, Fredo...! πŸ˜„
                        Cheers
                        Kim Frederik
                          Dan
                          I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
                            Dan
                            I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! 😍
                            A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
                            • takesh hT
                              takesh h
                              Yes the trick did the job, thanks Dan. πŸ‘
                                dylan
                                Thanks Dan, perfect!
                                I was trying to replace them in images DanielS.
                                • olisheaO
                                  olishea
                                  I love this tool, I use it all the time.
                                  Endless thanks 😍 😍 😍
                                  oli
                                  • fredo6F
                                    You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
                                    • fredo6F
                                      It seems there is a problem with that, but only on Mac.
                                      I am checking this issue.
                                      • MALAISEM
                                        MALAISE
                                        Merci Fredo, I watched the video, that gives us new horizons.... πŸ‘
                                        MALAISE
                                        La Connaissance n'a de valeur que partagΓ©e
                                          Dan
                                          Thanks a lot, Fredo!
                                          I completely forgot I can use it to change the default parameters... 😳
                                          This is one of the most complete plugins I see.
                                          Thanks again!
                                          • L
                                            lorca
                                            That did the trick:)------> Thanks.
                                            • 11
                                            • 12
                                            • 13
                                            • 31
                                            • 32
                                            • 11 / 32
