    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    1.5k Posts 470 Posters 3.3m Views 469 Watching
      Coronel
      If you came to Spain you are invited to take a "sangria", wine or whatever at the named "best natural beach" of the world: Cies Islands.
      Thank you very much
      • CadFatherC Offline
        CadFather
        .....the Master!
        ..and that's how sketchup became open source
        Thank You! ๐Ÿ˜„
        • utilerU Offline
          utiler
          Thank you very much
          That goes for Queensland, Australia..... your more than welcome here Fredo; I'll look after you like a King!!!
          purpose/expression/purpose/....
          • EarthMoverE Offline
            EarthMover
            Looks stellar. Should help add a new level of realism to Sketchup Rendering. Nothing like a nice round corner to catch those specular highlights! ๐Ÿ‘
            Thank you kind sir!!
            Content Creator at Skapeup
              BTM
              Amazing as usual!
                su30
                It's great!
                Thank you Fredo!
                I have to say your rich production and hardworking spirit affect me very much!
                -best wish from beijing
                su30
                  Rondement menรฉ! ๐Ÿ˜Ž
                  Bravo! โ˜€
                  Works fine in the V6
                  Bug Splatt in the V7 ๐Ÿ˜ฎ
                    chango70
                    That is brilliant! Thanks
                    • free agentF Offline
                      free agent
                      you are a genius FREDO sketchup would be a steaming pile of crap without you... amen
                      • StinkieS Offline
                        Stinkie
                        Oooh ... Excellent ruby! Thanks!
                        • fredo6F Offline
                          Pilou,
                          Thanks. Could you be more explicit on the bug splat in v7. TIG has one too, but apparently only with Bevel.
                          Do you see the Progress bar and then get a bugsplat, or does it happen right away when you execute?
                            Note: my bugsplats are with v7 and using bevel only, it does work perhaps 10% of tries, rest it splats immediately ! ๐Ÿ˜•
                              As soon as I press enter for apply! Splafffffffffffff ๐Ÿ˜ฎ
                              works one time and the second splafff ๐Ÿ˜„
                              with the 3 tools!
                              so yet very instable (for me) ๐Ÿ˜‰
                              • fredo6F Offline
                                TIG, Pilou,
                                Does it happen with complex shapes, meaning those where the operation would take several seconds.
                                I never got any Splat in my environments, so it is difficult for me to reproduce. But it maybe related to the way I make the operation interruptible. I guess that because you probably have fast machines, something happens in the first milliseconds of the operation.
                                It may be specific to SU7, because precisely SU7 blocks the GUI while creating geometry.
                                • massimoM Offline
                                  massimo Moderator
                                  Thank you so much Fredo. I had a quick test in SU 6 and it works very well.
                                    TIG, Pilou,
                                    My splats occur with a very simple 1m cube with 100mm bevel, to top face or multi-edges. it usually splats, but when it works it's done almost instantaneously ! The other 2 types of rounding work fine - never splatted yet !!!
                                      Could it be that it bugsplats as it tried to create faces too small?
                                      TIG: If you make a 10m cube and use 1000mm bevel, does it work then?
                                        Good thinking - although you might think that a simple bevel, with no small faces, would not respond to this (unlike the rounding options that cause NO splats at the 1m/100m size)... BUT I scaled it up x10 [10m cube 1m bevel] AND the bevel works fine for almost all of the time - after many tests I did eot one non-repeatable splat...
                                        Seems there's something in that idea ?
                                          ah yes that was that! Scale was 1 /100 too little! โ˜€
                                            DIEGO-RODRIGUEZ
                                            Fredo , thank you very much for this tools.
                                            I tested in sketchup 7pro and Sketchup 6pro, and it works perfect.
                                            Using Windows XP SP3 in Spanish.
                                            If you need any proof of plugins, in particular, just tell me.
                                            Tip>
                                            Can upload a file with different geometries, to test your plugins?
                                            To verify any type of error
                                            • 73
                                            • 74
                                            • 2 / 74
