    1.5k Posts 476 Posters 4.0m Views 476 Watching
    • free agentF Offline
      free agent
      you are a genius FREDO sketchup would be a steaming pile of crap without you... amen
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • StinkieS Offline
        Stinkie
        Oooh ... Excellent ruby! Thanks!
        • fredo6F Offline
          Bug Splatt in the V7 ๐Ÿ˜ฎ
          Pilou,
          Thanks. Could you be more explicit on the bug splat in v7. TIG has one too, but apparently only with Bevel.
          Do you see the Progress bar and then get a bugsplat, or does it happen right away when you execute?
            Note: my bugsplats are with v7 and using bevel only, it does work perhaps 10% of tries, rest it splats immediately ! ๐Ÿ˜•
              As soon as I press enter for apply! Splafffffffffffff ๐Ÿ˜ฎ
              works one time and the second splafff ๐Ÿ˜„
              with the 3 tools!
              so yet very instable (for me) ๐Ÿ˜‰
              • fredo6F Offline
                TIG, Pilou,
                Does it happen with complex shapes, meaning those where the operation would take several seconds.
                I never got any Splat in my environments, so it is difficult for me to reproduce. But it maybe related to the way I make the operation interruptible. I guess that because you probably have fast machines, something happens in the first milliseconds of the operation.
                It may be specific to SU7, because precisely SU7 blocks the GUI while creating geometry.
                • massimoM Offline
                  massimo Moderator
                  Thank you so much Fredo. I had a quick test in SU 6 and it works very well.
                    TIG, Pilou,
                    My splats occur with a very simple 1m cube with 100mm bevel, to top face or multi-edges. it usually splats, but when it works it's done almost instantaneously ! The other 2 types of rounding work fine - never splatted yet !!!
                      Could it be that it bugsplats as it tried to create faces too small?
                      TIG: If you make a 10m cube and use 1000mm bevel, does it work then?
                        Good thinking - although you might think that a simple bevel, with no small faces, would not respond to this (unlike the rounding options that cause NO splats at the 1m/100m size)... BUT I scaled it up x10 [10m cube 1m bevel] AND the bevel works fine for almost all of the time - after many tests I did eot one non-repeatable splat...
                        Seems there's something in that idea ?
                          ah yes that was that! Scale was 1 /100 too little! โ˜€
                            DIEGO-RODRIGUEZ
                            Fredo , thank you very much for this tools.
                            I tested in sketchup 7pro and Sketchup 6pro, and it works perfect.
                            Using Windows XP SP3 in Spanish.
                            If you need any proof of plugins, in particular, just tell me.
                            Tip>
                            Can upload a file with different geometries, to test your plugins?
                            To verify any type of error
                              free agent
                              all works fine here, i tried it on a 20mm box with a 1mm bevel and that works perfect. SU7
                              however with that special command bar that appears when i hover the mouse over any button there the cursor prompt say invalid ???
                                Yep with little measures that splatting soon as Enter!
                                Beginning to see the time scroll barr... then plaffffffffff! ๐Ÿ˜„
                                Something like these measures for first tool!
                                FredoTraceRoundCorner.txt
                                • fredo6F Offline
                                  Pilou,
                                  First, this does not seem to me to be 'little measures' but more just a normal case (5 cm on 3m).
                                  Second, are you sure the attached file is the one corresponding to the bugsplat. Its content indicates the operation terminated normally.
                                  • mitcorbM Offline
                                    mitcorb
                                    Hi, Fredo:
                                    This tool looks interesting.
                                    Would this be complimentary to Bevel and Round Edges by Bezier?
                                    mitcorb
                                      Here's my error message...FredoTraceRoundCorner[1mcube100mmbevel all edgesTIG].txt
                                      • StinkieS Offline
                                        Stinkie
                                        I have tried it, and it works great. This ruby is an enormous time saver. Really happy with it. โ˜€
                                        • fredo6F Offline
                                          @boilingsnow said:
                                          I tested it just now, it seems this ruby is still not very stable?
                                          It couses frequently sketchup errors and the program quits automatically everytime. Sometimes even when I was just do simple round corner on two sides, not to mention other more complicated objects. Perhaps that's only my problem due to my PC or some other personal settings? I don't know.
                                          But fredo I think you can make it better.
                                          It seems you are one of the users who get a bugsplat with SU7 (even with simple geometry).
                                          Would you mind to refer to this link http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a&start=15#p171844, use the modified file and report the txt.
                                          I am unable to reproduce the bugsplat in my environments (actually I never got a splat when writing and testing teh plugin), so I need users getting it to give me some hints on where it could come from.
                                          • fredo6F Offline
                                            @mitcorb said:
                                            Hi, Fredo:
                                            mitcorb
                                            RoundCorner includes a Sharp Mode as in RoundeEdges by Bezier. But you can keep both in parallel safely. RoundCorner also does Beveling (the green-gray icon).
                                            • 74
                                            • 75
                                            • 2 / 75
