    1.5k Posts 476 Posters 4.0m Views 476 Watching
      As always another tour de force...
      The tools work very well... except the bevel/chamfer - which I suspect is the simplest of the three ? - which keeps bug-splatting me e.g. a 1m cube 100/150mm bevel to top or all edges... Sure it'll be a simple fix...
      • utilerU Offline
        utiler
        Legend Fredo..... you don't know how much time you have saved me....
        Just Curious...
          Coronel
          If you came to Spain you are invited to take a "sangria", wine or whatever at the named "best natural beach" of the world: Cies Islands.
          Thank you very much
          • CadFatherC Offline
            CadFather
            .....the Master!
            ..and that's how sketchup became open source
            Thank You! ๐Ÿ˜„
            • utilerU Offline
              utiler
              Thank you very much
              That goes for Queensland, Australia..... your more than welcome here Fredo; I'll look after you like a King!!!
              Just Curious...
              • EarthMoverE Offline
                EarthMover
                Looks stellar. Should help add a new level of realism to Sketchup Rendering. Nothing like a nice round corner to catch those specular highlights! ๐Ÿ‘
                Thank you kind sir!!
                Content Creator at Skapeup
                  BTM
                  Amazing as usual!
                    su30
                    It's great!
                    Thank you Fredo!
                    I have to say your rich production and hardworking spirit affect me very much!
                    -best wish from beijing
                    su30
                      Rondement menรฉ! ๐Ÿ˜Ž
                      Bravo! โ˜€
                      Works fine in the V6
                      Bug Splatt in the V7 ๐Ÿ˜ฎ
                        chango70
                        That is brilliant! Thanks
                        • free agentF Offline
                          free agent
                          you are a genius FREDO sketchup would be a steaming pile of crap without you... amen
                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                          • StinkieS Offline
                            Stinkie
                            Oooh ... Excellent ruby! Thanks!
                            • fredo6F Offline
                              Pilou,
                              Thanks. Could you be more explicit on the bug splat in v7. TIG has one too, but apparently only with Bevel.
                              Do you see the Progress bar and then get a bugsplat, or does it happen right away when you execute?
                                Note: my bugsplats are with v7 and using bevel only, it does work perhaps 10% of tries, rest it splats immediately ! ๐Ÿ˜•
                                  As soon as I press enter for apply! Splafffffffffffff ๐Ÿ˜ฎ
                                  works one time and the second splafff ๐Ÿ˜„
                                  with the 3 tools!
                                  so yet very instable (for me) ๐Ÿ˜‰
                                  • fredo6F Offline
                                    TIG, Pilou,
                                    Does it happen with complex shapes, meaning those where the operation would take several seconds.
                                    I never got any Splat in my environments, so it is difficult for me to reproduce. But it maybe related to the way I make the operation interruptible. I guess that because you probably have fast machines, something happens in the first milliseconds of the operation.
                                    It may be specific to SU7, because precisely SU7 blocks the GUI while creating geometry.
                                    • massimoM Offline
                                      massimo Moderator
                                      Thank you so much Fredo. I had a quick test in SU 6 and it works very well.
                                        TIG, Pilou,
                                        My splats occur with a very simple 1m cube with 100mm bevel, to top face or multi-edges. it usually splats, but when it works it's done almost instantaneously ! The other 2 types of rounding work fine - never splatted yet !!!
                                          Could it be that it bugsplats as it tried to create faces too small?
                                          TIG: If you make a 10m cube and use 1000mm bevel, does it work then?
                                            Good thinking - although you might think that a simple bevel, with no small faces, would not respond to this (unlike the rounding options that cause NO splats at the 1m/100m size)... BUT I scaled it up x10 [10m cube 1m bevel] AND the bevel works fine for almost all of the time - after many tests I did eot one non-repeatable splat...
                                            Seems there's something in that idea ?
                                            • 74
                                            • 75
                                            • 1 / 75
